These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
These are used by only one arch and only within a single file. Drop the
declarations from the common file.
These functions belong in cpu_func.h. Another option would be cache.h
but that code uses driver model and we have not moved these cache
functions to use driver model. Since they are CPU-related it seems
reasonable to put them here.
Move them over.
Remove the unwanted space before the bracket.
These functions belong in cpu_func.h so move them over.
This function belongs in cpu_func.h so move it over.
This function is not defined anywhere. Drop it.
These functions belong in cpu_func.h since they do not use driver model.
Move them over. Don't bother adding comments since these functions should
be deleted.
This function belongs in mii.h so move it over.
This function belongs in time.h so move it over and add a comment.
This function belongs in time.h so move it over and update the comment
style.
This function has a similar name to the common wait_ticks(). It is only
used in one place and seems small enough to drop.
Inline it.
These functions belong in time.h so move them over and add comments.
Add a header file to house the lz4 compression function. Add a comment
while we are here, since it not even clear from the name what the function
actuall does.
These functions belong in serial.h so move them over.
Move this function header to serial.h since this function is clearly
related to serial. The function itself stays in console.c since we don't
have a single serial file. DM and non-DM each has a separate file so we
would have to either create a new common serial file, or repeat the
function in both serial.c and serial-uclass.c, neither of which seem
worthwhile.
The function declarations in serial.h are not in sync with what is
currently used in usbtty. Fix this by updating the header and including
it, to help catch future such problems.
This function relates to networking, so move it out of the common.h
header file.
At present this function sits in its own file but it does not really
justify it. There are similar string functions in vsprintf.h, so move it
there. Also add the missing function comment.
Use the vsprintf.h include file explicitly where needed.
These don't need to be in common.h so move them out into a new header.
Also add some missing comments.
These don't need to be in common.h so move them out.
It is not good practice to write code in a header file. If it is included
multiple times then the code can cause duplicate functions.
Move the bootcount_store() and bootcount_load() functions into SPL.
Note: bootcount is a bit strange in that it uses driver model but does not
define proper drivers. This should be fixed.
Drop inclusion of crc.h in common.h and use the correct header directly
instead.
With this we can drop the conflicting definition in fw_env.h and rely on
the crc.h header, which is already included.
Some of these have a space before the bracket. Drop it to fix the style.
Add some missing function comments while here.
Note that u32 and u8 cannot be used here since crc.h is included on the
host side.
We have an existing U-Boot header for the one function that this defines.
Use that instead of the linux/ one. Move over the nice comment.
Create a new rand.h header file and move functions into it, to reduce
the size of common.h
There are a few whitespace problems with this code. Tidy them up.
This is only used by a few files so it should not be in the common header.
Move it out.
This feature is not enabled by any board. Drop it.
These should be moved to driver model, but in the meantime, move them
out of the common header to help reduce its size.
- Assorted Gen5 fixes
- USB keyboard improvements
https://gitlab.denx.de/u-boot/custodians/u-boot-mmc
- fsl_esdhc update and some cleanup in ls1021a/mpc83xx code
- mmc tmio sdhi update for hs400
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Solve warning for stih410-b2260
- Device tree alignment on v5.4-rc4 for all stm32 boards
- Correct the eMMC pin configuration on stm32mp157c-ev1
- Add DFU and SPI-NAND support for stm32mp1 board
- powerpc: Fix DM_MMC related build warnings by adding eSDHC device
module support for T4240RDB, T2080RDB, T1042D4RDB, T1024RDB, P5040DS,
P4080DS, P3041DS, P2041RDB, P2020RDB, P1020RDB platforms
Instead of using single fixed value for the calibration offset,
add tables which dynamically adjust this per calibration code
from the SCC.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Some of the tuning taps produce suboptimal results. Add code
which skips those "bad" taps.
Check SCC for errors after check command if applicable and
optionally adjust the bus skew settings accordingly.
Disable the auto-retuning in HS400 mode in favor of manual calibration.
Adjust the TMPPORT3 offsets according to the latest information
from the chip vendor.
Adjust the DT2FF offsets in HS400 according to latest information
The M3W up to ES1.2 uses 4 tuning taps for HS400, make it so.
Retain the SMPCMP value from last calibration in private data.
This will be later used for skipping bad taps.
Retain the tap number from last calibration in private data. This
will be later used for SCC error checking after each command.
The clock.h was to define mxc_get_clock() providing clock value
to fsl_esdhc driver. Since fsl_esdhc driver is using global data
gd->arch.sdhc_clk directly now, we can remove this file.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Although layerscape platforms reuse mxc_get_clock() of i.MX platforms,
eSDHC clock getting do not have to use it. It uses global data
gd->arch.sdhc_clk directly in fsl_esdhc driver. Even there are more
than one eSDHC controllers on SoC, they use same reference clock.
The board_mmc_init() defined in board files is actually
doing same thing with the cpu_mmc_init() defined in
arch/arm/cpu/armv7/ls102xa/cpu.c. So drop it.
This patch is to get clock directly from global data.
- Remove uclass clk api method. This was what i.MX platforms were
using, while QorIQ platforms weren't.
- Get clock only from global data, dropping mxc_get_clock().
QorIQ eSDHC controllers on one silicon use same reference clock.
sdhci_get_cd() is not referenced anywhere else. Limit its scope to
sdhci.c.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
