2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04printk: collect printk stuff into <linux/printk.h> with loglevel supportMasahiro Yamada
When we import code from Linux, with regular re-sync planned, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts. We have include/linux/compat.h, but putting all sorts of unrelated things into a single header is just a temporal workaround. Hence this patch, to find the best home for all printk variants. If you want to use printk() and friends, please include <linux/printk.h>. This header is self-contained, and pulls in only a few headers. When I was testing this clean-up, I noticed the image size exceeded its platform limit on some boards. This is because all pr_*() that were previously defined as no-op in include/linux/mtd/mtd.h (unless CONFIG_MTD_DEBUG is set), are now enabled. To make such boards happy, this commit also implements CONFIG_LOGLEVEL. The concept is similar to the kernel parameter "loglevel". (Actually, the Kconfig help message was taken from kernel-paremeter.txt of Linux) Messages with a loglevel smaller than console loglevel will be printed. The difference is the loglevel is build-time determined. To save the image size, lower priority pr_*() are compiled out. I set the default of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages are compiled in. I adjusted CONFIG_LOGLEVEL to avoid build error for some boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04stdio.h: move printf() stuff from <common.h> to <stdio.h>Masahiro Yamada
<common.h> pulls in a lot of headers. Including it from every .c file is a bad idea. We need to remove contents until it contains nothing. Move printf() and friends to <stdio.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-03sandbox: Enable btrfs supportTom Rini
For better test coverage, enable btrfs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03fs/btrfs: Fix warning in btrfs_check_super()Tom Rini
We specifically say that the last arg is u32, so use %lu. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02sandbox: Use asm-generic/io.hPaul Burton
Convert the sandbox architecture to make use of the new asm-generic/io.h to provide address mapping functions. As sandbox actually performs non-identity mapping between physical & virtual addresses we can't simply make use of the generic mapping functions, but are able to implement phys_to_virt() & make use of it from map_physmem(). Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2017-10-02powerpc: Use asm-generic/io.hPaul Burton
Convert the powerpc architecture to make use of the new asm-generic/io.h to provide address mapping functions. As powerpc can actually perform non-identity mapping between physical & virtual addresses we can't simply make use of the generic phys_to_virt() & virt_to_phys() functions. However since map_physmem() already effectively implemented the same thing as virt_to_phys() we can simply implement virt_to_phys() instead of map_physmem() & use the generic map_physmem(). We also drop the no-op unmap_physmem(). This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Wolfgang Denk <wd@denx.de>
2017-10-02nios2: Use asm-generic/io.hPaul Burton
Convert the nios2 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As nios2 actually performs non-identity mapping between physical & virtual addresses we can't simply make use of the generic functions, with the exception of being able to drop our no-op unmap_physmem() and definitions of unused map flags. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Thomas Chou <thomas@wytron.com.tw>
2017-10-02mips: Use asm-generic/io.hPaul Burton
Convert the mips architecture to make use of the new asm-generic/io.h to provide address mapping functions. As mips actually performs non-identity mapping between physical & virtual addresses we can't simply make use of the generic functions, with the exception of being able to drop our no-op unmap_physmem() and definitions of unused map flags. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-10-02xtensa: Use asm-generic/io.hPaul Burton
Convert the xtensa architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for xtensa this is primarily a matter of moving code. This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com>
2017-10-02x86: Use asm-generic/io.hPaul Burton
Convert the x86 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for x86 this is primarily a matter of moving code. This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-02sh: Use asm-generic/io.hPaul Burton
Convert the sh architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for sh this is primarily a matter of moving code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-10-02nds32: Use asm-generic/io.hPaul Burton
Convert the nds32 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for nds32 this is primarily a matter of removing code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Macpaul Lin <macpaul@andestech.com>
