Add IPUv3 framebuffer support for Engicam i.CoreM6 qdl board.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Added kconfig entry for CONFIG_VIDEO_IPV3 driver.
Use CONFIG_DM_ETH and remove board_eth_init code
from board files.
Cc: Peng Fan <peng.fan@nxp.com>
Add FEC dts support for Engicam i.CoreM6 dql modules.
Add .read_rom_hwaddr on dm eth_ops.
- Remove exctra space
- Add space
- Add tab space
- Fix single line comments quotes
- Fix 'CHECK: Avoid CamelCase'
- Fix 'CHECK: Alignment should match open parenthesis'
- Fix 'WARNING: line over 80 characters'
- Re-arrage header include files
This patch add driver model support for fec_mxc driver.
fec_get_hwaddr never used eth_device argument, hence removed.
Add CX9020 board based on mx53loco.
Add simplified imx53 base device tree from kernel v4.8-rc8, to reuse
serial_mxc with DTE and prepare for device tree migration of other
functions and imx53 devices.
The CX9020 differs from i.MX53 Quick Start Board by:
- use uart2 instead of uart1
- DVI-D connector instead of VGA
- no audio
- CCAT FPGA connected to emi
- enable rtc
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Add plugin support for mx6sllevk board.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add i.MX6SLL EVK board support.
1. Add imx6sll-evk device tree.
2. Enable SDHC/I2C/UART.
3. Enable REGULATOR/PMIC/I2C/GPIO/SDHC/PINCTRL driver.
Boot Log:
U-Boot 2016.11-00127-gc635871-dirty (Nov 24 2016 - 13:28:19 +0800)
CPU: Freescale i.MX6SLL rev1.0 at 792MHz
CPU: Commercial temperature grade (0C to 95C)Reset cause: POR
Model: Freescale i.MX6SLL EVK Board
Board: MX6SLL EVK
DRAM: 2 GiB
i2c bus 0 at 35258368, no gpio pinctrl state.
PMIC: PFUZE100! DEV_ID=0x10 REV_ID=0x21
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
Add i.MX6SLL device tree.
There two iomuxc for i.MX6SLL. One is normal IOMUXC, the other
is for IOMUXC_SNVS.
Update lcdif regs for i.MX6SL/SLL
Signed-off-by: Ye.Li <ye.li@nxp.com>
Add the i.MX6SLL support to OCOTP driver.
The i.MX6SLL reuses the i.MX6ULL fuse, bank 7 and bank8 have 4 words
each, and there is a hole between bank 5 and bank 6.
Signed-off-by: Ye Li <ye.li@nxp.com>
Correct loadaddr and text base for i.MX6SLL
add Kconfig entry for i.MX6SLL
If L2 cache configured as OCRAM, reset it.
Switch to use runtime check.
Add clock support for i.MX6SLL.
The LCDIF Pixel clock mux is not glitchless, so need
to gate before changing mux.
Also change enable_lcdif_clock prototype with a new input
parameter to indicate disable or enable.
Add lcdif clock support for i.MX6SL.
The mux for the lcd clock is not glitchless,
so need to first gate the clock before changing the mux.
>From RM, per_periph2_clk_sel option3 is:
"derive clock from 198MHz clock (divided 392MHz PLL2 PFD)."
So fix it.
Add iomux settings for i.MX6 SLL
Add i.MX6 SLL GPT timer support.
Update register address for i.MX6 SLL
Add i.MX6SLL pinmux header files
Add i.MX6SLL cpu type.
MXC_CPU_MX6D is not a real value in chip, so change it to 0x6A.
u-boot allows modifying a device tree after it is loaded into
memory. Add fdt_fixup hook in u-boot environment which can
facilitate such modifications.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
liteBoard is a development board which uses liteSOM as its base.
Hardware specification:
* liteSOM (i.MX6UL, DRAM, eMMC)
* Ethernet PHY (id 0)
* USB host (usb_otg1)
* MicroSD slot (uSDHC1)
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
liteSOM is a System On Module (http://grinn-global.com/litesom/). It
can't exists on its own, but will be used as part of other boards.
* NXP i.MX6UL processor
* 256M or 512M DDR3 memory
* optional eMMC (uSDHC2)
Here we treat SOM similar to SOC, so we place it inside arch/arm/mach-*
directory and make it possible to reuse initialization code (i.e. DDR,
eMMC init) for all boards that use it.
UDOO Neo boards has one FEC port connected to KSZ8091, add support for it.
Tested on a UDOO Neo Full with "dhcp zImage" command.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
UDOO Neo boards has a PFUZE300 connected to I2C1 bus.
Tested on a UDOO Neo Full with "pmic PFUZE3000 dump" command.
Add pfuze3000 voltage configuration macro for SW1AB, SW3 and VLDO1/2 according
to tables 53, 57 and 62 on PF3000 datasheet.
Add thermal support on the Kconfig file.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
It's not necessary to define the console option as we use the distro config.
It's not necessary to define the mmcautodetect as it is not used anywhere.
Change board_string() function to static because it's being used locally.
It's not necessary to define the processor in the defconfig file.
The preferred method to select the SoC is via Kconfig file.
It's not necessary to support USDHC3 in U-Boot as it's being used for
the WLAN.
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
Add proper reg values for the two AIPS bus nodes. This avoids this
two warnings:
Node /soc/aips-bus@40000000 has a unit name, but no reg property
Node /soc/aips-bus@40080000 has a unit name, but no reg property
Currently a divider of 6 has been used, leading to following NAND
Flash Controller (NFC) clocks:
VF61: 27.7 MHz (166.7MHz bus clock)
VF50: 22 MHz (132MHz bus clock)
The NAND Flash Memory used on VF50 allows to use clock speed of
up to 33MHz, while the Flash Memory of VF61 allows 50MHz. We can
use the same divider of 4 on both modules to configure the maximal
possible clock speeds:
VF61: 41.7 MHz
VF50: 33 MHz
Use the same preprocessor define to enable clocks as we use to
enable the driver. Make sure that the necessary PLL's are on
(they get enabled by boot ROM by default, so this is more for
completness).
Use device-tree fixup to communicate the MTD partitions to the
kernel. U-Boot's mtdparts environment variable will be used as
partition source for the device-tree based partition table too.
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
Use the proper config option to guard the USB Download Function
fixup callback.
Despite I leave Samsung by the end of the year, I'm going to maintain DFU
in u-boot.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
