Tidy up unused definition related to power control of 3DG.
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
GSX clock force supply code is unnecessary at U-Boot,
because GSX clock control is supported at the kernel driver.
This code is unnecessary, because these registers are set by the
initial program loader (IPL).
U-Boot uses ARM generic timer, TMU0 and TMU1 are not used, remove them.
This patch removes 'console=' argument, because kernel uses
stdout-path as parameter.
This patch fixes the write-protect control of CPG.
Patch queue for efi - 2018-10-17
A few bug fixes for the 2018.11 release:
- Fix block seeking on 32bit
- Fix execution with DEBUG set
- Fix a few Coverity found bugs
- Fix warnings
Heinrich Schuchardt (13):
efi_loader: fix relocation on x86_64
efi_loader: correct signature of GetPosition, SetPosition
efi_loader: execute efi_save_gd() first
efi_loader: efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, ...)
efi_loader: error handling in read_console()
efi_loader: return type efi_console_register()
efi_loader: superfluous statement in is_dir()
efi_loader: memory leak in efi_set_variable()
efi_loader: remove lcd.h from efi_net.c
arm: do not include efi_loader.h twice
efi_loader: fix typo in efi_boottime.c
efi_selftest: creating new handle in controller test
efi_loader: efi_dp_get_next_instance() superfluous statement
Tom Rini (2):
efi_loader: Fix warning in efi_load_image()
fs: fat: Fix warning in normalize_longname()
Remove a superfluous statement in efi_dp_get_next_instance().
When the last protocol interface is uninstalled the handle is deleted but
this does not set the value of the handle to NULL.
To create a new handle with OpenProtocolInterface the value of the handle
must be NULL.
Xilinx changes for v2018.11-rc2-v2
FPGA:
- Fix SPL fpga loading from FIT
ARM64:
- Fix gic accesses in EL2/EL1
Xilinx:
- Add dlc20 board support
- Add Versal board support
- Sync defconfigs
- Enable MP via Kconfig
- Add missing efuse node
- Enable CDC for zcu100
cmd:
- Fix kgdb Kconfig dependency
Only PPC supports this option that's why there should be proper
dependency setup via Kconfig.
Simplify defconfig for ZynqMP but keep option not to enable it for mini
targets.
This patch adds new zynqmp command "zynqmp tcminit mode" to
initialize TCM. TCM needs to be initialized before accessing
to avoid ECC errors. This new command helps to perform
the same. It also makes tcm_init() as global and uses it for
doing the TCM initialization.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
This patch moves TCM initialization to a separate routine to
make it modular and can be reused if required. It also prints
warning message now as it writes to TCM.
Virtual QEMU board is generating DTB self and putting it to
VERSAL_QEMU_DTB_ADDR address.
Board is using CONFIG_OF_BOARD which ensures that u-boot is aligned with
board created by QEMU.
Xilinx SoC Versal is using fixed clock where setting rate is not supported.
That's why workaround the driver till real clock driver is supported.
Xilinx is introducing Versal, an adaptive compute acceleration platform
(ACAP), built on 7nm FinFET process technology. Versal ACAPs combine
Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent
Engines with leading-edge memory and interfacing technologies to deliver
powerful heterogeneous acceleration for any application. The Versal AI
Core series has five devices, offering 128 to 400 AI Engines. The series
includes dual-core Arm Cortex™-A72 application processors, dual-core Arm
Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more
than 1,900 DSP engines optimized for high-precision floating point with
low latency.
The patch is adding necessary infrastructure in place without enabling
platform which is done in separate patch.
%s/conncected/connected/
As observed with clang:
fs/fat/fat_write.c:1024:13: warning: comparison of constant 128
with expression of type 'char' is always false
[-Wtautological-constant-out-of-range-compare]
if ((0x80 <= c) && (c <= 0xff))
fs/fat/fat_write.c:1024:25: warning: comparison of constant 255
with expression of type 'char' is always true
Fixes: 25bb9dab14f4 ("fs: fat: check and normalize file name")
lib/efi_loader/efi_boottime.c:1624:7: warning: variable 'info'
is used uninitialized whenever 'if' condition is true [-Wsometimes-uninitialized]
if (ret != EFI_SUCCESS)
lib/efi_loader/efi_boottime.c:1653:7: note: uninitialized use
occurs here
free(info);
lib/efi_loader/efi_boottime.c:1624:3: note: remove the 'if' if
its condition is always false
lib/efi_loader/efi_boottime.c:1602:31: note: initialize the
variable 'info' to silence this warning
struct efi_loaded_image *info;
= NULL
Rather than change how we unwind the function it makes the most sense to
initialize info to NULL so that we can continue to pass it to free().
Fixes: c982874e930d ("efi_loader: refactor efi_setup_loaded_image()")
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
We should not include the same include twice.
Fixes: 99b8db7291ce ("arm: print information about loaded UEFI images")
Remove superfluous include.
Do not leak native_name if out of memory.
This addresses CoverityScan CID 184095.
Reported-by: Tom Rini <trini@konsulko.com>
When is_dir() is called we have already execute set_blk_dev(fh).
