Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
A20-SOM204 board has option with onboard 16GB eMMC. The chip is wired
to MMC2 slot.
This patch adds defconfig and dts files for this board. The dts is same
with mainline kernel.
Signed-off-by: Stefan Mavrodiev <stefan@olimex.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This is new System-On-Module platform with universal dimm socket for
easy insertation. The EVB board is designed to be universal with
future modules.
Base features of A20-SOM204 board includes:
* 1GB DDR3 RAM
* AXP209 PMU
* KSZ9031 Gigabit PHY
* AT24C16 EEPROM
* Status LED
* LCD connector
* GPIO connector
There will be variants with the following options:
* Second LAN8710A Megabit PHY
* 16MB SPI Flash memory
* eMMC card
* ATECC508 crypto device
The EVB board has:
* Debug UART
* MicroSD card connector
* USB-OTG connector
* Two USB host
* RTL8723BS WiFi/BT combo
* IrDA transceiver/receiver
* HDMI connector
* VGA connector
* Megabit ethernet transceiver
* Gigabit ethernet transceiver
* SATA connector
* CAN driver
* CSI camera
* MIC and HP connectors
* PCIe x4 connector
* USB3 connector
* Two UEXT connectors
* Two user LEDs
Some of the features are multiplexed and cannot be used the same time:
CAN and Megabit PHY. Others are not usable with A20 SoC: PCIe and USB3.
with mainline kernel, except some nodes are removed to make file
compatible with existing dtsi file.
CONFIG_PHY_ADDR is used for old-style configuration. This makes
impossible changing the PHY address, if multiple boards share a same
config header file (for example include/configs/sunxi-common.h).
Moving this to Kconfig helps overcoming this issue. It's defined
as entry inside PHYLIB section.
After the implemention, moveconfig was run. The issues are:
- edb9315a - CONFIG_PHYLIB is not enabled. Entry is
deleted.
- ds414 - CONFIG_PHYLIB is in incompatible format:
{ 0x1, 0x0 }. This entry is also deleted.
- devkit3250 - The PHY_ADDR is in hex format (0x1F).
Manually CONFIG_PHY_ADDR=31 is added in
the defconfig.
After the changes the suspicious defconfigs passes building.
[jagan: rebased on master]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
The previous code tried to update the PHY parameters without waiting for
autonegotiation to complete. This caused wrong values to be written to
the EMAC in sun8i_adjust_link(). As a result, any commands that called
eth_start() before autonegotiation completed would find the network
nonfunctional. Fix this by using the correct function to start up the
PHY.
Signed-off-by: Samuel Holland <samuel@sholland.org>
In README.sunxi64 we tell the user how to optionally create
u-boot-sunxi-with-spl.bin by manually running cat. Instead, have the
build system create the file automatically just like it does for 32-bit
sunxi boards.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
We're going to need this logic for 64-bit builds as well, so move it
out from under arch/arm/cpu/armv7.
With CONFIG_DM_MMC the BananaPi does not detect SD cards.
The sunxi device trees use the cd-inverted property to indicate that
the card detect is inverted.
This property is documented in Linux kernel devicetree/bindings/mmc/mmc.txt
The property is not marked as deprecated.
A similar patch was posted by Tuomas but is in status "Changes Requested".
https://patchwork.ozlabs.org/patch/850377/
This patch is a stripped down version of his patch.
Suggested-by: Tuomas Tynkkynen <tuomas@tuxera.com>
When the OTG node was added, its reg property for its address space was
missing. With commit f4f9896ac310 ("musb: sunxi: Use base address from
device tree"), the OTG controller's address is derived from the device
tree exclusively. The missing property results in U-boot crashing when
MUSB is initialized.
Fixes: b0bea6678981 ("sunxi: Add USB and R_PIO nodes to sun8i-a83t.dtsi")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Tested-by: Jagan Teki <jagan@openedev.com>
With the merge of the new u-boot.itb size check now the build for
pine64_plus_defconfig breaks, as this file gets too large:
u-boot.itb exceeds file size limit:
limit: 516096 bytes
actual: 521852 bytes
excess: 5756 bytes
make: *** [u-boot.itb] Error 1
One easily fixable reason is that we actually have two .dtbs in our FIT
image, one for the regular Pine64+ board, and one for the non-plus version.
The only difference U-Boot cares about is the 100Mbit Ethernet PHY used
on the non-plus version, however Ethernet isn't enabled in the non-plus
DT anyway.
So we could avoid the non-plus special handling, and remove that extra
.dtb from the FIT image, which saves a few KBs and brings us back below the
limit. The Pine64 would boot with a Pine64+ .dtb, and would fail to
enable Ethernet. Given that it didn't work in the first place, this is not
a regression.
Once we switch to a non-MMC environment, we can bring this back, then
with a proper .dtb and hopefully working Ethernet.
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
commit 8c4037a09a5c ("imx: hab: Ensure the IVT DCD pointer is Null prior
to calling HAB authenticate function.") makes the DCD field being NULL a
dependency.
