2017-12-21Merge git://git.denx.de/u-boot-x86Tom Rini
2017-12-21x86: tangier: Use official ACPI HID for FLIS IPAndy Shevchenko
FLIS IP since now gets its own ACPI ID. Drop PRP0001 workaround in favour of official ACPI HID. Corresponding kernel commit dabd4bc6de2b pinctrl: intel: merrifield: Introduce ACPI device table in the pin control subsystem tree [1] targeting v4.16. [1]: https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl.git/commit/?h=for-next&id=dabd4bc6de2b Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-12-19Merge git://git.denx.de/u-boot-spiTom Rini
2017-12-19Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-12-19efi_loader: Setup logical_partition media informationEmmanuel Vadot
When adding a partition, set the logical_partition member in the media structure as mandated by the UEFI spec. Signed-off-by: Emmanuel Vadot <manu@freebsd.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-12-19mtd/spi: fix block count for is25lq040bSean Nyekjaer
This spi-nor is 4Mbit/512KB Fixes: b4fbcbc5a5 ("mtd/spi: add support for is25lq040b") Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-19arm64: dts: sun50i: h5: Order nodes in alphabetic for orangepi-primeJagan Teki
Order sun50i-h5-orangepi-prime.dts nodes in alphabetic Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-19configs: sunxi: Drop FASTBOOT_FLASHJagan Teki
Now FASTBOOT_FLASH is auto select for sunxi platform, so drop explicit addition. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-19sunxi: arm64: Increase CONFIG_SYS_BOOTM_LEN to 32MBJagan Teki
The default value of CONFIG_SYS_BOOTM_LEN, 0x800000, causes error when uncompressing Image.gz out of FIT image. Uncompressing Kernel Image ... Error: inflate() returned -5 Image too large: increase CONFIG_SYS_BOOTM_LEN and loading Image out of FIT image. Loading Kernel Image ... Image too large: increase CONFIG_SYS_BOOTM_LEN Must RESET board to recover Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-18Prepare v2018.01-rc2Tom Rini
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-18Merge git://git.denx.de/u-boot-rockchipTom Rini
2017-12-18Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-12-18common: image.c: Fix CACHE: Misaligned operation outputHeiko Schocher
When booting a itb file with a Ramdisk on a imx6 based board, U-Boot drops the warning: Loading Kernel Image ... OK Loading Ramdisk to 4ecf1000, end 4ef8b11f ... \ CACHE: Misaligned operation at range [4ecf1000, 4ef8b11f] Fix it! Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Ayoub Zaki <hs@denx.de>
2017-12-18am335x_evm: Fix DFU for eMMCSam Protsenko
Use dfu_alt_info_emmc variable from include/environment/ti/dfu.h file. It was probably overlooked when extracting DFU variables to mentioned file. This patch fixes DFU on BeagleBone Black, so that we can use commands like ones below to upgrade various images on eMMC: => setenv dfu_alt_info $dfu_alt_info_emmc => dfu 0 mmc 1 $ dfu-util -D MLO -a MLO.raw $ dfu-util -D u-boot.img -a u-boot.img.raw Without this patch, the user is forced to assign the value to dfu_alt_info_emmc manually, which contradicts with instructions [1]. [1] http://processors.wiki.ti.com/index.php/Linux_Core_U-Boot_User%27s_Guide Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-12-18net: phy: meson-gxl: detect LPA corruptionJerome Brunet
This patch is ported from the Linux patch posted at [1] and applied to net tree as commit f1e2400a80ff. The purpose of this change is to fix the incorrect detection of the link partner (LP) advertised capabilities which sometimes happens with this PHY (roughly 1 time in a dozen) This issue may cause the link to be negotiated at 10Mbps/Full or 10Mbps/Half when 100MBps/Full is actually possible. In some case, the link is even completely broken and no communication is possible. To detect the corruption, we must look for a magic undocumented bit in the WOL bank (hint given by the SoC vendor kernel) but this is not enough to cover all cases. We also have to look at the LPA ack. If the LP supports Aneg but did not ack our base code when aneg is completed, we assume something went wrong. The detection of a corrupted LPA triggers a restart of the aneg process. This solves the problem but may take up to 6 retries to complete. [1] https://lkml.kernel.org/r/20171208110811.30789-1-jbrunet@baylibre.com Fixes: 8995a96d1d67 ("net: phy: Add Amlogic Meson GXL Internal PHY support") Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2017-12-18ARM: arch-meson: fix writel arguments orderHans Verkuil
Using writel causes a "Synchronous Abort". Invert the arguments. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2017-12-18Merge tag 'xilinx-for-v2018.01-rc2-v2' of ↵Tom Rini
git://www.denx.de/git/u-boot-microblaze Xilinx changes for v2018.01-rc2-v2 fpga: - Enable loading bitstream via fit image for !xilinx platforms zynq: - Fix SPL SD boot mode zynqmp: - Not not reset in panic - Do not use simple allocator because of fat changes - Various dt chagnes - modeboot variable setup - Fix fpga loading on automotive devices - Fix coverity issues test: - Fix env test for !hush case - Stephen's patch
2017-12-18armv8: ls1046aqds: Adjust IFC timing for NOR flashYork Sun
Increase setup, assertion and hold time related to chip-select signal. Additional delay is needed for the signal to propogate through FPGA. This adjustment slightly increase the read and write cycle but has no impact on burst read or write. Signed-off-by: York Sun <york.sun@nxp.com>