So don't call it again.
This fixes CoverityScan CID 184093.
Use a return type that can encompass the return value.
This fixes CoverityScan CID 184090.
getc() might return an error code. Avoid an incorrect converison to
Unicode.
This addresses CoverityScan CID 184087.
The first parameter of efi_allocate_pool is a memory type. It cannot be
EFI_ALLOCATE_ANY_PAGES. Use EFI_BOOT_SERVICES_DATA instead.
If DEBUG is defined we may be calling EFI_CALL already during the
initialization of the EFI subsystem. We must make sure efi_save_gd() has
already been called at that moment.
Anyway it is better to have this call in one location instead of three.
This fixes an illegal memory access occurring since 4e6b5d6503ce
("efi_loader: create root node") with DEBUG = 1.
Fixes: 4e6b5d6503ce ("efi_loader: create root node")
The UEFI spec requires that file positions are passed as u64 in
GetPosition() and SetPosition().
Check if the file handle points to a directory in GetPosition().
Provide a unit test for GetPosition() and SetPosition().
Fix Coverity warning CID 184079 (CONSTANT_EXPRESSION_RESULT).
Add comments.
Fixes: b6dd57773719 ("efi_loader: use correct types in EFI_FILE_PROTOCOL")
Currently the relocation of the EFI runtime on x86_64 fails. This renders
the EFI subsystem unusable. The ELF relocation records for x86_64 contain
an addend field.
Always write the function name into error messages related to the EFI
runtime relocation.
Break an excessively long line.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Do gic cpu initialization based on EL level which u-boot enters.
U-Boot can't access EL3 regs when runs in EL2/EL1, etc.
Ethernet is not present on this board that's why there are two other
options how to wire the board to ethernet. The first is asix_eth usb
host converter which is already enabled by default. The second option is
to use USB CDC/RNDIS ethernet gadget.
This patch is enabling CDC which is working with Linux.
With new bind/unbind command there is no need to call usb_ether_init()
from platform code and use for example these commands:
bind /amba/usb0@ff9d0000/dwc3@fe200000 usb_ether
dhcp
unbind /amba/usb0@ff9d0000/dwc3@fe200000
There are some inconsistencies which should be fixed.
Add access to efuse for Zynq-7000S device detection.
Xilinx DLC20 has I2C0 with EEPROM(1KB), UART1, GPIO, SD0 (EMMC 4GB),
USB0 device, ENET0, QSPI (16MB) and DDR(two of 256MB each).
Boards have mix of Winbond/ST QSPIs.
Enable loading FPGA from FIT image in SPL.
This patch partially reverts:
"spl: fit: Add support for loading FPGA bitstream"
(sha1: 26a642238bdecc53527142dc043b29e21c5cc94c)
There shouldn't be a need to call private spl_load_fpga_image function
because the whole sequence should be already handled by fpga framework.
If there is missing loading bistream by chunks it should be done via
fpga framework instead of having private hooks.
Also spl_load_fpga_image() weak function is not used anywhere and
opening a way for not reviewed hacks out of mainline U-Boot is not the
right way to go.
This reverts commit c35a7d375ec8f0a8ee343ae4868be3242172632e.
This commit is breaking SPL on zc706.
Tested-by: Patrice Chotard <patrice.chotard@st.com> [on STM32F746-disco]
More fixes and improvements for ARC here:
Fixes (this time included for real):
* Take care of global uninitialized variables
They used to be put right after .bss section and were never
zeroed as they should be. Now merged with normal .bss
Improvements:
* Print more verbose CPU info for boards built on real silicon
* Add support for SD-card detection on all ARC boards
* Quite a few fixes for IoT DK
- Support reset by command
- Print of CPU freq on boot
- Link for eFlash etc
By default GCC puts global non-initialized variables in COMMON section.
And we used to ignore existence of COMMON section in our linker
scripts though smart LD silently appended it right after .bss.
And the problem here is variables from COMMON section even though
require zeroing in run-time were not zeroed as they were placed
right after __bss_end symbol.
It was a pure luck we never faced serious problem due to this,
but now it is fixed.
Now as for some other architectures we'll just force GCC to put
those global variables in normal .bss section.
This solution is much nicer than adding COMMON section to each and
every linker script.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
[trini: Convert da850evm_nand defconfig now to to SPL_DM]
That's what we'll have in production.
But note it won't work for loading via JTAG as
eFlash is not directly writable, one needs to use
prebootloader to flash uboot.bin from SD-card into eFlash.
So now we may detect MMC/SD-card existence and
instead of completely misleading message on missing card:
------------------------>8-----------------------
Loading Environment from FAT... Card did not respond to voltage select!
we now get very clear one:
Loading Environment from FAT... MMC: no card present
Since gd->cpu_clk is a global item we may once populate it from .dtb
ans use it then in other places like for printing CPU info etc.
It is done by writing some magic sequence in a special register.
ARC IDENTITY register only encodes major architecture
type and version while for a particular board/silicon we
may know better which template was used and so we may identify
CPU more precise, which exactly we do here.
