CONFIG_FPGA_SOCFPGA
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
CONFIG_FPGA
CONFIG_FPGA_ALTERA
Move FPGA driver which is Gen5 specific code into Gen5 driver file
and keeping common FPGA driver intact. All the changes are still keeping
in driver/fpga/ and no functional change. Subsequent patch would move
FPGA manager driver from arch/arm into driver/fpga/.
Remove parameter from socfpga_bridges_reset(), and keeping this function
for single purpose which is just triggering reset on bridges.
socfpga_reset_deassert_bridges_handoff() can be called for releasing reset
on any bridges based on the bridge setting defined in fdt.
CONFIG_ENV_IS_IN_ONENAND
CONFIG_ENV_IS_IN_FAT
CONFIG_ENV_IS_IN_REMOTE
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_ENV_IS_IN_DATAFLASH
CONFIG_ENV_IS_IN_EEPROM
CONFIG_ENV_IS_IN_NVRAM
CONFIG_ENV_IS_IN_FLASH
The CONFIG_ENV_IS_IN_... options which have already been converted to
Kconfig only have a small amount of help. Move the rest of it over from
the README.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
Remove the ARCH_SUNXI and RBTREE dependencies.
CMD_UBIFS already gets RBTREE from CMD_UBI (from MTD_UBI), and should
the first become independant from the latter, there would likely be a
dependency on MTD_UBI anyway.
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Jagan Teki <jagan@openedev.com>
Signed-off-by: Karl Beldan <karl.beldan-ext@sagemcom.com>
Many configs still define CMD_MTDPARTS in their non-Kconfig but
CMD_MTDPARTS has now moved to Kconfig.
This missing dependency has probably remained under the radar because
MTD_PARTITIONS is still whitelisted.
Remove the ARCH_SUNXI dependency.
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Remove the ARCH_SUNXI dependency on selection of RBTREE.
With PowerPC 4xx support removed, we have removed xilinx-ppc support as
well, remove this file now.
Fixes 98f705c9cefd ("powerpc: remove 4xx support")
Pasting longer lines into the U-Boot console prompt sometimes leads to
characters missing. One problem here is the small 16-byte FIFO of the
legacy NS16550 UART, e.g. on x86 platforms.
This patch now introduces a Kconfig option to enable RX interrupt
buffer support for NS16550 style UARTs. With this option enabled, I was
able paste really long lines into the U-Boot console, without any
characters missing.
Cc: Bin Meng <bmeng.cn@gmail.com>
[trini: Guard ns16550_serial_remove with
CONFIG_IS_ENABLED(SERIAL_PRESENT) to match struct assignment]
Fixes 4bd754d8abef ("arm: omap: Detect boot mode very early") where
the intent was to store the boot params information in a known
location and pass it to SPL very early. Unfortunately it didn't
account for OMAP3 boards.
This patch adds adds this functionality back into OMAP3 boards.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
commit 2eb48ff7a210d ("powerpc, 8260: remove support for mpc8260")
removed support for 8260 CPU.
This patch remove some remainders.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Add missing .h and add missing declarations in .h
Declare local functions as static. Make interrupt_init_cpu function
signatures consistent with how decrementer_count is declared.
Based on warnings reported by 'make C=2'
[trini: drop cpu_init_f as 8xx/83xx are different from the rest, rework
interrupt_init_cpu/decrementer_count]
Avoid unnecessary assembly functions when they can easily be written
in C.
in C.
in C.
in C.
Also remove dc_read() as it is nowhere referenced
All complex case have been removed and we now only support
MPC866 and MPC885 families.
So check_CPU() can be made a lot simpler.
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo()
or mpc86xx_reginfo() based on CONFIG_ symbol.
As those 3 functions can't me defined at the same time, let's
rename them print_reginfo() to avoid the #ifdefs
The name is kept generic as it is not at all dependent on
powerpc arch and any other arch could want to also print
such information.