2017-12-18armv8: ls2085a: Update README file for NAND bootYork Sun
Update README file to note LS2088A and LS1088A don't support booting from NAND flash. Signed-off-by: York Sun <york.sun@nxp.com>
2017-12-18armv8: ls2080a: Increase load image len for NAND bootYork Sun
Again the image size increases and the length needs to be adjusted. Signed-off-by: York Sun <york.sun@nxp.com>
2017-12-18rockchip: add a common script for generate fit itsKever Yang
Rockchip release bl31.elf file for armv8 SoCs like rk3399, rk3328, the elf have more than one section, we need to decode it first and packed them into u-boot.itb with its file. This script is to generate the its script. Need default bl31.elf in root directory of U-Boot source and dtb as parameter. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: firefly-rk3399: add FIT for rk3399Kever Yang
Enable SPL_FIT_GENERATOR with path for it. With this patch you can get u-boot.itb for rk3399-firefly with: > make u-boot.itb Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: evb-rk3399: update document for board bring upKever Yang
Since we support ATF in SPL and add script for it, let's make the document up to date. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: update ROCKCHIP_SPL_RESERVE_IRAM to 0Kever Yang
Only rk3399 atf need ROCKCHIP_SPL_RESERVE_IRAM. This commit updates its default setting to 0 so that other SoCs do not need to define it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18rockchip: update boot0 hookKever Yang
Rockchip SoCs only need boot0 hook at SPL, and the U-Boot proper do not need it. The very beginning of U-Boot proper is different between armv7 and armv8: armv7 start with ARM_VECTORS while armv8 start with 'b reset'. Here is the map of very beginning for all cases: armv7 SPL: TAG(overwrite 'b 1f')+'b reset' + ARM_VECTORS armv7 U-Boot: ARM_VECTORS armv8 SPL: TAG(overwrite 'b 1f')+'b reset' + Reserved_iram(rk3399) armv8 U-Boot: 'b reset' Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-18test/py: Setup variables based on HUSH selectionStephen Warren
After adding our small zynq uboot which has hush parser off same variable tests start to failed. Use quotes only when hush is enabled. Reported-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2017-12-18arm64: zynqmp: Access timestamp_ref_ctrl register only if running in el3Siva Durga Prasad Paladugu
Access the timestamp ref ctrl register only if runinng at el3 level otherwise just return. This change fixes the issue when CRL APB is marked as secure and accessing when not in el3 causes exception. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18tools: zynqmpimage: Check return values from file functionsMichal Simek
Check all return values from file functions. In case of negative return exit immediately. Also change fsize return value which can't be negative. Reported-by: Coverity (CID: 23276, 23304, 169357) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18arm64: zynqmp: Dont use 4K sector erase by default for spi-flashesSiva Durga Prasad Paladugu
Dont use 4K sector erase by default, Disabling this would use 64K sector erase and decreases erase time. Also disabled by the fact that UBIFS and JFFS2 won't work with 4K sector erase. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18arm64: zynqmp: Enable spi flashesMichal Simek
Enabling all spi flashes because some of these boards can have different flashes compared to public version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-18rockchip: move CONFIG_ENV_SIZE and CONFIG_ENV_OFFSET to KconfigKlaus Goger
This commit adds ENV_SIZE and ENV_OFFSET configuration items for ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given). With these new items present, the configuration from the header files is moved to Kconfig. Keeping these non-visible is necessary to have the possibility to select new default values if CONFIG_IS_IN_* is changed (interactively or with oldconfig). Otherwise it will always be set to a previous value if used with a prompt. As an example if we do a defconfig with CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct values as defconfig will already have set them to the default values of CONFIG_IS_IN_MMC in .config. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-17Merge tag 'signed-efi-v2018.01' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2017-12-17 A few fixes for 2018.01: - Compile fix with helloworld example - DP match fix (fixes FreeBSD loader and grub on block storage) - More DP fixes for SD, block - Fix use-after-free
2017-12-17rockchip: rk3399-puma: set gpio4cd iodomain to 1.8VJakob Unterwurzacher
The PCIe reset signal is connected to GPIO4_C6 on the Puma module. This pin is supplied by 1.8V, but the default iodomain setting is 3.0V and in this situation the pin is unable to go high. Linux assumes that this signal works in early boot as PCIe is probed before loading the iodomain driver. Make PCIe work in Linux by setting the gpio4cd iodomain to 1.8V. Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-17rockchip: config: update part tableKever Yang
User do not need to access the reserved part in system, remove them from partition table. Rename atf to trust as generic name for armv7 do not use ATF. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-12-16efi_loader: comments for dp_part_fill()Heinrich Schuchardt