2017-10-02microblaze: Use asm-generic/io.hPaul Burton
Convert the microblaze architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for microblaze this is primarily a matter of removing code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Michal Simek <monstr@monstr.eu>
2017-10-02m68k: Use asm-generic/io.hPaul Burton
Convert the m68k architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for m68k this is primarily a matter of emoving code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Huan Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it> Acked-by: Angelo Dureghello <angelo@sysam.it> Tested-by: Angelo Dureghello <angelo@sysam.it>
2017-10-02arm: Use asm-generic/io.hPaul Burton
Convert the arm architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for arm this is primarily a matter of removing code. This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-02arc: Use asm-generic/io.hPaul Burton
Convert the arc architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for arc this is primarily a matter of removing code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Alexey Brodkin <alexey.brodkin@synopsys.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-10-02Provide a generic io.h & address mapping functionsPaul Burton
Most architectures currently supported by U-Boot use trivial implementations of map_to_physmem & virt_to_phys which simply cast a physical address to a pointer for use a virtual address & vice-versa. This results in a lot of duplicate implementations of these mapping functions. The set of functions provided by different architectures also differs, with some having implementations of phys_to_virt & others not. A later patch will make use of phys_to_virt in architecture-neutral code, and so requires that it be provided for all architectures. This patch introduces an asm-generic/io.h which provides generic implementations of address mapping functions, allowing the duplication of them between architectures to be removed. Once architectures are converted to make use of this generic header it will also ensure that all of phys_to_virt, virt_to_phys, map_physmem & unmap_physmem are provided. The 2 families of functions differ in that map_physmem may create dynamic mappings whilst phys_to_virt may not & therefore is more limited in scope but doesn't require information such as a length & flags. This patch doesn't convert any architectures to make use of this generic header - later patches in the series will do so. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Alexey Brodkin <alexey.brodkin@synopsys.com> Cc: Angelo Dureghello <angelo@sysam.it> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Angelo Dureghello <angelo@sysam.it> Tested-by: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-10-02mvebu: turris_omnia: Add CONFIG_CMD_BTRFS to defconfigMarek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-02cmd: Add the 'btrsubvol' command to list BTRFS subvolumesMarek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 cmd/btrfs.c
2017-10-02fs: btrfs: Add U-Boot fs handlers.Marek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/Kconfig create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h
2017-10-02fs: btrfs: Add single-device read-only BTRFS implementationMarek Behún
This adds the proper implementation for the BTRFS filesystem. The implementation currently supports only read-only mode and the filesystem can be only on a single device. Checksums of data chunks is unimplemented. Compression is implemented (ZLIB + LZO). Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs.h create mode 100644 fs/btrfs/chunk-map.c create mode 100644 fs/btrfs/compression.c create mode 100644 fs/btrfs/ctree.c create mode 100644 fs/btrfs/dev.c create mode 100644 fs/btrfs/dir-item.c create mode 100644 fs/btrfs/extent-io.c create mode 100644 fs/btrfs/hash.c create mode 100644 fs/btrfs/inode.c create mode 100644 fs/btrfs/root.c create mode 100644 fs/btrfs/subvolume.c create mode 100644 fs/btrfs/super.c
2017-10-02fs: btrfs: Add disk-to-cpu and cpu-to-disk conversion functionsMarek Behún
BTRFS on disk structures are stored in Little Endian. Add functions to convert this structures to cpu and to disk format. On Little Endian hosts, these functions do nothing. On Big Endian the CALL_MACRO_FROM_EACH from variadic-macro.h is used to define all the members for each structure on which cpu_to_le* or le*_to_cpu is to be called. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/conv-funcs.h
2017-10-02fs: btrfs: Add btrfs_tree.h and ctree.h from Linux (and modified)Marek Behún
Add btrfs_tree.h and ctree.h from Linux which contains constants and structures for the BTRFS filesystem. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs_tree.h create mode 100644 fs/btrfs/ctree.h
2017-10-02include: Add a variadic macro to call a callback for all argumentsMarek Behún
