Now that U-Boot works fine with highmem enabled, there is no need to
tell users to disable highmem.
Now that PCI devices work with highmem-enabled QEMU emulation, bump up
the RAM size in the MMU tables to gain access to the full 255 GB of RAM
potential instead of the puny 3 GB.
Currently, qemu_arm_defconfig and qemu_arm64_defconfig only work with
the 'highmem=off' parameter passed to QEMU's virt machine. The reason is
that when 'highmem' is not disabled, QEMU appends 64-bit a memory
resource to the PCI controller's regions property in DT in addition to
the 32-bit PCI memory window in low memory. And the current DT parsing
code picks the last (thus the 64-bit one) memory resource, whose address
eventually gets silently truncated to 32 bits because
CONFIG_SYS_PCI_64BIT is not set, which obviously causes PCI to break.
Avoid this problem by ignoring memory regions whose addresses are above
the 32-bit boundary when CONFIG_SYS_PCI_64BIT is not set.
Enable the Sandbox TPMv2 driver in all possible configurations.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
This node declares the presence of the Sandbox TPMv2.x emulated chip,
available for testing.
Add Sandbox TPMv2.0 module bindings.
This driver can emulate all the basic functionalities of a TPMv2.x
chip and should behave like them during regular testing.
Add tests for the TPMv2.x commands.
These commands may run both on a physical TPM and with the sandbox
driver.
Add TIS TPMv2.0 SPI module bindings.
On some designs, the reset line could not be connected to the SoC reset
line, in this case, request the GPIO and ensure the chip gets reset.
Add the tpm2_tis_spi driver that should support any TPMv2 compliant
(SPI) module.
Add support for the TPM2_PCR_SetAuthPolicy and
TPM2_PCR_SetAuthValue commands.
Change the command file and the help accordingly.
Note: These commands could not be tested because the TPMs available
do not support them, however they could be useful for someone else.
The user is warned by the command help.
Add support for the TPM2_HierarchyChangeAuth command.
Add support for the TPM2_DictionaryAttackParameters and
TPM2_DictionaryAttackLockReset commands.
Add support for the TPM2_GetCapability command.
Add support for the TPM2_PCR_Read command.
Add support for the TPM2_PCR_Extend command.
Add support for the TPM2_Clear command.
Add support for the TPM2_Selftest command.
Add support for the TPM2_Startup command.
Instead of returning a generic 'library' error, report back the actual
error code so it can be displayed to the user by the regular error path.
When debugging, it is welcome to get more information about what the TPM
returns. Add the possibility to print the packets received to show their
exact content.
TPM commands are much easier to read/write with these macros that will
transform words or integers into byte strings. This way, there is no
need to call pack_byte_string() while all variable length in a command
are known (and at must 4 bytes, which is a lot of them).
Choice between v1 and v2 compliant functions is done with the
configuration.
Create the various files that will receive TPMv2-only code on the same
scheme as for the TPMv1 code.
Both parameters 'duration_ms' and 'retry_time_ms' of the tpm_chip_priv
structure are documented is the comment above the declaration but 'buf'
was forgotten. Add the missing description.
There are no changes in this commit but a new organization of the code
as follow.
* cmd/ directory:
> move existing code from cmd/tpm.c in cmd/tpm-common.c
> move specific code in cmd/tpm-v1.c
> create a specific header file with generic definitions for
commands only called cmd/tpm-user-utils.h
* lib/ directory:
> move existing code from lib/tpm.c in lib/tpm-common.c
> move specific code in lib/tpm-v1.c
the library itself called lib/tpm-utils.h
* include/ directory:
> move existing code from include/tpm.h in include/tpm-common.h
> move specific code in include/tpm-v1.h
Code designated as 'common' is compiled if TPM are used. Code designated
as 'specific' is compiled only if the right specification has been
selected.
All files include tpm-common.h.
Files in cmd/ include tpm-user-utils.h.
Files in lib/ include tpm-utils.h.
Depending on the specification, files may include either (not both)
tpm-v1.h or tpm-v2.h.
[trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic]
Because both major revisions are not compatible at all, let's make them
mutually exclusive in Kconfig. This way we will be sure, when using a
command or a library function that it is supported by the right
revision.
Current drivers are currently prefixed by "tpm_", we will prefix TPMv2.x
files by "tpm2_" to make the distinction without moving everything.
The Kconfig menu about TPM drivers is now divided into two sections, one
for each specification. Compliant drivers with one specification will
only show up if this specification _only_ has been selected, otherwise a
comment is displayed.
