This patch adds ethernet support for the MIPS based Mediatek MT76xx SoCs
(e.g. MT7628 and MT7688), including a minimum setup of the integrated
switch. This driver is loosly based on the driver version included in
this MediaTek github repository:
https://github.com/MediaTek-Labs/linkit-smart-uboot.git
Tested on the MT7688 LinkIt smart-gateway and on the
Gardena-smart-gateway.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Frank Wunderlich <frankwu@gmx.de>
Cc: Weijie Gao <hackpascal@gmail.com>
- replace the dynamic size of the relocation table
with a fixed but configurable size
- fixes non-working CONFIG_OF_SEPARATE=y due to invalid _end symbol
Currently the size of the relocation table will be shrunk
to the actual size needed. Although this gives a maximal
space saving, it messes up the _end symbol. This breaks
features like appended DTBs because the _end symbol doesn't
point to the real end of the U-Boot binary.
Remove the size shrinking and make the size of the relocation
table fixed but configurable. This follows the Linux approach
and the user can adjust the size to his needs.
Also rename the relocation table section from .rel to .data.reloc
to follow the Linux approach and to avoid ambiguities with the
.rel.* sections added by the linker.
Reported-by: Lars Povlsen <lars.povlsen@microsemi.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
It is perfectly fine to write th DTCNTL TAP count and enable the
SCC sampling clock operation in the same write.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
When the bus switches to 1.8V mode of operation, it is necessary to
verify that the card correctly initiated and completed the voltage
switch. This is done by reading out the state of DATA0 line.
This patch implement support for reading out the state of the DATA0
line, so the MMC core code can correctly switch to 1.8V mode.
Make sure to clear HS400 configuration when resetting the SCC block.
Add check to avoid touching the SCC tuning registers in case the IP
doesn't support them or if the support isn't in place yet.
Preinitialize the SD card signals regulator to 3.3V, which is the
default post-reset setting, to be sure the regulator is set to a
valid value.
Configure the clock settings before reconfiguring any other IO settings.
This is required when the clock must be stopped before changing eg. the
pin configuration or any of the other properties of the bus. Running the
clock configuration first allows the MMC core to do just that.
In case the controller performs card tuning, that is, sends MMC
command 19 or 21, silence possible CRC error warning prints. The
warnings are bound to happen, since the tuning will fail for some
settings while searching for the optimal configuration of the bus
and that is perfectly OK.
This patch passes around the MMC command structure and adds check
into tmio_sd_check_error() to avoid printing CRC error warning
when the tuning happens.
Properly handle return values and abort operations when they are
non-zero. This is a minor improvement, which fixes two remaining
unchecked return values.
The SD UHS SDR12, SDR25, SDR50, SDR104, DDR50 and MMC HS200, HS400
modes all use 1.8V signaling, while all the legacy modes use 3.3V
signaling. While there are extra modes which use 1.2V signaling,
the existing hardware does not support those.
Simplify the pinmux such that 3.3V signaling implies legacy mode
pinmux and the rest implies UHS mode pinmux. This prevents the
massive case statement from growing further. Moreover, it fixes
an edge case where during SD 1.8V switch, the bus mode is still
set to default while the signaling is already set to 1.8V, which
results in an attempt to communicate with a 1.8V card using pins
in 3.3V mode and thus communication failure.
Patch "ARM: rmobile: Mark 4-64GiB as DRAM on Gen3" marked the entire
64bit DRAM space as cachable. On CortexA57, this might result in odd
side effects, where the CPU tries to prefetch from those areas and if
there is no DRAM backing them, CPU bus hang can happen.
This patch fixes it by generating the mem_map structure based on the
actual memory layout obtained from the DT, thus not marking areas
without any DRAM behind them as cachable.
Fixes: c1ec34763811d ("ARM: rmobile: Mark 4-64GiB as DRAM on Gen3")
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add definition of the POCCTRL register and bits therein to R8A77990 E3
pincontrol driver. This allows the pincontrol driver to configure SDHI
pin voltage according to power-source DT property.
Use fixed 4bit size for generating the DRV register element mask,
not the size of the value, which can be smaller.
Just 2 non-functinal changes:
1. Rename of EMDK to EMSDP so it matches real marketing name
2. Add essential README for IoTDK
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Real marketing name of the board was recently updated so
to accommodate that change renaming the board and all
related to it.
This part should've been remove in commit 88d60db01168 ("arm: ti: boot:
Remove environment partition"), but I missed it somehow. Remove reading
dtb file from environment partition on eMMC, as we don't have it
anymore.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Fixes possible resource leak in dm_test_tee() reported by Coverity.