Add a header variadic-macro.h which defines the CALL_MACRO_FOR_EACH marco. This macro can be used as follows: #define TEST(x) CALL_MACRO_FOR_EACH(TEST, a, b, c, d) This will expand to TEST(a) TEST(b) TEST(c) TEST(d) The nice thing is that CALL_MACRO_FOR_EACH is a variadic macro, thus the number of arguments can vary (although it has an upper limit - in this implementation 32 arguments). Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 include/u-boot/variadic-macro.h
2017-10-02fs: Create a common fs_devread for ext4/reiserfs/zfsMarek Behún
The ext4, reiserfs and zfs filesystems all have their own implementation of the same function, *_devread. Generalize this function into fs_devread and put the code into fs/fs_internal.c. Signed-off-by: Marek Behun <marek.behun@nic.cz> [trini: Move fs/fs_internal.o hunk to the end of fs/Makefile as all cases need it] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02lib: Add CRC32-CMarek Behún
This is needed for BTRFS. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 lib/crc32c.c
2017-10-02Prepare v2017.11-rc1Tom Rini
2017-10-02scripts: dtc: Add .gitignoreBin Meng
Ignore these generated files during the build of dtc. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01Merge git://git.denx.de/u-boot-usbTom Rini
2017-10-01Merge git://git.denx.de/u-boot-rockchipTom Rini
2017-10-01usb: dwc3: add UniPhier specific glue layerMasahiro Yamada
Add UniPhier platform specific glue layer to support USB3 Host mode on Synopsys DWC3 IP. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-10-01usb: storage: Fix overwritten in usb_stor_set_max_xfer_blk()Bin Meng
The stored 'blk' value is overwritten to 'size / 512' before it can be used in usb_stor_set_max_xfer_blk(). This is not what we want. In fact, when 'size' exceeds the upper limit (USHRT_MAX * 512), we should simply assign 'size' to the upper limit. Reported-by: Coverity (CID: 167250) Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Set 'Average TRB Length' to 8 for control endpointsBin Meng
Update the codes to conform with xHCI spec chapter 6.2.3. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Set 'Error Count' to 0 for isoch endpointsBin Meng
Per xHCI spec, 'Error Count' should be set to 0 for isoch endpoints. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Program max burst size for endpointBin Meng
The 'Max Burst Size' indicates to the xHC the maximum number of consecutive USB transactions that should be executed per scheduling opportunity. This is a “zero-based” value, where 0 to 15 represents burst sizes of 1 to 16, but at present this is always set to zero. Let's program the required value according to real needs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Honor endpoint's intervalBin Meng
USB endpoint reports the period between consecutive requests to send or receive data as bInverval in its endpoint descriptor. So far this is ignored by xHCI driver and the 'Interval' field in xHC's endpoint context is always programmed to zero which means 1ms for low speed or full speed , or 125us for high speed or super speed. We should honor the interval by getting it from endpoint descriptor. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: hub: Clear BH reset status change for a 3.0 hubBin Meng
USB 3.0 hubs report bit[5] in the port status change response as BH reset. The hub shall set the C_BH_PORT_RESET field for this port. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: hub: Clear port reset before usb_hub_port_connect_change()Bin Meng
During usb_hub_port_connect_change(), a port reset set feature request is issued to the port, and later a port reset clear feature is done to the same port before the function returns. However at the end of usb_scan_port(), we attempt to clear port reset again on a cached port status change variable, which should not be done. Adjust the call to clear port reset to right before the call to usb_hub_port_connect_change(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Fix max packet size for full speed device endpoint 0Bin Meng
In xhci_check_maxpacket(), the control endpoint 0 max packet size is wrongly taken from the interface's endpoint descriptor. However the default endpoint 0 does not come with an endpoint descriptor hence is not included in the interface structure. Change to use epmaxpacketin[0] instead. The other bug in this routine is that when setting max packet size to the xHC endpoint 0 context, it does not clear its previous value at all before programming a new one. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: Read device descriptor after device is addressed for xHCIBin Meng
For xHCI it is not possible to read a device descriptor before it has been assigned an address. That's why usb_setup_descriptor() was called with 'do_read' being false. But we really need try to read the device descriptor before starting any real communication with the default control endpoint. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: Only get 64 bytes device descriptor for full speed devicesBin Meng