In addition, as the Makefile compiles cmd/reginfo.c only when
CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD
definition inside a #ifdef CONFIG_CMD_REGINFO
Lets all remove the #ifdefs around the U_BOOT_CMD as this
file is only compiled when CONFIG_CMD_REGINFO is defined
Finally, this is a PowerPC-only command, disable it on a number of
non-PowerPC platforms.
set_msr() and get_msr() are defined and used twice.
This patch moves them into ppc.h
In order to avoid TBU increment due to TBL reaching its max
and wrapping, reset TBL before resetting TBU
The actions inside #ifdef CONFIG_8xx in arch/powerpc/lib/time.c
can be performed before, in a 8xx dedicated function.
This function has never been used, at least since the beginning
of the git repository
divider is calculated based on SCCR_DFBRG, with:
SCCR_DFBRG 00 => divider 1 = 1 << 0
SCCR_DFBRG 01 => divider 4 = 1 << 2
SCCR_DFBRG 10 => divider 16 = 1 << 4
SCCR_DFBRG 11 => divider 64 = 1 << 6
This can be easily converted to a single shift operation:
divider = 1 << (SCCR_DFBRG * 2)
It is possible to flag MAC addresses as locally administred. In this
case they don't need to be unique. This is only allowed for interfaces
which have no connection to the outside. For the TEGR1 board we use
this feature.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
If we rebrand the IVM and ethaddr was set previously we need to change
ethaddr. Otherwise we end up with a wrong MAC adress for the ethernet
interface.
It is annoying to have to set up and maintain two sets of toolchains, one
for buildman and one for moveconfig.
Adjust moveconfig to make use to buildman's toolchains. This should make
things easier.
One missing feature is the ability to specify the toolchain on the command
line with a special environment variable, e.g. CROSS_COMPILE_ARM. I'm not
sure if that is useful, but if it is it could be implemented in buildman.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add an option to specify 'all' to enable all flags. Also print an error
if an unrecognised flag is used. At present it just prints usage
information which is not very helpful.
Disable RNG and add TEE to FDT used on HS devices.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Add support for loading a TEE and setting up firewalled regions to
AM43xx HS boards.
Similar to what is done with OMAP5 class boards we need to
perform fixups common to this SoC class, add support for this here
and add HS fixups.
If a firmware node is already present in the FDT we will fail to create
one and so fail to add our OP-TEE node, make this fixup first check for
a firmware node and then only try to add one if it is not found.
Some of the fixups currently done for OMAP5 class boards are common to
other OMAP family devices, move these to fdt-common.c.
TEE loading and firewall setup are common to all omap2 devices, move
these function out of omap5 and into mach-omap2. This allows us
to use these functions from other omap class devices.
When running a 'make clean' or carelessly removing u-boot.cfg, all
future make invocations (until autoconf is regenerated) will print
an error for a missing u-boot.cfg due to missing rules and dependencies.
This commit adds (i) an explicit rule dependency from all (which will
invokes the configuration checker) to cfg, and (b) adds a rule to
invoke scripts/Makefile.autoconf to regenerate u-boot.cfg.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
FreeBSD recently switch to it's BSDL dtc. While it support most of the
features of the GPL one it still lacks the incbin directive.
Add the possibility to specify which dtc we want to use for compiling dts
and generating fit image.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
The Odroid C2 has two GiB of memory with two reserved regions.
reg = <0x0 0x0 0x0 0x1000000>;
reg = <0x0 0x10000000 0x0 0x200000>;
Patch
bfcef28ae4cf (arm: add initial support for Amlogic Meson and
ODROID-C2) provided function dram_init_banksize to reserve the
first 16 MiB of RAM for firmware in function dram_init_banksize
in arch/arm/mach-meson/board.c and defined
CONFIG_NR_DRAM_BANKS = 1.
With this patch dram_init_banksize is changed to additionally
reserve the 2MiB region for the ARM Trusted Firmware (BL31).
CONFIG_NR_DRAM_BANKS is set to 2.
Cc: Andreas Färber <afaerber@suse.de>
