2016-11-23powerpc: P1020RDB-PC: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and config macros. Remove macro CONFIG_P1020RDB_PC. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1020MBG: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020MBG instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and other macros. Remove macro CONFIG_P1020MBG. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1017: Drop configuration for P1017York Sun
P1017 is a single-core version of P1023. There is no P1017 target configured. Drop related macros. P1017 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1014: Drop configuration for P1014York Sun
P1014 is a variant of P1010. There is no P1014 target configured. Drop related macros. P1014 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1013: Drop configuration for P1013York Sun
P1013 is a single-core version of P1022. There is no P1022 target configured. Drop related macros. P1022 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1012: Drop configuration for P1012York Sun
P1012 is a single-core version of P1021. There is no P1012 target configured. Drop related macros. P1012 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1011: Remove macro CONFIG_P1011York Sun
Replace CONFIG_P1011 with ARCH_P1011 in Kconfig. P1011RDB seems to be in scrapyard though. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1023: Remove macro CONFIG_P1023York Sun
Replace CONFIG_P1023 with ARCH_P1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1022DS: Remove macro CONFIG_P1022DSYork Sun
Use CONFIG_TARGET_P1022DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1022: Remove macro CONFIG_P1022York Sun
Replace CONFIG_P1022 with ARCH_P1022 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1010RDB: Remove macros CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PBYork Sun
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1010: Remove macro CONFIG_P1010York Sun
Replace CONFIG_P1010 with ARCH_P1010 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: xpedite: Remove macro CONFIG_XPEDITE5370York Sun
This macro is no longer used. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8572DS: Remove macro CONFIG_MPC8572DSYork Sun
Use CONFIG_TARGET_MPC8572DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8572: Remove macro CONFIG_MPC8572York Sun
Replace CONFIG_MPC8572 with ARCH_MPC8572 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8569MDS: Remove macro CONFIG_MPC8569MDSYork Sun
Use CONFIG_TARGET_MPC8569MDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8569: Remove macro CONFIG_MPC8569York Sun
Replace CONFIG_MPC8569 with ARCH_MPC8569 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8568MDS: Remove macro CONFIG_MPC8568MDSYork Sun
2016-11-23powerpc: MPC8568: Remove macro CONFIG_MPC8568York Sun
Replace CONFIG_MPC8568 with ARCH_MPC8568 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8560ADS: Remove macro CONFIG_MPC8560ADSYork Sun
2016-11-23powerpc: MPC8560: Remove macro CONFIG_MPC8560York Sun
Replace CONFIG_MPC8560 with ARCH_MPC8560 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8555CDS: Remove macro CONFIG_MPC8555CDSYork Sun
Use CONFIG_TARGET_MPC8555CDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8555: Remove macro CONFIG_MPC8555York Sun
Replace CONFIG_MPC8555 with ARCH_MPC8555 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8541CDS: Remove macro CONFIG_MPC8541CDSYork Sun
Replace with CONFIG_TARGET_MPC8541CDS from Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: mpc8541: Remove macro CONFIG_MPC8541York Sun
Replace CONFIG_MPC8541 with ARCH_MPC8541 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8540ADS: Remove macro CONFIG_MPC8540ADSYork Sun
2016-11-23powerpc: mpc8540: Remove macro CONFIG_MPC8540York Sun
Replace CONFIG_MPC8540 with ARCH_MPC8540 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8536DS: Remove macro CONFIG_MPC8536DSYork Sun
Use CONFIG_TARGET_MPC8536DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8536: Move CONFIG_MPC8536 to Kconfig optionYork Sun
Replace CONFIG_MPC8536 with ARCH_MPC8536 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: C29XPCIE: Remove macro CONFIG_C29XPCIEYork Sun
Use CONFIG_TARGET_C29XPCIE instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: C29X: Move CONFIG_PPC_C29X to Kconfig optionYork Sun
