2017-04-30Drop the pdsp188x driverSimon Glass
This is not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30powerpc: Drop configs/manrolandSimon Glass
This is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_DISPLAY to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DISPLAY Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Kconfig: Drop CONFIG_CMD_DFLSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_DEKBLOB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DEKBLOB Note: This option does not seem to actually be enabled by any board. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply under SECURE_BOOT for mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Kconfig: Drop CONFIG_CMD_DEFAULTENV_VARSSimon Glass
This option does not exist in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_CLK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CLK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CLK on ARCH_ZYNQ] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Drop CONFIG_CMD_CLEARSimon Glass
2017-04-30Convert CONFIG_CMD_CHIP_CONFIG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CHIP_CONFIG Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30fs: Kconfig: Add a separate config for FS_CBFSSimon Glass
Rather than using CMD_CBFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CBFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CBFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CBFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_BSP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BSP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_BLOB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BLOB Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add imply CMD_BLOB under CHAIN_OF_TRUST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_BEDBUG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BEDBUG Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_BAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30ti816x_evm: Change CONFIG_CMD_ASKEN to CONFIG_CMD_ASKENVSimon Glass
This looks like a typo. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_AES et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_AES CONFIG_AES Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add select AES to CMD_AES] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30power: Drop CONFIG_PMICSimon Glass
2017-04-30power: Drop CONFIG_I2C_PMICSimon Glass
This is only used by one board and should not be a CONFIG option. Instead it should use the driver model pmic framework. For now, just move the setting into the only board that uses it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Move as3722 pmic to pmic/ directorySimon Glass
Most of the PMICs are in the drivers/power/pmic/ directory. Move this one there. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Rename CONFIG_AS3722_POWER to CONFIG_PMIC_AS3722Simon Glass
Before converting this to Kconfig, rename it to match the other PMICs. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30arm: Re-sync ARCH_MX5 / MX51 / MX53 CONFIG optionsTom Rini
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 / CONFIG_MX53 being in Kconfig. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27Merge tag 'xilinx-fixes-for-v2017.05' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx fixes for v2017.05 - Fix usbotg on Miami board - Cleanup zc1751 defconfig
2017-04-27ext4: Fix comparision of unsigned expression with < 0Lokesh Vutla
In file ext4fs.c funtion ext4fs_read_file() compares an unsigned expression with < 0 like below lbaint_t blknr; blknr = read_allocated_block(&(node->inode), i); if (blknr < 0) return -1; blknr is of type ulong/uint64_t. read_allocated_block() returns long int. So comparing blknr with < 0 will always be false. Instead declare blknr as long int. Similarly ext4/dev.c does a similar comparison. Drop the redundant comparison. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27MAINTAINERS: Update for Keystone2 secure devicesLokesh Vutla
Update Keystone2 secure device configs under "TI SYSTEM SECURITY". Without this buildman keeps complaining about the status of these boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Andrew F. Davis <afd@ti.com>
2017-04-27arm/lib/bootm.c: keep ARM v7M in thumb mode during boot_jump_linux()Patrice Chotard
On ARM v7M, the processor will return to ARM mode when executing a blx instruction with bit 0 of the address == 0. Always set it to 1 to stay in thumb mode. Tested on STM32f746-disco board Similar commit: f99993c10882f7dc8ec35993d5febe59aac01e6a Author: Matt Porter <mporter@konsulko.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27add Kconfig for fsuuid commandJosua Mayer
CONFIG_CMD_FS_UUID was neither whitelisted, nor was it declared in Kconfig. Now it can be enabled in .config and defconfig as expected. Signed-off-by: Josua Mayer <josua.mayer97@gmail.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27travisci: Add support for ARCAlexey Brodkin
Finally adding support for ARC boards in TravisCI. To build for ARC boards we need to install Synopsys prebuilt toolchain which we do here. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27board: dra71: Fix selection of OPPsLokesh Vutla
As per the DM[1] Dated June 2016–Revised February 2017, Table 5-3, DRA71 supports the following OPPs for various voltage domains: VDD_MPU: OPP_NOM VDD_CORE: OPP_NOM VDD_GPU: OPP_NOM VDD_DSPEVE: OPP_NOM, OPP_HIGH VDD_IVA: OPP_NOM, OPP_HIGH This patch add support for selection of the above OPPs instead of using OPP_NOM for all voltage domains. [1] http://www.ti.com/lit/ds/symlink/dra718.pdf Reported-by: Vishal Mahaveer <vishalm@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-27rockchip: mkimage: remove (left-over) assignment w/o effect [coverity]Philipp Tomsich
An assignment (of a value to itself) was left over (after removing and addition from the line) from moving the common padding code into rkcommon_vrec_header. This change removes this to avoid a spurious warning in static code analysis (i.e. Coverity). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reported-by: Coverity (CID: 161418) Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27clean-up: Remove uselsess mentions of CONFIG_COMMAND_HISTORYAlexey Brodkin
These were reminders that somehow slipped through the cracks or were erroneously introduced after previous clean-ups. Getting rid of then once again. Hopefully for good now :) Where missing and appropriate replace with CONFIG_CMDLINE_EDITING which really enables shell history as of now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Peter Griffin <peter.griffin@linaro.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Jon Mason <jon.mason@broadcom.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-27arm: Warn that starting with v2018.01 gcc-6 or later is requiredTom Rini
There are more and more cases where if we do not use gcc-6.0 or later we run into problems where our binaries are too large for the targets. Given the prevalence of gcc-6.0 or later toolchains at this point in time, we give notice now that starting with v2018.01 we will require gcc-6 (or later) for ARM. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27dm: sandbox: pwm: Add a basic pwm testSimon Glass
Unfortunately a test for the PWM uclass was not included when it was submitted. This was noticed when trying to add more functionality: http://patchwork.ozlabs.org/patch/748172/ Add a simple test to get us started. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27OMAP3: Correct name of omap34xx_gpios when using DM_GPIOAdam Ford
The name of the gpio bank under DM_GPIO appear to be a copy-paste error. This changes the name of the gpio bank from am33xx_gpios to omap34xx_gpios. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27omap3: i2c: correct registerAdam Ford
The register names and offset were not correct as per the TRM for OMAP3530 and OMAP3630. Correct the naing and offsets per the documentation Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-04-27arm64: zynqmp: Sync defconfig with KconfigMichal Simek
Remove option which depends on MMC controller which is disabled for dc2. Savedefconfig is removing it because of new dependencies. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-04-27zynq-topic-miami.dts: Add usbotg0 alias to make USB actually workMike Looijmans
Fixes the following problem: zynq-uboot> run dfu_ram Setting bus to 1 g_dnl_register: failed!, error: -19 The cause appears to be that the USB framework is looking for a usbotg aliases, so add the alias to point to our USB device. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-04-25Merge git://git.denx.de/u-boot-sunxiTom Rini
