2018-07-10Makefile: drop unused cpp_cfg macroBaruch Siach
Commit e19b0fb4851f (kbuild: generate u-boot.cfg as a byproduct of include/autoconf.mk) removed the use of the cpp_cfg macro in Makefile, but forgot to remove its definition. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-10omap3_logic: Change console from ttyO0 to ttyS0Adam Ford
Newer kernels have moved from ttyO0 to ttyS0, and when booting it drops a notice: WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' This ensures that you still see kernel messages. Please update your kernel commandline. This patch updates the console to use ttyS0 and eliminate the chatter. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-10common: print \n in initr_scsi()Heinrich Schuchardt
Typically init_scsi() does not output anything. So initr_scsi() should provide a \n or we may see borked output like SCSI: Net: No ethernet found. as observed with sandbox_defconfig. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-10gpio: omap_gpio: Convert to auto-alloc feature when DT is supportedAdam Ford
The omap_gpio driver has a TODO that says when every board is converted to DM and DT, the omap_gpio_bind can stop using calloc and switch to auto-alloc. This patch converts this driver to auto-calloc when DT is enabled. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-10vboot: Do not use hashed-strings offsetTeddy Reed
The hashed-strings signature property includes two uint32_t values. The first is unneeded as there should never be a start offset into the strings region. The second, the size, is needed because the added signature node appends to this region. See tools/image-host.c, where a static 0 value is used for the offset. Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-10vboot: Add FIT_SIGNATURE_MAX_SIZE protectionTeddy Reed
This adds a new config value FIT_SIGNATURE_MAX_SIZE, which controls the max size of a FIT header's totalsize field. The field is checked before signature checks are applied to protect from reading past the intended FIT regions. This field is not part of the vboot signature so it should be sanity checked. If the field is corrupted then the structure or string region reads may have unintended behavior, such as reading from device memory. A default value of 256MB is set and intended to support most max storage sizes. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
2018-07-10spl: fit: verify images prior to post processingBen Whitten
Verification of hashes needs to take place before any image post processing, thus matching full FIT image processing. This allows mechanisms such as encryption be applied to images prior to fit generation at the spl level. Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com>
2018-07-10configs: Remove empty #ifdef/#ifndef blocks from configsAlex Kiernan
Remove empty #ifdef/#ifndef..#endif blocks where the configuration they guarded has been completely removed. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-07-10spl: fit: Fix support for loading FPGA bitstreamMarek Vasut
Move the FPGA loading from IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP) conditional. The FPGA loading can be used without OS loading and GZIP support in SPL. This issue was most likely induced by some merge conflict, so fix it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2018-07-10spl: spi: Support full fitImage handlingMarek Vasut
Handle the case where the full fitImage support is enabled. In this case, the whole fitImage must be loaded up front as some parts of the fitImage code require memory-mapped access to the entire fitImage. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org>
2018-07-10spl: fat: Support full fitImage handlingMarek Vasut
2018-07-10fit: Verify all configuration signaturesMarek Vasut
Rather than verifying configuration signature of the configuration node containing the kernel image types, verify all configuration nodes, even those that do not contain kernel images. This is useful when the nodes contain ie. standalone OSes or U-Boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-10Merge git://git.denx.de/u-boot-dmTom Rini
2018-07-09net: designware: Add reset ctrl to driverLey Foon Tan
Add code to reset all reset signals as in Ethernet DT node. A reset property is an optional feature, so only print out a warning and do not fail if a reset property is not present. If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-09serial: ns16550: Add reset ctrl to driverLey Foon Tan
Add code to reset all reset signals as in serial DT node. A reset property is an optional feature, so do not fail if a reset property is not present. If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09mmc: dwmmc: socfpga: Add reset ctrl to driverLey Foon Tan
Add code to reset all reset signals as in mmc DT node. A reset property is an optional feature, so only print out a warning and do not fail if a reset property is not present. If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09include: reset: Change to use CONFIG_IS_ENABLED(DM_RESET)Ley Foon Tan
Change to use CONFIG_IS_ENABLED(DM_RESET), so this can work in SPL build (CONFIG_SPL_DM_RESET) and U-boot build (CONFIG_DM_RESET). Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09reset: Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESETLey Foon Tan
Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESET, so can use CONFIG_IS_ENABLED(DM_RESET) checking in reset.h later. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09MAINTAINERS: Add entries for Actions Semi OWL familyManivannan Sadhasivam
Add myself as the Maintainer for Actions Semi OWL family and its relevant board, drivers. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09serial: Add Actions Semi OWL UART supportManivannan Sadhasivam
This commit adds Actions Semi OWL family UART support. This driver relies on baudrate configured by primary bootloaders. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09arm: dts: bubblegum_96: Enable UART5 for serial consoleManivannan Sadhasivam
This commit enables UART5 found in S900 SoC for serial console support. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09arm: dts: s900: Add UART nodeManivannan Sadhasivam
This commit adds UART node for Actions Semi S900 SoC. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09clk: Add Actions Semi OWL clock supportManivannan Sadhasivam
This commit adds Actions Semi OWL family base clock and S900 SoC specific clock support. For S900 peripheral clock support, only UART clock has been added for now. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09arm: dts: s900: Add Clock Management Unit (CMU) nodesManivannan Sadhasivam
This commit adds Clock Management Unit (CMU) nodes for Actions Semi S900 SoC. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09dt-bindings: clock: Add S900 CMU register definitionsManivannan Sadhasivam
