Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Many boards use only single depth configuration, for such boards
there is some unused code in video and console uclass routines.
Add guards to avoid dead code.
In case the BMP size is bigger than the frame buffer, don't use
the BMP's width and height in video_display_rle8_bitmap, but the
one's checked in video_bmp_display() as parameters to
video_display_rle8_bitmap().
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
CC: Yannick Fertré <yannick.fertre@st.com>
Convert panel_picture_delta and axis_alignment from unsigned long
to long to insure to store correctly the difference between
panel_size and picture_size in case the panel_size is smaller
than picture_size.
[agust: change axis_alignment to long]
- Assorted omapl138_lcdk / da850-evm fixes
- FAT fix, add another pytest as well for FAT.
- Assorted general fixes
SPL has limited available resources, and the performance between
ARM and Thumb isn't that significant.
This patch builds using Thumb instruction set to reduce the code
size by nearly 6K.
Original:
26526 4004 1376 31906 7ca2 spl/u-boot-spl
Thumb:
20232 4004 1376 25612 640c spl/u-boot-spl
Tested-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
The da850-evm doesn't have the boot pins configured in a way
to make MMC/SD booting an option, and MMC/SD support is not
enabled in SPL. Therefore, there is no need to support raw mode
mmc/sd support in SPL.
This patch disables CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
At the moment entry_point is set to image_get_load(header) that sets it
to "load address" instead of "entry point", assuming entry_point is
equal to load_addr, but it's not true. Then load_addr is set to
"entry_point - header_size", but this is wrong too since load_addr is
not an entry point.
So use image_get_ep() for entry_point assignment and image_get_load()
for load_addr assignment.
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
# This is actually a resent patch of
# [1] https://lists.denx.de/pipermail/u-boot/2019-May/369170.html
Two test cases are added under test_fs_ext:
test case 10: for root directory
test case 11: for non-root directory
Those will verify a behavior fixed by the commits related to
root directory
("fs: fat: allocate a new cluster for root directory of fat32" and
"fs: fat: flush a directory cluster properly"), and focus on
handling long-file-name directory entries under a directory.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Unlink test for FAT file system seems to fail at test_unlink2.
(When I added this test, I haven't seen any errors though.)
for example,
===8<===
fs_obj_unlink = ['fat', '/home/akashi/tmp/uboot_sandbox_test/128MB.fat32.img']
def test_unlink2(self, u_boot_console, fs_obj_unlink):
Test Case 2 - delete many files
fs_type,fs_img = fs_obj_unlink
with u_boot_console.log.section('Test Case 2 - unlink (many)'):
output = u_boot_console.run_command('host bind 0 %s' % fs_img)
for i in range(0, 20):
output = u_boot_console.run_command_list([
'%srm host 0:0 dir2/0123456789abcdef%02x' % (fs_type, i),
'%sls host 0:0 dir2/0123456789abcdef%02x' % (fs_type, i)])
assert('' == ''.join(output))
'%sls host 0:0 dir2' % fs_type)
> assert('0 file(s), 2 dir(s)' in output)
E AssertionError: assert '0 file(s), 2 dir(s)' in ' ./\r\r\n ../\r\r\n 0 0123456789abcdef11\r\r\n\r\r\n1 file(s), 2 dir(s)'
test/py/tests/test_fs/test_unlink.py:52: AssertionError
===>8===
This can happen when fat_itr_next() wrongly detects an already-
deleted directory entry.
File deletion, which was added in the commit f8240ce95d64 ("fs: fat:
support unlink"), is implemented by marking its entry for a short name
with DELETED_FLAG, but related entry slots for a long file name are kept
unmodified. (So entries will never be actually deleted from media.)
To handle this case correctly, an additional check for a directory slot
will be needed in fat_itr_next().
In addition, I added extra comments about long file name and short file
name format in FAT file system. Although they are not directly related
to the issue, I hope it will be helpful for better understandings
in general.
The mmc CID value is one of the input parameters used to provision the
RPMB key. The trusted execution environment expects this value to be
specified in big endian format.
Before this fix, on little endian systems, the value returned by the
linux kernel mmc driver differed from the one returned by u-boot.
This meant that if linux provisioned the RPMB key, u-boot would not
have access to the partition (and the other way around).
Signed-off-by: Jorge Ramirez-Ortiz <jorge@foundries.io>
Reviewed-by: Jens Wiklander <jens.wiklander@linaro.org>
The command cp fails on sandbox because the address is used
directly. To fix this issue, we call the function map_sysmem
to translate the address.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
The command iminfo fails on sandbox because the address
is used directly. To fix this issue, we call the function
map_sysmem to translate the address.