Reported-by: Coverity (CID: 184175)
Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
This line is no more needed and can be removed.
Only CONFIG_CMD_SOURCE is defined in Kconfig and
used in defconfig files.
CONFIG_SOURCE if not defined in source code and
"config SOURCE" is not present in any Kconfig.
The Makefile already tests for SPL_DM_REGULATOR_GPIO, but Kconfig
does not provide it. This adds SPL_DM_REGULATOR_GPIO to Kconfig.
Currently the base is 3 fix it 10 so that IDs follow decimal system.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvulta@ti.com>
On our demo setup for SD card boot, the u-boot environment
is in a FAT partition.
This patch changes the default configuration, specifing that
the u-boot environment is in a FAT partition instead of raw MMC.
Signed-off-by: Andrei Stefanescu <andrei.stefanescu@microchip.com>
Acked-by: Eugen Hristev <eugen.hristev@microchip.com>
The default bootcommand needs to be accurate w.r.t the nand memory map
at http://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91sam9x5ekMainPage#NAND_Flash_demo_Memory_map
Updated to load kernel + dtb at right offsets and boot the zImage.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
When the "w1 bus" command is used with no bus master present
a data abort may occur.
This is because uclass_first_device() returns zero, but sets the output
struct udevice pointer to NULL in the no device found case.
Fix w1_get_bus() to account for this and return an error code
as is expected by the callers.
Signed-off-by: Martin Fuzzey <martin.fuzzey@flowbird.group>
Reviewed-by: Eugen Hristev <eugen.hristev@microchip.com>
Data abort was occurring when using "w1 bus" with a DS24B33 present.
The abort occurred in the ds24xxx_probe() because the struct w1_device
pointer was NULL. This is because that structure is allocated by
the parent device uclass (by .per_child_platdata_auto_alloc_size)
and thus the correct accessor is dev_get_parent_platdata() not
dev_get_platdata()
Using imply for SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION instead of
select ensures we can build without partition support (used to build
a network boot only version of SPL and U-Boot).
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Commit 768f23dc8ae3 ("ARM: socfpga: Put stack at the end of SRAM") broke
those socfpga boards that keep the bootcounter at the end of the
internal SRAM as the bootcounter needs 8 bytes by default and thus the
very first SPL call to board_init_f_alloc_reserve overwrites the
bootcounter.
This patch allows to move the initial stack pointer down a bit by
checking if CONFIG_SYS_BOOTCOUNT_ADDR is located in the internal SRAM
area and then using this address as location for the start of the
stack pointer.
No new macros / defines are added by this approach.
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
The 'status' variable in 'socfpga_load()' for both gen5 and arria10
is of type 'unsigned long' while it is always used as 'int' only.
Change it to 'int'.
Workaround and bug fix for Freescale PowerPC
Add workaround for Freescale USB erratum A005275.
Correct RCW macros for T1080.
Per T1040RM (Rev. 1, 08/2015), there are 2 issues with the RCW EC2
settings.
- The value of FSL_CORENET_RCWSR13_EC2_FM1_GPIO is wrong and should
be 0x04000000 (value of 1 in RCW bit [420:421])
- Value of 2/3 are reserved in RCW bit [420:421], hence there is no
macro FSL_CORENET_RCWSR13_EC2_FM1_DTSEC5_MII.
Acked-by: Poonam Aggrwal <poonam.aggrwal@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Per T1040RM (Rev. 1, 08/2015), the value of
FSL_CORENET_RCWSR13_MAC2_GMII_SEL_ENET_PORT is wrong
and should be 0x00000080 (bit 440 in the RCW).
Workaround makes FS as default mode on all affected socs.
Add support to check erratum-A005275 validity for an soc. This info is
required to determine whether a given soc is affected by this erratum.
Add quirk for this erratum "has_fsl_erratum_a005275" . This quirk is used
to enable workaround for the errata
Force FS mode as default by:
- making EPS as FS
- setting PFSC bit to disable HS chirping
This workaround can be disabled by mentioning "no_erratum_a005275" in
hwconfig string
Signed-off-by: Chris Packham <judge.packham@gmail.com>
At the moment we rely on the infamous get_ram_size() function to learn
the actual DRAM size in U-Boot proper. This function has two issues:
1) It only works if the DRAM size is a power of two. We start to see
boards which have 3GB of (usable) DRAM, so this does not fit anymore.
