The PIC32MZ DA Starter Kit does not need the card detect workaround
because the SDCD signal line is connected properly. Disable the
workaround in this case.
Signed-off-by: John Robertson <john.robertson@simiatec.com>
The GPIO pins used by the SDHCI controller need to be configured to
allow the interface to work.
The existing driver is not compatible with the Driver Model.
This patch makes the necessary changes while also removing obsolescent
calls/properties as follows:
- fdtdec_* calls replaced with dev_read_* equivalents;
- 'clock-freq-min-max' property replaced by querying the frequency of
the source clock 'base_clk';
- The card detect erratum workaround is applied during probe rather than
overriding get_cd.
The card detect workaround (Microchip ref. DS80000736E, erratum #15) is
not always needed and can be disabled using a vendor specific DT
property.
- Fix for environment location on some PowerPC boards
- Typo / documentation fix
- Two fixes for mpc8xxx
Setting CONFIG_ENV_ADDR to something other than 0 stops gd->env_addr
from being allocated dynamically. When the environment is in SPI we need
it to be allocated as we can't use a direct memory mapped address.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
512 * 2^32 bytes equals 2 tebibytes.
The install command is missing for an apt-get command.
Fix build failure, it used to get this implicitly through common.h
until f7ae49fc4f (common: Drop log.h from common header).
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Somewhere between v2020.04 and v2020.07 the mpc8xxx_spi driver broke,
I'm guessing due to this hunk
@@ -559,6 +560,8 @@ int dm_gpio_set_dir_flags(struct gpio_desc *desc, ulong flags)
if (ret)
return ret;
+ /* combine the requested flags (for IN/OUT) and the descriptor flags */
+ flags |= desc->flags;
ret = _dm_gpio_set_dir_flags(desc, flags);
from commit 695e5fd5469a ("gpio: update dir_flags management"). But
the blame is mostly on the driver itself which seems rather confused:
The chip select gpios are requested with GPIOD_ACTIVE_LOW, but then in
each activate/deactivate, dm_gpio_set_dir_flags() is called with
merely GPIOD_IS_OUT, and then the driver call set_value(0) for
activate.
That used to work, but with the above hunk, the ACTIVE_LOW setting
from the request becomes persistent, so the gpio driver ends up being
asked to set the value to 1 in mpc8xxx_spi_cs_activate().
So drop the dm_gpio_set_dir_flags() calls in the activate/deactivate
functions, and use a value of 1 to mean "logically enabled".
Ideally, I think we should also drop the GPIOD_ACTIVE_LOW from the
request and make it up to the list of gpio cs in DT to indicate
whether that CS is enabled when driven low (as is of course usually
the case), but that requires changing
arch/powerpc/dts/gdsys/gazerbeam-base.dtsi among others, and I don't
have that hardware to test on. I have, however, tested our
own (mpc8309-based) hardware with this change, and I have also tested
that removing the GPIOD_ACTIVE_LOW from the request and updating our
DT as
- gpios = <&spisel 0 0>;
+ gpios = <&spisel 0 GPIO_ACTIVE_LOW>;
still works.
- Several ACPI bug fixes
- Intel edison: Move config SYS_MALLOC_LEN to Kconfig
- Use "emmc" in ApolloLake FSP devicetree bindings
Add a missing memset to acpi_create_spcr().
The other acpi_create_xxxx() functions perform a memset on their
structures, acpi_create_spcr() does not and as a result the contents of
this table are partly uninitialized (and thus random after every reset).
Fixes: b288cd960072 ("x86: acpi: Generate SPCR table")
Signed-off-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[bmeng: fix the tags format in the commit message]
Currently, the calculation for the length of the DSDT table includes any
bytes that are added for alignment, but those bytes are not initialized.