This define indicates if DM_GPIO shall be supported in SPL. This allows
proper operation of DM converted GPIO drivers in SPL, which use
boards.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
PCI devices may be disabled in the device tree. Devices which are probed
by the device tree handle the "status" property and are skipped if
disabled. Devices which are probed by the PCI enumeration don't check
that property. Fix it.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Alex Marginean <alexandru.marginean@nxp.com>
Tested-by: Alex Marginean <alexandru.marginean@nxp.com>
- Convert some R-Car Gen3 platforms to DM_SPI{,_FLASH}
- Merge the series to clean up our MTD Kconfig and Makefile logic
Move MTD-related lines out of the root Makefile. Put them in their
respective directories. Enclose some of these new lines to skip them
when building the SPL. MTD core files and some MTD device drivers are
compiled in a mtd.o object and included in the final object only if
MTD support is required (there are two different symbols for that, one
for U-Boot and one for the SPL).
Now that all defconfigs have been fixed, we can stop the logic where
enabling a command selects the core files to compile. This logic is
broken since selecting a symbol with a 'depends on' will not enforce
this secondary dependency.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Defconfigs have been fixed, now we can add proper dependencies in
Kconfig. SPI FLASH is still not dependent on MTD (deeper rework needed).
The 'sf' command is not supposed to rely on the MTD stack, but both
'sf' and 'nand' commands use helpers located in mtd_uboot.c. Despite
their location, these functions do not depend at all on the MTD
stack.
This file (drivers/mtd/mtd_uboot.c) is only compiled if CONFIG_MTD is
selected, which is inconsistent with the current situation. Solve this
by moving these three functions (which are only used by the above two
commands) out of mtd_uboot.c and put them in a C file only compiled
with cmd/sf.c and cmd/nand.c.
[trini: Don't export get_part function now]
Move the Kconfig entry of the option right after the entry of the
mtdparts command.
It is already the case that all defconfigs with SPI_FLASH_MTD also
declare using MTD, but let's make this consistent and enforce it in
Kconfig. Most of the time SPI_FLASH_MTD is used in conjunction with
UBI, which already depends on MTD.
Suggested-by: Vignesh R <vigneshr@ti.com>
CONFIG_DFU_NAND needs the raw NAND core being compiled.
Also fix the colibri_vf defconfig to reflect this dependency.
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Because of the include's game, when some files are compiled for a SPI
NAND device, no warning appears. But when it is for a raw NAND device,
GCC complains. Fix these warning by including <common.h>.
Enabling TFABOOT configuration will compile-in a call to nand_read in
the boot sequence. Handle the situation by also selecting officially
the raw NAND core in this case.
There is no flash on this board, there is no reason to define MTD
environment variables nor UBI. Drop them from the configuration file.
Reviewed-by: Wolfgang Grandegger <wg@aries-embedded.de>
While the right Kconfig entries were selected, because of the missing
CMD_NAND symbol the raw NAND core was never compiled. Remove it from
the defconfigs otherwise the build will fail.
[trini: Also do this on bcm11130_nand]
Due to previous Makefile organization, the raw NAND subdirectory was
not compiled in if CMD_NAND was not enabled. Because the Denali driver
does not compile with these boards (undefined environment offset),
remove the dependency within the defconfig over the controller driver
(was ignored anyway in the past).
Let's be consistent and always declare CONFIG_MTD from the defconfig
file when needed.
MTD support must be enabled when using mtdparts. Indeed, functions
like get_mtd_info(), get_mtd_device() and put_mtd_device() are in
drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
In some files, options of CMD_NAND are selected but not the command
itself. Fix this inconsistency.
Raw NAND support must be enabled when the environment is in NAND.
UBI must be enabled when the environment is in UBI.
UBI must be enabled when using fastmap, reflect this is defconfigs.
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Enable DM_SPI and DM_SPI_FLASH in U-Boot on M2N Gose.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Enable DM_SPI and DM_SPI_FLASH in U-Boot on M2W Koelsch.
Enable DM_SPI and DM_SPI_FLASH in U-Boot on H2 Lager.
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
[trini: Add Kconfig files]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-01-rc5
A type error in the implementation of the efidebug command is fixed.
Fix stdout-path handling
- omapl138_lcdk fixes
- MediaTek MT8518 support
- VxWorks standard DTB support
- Assorted bug fixes
I detected the following error in sandbox with Clang on Travis CI:
+cmd/efidebug.c:703:15: error: result of comparison of constant
9223372036854775822 with expression of type 'int' is always false
[-Werror,-Wtautological-constant-out-of-range-compare]
+ else if (ret == EFI_NOT_FOUND)
Simply changing a type of 'ret' to efi_status_t will fix this error.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Defconfig is pointing to incorrect DT file which needs to be fix.
This adds a general board file based on MT8518 SoCs from MediaTek.
Apart from the generic parts (cpu) we add some low level init codes
and initialize the early clocks.
This commit is adding the basic boot support for the MT8518 eMMC board.
Signed-off-by: mingming lee <mingming.lee@mediatek.com>
[trini: Migrate env location to defconfig, set ENV_IS_IN_MMC]
Signeed-off-by: Tom Rini <trini@konsulko.com>