This change though will break loading and executing of existing pre-signed
binaries on a u-boot update i.e. if this change is deployed on a board you
will be forced to redo all images on that board to NULL out the DCD.
There is no prior guidance from NXP that the DCD must be NULL similarly
public guidance on usage of the HAB doesn't call out this NULL dependency
(see boundary devices link).
Since later SoCs will reject a non-NULL DCD there's no reason to make a
NULL DCD a requirement, however if there is an actual dependency for later
SoCs the appropriate fix would be to do SoC version checking.
Earlier SoCs are capable (and happy) to authenticate images with non-NULL
DCDs, we should not be forcing this change on downstream users -
particularly if it means those users now must rewrite their build systems
and/or redeploy signed images in the field.
Fixes: 8c4037a09a5c ("imx: hab: Ensure the IVT DCD pointer is Null prior
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Cc: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Link: https://boundarydevices.com/high-assurance-boot-hab-dummies
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The README.mxc_hab is outdated and need improvements, add the following
modifications:
- Reorganize document and remove duplicate content
- Add CST download link
- Update CST package name
- Align command lines with CST v2.3.3
- Update U-Boot binary name
- Remove CSF padding since is not documented in AN4581
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Currently the High Assurance Boot procedure is documented in two
places:
- doc/README.imx6
- doc/README.mxc_hab
It is better to consolidate all HAB related information into
README.mxc_hab file, so move the content from README.imx6 to
README.mxc_hab.
commit cd2d46003ce1 ("arm: imx: hab: Add IVT header definitions") declares
struct ivt_header as "__attribute__((packed))".
commit ed286bc80e9d ("imx: hab: Check if CSF is valid before
authenticating image") declares struct hab_hdr with __packed.
This patch makes the __packed convention consistent.
commit ed286bc80e9d ("imx: hab: Check if CSF is valid before authenticating
image") makes use of "__packed" as a prefix to the "struct hab_hdr"
declaration.
With my compiler "gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)" we
get:
./arch/arm/include/asm/mach-imx/hab.h:42:25: error: expected ‘=’, ‘,’, ‘;’,
‘asm’ or ‘__attribute__’ before ‘{’ token
struct __packed hab_hdr {
Fix this problem by including <linux/compiler.h>
This patch fixes the wrongly included dtsi file which was
breaking mainline support for Engicam i.CoreM6 DualLite/Solo RQS.
Linux commit details for the same change as
"ARM: dts: imx6dl: Include correct dtsi file for Engicam i.CoreM6
DualLite/Solo RQS"
(sha1: c0c6bb2322964bd264b4ddedaa5776f40c709f0c)
usdhc4 node need to update pinctrl, bus-width and non-removable
properties, sync the same from Linux.
The system call used by mkimage to run dtc redirects stdout to a
temporary file. This can cause problems on Windows (with a MinGW
cross-compiled version). Using the "-o" dtc parameter avoids
this problem.
Signed-off-by: Stefan Theil <stefan.theil@mixed-mode.de>
Other filesystem drivers don't do this.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
NETWORK should be after NAND_FLASH.
kmerr: verify that malloc and calloc are followed by a check to verify
that we are not out of memory.
badzero: Compare pointer-typed values to NULL rather than 0
Both checks are copied from the Linux kernel archive.
The iterator of list_for_each() is never NULL.
Identified with coccinelle.
After the UART was initialized, we may still have bogus data in the
RX queue if it was enabled with incorrect pin muxing before.
So let's flush the RX queue whenever we initialize baud rates.
This fixes a regression with the dynamic pinmuxing code when enable_uart=1
is not set in config.txt on Raspberry Pis that use pl011 for serial.
Fixes: caf2233b28 ("bcm283x: Add pinctrl driver")
Reported-by: Göran Lundberg <goran@lundberg.email>
Reported-by: Peter Robinson <pbrobinson@gmail.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Tested-by: Tuomas Tynkkynen <tuomas@tuxera.com>
is not set in config.txt.
The following config symbols are only defined once and never referenced
anywhere else:
CONFIG_AT91SAM9263EK
CONFIG_AT91SAM9RLEK
CONFIG_BARIX_IPAM390
CONFIG_BOARD_H2200
CONFIG_EP9301
CONFIG_KZM_A9_GT
CONFIG_PICOSAM
CONFIG_PLATINUM_PICON
CONFIG_PLATINUM_TITANIUM
CONFIG_PM9261
CONFIG_PM9263
CONFIG_PM9G45
CONFIG_SIEMENS_DRACO
CONFIG_SIEMENS_PXM2
CONFIG_SIEMENS_RUT
CONFIG_SMDKC100
CONFIG_SMDKV310
CONFIG_STM32F4DISCOVERY
Most of them are config symbols named after the respective boards which
seems to have been a standard practice at some point.
anywhere else:
CONFIG_ARM926EJS
CONFIG_CPUAT91
CONFIG_EXYNOS5800
CONFIG_SYS_CORTEX_R4
Most of them are config symbols named after the respective SoCs which
anywhere else:
CONFIG_DBAU1X00
CONFIG_PB1X00
The @gdsys.cc addresses are supposed to be used for mailing lists.