Once a driver is selected by the user, it selects automatically a
boolean value, that is needed in order to activate the TPM commands.
Selecting the TPM commands will automatically select the right
command/library files.
[trini: Rework deps as TPM_V1 and TPM_V2 depend on TPM,
drop TPM_DRIVER_SELECTED]
TPM are shipped with a few read-only register from which we can retrieve
for instance:
- vendor ID
- product ID
- revision ID
Product and vendor ID share the same register and are already referenced
in the tpm_chip structure. Add the revision ID entry which is missing.
Fix following checkpatch.pl issue in TPM-related code:
WARNING: Missing a blank line after declarations
Fix following checkpatch.pl issues in TPM-related code:
CHECK: '<x>' may be misspelled - perhaps '<y>'?
CHECK: Prefer using the BIT macro
CHECK: Alignment should match open parenthesis
CHECK: Prefer kernel type 'u8' over 'uint8_t'
CHECK: Prefer kernel type 'u16' over 'uint16_t'
CHECK: Prefer kernel type 'u32' over 'uint32_t'
WARNING: space prohibited between function name and open
parenthesis '('
CHECK: Please don't use multiple blank lines
Add support for DEBUG_UART on ARC devboards
This required us to do 2 things:
1) Insert a call to debug_uart_init() in early boot code
2) Convert serial_arc to Kconfig
Once both items above are done we just patched defconfigs.
Patch queue for rpi - 2018-05-24
Some minor fixes for the Raspberry Pi:
- Fix SD writes on new sdhost controller
- Sanitize default load addresses, allowing for better payload placement
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
One step closer to completely Kconfig-driven target configuration in
U-Boot :)
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
The debug UART is intended for use very early in U-Boot to debug
problems before serial drivers are up.
Call debug_uart_init right before board_init_f.
As of Linux 4.16, a multiplatform AArch64 kernel with our distro config
takes 26M. The current space reservation leaves only 17M for the kernel
and if it goes over it, the initrd gets overwritten when loading the
kernel from the filesystem.
A similar problem happens on ARMv7 with the DTBs taken from the
downstream Raspberry Pi foundation kernel. I guess they compile them
with DT overlay support enabled which grows them just enough.
Fix both of these problems by rewriting the memory map, which now allows
kernels to be up to 36M and DTBs up to 1M. Also the comment block was
kind of obsolete ever since the introduction of AArch64 support and the
firmware-loaded DTB doesn't get placed at 0x100 anymore either, so that
is fixed as well.
Add support for loading U-Boot and optionally FDT from a fitImage
in SPL by using the full fitImage support from U-Boot. While we do
have limited SPL loading support in SPL with a small footprint, it
is missing a lot of important features, like checking signatures.
This support has all the fitImage features, while the footprint is
obviously larger.
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Add missing CC and LDSHARED variables to the Makefile to pass the
correct C compiler and linker path to the build of _libfdt.so .
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The script decodecode can be used to disassemble the 'Code:' line written
when an exception occurs.
The script is copied from Linux v4.16.
If an exception occurs in a loaded image and the relocation offset is
unknown, it is helful to know the instructions pointed to by the
program counter. This patch adds the missing output.
A possible output is:
Code: e1c560d0 e12fff1e e120077b e12fff1e (e7f7defb)
The parentheses indicate the instruction causing the exception.
The output can be disassembled using the decodecode script provided
by the Linux kernel project.
Implement timer_get_boot_us() based on available functions to support
bootstage command.
Following the conversion of the SPDX license tags, a number of files
compiled with -pedantic now generate warnings similar to the following
for using C99-style '//' comments in ISO C90 code:
tools/gen_eth_addr.c:1:1: warning: C++ style comments are not allowed in ISO C90
// SPDX-License-Identifier: GPL-2.0+
The SPDX comment-style change means that these files have adopted C99,
so need to change the language-standard to --std=gnu99 or --std=gnu11
to let the compiler know this.
As we now require GCC 6 or newer for the cross-compiler, the project has
implicitly moved the project to GNU11: let older GCC versions on various
Linux distros know to treat our host tools as GNU11 as well.
References: commit 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style")
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
MMC is not initialized in SPL, so it cannot load u-boot.img
preventing boot from MMC.
Also driver specific functions are guarded with generic
configuration options which leads to build failures when device
driver is not enabled in config. Fix that by using driver
specific defines.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