This is because the DSDT length is calculated after a call to
acpi_inc_align(). Split this up into the following sequence:
* acpi_inc()
* Calculate DSDT length
* acpi_align()
The term eMMC is used inconsistently within the FSP devicetree
bindings (e-mmc and emmc), especially for "emmc-host-max-speed"
documentation and code disagree.
Change all eMMC instances within the FSP bindings to consistently
use "emmc". The term "emmc" is already used a lot within U-Boot,
while "e-mmc" is only used in the FSP bindings.
[bmeng: correct one typo in the commit message]
The revisions are usually dates in hex-decimal format representing
YYYYmmdd. Print them in hex to see this clearly.
Before:
FACP 000e5420 0000f4 (v06 U-BOOT U-BOOTBL 538970376 INTL 0)
DSDT 000e4780 000ba0 (v02 U-BOOT U-BOOTBL 65536 INTL 538968870)
After:
FACP 000e5420 0000f4 (v06 U-BOOT U-BOOTBL 20200908 INTL 0)
DSDT 000e4780 000ba0 (v02 U-BOOT U-BOOTBL 10000 INTL 20200326)
Fixes: 0b885bcfd9b0 ("acpi: Add an acpi command")
Cc: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
This patch moves the the config SYS_MALLOC_LEN to Kconfig
as it is already done for zynq arch in commit 01aa5b8f0503
("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq").
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-10-rc5 (2)
The following bugs are fixed:
* incorrect online help for setenv and env
* description of function efi_mem_carve_out()
* replace printf() by log_err() in stm32mp1_rng driver
A unit test is provided to check that the boot hart id is provided in the
RISC-V device-tree.
- SquashFS Coverity fixes
- bitflip fix in the alternate memtest command
- Disable networking on bcmstb boards where we didn't have any network
drivers enabled.
'env -e -i' syntax was changed from "," to ":". Account for this also
in the documentation.
Fixes: 2b3fbcb59f41 ("efi_loader: use ':' as separator for setenv -i")
Signed-off-by: Maxim Uvarov <maxim.uvarov@linaro.org>
Correct the usage description for setenv -e too.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
On RISC-V check that the /chosen node has a boot-hartid property.
To run the test configure with CONFIG_CMD_BOOTEFI_SELFTEST=y and issue
setenv efi_selftest device tree
setenv serial# myserial
bootefi selftest
If the test succeeds, it reports the boot-hartid, e.g.
boot-hartid: 1
Allow specifying the node on which a property is searched.
Test the device tree consistency more rigorously.
Some efi_st_printf() calls have been converted to efi_st_error().
Refine text for overlap_only_ram description to
match to what exactly flag does and aling description
with other functions.
The logging system provides flexible filtering and enhanced output.
Reviewed-by: Sughosh Ganu <sughosh.ganu@linaro.org>
The bitflip test uses two equal sized memory buffers. This is achieved
by splitting the range of memory into two pieces. The address of the
second buffer, as well as the length of each buffer, were not correctly
calculated. This caused bitflip test to access beyond the end of range.
This patch fixes the pointer arithmetic problem.
A second problem arises because u-boot "mtest" command expects the
ending address to be inclusive. When computing (end - start) this
results in missing 1 byte of the requested length. The bitflip test
expects a count rather than an "ending" address. Thus it fails to test
the last word of the requested range. Fixed by using (end - start + 1).
Added Kconfig option to optionally disable the bitflip test, since it
does add significantly to the time taken for "mtest".
Fixes: 8e434cb705d463bc8cff935160e4fb4c77cb99ab ("cmd: mem: Add bitflip
memory test to alternate mtest")
Signed-off-by: Ralph Siemsen <ralph.siemsen@linaro.org>
Silence the "Driver Model for Ethernet drivers" migration warning for
the bcm7445 and bcm7260 ports, neither of which supports networking yet.
Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Fix control flow issues and null pointer dereferences.