Switch all occurrences of @gdsys.de mail addresses to their @gdsys.cc
equivalent.
Also, Dirk's address was wrong in one place; fix that as well.
Signed-off-by: Mario Six <six@gdsys.cc>
CONFIG_SYS_CBSIZE determines the maximum length of the kernel command
line, and the default value of 256 is too small for booting some Linux
images in the wild.
Without the volatile attribute, compilers are entitled to optimize out
the same asm(). In the case of __udelay() in syscounter.c, it calls
`get_ticks()` twice, one for the starting time and the second in the
loop to check the current time. When compilers inline `get_ticks()`
they see the same `mrrc` instructions and optimize out the second one.
This leads to infinite loop since we don't get updated value from the
system counter.
Here is a portion of the disassembly of __udelay:
88: 428b cmp r3, r1
8a: f8ce 20a4 str.w r2, [lr, #164] ; 0xa4
8e: bf08 it eq
90: 4282 cmpeq r2, r0
92: f8ce 30a0 str.w r3, [lr, #160] ; 0xa0
96: d3f7 bcc.n 88 <__udelay+0x88>
98: e8bd 8cf0 ldmia.w sp!, {r4, r5, r6, r7, sl, fp, pc}
Note that final jump / loop at 96 to 88, we don't have any `mrrc`.
With a volatile attribute, the above changes to this:
8a: ec53 2f0e mrrc 15, 0, r2, r3, cr14
8e: 42ab cmp r3, r5
90: f8c1 20a4 str.w r2, [r1, #164] ; 0xa4
94: bf08 it eq
96: 42a2 cmpeq r2, r4
98: f8c1 30a0 str.w r3, [r1, #160] ; 0xa0
9c: d3f5 bcc.n 8a <__udelay+0x8a>
9e: e8bd 8cf0 ldmia.w sp!, {r4, r5, r6, r7, sl, fp, pc}
a2: bf00 nop
I'm advised[1] to put volatile on all asm(), so this commit also adds it
to the asm() in timer_init().
[1]: https://lists.denx.de/pipermail/u-boot/2018-March/322062.html
Signed-off-by: Yasushi SHOJI <yasushi.shoji@gmail.com>
Sometimes imximage throws the following error:
CFGS board/freescale/vf610twr/imximage.cfg.cfgtmp
MKIMAGE u-boot-dtb.imx
Error: No BOOT_FROM tag in board/freescale/vf610twr/imximage.cfg.cfgtmp
arch/arm/mach-imx/Makefile:100: recipe for target 'u-boot-dtb.imx' failed
Later on, when running mkimage for the u-boot.imx it will succeed in
finding the IVT offset.
Looks like some race condition happening during parallel build when
processing mkimage for u-boot-dtb.imx and u-boot.imx.
A proper fix still needs to be implemented, but as a workaround let's
remove the error when the IVT offset is not found.
It is useful to have such message, especially during bring-up phase,
but the build error that it causes is severe, so better avoid the
build error for now.
The error checking can be re-implemented later when we have a proper
fix.
Reported-by: Breno Lima <breno.lima@nxp.com>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
This was missing the 'S' line causing a warning from genboardscfg.py
This should clean up a warning about a missing phy-cells
POWER should be after ONENAND
Keep spelling.txt in sync with the version from kernel 4.16-rc4.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Due to evolution of the MMC driver and better support, let's
remove unnecessary undefs.
With the migration to Kconfig, the I2C block no longer exists in here.
Let's clean up the comment.
Enable DHCP support for this board.
Signed-off-by: Ed Bartosh <ed.bartosh@linux.intel.com>
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
There are no headers for libfdt in lib/libfdt, as they are instead
located in scripts/dtc/libfdt. Specifying lib/libfdt for headers
inclusion in host tools results in using the system libfdt headers,
which is not what we want. Change this to the proper path.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Add a comment indicating that the German key map assumes code page 437.
Add support for character ² (square sign) in the German key map.
The PCA953x driver uses "gpio@%x_" as the GPIO bank name, where "%x" is
instantiated with the I2C address of the chip. While this works, it
becomes very confusing if a board has multiple PCAs with the same
address on different I2C busses, and it also becomes an issue when a
GPIO's value is to be set via the 'gpio' command, because this command
only ever sets the value of the first device it encounters, leaving the
other devices inaccessible to the command.
As to not break boards that rely on this naming scheme, we introduce a
new device tree string property "label" for the driver. If it exists, it
is used to build a bank name of the form "%s@%x_" (where %x is still
instantiated with the I2C address). If it does not exist, the legacy
labeling scheme is used.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
U-boot CONFIG
Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER.
This enables users to block text using CONFIG_IS_ENABLED() instead
of resorting to #if ladders with SPL and non-SPL cases.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Treat the first equal sign as a key/value separation too. This makes
the script files compatible with mkenvimage input file format. It
won't support variables with equal signs anymore, but this seems not
really like a loss.
