- Bug fixes on ls1012a, ls1021a, ls1028ardb platforms Integrate fspi for
ls1028a, add DM-I2C support, update secure boot header offset
https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi
- DFU support file operations lager then the default max size
- add dfu support to dwc2 for bcm2835
- enable DFU for RPi4
- Fix RPi4 memory map to include the genet device
- add driver for the genet ethernet device
- enable network support in RPi4 config
- Various minor fixes for x86
- Switch to ACPI mode on Intel edison
- Support run-time configuration for NS16550 driver
- Update coreboot and slimbootloader serial drivers to use NS16550
- ICH SPI driver fixes to hardware sequencing erase case
- Move ITSS from Apollo Lake to a more generic location
- Intel GPIO driver bug fixes
- Move to vs2017-win2016 platform build host for Azure pipelines
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- DFU boot support for J721e
- I2C support for J721e
- GPIO support for J721e
- Android boot image updates on AM57XX
- OMAP watchdog fixes
Inside Kconfig we must not use the CONFIG_ prefix with the imply statement.
Fixes: 28e3c39e535b ("board: freescale: ls1012a2g5rdb: enable network
support on ls1012a2g5rdb")
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Updates the secure boot headers offsets of Kernel and other
firmware images for SD and NOR boot sources used by
esbc_validate command.
Signed-off-by: Priyanka Singh <priyanka.singh@nxp.com>
firmware images for SD and QSPI boot sources used by
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
firmware images for SD and XSPI boot sources used by
firmware images used by esbc_validate command.
The default reserved memory for CMA is high memory. If LPAE is enabled,
highmem pages are non-remapped and can not be used with
dma_alloc_coherent. This patch will reserve low memory for CMA and fix
the issue on LS1021A.
Signed-off-by: Peng Ma <peng.ma@nxp.com>
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Signed-off-by: Alison Wang <alison.wang@nxp.com>
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1021A
Signed-off-by: Biwen Li <biwen.li@nxp.com>
for SoC LS1012A
The default value of CONFIG_SYS_MALLOC_F_LEN (0x400)
leaves U-Boot with not enough memory to load i2c driver
before relocate, causing it to hang.
Change the default value of CONFIG_SYS_MALLOC_F_LEN
for below SoCs,
- LS1012A
- LS1021A
- LS1043A
- LS1046A
This adds DM_FLAG_PRE_RELOC flag to probe i2c driver
before relocation
Fix below SPL build error when DM_I2C is enabled,
- arch/arm/cpu/armv8/built-in.o: In function `board_init_f:
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74: undefined reference to `i2c_init_all'
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74:(.text.board_init_f+0x30):
relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol
`i2c_init_all'
make[2]: *** [spl/u-boot-spl] Error 1
make[1]: *** [spl/u-boot-spl] Error 2
make: *** [sub-make] Error 2
arch/arm/cpu/armv8/fsl-layerscape/spl.c: In function 'board_init_f':
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74:2: warning: implicit
declaration of function 'i2c_init_all'; did you mean 'misc_init_r'?
[-Wimplicit-function-declaration]`
Add support of driver model of pcf8563
Enable FSPI controller support. So, flash environment can now be used
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Align flexspi node properties with linux device-tree properties
Tested on LX2160A-RDB
Tested on LS1028A-RDB
Add support of "qixis_reset emmc" command for lx2160a based platforms
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
Sync the interrupt properties with the ones from Linux. Also use the
constants provided by the dt-bindings header. Please note, that there
are actual changes/fixes in the irq flags. U-Boot won't use the
interrupt properties anyway. It's just to be consistent with the Linux
device tree.
Signed-off-by: Michael Walle <michael@walle.cc>
Also align the fspi node with the kernel one.
Reviewed-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Enable the config for ls1012ardb as the entry got missed earlier.
Fixes: 8d8ee47e03 ("env: Add CONFIG_SYS_RELOC_GD_ENV_ADDR symbol")
Azure is moving to remove the vs2015-win2012r2 platform build host. The
two suggested new platforms to use are vs2017-win2016 and windows-2019.
