2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-31dm: console: Check for serial devices properlySimon Glass
With driver model the serial device is often not called "serial". Mark driver-model stdio devices so that they can be detected and we can look up the uclass. This is a more reliable way of finding out whether the console is connected to a serial device or not. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-31console: Unify the check for a serial consoleSimon Glass
Put the check for whether a console is a serial device in a function so that we can share the code in the two places that use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-31arm: mach-omap2: Align image address before cache operationsAndrew F. Davis
The image address passed to secure_boot_verify_image() may not be cacheline aligned, round the address down to the nearest cacheline. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-07-31ti: Default to ENV_IS_IN_FAT if MMC_OMAP_HSTom Rini
When we have MMC available we assume that we want to put the env as a file on FAT. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31am335x_hs_evm: Disable CONFIG_SPL_ENV_SUPPORTTom Rini
The main uses of CONFIG_SPL_ENV_SUPPORT are for network support and for disabling "Falcon Mode" support at run-time. As this build enables neither, remove this feature. Cc: Andrew F. Davis <afd@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31Remove unused CONFIG_TWL4030_PWMAdam Ford
CONFIG_TWL4030_PWM is not being used by any source, so let's remove the #define and the whitelist entry Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-31serial: stm32x7: Convert CONFIG_STM32X7_SERIAL to KconfigPatrice Chotard
Add CONFIG_STM32X7_SERIAL as a Kconfig option. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-07-31dm: Kconfig: fix typo in help for SPL_PINCTRLPhilipp Tomsich
Changes 'controlloers' to 'controllers' in the help-text for SPL_PINCTRL. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-31efi_loader: Fix warning in efi_gopAlexander Graf
Commit ca9193d2b16 ("efi_loader: gop: fixes for CONFIG_DM_VIDEO without CONFIG_LCD") dropped the explicit (void*) cast for fb_base in efi gop support for CONFIG_LCD without DM. This patch adds it back, eliminating the now occuring warning again Fixes: ca9193d2b16 ("efi_loader: gop: fixes for CONFIG_DM_VIDEO without CONFIG_LCD") Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-07-31Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2017-07-29 A lot of EFI greatness this time around. Thanks a lot to the two amazing new contributors Heinrich Schuchardt and Rob Clark we now gain - stable objects across multiple bootefi invocations - fixes for shim - fixes for ipxe - protocol installation - device path conversion to/from text - working "lsefi" support in grub - working notifiers - various bug fixes
2017-07-30x86: minnowmax: Remove CONFIG_SMSC_LPC47MBin Meng
There is no SMSC LPC47M Super I/O chipset on the MinnowMax board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: acpi: Don't touch hardware on HW reduced platformsAndy Shevchenko
If ACPI HW reduced bit in FADT is set we should ignore any ACPI hardware communications. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: acpi: Export acpi_fill_mcfg() with __weak attributeAndy Shevchenko
Some platforms might require different approach when filling memory mappings configuration table. Allow them to override the common method. At the same time export acpi_create_mcfg_mmconfig(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: acpi: Deduplicate acpi_fill_madt() implementationAndy Shevchenko
In Baytrail and Quark support code acpi_fill_madt() is identical. Deduplicate its implementation by moving to lib/acpi_tables.c. At the same time mark acpi_fill_madt() with __weak attribute to keep a possibility to override it in platform code Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: acpi: Name fields in FADT in accordance with specificationAndy Shevchenko
ACPI specification defines FADT fields marked as reserved in U-Boot. Name these fields in accordance with ACPI specification. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: acpi: Fill OEM revisionAndy Shevchenko
Fill OEM revision field in the tables by U-Boot build date. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30Makefile: Export build date as integerAndy Shevchenko
In some cases we would need build date as integer value. Export U_BOOT_BUILD_DATE as %Y%m%d integer value. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30Makefile: Don't shadow actual error when compile ASLAndy Shevchenko
If ASL compiler failed by any reason do not produce output C file. Otherwise sequential run of make will shadow the actual error in ASL, i.e. CC board/intel/edison/dsdt.o board/intel/edison/dsdt.c:1:1: error: unterminated comment /* and user has to remove dsdt.c and run make in order to see the error again. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: conga-qeval20-qa3-e3845.dts: Enable xHCI support in dtsStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: dfi-bt700: Add xHCI USB supportStefan Roese