Replace CONFIG_PPC_C29X with ARCH_C29X in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: BSC9132QDS: Remove CONFIG_BSC9132QDS macroYork Sun
Use CONFIG_TARGET_BSC9132QDS from Kconfig option, remove CONFIG_BSC9132QDS macro. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: BSC9131RDB: Remove CONFIG_BSC9131RDB macroYork Sun
This macro CONFIG_BSC9131RDB is no longer needed. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: BSC9131/2: Move CONFIG_BSC9131/2 to Kconfig optionsYork Sun
Replace CONFIG_BSC9131, CONFIG_BSC9132 with ARCH_BSC9131, ARCH_BSC9132 Kconfig options. Also drop #ifdef in BSC9131RDB.h since it is redundant. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8544DS: Remove macro CONFIG_MPC8544DSYork Sun
Use CONFIG_TARGET_MPC8544DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8544: Move CONFIG_MPC8544 to Kconfig optionYork Sun
Replace CONFIG_MPC8544 with ARCH_MPC8544 in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8548CDS: Remove macro CONFIG_MPC8548CDSYork Sun
Use CONFIG_TARGET_MPC8548CDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8548: Move CONFIG_MPC8548 to Kconfig optionYork Sun
Replace CONFIG_MPC8548 with ARCH_MPC8548 in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23tools/env: Correct include kconfigYork Sun
While we move some config macros to Kconfig, kconfig header is needed to avoid compiling error if not already included. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-17Merge branch 'master' of http://git.denx.de/u-boot-mmcTom Rini
2016-11-17Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2016-11-17 Highlights this time around: - x86 efi_loader support - hello world efi test case - network device name is now representative - terminal output reports modes correctly - fix psci reset for ls1043/ls1046 - fix efi_add_runtime_mmio definition for x86 - efi_loader support for ls2080
2016-11-17ls2080ardb: Convert to distro bootAlexander Graf
Most new systems in U-Boot these days make use of the generic "distro" framework which allows a user to have U-Boot scan for a bootable OS on all available media types. This patch extends the LS2080ARDB board to use that framework if the hard coded NOR flash location does not contain a bootable image. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-17armv8: fsl-layerscape: Add support for efi_loader RTS resetAlexander Graf
When implementing efi loader support, we can expose runtime services for payloads. One such service is CPU reset. This patch implements RTS CPU reset support for layerscape systems. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17armv8: ls2080a: Declare spin tables as reserved for efi loaderAlexander Graf
The efi loader code has its own memory map, so it needs to be aware where the spin tables are located, to ensure that no code writes into those regions. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-17ls2080ardb: Reserve DP-DDR RAMAlexander Graf
The DP-DDR shouldn't be exposed as conventional memory to an OS, so let's rather claim it's a reserved region in the EFI memory map Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17ls2080: Exit dpaa only right before exiting U-BootAlexander Graf
On ls2080 we have a separate network fabric component which we need to shut down before we enter Linux (or any other OS). Along with that also comes configuration of the fabric using a description file. Today we always stop and configure the fabric in the boot script and (again) exit it on device tree generation. This works ok for the normal booti case, but with bootefi the payload we're running may still want to access the network. So let's add a new fsl_mc command that defers configuration and stopping the hardware to when we actually exit U-Boot, so that we can still use the fabric from an EFI payload. For existing boot scripts, nothing should change with this patch. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com> [agraf: Fix x86 build]
2016-11-17efi_loader: Fix efi_add_runtime_mmio definitionAlexander Graf
The efi_add_runtime_mmio prototype for disabled CONFIG_EFI_LOADER was different from the enabled one. Sync them. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-17efi_loader: Disable PSCI reset for ls1043 and ls1046Alexander Graf
The NXP ls1043 and ls1046 systems do not (yet) have PSCI enablement for reset. Don't enable generic PSCI reset code on them. Signed-off-by: Alexander Graf <agraf@suse.de>