Add a description for dp_part_fill(). Reword a comment in the function. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: correct DeviceNodeToText for media typesHeinrich Schuchardt
When converting device nodes and paths to text we should stick to the UEFI spec. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: correctly setup device paths for block devicesHeinrich Schuchardt
According to the UEFI spec the numbering of partitions has to start with 1. Partion number 0 is reserved for the optional device path for the complete block device. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: correctly determine if an MMC device is an SD-cardHeinrich Schuchardt
The SD cards and eMMC devices have different device nodes. The current coding interpretes all MMC devices as eMMC. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: error handling in efi_load_image()Heinrich Schuchardt
If a failure occurs when trying to load an image, it is insufficient to free() the EFI object. We must remove it from the object list, too. Otherwise a use after free will occur the next time we iterate over the object list. Furthermore errors in setting up the image should be handled. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: new function efi_delete_handle()Heinrich Schuchardt
Provide a function to remove a handle from the object list after removing all protocols. To avoid forward declarations other functions have to move up in the coding. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: return status from efi_setup_loaded_image()Heinrich Schuchardt
efi_setup_loaded_image() should return an error code indicating if an error has occurred. An error occurs if a protocol cannot be installed. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: Ensure efi_dp_find_obj() finds exact matchesAlexander Graf
When calling efi_dp_find_obj(), we usually want to find the *exact* match of an object for a given device path. However, I ran into a nasty corner case where I had the following objects with paths available: Handle 0x9feffa70 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/EndEntire Handle 0x9feffb58 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/HD(1,800,32000,2de808cb00000000,1,1)/EndEntire and was searching for /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/HD(1,800,32000,2de808cb00000000,1,1)/EndEntire But because our device path search looked for any substring match, it would return /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/EndEntire because that path is a full substring of the path we were searching for. So this patch adapts the device path search logic to always look for exact matches first. The way we distinguish between those cases is by looking at whether our caller actually deals with remainders. As a side effect, the code as is from all I can tell now never does a substring match anymore, because it always gets called with rem=NULL, so we always only do exact matches now. Reported-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: helloworld.c: Reduce file sizeAlexander Graf
The efi linker script includes sections needed for the dynamic linker. However, in our EFI application environment we don't have a dynamic linker. So let's remove them. That way we save on 4k padding and reduce the file size of the hello world efi binary from ~4k to ~1k. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: helloworld.c: Explicitly use .rodata for loaded_image_guidAlexander Graf
Commit bbf75dd9345d0b ("efi_loader: output load options in helloworld") introduced a const variable in efi_main() called loaded_image_guid which got populated from a constant struct. While you would usually expect a compiler to realize that this variable should really just be a global pointer to .rodata, gcc disagrees and instead puts it on the stack. Unfortunately in some implementations of gcc it does so my calling memcpy() which we do not implement in our hello world environment. So let's explicitly move it to a global variable which in turn puts it in .rodata reliably and gets rid of the memcpy(). Fixes: bbf75dd9345d0b ("efi_loader: output load options in helloworld") Reported-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Tested-by: Florian Fainelli <f.fainelli@gmail.com>
2017-12-14armv8: ls1012ardb: support hwconfig for eSDHC1 enablingYangbo Lu
I2C reading for DIP switch setting is not reliable for LS1012ARDB RevD and later versions. This patch is to add hwconfig support to enable/disable eSDHC1 manually for these boards. Also drop 'status' fix-up for eSDHC0 and leave it as it is. It shouldn't always be fixed up with 'okay'. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14armv8: ls1012ardb: add more board version informationYangbo Lu
Add LS1012ARDB RevC/RevC1/RevC2/RevD/RevE information and detect it when u-boot starts up. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14armv8: ls1012ardb: clean up definitions for I2C IO expandersYangbo Lu
This patch is to clean up definitions for I2C IO expanders. The value 0x10 of __SW_BOOT_EMU is wrong. It should be 0x2. Fixed it in this patch. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14board/ls2080a, ls1088a: Add check for mc-dpl applied in fdtYogesh Gaur
Function fdt_fixup_board_enet() performs fdt fixup. Only return fdt_status_okay() when both MC is applied and DPL is deployed, else return fdt_status_fail(). This check is added to LS1088A/LS2080A/LS2088A boards. Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14Merge git://git.denx.de/u-boot-dmTom Rini