Change from EHCI to xHCI on the DFI BayTrail SoM. The xHCI USB hub is connected to an GPIO on the DFI BayTrail SoM. For correct operation, it needs to get reset upon power-up. Otherwise it may happen that the hub is not detected after a software reboot. This patch also configures this GPIO in the dts for correct operation. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: conga-qeval20-qa3-e3845: Select CONFIG_BOARD_LATE_INITStefan Roese
This config option is needed on the congatec x86 BayTrail board, as otherwise the USB hub will not get initialized correctly. This patch selects this Kconfig option again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: theadorable-x86-dfi-bt700: Add Spansion SPI support and move VIDEO blobStefan Roese
To support the Spansion SPI NOR flashes, this patch enables the support in defconfig. This increases the U-Boot binary too much so that it does not fit into its area in the ROM. So also move the VIDEO BIOS blob a bit to make some space here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: Add Intel Edison board filesAndy Shevchenko
Add Intel Edison board which is using U-Boot. The patch is based on work done by the following people (in alphabetical order): Aiden Park <aiden.park@intel.com> Dukjoon Jeon <dukjoon.jeon@intel.com> eric.park <eric.park@intel.com> Fabien Chereau <fabien.chereau@intel.com> Felipe Balbi <felipe.balbi@linux.intel.com> Scott D Phillips <scott.d.phillips@intel.com> Sebastien Colleur <sebastienx.colleur@intel.com> Steve Sakoman <steve.sakoman@intel.com> Vincent Tinelli <vincent.tinelli@intel.com> In case we're building for Intel Edison, we must have 4096 bytes of zeroes in the beginning on u-boot.bin. This is done in board/intel/edison/config.mk. First run sets hardware_id environment variable which is read from System Controller Unit (SCU). Serial number (serial# environment variable) is generated based on eMMC CID. MAC address on USB network interface is unique to the board but kept the same all over the time. Set mac address from U-Boot using following scheme: OUI = 02:00:86 next 3 bytes of MAC address set from eMMC serial number This allows to have a unique mac address across reboot and flashing. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> [bmeng: Add MAINTAINERS file for Intel Edison board] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30x86: Add Intel Tangier supportFelipe Balbi
Add Intel Tangier SoC support. Intel Tangier SoC is a core part of Intel Merrifield platform. For example, Intel Edison board is based on such platform. The patch is based on work done by the following people (in alphabetical order): Aiden Park <aiden.park@intel.com> Dukjoon Jeon <dukjoon.jeon@intel.com> eric.park <eric.park@intel.com> Fabien Chereau <fabien.chereau@intel.com> Scott D Phillips <scott.d.phillips@intel.com> Sebastien Colleur <sebastienx.colleur@intel.com> Steve Sakoman <steve.sakoman@intel.com> Vincent Tinelli <vincent.tinelli@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-30x86: Add dma-mapping.h to architectural codeAndy Shevchenko
Some cross-platform drivers rely on this header present. Make it so for x86. It's just a copy'n'paste of arch/arm/include/asm/dma-mapping.h. Suggested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-30watchdog: Introduce watchdog driver for Intel TangierFelipe Balbi
Add watchdog driver for Intel Tangier based platforms. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-30arch/x86: Select USB before selecting host driverAndy Shevchenko
Kbuild complains if USB is not selected before any of host driver. warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB) Select it for X86. Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> [bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-29Merge git://git.denx.de/u-boot-socfpgaTom Rini
2017-07-29Merge git://git.denx.de/u-boot-usbTom Rini
2017-07-29efi_loader: indent entry/exit prints to show nesting levelRob Clark
This should make it easier to see when a callback back to UEFI world calls back in to the u-boot world, and generally match up EFI_ENTRY() and EFI_EXIT() calls. Signed-off-by: Rob Clark <robdclark@gmail.com> [agraf: remove static from const var] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-07-29efi_loader: add checking for incorrect use of EFI_ENTRY/EXITRob Clark
Missing an EFI_ENTRY() or doubling up EFI_EXIT() leads to non-obvious crashes. Let's add some error checking. Signed-off-by: Rob Clark <robdclark@gmail.com> [agraf: fix bogus assert() and fix app_gd breakage] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-07-28clk: fix compilation errors for poplar platformPatrice Chotard
Move clk_release_all() prototype and definition inside OF_CONTROL flag to avoid following compilation error for poplar platform: aarch64: + poplar +drivers/usb/host/built-in.o: In function `ehci_usb_remove': +drivers/usb/host/ehci-generic.c:159: undefined reference to `clk_release_all' +drivers/usb/host/built-in.o: In function `ehci_usb_probe': +drivers/usb/host/ehci-generic.c:133: undefined reference to `clk_release_all' +make[1]: *** [u-boot] Error 139 +make: *** [sub-make] Error 2 Introduced by 4e542c4 clk: add clk_release_all() Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28usb: host: xhci-dxc3: fix compilation warningsPatrice Chotard