This commit adds Actions Semi S900 CMU register definitions to clock bindings. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09board: Add uCRobotics Bubblegum-96 board supportManivannan Sadhasivam
This commit adds uCRobotics Bubblegum-96 board support. This board is one of the 96Boards Consumer Edition platform based on Actions Semi S900 SoC. Features: - Actions Semi S900 SoC (4xCortex A53, Power VR G6230 GPU) - 2GiB RAM - 8GiB eMMC, uSD slot - WiFi, Bluetooth and GPS module - 2x Host, 1x Device USB port - HDMI - 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons U-Boot will be loaded by ATF at EL2 execution level. Relevant driver support will be added in further commits. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09arm: Add support for Actions Semi OWL SoC familyManivannan Sadhasivam
This commit adds Actions Semi OWL SoC family support with S900 as the first target SoC. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-07-09configs: Resync with savedefconfigTom Rini
2018-07-09binman: Support updating the device tree with calc'd infoSimon Glass
It is useful to write the position and size of each entry back to the device tree so that U-Boot can access this at runtime. Add a feature to support this, along with associated tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Add a SetCalculatedProperties() methodSimon Glass
Once binman has packed the image, the position and size of each entry is known. It is then possible for binman to update the device tree with these positions. Since placeholder values have been added, this does not affect the size of the device tree and therefore the packing does not need to be performed again. Add a new SetCalculatedProperties method to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Add a ProcessFdt() methodSimon Glass
Some entry types modify the device tree, e.g. to remove microcode or add a property. So far this just modifies their local copy and does not affect a 'shared' device tree. Rather than doing this modification in the ObtainContents() method, and a new ProcessFdt() method which is specifically designed to modify this shared device tree. Move the existing device-tree code over to use this method, reducing ObtainContents() to the goal of just obtaining the contents without any processing, even for device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Complete documentation of stagesSimon Glass
At present one of the stages is badly numbered and not described. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Add functions to add integer propertiesSimon Glass
Add a few simple functions to add a placeholder integer property, and set its value. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Avoid unwanted output during testsSimon Glass
At present some warnings are printed to indicate failures which are a known part of running the tests. Suppress these. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09test: Enable cover-coverage tests for dtoc and fdtSimon Glass
Now that we have 100% code coverage we can enable these tests in the test script also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Increase code coverage to 100%Simon Glass
Add more tests to increase dtoc code coverage to 100%. Correct a whitespace error in some test .dts files at the same time. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Move capture_sys_output() to test_utilSimon Glass
This function is useful in various tests. Move it into the common test utility module. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Add a test for code coverageSimon Glass
Add a -T option to run a code-coverage test on dtoc. At present this is about 96%. Future work will increase it to 100%. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Fix some minor errorsSimon Glass
Fix some comments and a printf string which is incorrect. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Fix properties with a single zero-arg phandleSimon Glass
At present a property with a single phandle looks like an integer value to dtoc. Correct this by adjusting it in the phandle-processing code. Add a test for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Fix Fdt.GetNode() to handle a missing nodeSimon Glass
At present the algortihm is not correct since it will return the root node if the requested node is not found and there are no slashes in the requested node name. Fix this and add a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Keep track of property offsetsSimon Glass
At present the Fdt class does not keep track of property offsets if they change due to removal of properties. Update the code to handle this, and add a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Update fdt tests to increase code coverageSimon Glass
At present only some of the fdt functionality is tested. Add more tests to cover the rest of it. Also turn on test coverage, which is now 100% with a small exclusion for a Python 3 feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Drop use of a local dtb bufferSimon Glass
At present the Fdt class has its own copy of the device tree. This is confusing an unnecessary now that pylibfdt has its own. Drop it and provide access functions to the buffer. This allows us to move the rest of the implementation to use pylibfdt methods instead of directly calling libfdt stubs. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Make use of the new pylibfdt methodsSimon Glass
Now that pylibfdt supports a fuller API we don't need to directly call the libfdt stubs. Update the code to use the Fdt methods instead. Some other cases remain which will be tidied up in a later commit, since they need larger changes. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Update tests to write failures to /tmpSimon Glass
When a test fails due to an output mismatch (e.g. due to a new property being adding to a test file) it is currently hard to update the test to the new output. In particular the tabs in the file are written as \t in the Python tests. To make this easier, write both the expected and actual results to /tmp to allow use of meld, and copying into the test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09dtoc: Add some tests for the fdt moduleSimon Glass
At present this module is tested via the dtoc tests. This is a bit painful since the tests are at a higher level and so failures are more difficult to diagnose. Add some tests that exercise the fdt module directly. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Move coverage logic into a new test_util fileSimon Glass
At present only binman has the logic for determining Python test coverage but this is useful for other tools also. Move it out into a separate file so it can be used by other tools. Signed-off-by: Simon Glass <sjg@chromium.org>