Full speed device endpoint 0 can have 8/16/32/64 bMaxPacketSize0. Other speed devices report fixed value per USB spec. So it only makes sense if we send a get device descriptor with 64 bytes to full speed devices. While we are here, update the comment block to be within 80 cols. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Add interrupt transfer supportBin Meng
xHCI uses normal TRBs for both bulk and interrupt. This adds the missing interrupt transfer support to xHCI so that devices like USB keyboard that uses interrupt transfer can work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: Handle audio extension endpoint descriptor in usb_parse_config()Bin Meng
Normal endpoint descriptor size is 7, but for audio extension it is 9. Handle that correctly when parsing endpoint descriptor. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: xhci: Don't assume LS/FS devices are always behind a HS hubBin Meng
At present xHCI driver assumes LS/FS devices are attached directly to a HS hub. If they are connected to a LS/FS hub, the driver will fail to perform the USB enumeration process on such devices. This is fixed by looking from the device itself all the way up to the HS hub where the TT that serves the device is located. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01test: dm: usb: Update test cases for USBBin Meng
Now that we have changed to remove all devices under the root hub in usb_stop(), and corrected the USB emulator select logic, it makes no sense to do various tests based on 'usb tree' output since the order of devices is no longer fixed. Remove these USB test cases related to 'usb tree'. For the USB remove test, ideally we should remove an emulator device node from the device tree, but this is so far not working. Change to test the 'usb stop' only. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01dm: usb: emul: Drop usb_emul_reset()Bin Meng
With the root hub unbinding in usb_stop(), there is no need to do a Sandbox-specific reset operation. usb_emul_reset() is no longer used anywhere, drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01dm: usb: Remove no longer needed blk_unbind_all()Bin Meng
With the root hub unbinding in usb_stop(), there is no need to do a blk uclass specific unbind operation. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01dm: usb: Fix broken usb_stop()Bin Meng
At present we only do device_remove() during usb stop. The DM API device_remove() only marks the device state as inactivated, but still keeps its USB topology (eg: parent, children, etc) in the DM device structure. There is no issue if we only start USB subsystem once and never stop it. But a big issue occurs when we do 'usb stop' and 'usb start' multiple times. Strange things may be observed with current implementation, like: - the enumeration may report only 1 mass storage device is detected, but the total number of USB devices is correct. - USB keyboard does not work anymore after a bunch of 'usb reset' even if 'usb tree' shows it is correctly identified. - read/write flash drive via 'fatload usb' may complain "Bad device" In fact, every time when USB host controller starts the enumeration process, it takes random time for each USB port to show up online, hence each USB device may appear in a different order from previous enumeration, and gets assigned to a totally different USB address. As a result, we end up using a stale USB topology in the DM device structure which still reflects the previous enumeration result, and it may create an exact same DM device name like generic_bus_0_dev_7 that is already in the DM device structure. And since the DM device structure is there, there is no device_bind() call to bind driver to the device during current enumeration process, eventually creating an inconsistent software representation of the hardware topology, a non-working USB subsystem. The fix is to clear the unused USB topology in the usb_stop(), by calling device_unbind() on each controller's root hub device, and the unbinding will unbind all of its children automatically. For Sandbox, we need scan the device tree each time when we start the USB stack, in order to re-create the emulated USB devices and bind drivers for them before we actually do the driver probe. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: emul: hub: Report the actual device speed of the emulation deviceBin Meng
At present the usb hub emulator always reports its downstream port speed as full speed. Actually it is high speed for sandbox-flash, and low speed for sandbox-keyb. We can determine the device speed by checking its device descriptor bcdUSB field, and do the proper hub port status report based on that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