Fix following warnings encountered with platforms dra7xx_evm and dra7xx_hs_evm : arm: + dra7xx_evm + hccr = (struct xhci_hccr *)devfdt_get_addr(dev); + ^ + hcor = (struct xhci_hcor *)((phys_addr_t)hccr + + ^ w+drivers/usb/host/xhci-dwc3.c: In function 'xhci_dwc3_probe': w+drivers/usb/host/xhci-dwc3.c:124:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] w+drivers/usb/host/xhci-dwc3.c:125:30: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] w+drivers/usb/host/xhci-dwc3.c:125:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] arm: + dra7xx_hs_evm + hccr = (struct xhci_hccr *)devfdt_get_addr(dev); + ^ + hcor = (struct xhci_hcor *)((phys_addr_t)hccr + + ^ w+drivers/usb/host/xhci-dwc3.c: In function 'xhci_dwc3_probe': w+drivers/usb/host/xhci-dwc3.c:124:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] w+drivers/usb/host/xhci-dwc3.c:125:30: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] w+drivers/usb/host/xhci-dwc3.c:125:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] Introduced by 7e65e84 usb: host: xhci-dwc3: Convert driver to DM Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28phy: add a NO-OP phy driverJean-Jacques Hiblot
This driver is used to stub PHY operations in a driver (USB, SATA). This is useful when the 'client' driver (USB, SATA, ...) uses the PHY framework and there is no actual PHY harwdare to drive. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-28usb: host: ohci-generic: initialize PHY only when foundPatrice Chotard
Call generic_phy_init() only when a PHY was found. This will avoid a crash if no "phys" property is found in DT. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28usb: host: ehci-generic: initialize PHY only when foundPatrice Chotard
2017-07-28dm: usb: host: xhci-dwc3: add missing #ifdef CONFIG_DM_USBPatrice Chotard
Add CONFIG_DM_USB flag to avoid following compilation errors detected by buildman : +drivers/usb/host/built-in.o: In function `xhci_dwc3_remove': +drivers/usb/host/xhci-dwc3.c:168: undefined reference to `xhci_deregister' +drivers/usb/host/built-in.o: In function `xhci_dwc3_probe': +drivers/usb/host/xhci-dwc3.c:145: undefined reference to `usb_get_dr_mode' +drivers/usb/host/xhci-dwc3.c:152: undefined reference to `xhci_register' introduced by patch d5c3f014da3 "usb: host: xhci-dwc3: Convert driver to DM" Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Ran Wang <ran.wang_1@nxp.com>
2017-07-28dm: phy: add missing #ifdef CONFIG_PHYPatrice Chotard
To avoid compilation breakage on platform that doesn't support DM PHY but uses xhci-dwc3 driver, add the missing CONFIG_PHY flag. Introduced by patch : 84e53877 "usb: host: xhci-dwc3: Add generic PHY support" Cc: Ran Wang <ran.wang_1@nxp.com> Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reported-by: Ran Wang <ran.wang_1@nxp.com>
2017-07-28dfu: add common function to initiate transactionPatrick Delaunay
- factorize code between read and write transaction - always use dfu_transaction_cleanup() to initialize the internal variable: easy maintenance - replace direct access by dfu_get_buf() and dfu_get_buf_size() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: factorize transaction cleanupPatrick Delaunay
rename cleanup function, as now called by read Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: remove limitation on partition sizePatrick Delaunay
Change long (32 bits on arm) to u64 (same type than offset) for size and read offset r_left So partition and device used for DFU can be greater than 4GB Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: allow dfu read on partition greater than 2GBPatrick Delaunay
solve issue on get_medium_size() function the detection of error is a simple test < 0 but for ARM platform, long is 32bits and 2GB = 0x80000000 is seen as error. I solve the issue by changing the prototype fo the function to separate size and result. This patch prepare the next patch with size change to u64. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28usb: gadget: f_thor: Free the allocated out request bufferSiva Durga Prasad Paladugu
Fix the memory leak by freeing the allocated out request buffer Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-07-28usb: xhci: Enable TT to support LS/FS devices behind a HS hubBin Meng
So far LS/FS devices directly attached to xHC root port can be successfully enumerated by xHCI driver, but if they are connected behind a hub, the enumeration process fails to address the device. It turns out xHCI driver still misses a part that in the device's input slot context, all Transaction Translator (TT) related fields are not programmed. The xHCI spec defines how to enable TT. Now LS/FS devices like USB keyboard/mouse can be enumerated behind a high speed hub. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Correct TT_SLOT and TT_PORT macrosBin Meng
These two macros really need a parameter to make them useful. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: xhci: Implement update_hub_device() operationBin Meng
There is no way to know whether the attached device is a hub or not in advance before the device's descriptor is fetched. But once we know it's a high speed hub, per the xHCI spec, we need to tell xHC it's a hub device by initializing hub-related fields in the input slot context. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Call usb_update_hub_device() after hub descriptor is fetchedBin Meng
After fetching hub descriptor, we need to call USB uclass operation update_hub_device() to notify HCD to do some preparation work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