2) As U-Boot has no notion of reserved memory so far, it will happily
ride through the DRAM, possibly stepping on secure-only memory. This
could be a region of DRAM reserved for OP-TEE or some other secure
payload, for instance. It will most likely crash in that case.
As the SPL DRAM init routine has very accurate knowledge of the actual
DRAM size, lets propagate this wisdom to U-Boot proper.
We re-purpose a currently reserved word in our SPL header for that.
The SPL itself stores the detected DRAM size there, and bumps the SPL
header version number in that case. U-Boot proper checks for a valid
SPL header and a high enough version number, then uses the DRAM size
from there. If the SPL header field is not sufficient, we fall back to
the old DRAM scanning routine.
Part of the DRAM might be present and probed by SPL, but not accessible
by the CPU. They're restricted in the main U-Boot binary, when accessing
the DRAM size from SPL header.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Allwinner 64-bit SoCs can use 4GiB DRAM chip, however their memory map
has only allocated 3GiB for DRAM, so only 3GiB of the DRAM is
accessible.
Add a Kconfig option for the maximum accessible DRAM.
For A80 it should be a much higher value (8GiB), but as I have no A80
device to test and originally U-Boot only supports 2GiB DRAM on A80, it
currently still falls under the 2GiB situation.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
All Allwinner 64-bit SoCs now are known to be able to access 3GiB of
external DRAM, however the size of DRAM part in the MMU translation
table is still 2GiB.
Change the size of DRAM part in MMU table to 3GiB.
So far we have two users which want to look at the SPL header. We will
get more in the future.
Refactor the existing SPL header checks into a common function, to
simplify reusing the code.
Now that this is easy, add proper version checks to the DT name parsing.
Acked-by: Jagan Teki <jagan@openedev.com>
On Allwinner SoCs we use some free bytes at the beginning of the SPL image
to store various information. We have a version byte to allow updates,
but changing this always requires all tools to be updated as well.
Introduce the concept of semantic versioning [1] to the SPL header:
The major part of the version number only changes on incompatible
updates, a minor number bump indicates backward compatibility.
This patch just documents the major/minor split, adds some comments
to the header file and uses the versioning information for the existing
users.
[1] https://semver.org
The Pine A64 Plus/non-Plus model detection code is now built on all
64-bit ARM SoCs, even if the code cannot be triggered when H5/H6 is in
use.
Disable them when the board is Pine A64 by adding a Kconfig option that
is only selected on Pine A64.
On GCC 7.3.1 this makes the size of the function reduces 184 bytes, and
saves a 104 byte strstr() function, then makes SPL on H6 succeed to
build.
Complete in the drivers directory the work started with
commit 83d290c56fab ("SPDX: Convert all of our single
license tags to Linux Kernel style").
Since commit 80df194f0165 ("x86: detect unsupported relocation types"),
an error message is seen on QEMU x86 target during boot:
do_elf_reloc_fixups32: unsupported relocation type 0x1 at fff841f0, offset = 0xfff00087
do_elf_reloc_fixups32: unsupported relocation type 0x2 at fff841f8, offset = 0xfff00091
Check offset 0xfff00087 and 0xfff00091 in the u-boot ELF image,
fff00087 000df401 R_386_32 00000000 car_uninit
fff00091 000df402 R_386_PC32 00000000 car_uninit
we see R_386_32 and R_386_PC32 relocation type is generated for
symbol car_uninit, which is declared as a weak symbol in start.S.
However the actual weak symbol implementation ends up nowhere. As
we can see below, it's *UND*.
$ objdump -t u-boot | grep car_uninit
00000000 w *UND* 00000000 car_uninit
With this fix, it is normal now.
fff00094 w F .text.start 00000001 car_uninit
Reported-by: Hannes Schmelzer <hannes@schmelzer.or.at>
Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
The build breaks because its not fitting the U-Boot binary into the ROM
image. So lets move VGA BIOS a bit to make room for the grown U-Boot
binary.
To enable the root device selection (kernel cmd-line) via PARTUUID, this
patch enables CMD_PART on all missing theadorable-x86 boards and
changes the default environment to generate the root=PARTUUID string
automatically.
This fixes problems that have been noticed on systems with multiple
SATA/AHCI controller connected via PCIe, where the device name for the
root device / partition (/dev/sdaX) was incorrect.
This is needed for the PCIe hotplug to work correctly on some boards
with the newer Linux kernel versions.
Cc: Bin Meng <bmeng.cn@gmail.com>