Signed-off-by: Joao Marcos Costa <jmcosta944@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.10
- Toradex boards
- mx6qsabrelite: fix env offset
- esdhc_imx: waiting for clock instead of sleep
- dyn RAM calibration for entry point i.MX6
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/728274602
This is not required for sysboot (we defined fdtfile), let's save a few
bytes in the binary image without these variables.
Signed-off-by: Soeren Moch <smoch@web.de>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- Assorted bug fixes
The Toradex product is called apalis-imx8 consisting of SoM with
i.MX8QM and i.MX8QP SoCs.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
The Toradex product is called colibri-imx8x consisting of SoM with
i.MX8QXP and i.MX8DX SoCs.
Currently, after config the clock rate, delay 10ms, this is quite a rough
method. Check the clock stable status in the present status register is
enough.
Tested-by: Ji Luo <ji.luo@nxp.com>
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
This patch adds support for iMX6UL/ULL/SL/SDL MMDC into the DDR calibration
code. The difference between MX6DQ and MX6UL/ULL/SL is that the later SoCs
have 2 SDQS registers, just like MX6SX, while the MX6DQ/MX6SDL has 8.
Fixes: 4f4c128c65 ("ARM: mx6: ddr: Add support for iMX6SX")
Cc: Eric Nelson <eric@nelint.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
The size of the binary created with the default U-boot config is much
greater than the default offset for environment `0x60000`.
In case if that binary is used for booting via MMC it is overlapped with
the environment stored on MMC.
This leads to U-Boot corruption while saving environment with `saveenv`
command and non-bootable SabreLite board.
The offset for environment `CONFIG_ENV_OFFSET=0x60000` was added in
commit a09fea1 but did not count in the change to `0xC0000` if option
`CONFIG_ENV_IS_IN_MMC` is used.
The offset is also used for variant with environment saving onto SPI NOR
flash (with enabled option `CONFIG_ENV_IS_IN_SPI_FLASH`). In that case the
U-Boot binary flashed on SPI NOR is also corrupted after environment
saving with the original 0x60000 offset.
Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com>
Latest datasheet revE has removed MIMX8ML7D/5D/7C/5C parts, so
update u-boot to remove decoding and support for those parts.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add missed return
Fix SSCG_PLL_REFCLK_SEL_x, the offset starts from 0, not 16
Reported-by: Coverity 3448860
Reviewed-by: Ye Li <ye.li@nxp.com>
Coverity reported dead code, however it is FRAC_PLL_REFCLK_SEL_MASK
was wrongly set.
Reported-by: Coverity 10045172
According to i.MX 7Dual Applications Processor Reference Manual, Rev. 1
The target interface CCM root index ranges [0,124], so the number
should be 125.
Reported-by: Coverity 18045
Provide fdtfile value in default env instead of setting
it dynamically in runtime.
Fixes: 85cb2bc686("apalis/colibri imx6: provide proper fdtfile value")
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Enable and set preboot var with fdtfile evaluation.
preboot will be checked and run immediately before starting the
CONFIG_BOOTDELAY countdown and/or running the auto-boot command resp.
entering interactive mode.
This provides possibility to use different boot cmds in interactive mode
without manual setting fdtfile value, as it it's already evaluated
before entering interactive mode.
Fixes: a62c60610f("colibri_imx7_emmc: add Colibri iMX7D 1GB (eMMC) module support")
Fixes: 304042c1f3("colibri_vf: set fdtfile for distroboot")
Fixes: board: 31b1e17f44("toradex: add Colibri iMX6ULL support")
Wrap video specific functionality with ifdefs.
Fixes: 195011b24d("colibri-imx7: fix splash logo drawing")
Drop show_boot_logo legacy function, as splashscreen functionality can
be used instead.
Fixes: d324189772("toradex: common: show boot logo")
Set proper splashscreen env value instead of calling legacy function
to show embed boot logo.
Fixes: 391c712dde("colibri-imx6ull: show boot logo")
Provide the settings for the debug UART on the QEMU ARM virt board.