For now, move up to vs2017-win2016.
Cc: Bin Meng <bmeng.cn@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Fix the following in intel_gpio_get_value():
* The value of the register is contained in the variable 'reg', not in
'mode'. The variable 'mode' contains only the configuration whether
the gpio is currently an input or an output.
* The correct bitmasks for the input and output value are
PAD_CFG0_RX_STATE and PAD_CFG0_TX_STATE.
Use them instead of the currently used PAD_CFG0_RX_STATE_BIT and
PAD_CFG0_TX_STATE_BIT.
Signed-off-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
Add missing 'PAD_CFG0_TX_STATE' to the clear mask for pcr_clrsetbits32().
Otherwise this bit cannot be cleared again after it has been set once.
The function pcr_clrsetbits32() expects a device with a P2SB parent
device. In intel_gpio_direction_output() and intel_gpio_set_value()
the device 'dev' is passed to pcr_clrsetbits32(), which is a
gpio-controller with a device 'pinctrl' as parent. This does not match
the expectations of pcr_clrsetbits32(). But the 'pinctrl' device has a
P2SB as parent.
Pass the 'pinctrl' device instead of the 'dev' device to
pcr_clrsetbits32().
The Interrupt Timer Subsystem (ITSS) is not specific to Apollo Lake, so
remove the apl-prefix of the implemented functions/structures/...
Add a Kconfig option to support enabling/disabling the inclusion of
the ITSS driver depending on the platform.
Atuomatically select the ITSS driver when building for Apollo Lake.
[bmeng: squashed in http://patchwork.ozlabs.org/patch/1232761/]
move it to a common location within arch/x86.
[bmeng: conditionally build itss.c]
Fix obvious coding style problems, no functional change.
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Suniel Mahesh <sunil.m@techveda.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
The watchdog timer value was never updated in the hardware by this
driver, so the watchdog triggered on some random stale value that
was left in the hardware. The TI SPRUH37C says, quote:
20.4.3.9 Modifying Timer Count/Load Values and Prescaler Setting
After a write access, the load register value and prescaler ratio
registers are updated immediately, but new values are considered
only after the next consecutive counter overflow or after a new
trigger command (the WDT_WTGR register).
This means at least one trigger must happen. The driver probably
depended on someone calling it's .reset() callback, however that
is not guaranteed e.g. if the WDT operates without servicing.
Add this missing trigger.
The timeout parameter of omap3_wdt_start() is in miliseconds, while
GET_WLDR_VAL() expects parameter in seconds. Fix this so the WDT
driver is actually usable.
Enable CONFIG_DA8XX_GPIO to enable GPIO support.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Add the main_gpio0 node.
Add "ti,keystone-gpio" compatible so as be able to use Linux DT files as
is.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Fix below compiler warning for 64bit builds
drivers/gpio/da8xx_gpio.c: In function ‘davinci_get_gpio_bank’:
drivers/gpio/da8xx_gpio.c:446:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
return (struct davinci_gpio *)addr;
Enable PCA953x IO expander to control MMC/SD power lines.
IO expanders are required to power cycle SD card. So enable the same
Add I2C GPIO expander required to power cycle MMC/SD
J721e SoC has 2 I2C instances in MCU domain and 7 I2C instances in main
domain. Add DT nodes for the same
J721e EVM has a TCA6424 IO expander that has 24 GPIOs. Add support for
the same
Enable DFU, Fastboot and USB mass storage gadget related configs
Enable USB Gadget for R5 SPL, A72 SPL and A72 U-Boot to support DFU boot
Increase R5 SPL early malloc memory pool by ~7K to accommodate SPL USB
DFU boot requirements
Add configs to download varies stages of bootloader images to RAM during
DFU boot.
Enable USB0 in peripheral mode so that it be used for DFU
Add support to download SYSFW into internal RAM via DFU in DFU boot
mode. Prepare a DFU config entity entry dynamically using buffer address
allocated for SYSFW and start DFU gadget to get SYSFW.
