2016-06-06arm/arm64: implement a boot header capabilityAndre Przywara
Some SPL loaders (like Allwinner's boot0, and Broadcom's boot0) require a header before the actual U-Boot binary to both check its validity and to find other data to load. Sometimes this header may only be a few bytes of information, and sometimes this might simply be space that needs to be reserved for a post-processing tool. Introduce a config option to allow assembler preprocessor commands to be inserted into the code at the appropriate location; typical assembler preprocessor commands might be: .space 1000 .word 0x12345678 Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Steve Rae <srae@broadcom.com> Commit Notes: Please note that the current code: start.S (arm64) and vectors.S (arm) already jumps over some portion of data already, so this option basically just increases the size of this region (and the resulting binary). For use with Allwinner's boot0 blob there is a tool called boot0img[1], which fills the header to allow booting A64 based boards. For the Pine64 we need a 1536 byte header (including the branch instruction) at the moment, so we add this to the defconfig. [1] https://github.com/apritzel/pine64/tree/master/tools END Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06lib: make strmhz available in SPLChris Packham
When setting up a DDR controller it is useful to be able to display frequencies in a readable form. Make the strmhz() function available in SPL builds provided there is full vsprintf available. Reviewed-by: Tony O'Brien <tony.obrien@alliedtelesis.co.nz> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-06-06Remove unneeded remnants of bcopy().Robert P. J. Day
Since bcopy() is no longer used, delete all remaining references to it. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-06-06configs: k2*_evm: Update fdt file namesLokesh Vutla
Now that all Keystone2 dts file names are changed in Linux kernel, reflect the same in evn variables inorder to find the right dtb file. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-06-06ARM: DRA7xx: Enable FIT for hs platformsLokesh Vutla
Use a single defconfig for all DRA7xx hs platforms by enabling FIT and delete the platform specific defconfigs. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-06-06armv7: fix order of OMAP die ID printingLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2016-06-06efi_loader: Add DM_VIDEO supportAlexander Graf
Some systems are starting to shift to support DM_VIDEO which exposes the frame buffer through a slightly different interface. This is a poor man's effort to support the dm video interface instead of the lcd one. We still only support a single display device. Signed-off-by: Alexander Graf <agraf@suse.de> [trini: Remove fb_size / fb_base as they were not used] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06efi_loader: Don't allocate from memory holesAlexander Graf
When a payload calls our memory allocator with the exact address hint, we happily allocate memory from completely unpopulated regions. Payloads however expect this to only succeed if they would be allocating from free conventional memory. This patch makes the logic behind those checks a bit more obvious and ensures that we always allocate from known good free conventional memory regions if we want to allocate ram. Reported-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06efi_loader: Move to normal debug infrastructureAlexander Graf
We introduced special "DEBUG_EFI" defines when the efi loader support was new. After giving it a bit of thought, turns out we really didn't have to - the normal #define DEBUG infrastructure works well enough for efi loader as well. So this patch switches to the common debug() and #define DEBUG way of printing debug information. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06efi_loader: Add exit supportAlexander Graf
Some times you may want to exit an EFI payload again, for example to default boot into a PXE installation and decide that you would rather want to boot from the local disk instead. This patch adds exit functionality to the EFI implementation, allowing EFI payloads to exit. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06arm: Introduce setjmp/longjmpAlexander Graf
To quit an EFI application we will need logic to jump to the caller of a function without returning from the function we called into, so we need setjmp/longjmp functionality. This patch introduces a trivial implementation of these that I verified works on armv7, thumb2 and aarch64. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06strider: Support cpu-dp flavorDirk Eibach
There is new strider cpu flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06strider: Support con-dp flavorDirk Eibach
There is a new strider console flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06gdsys: osd: Allow osdsize on valid screens onlyDirk Eibach
Limit "osdsize"-command to access valid screens only. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06ioep-fpga: Support intempo compressionDirk Eibach
There is a new "intempo" compression type that can be reported on startup. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06Fix to davinci_nand.h to place CEnCFG registers at correctPeter Howard
Signed-off-by: Peter Howard <phoward@gme.net.au>
2016-06-06dm: scsi: if_typename should be scsiEd Swarthout
Fixes: => ext2ls scsi 0:1 ** Bad device scsi 0:1 ** for boards which use the scsi legacy driver (such as ls1043ardb). Signed-off-by: Ed Swarthout <Ed.Swarthout@nxp.com> Tested-by: George McCollister <george.mccollister@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-06-06ARM64: zynqmp: Extend malloc space before relocationMichal Simek
For boards which have more devices it is necessary to extend malloc space. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Add support for standard distro boot commandsMichal Simek
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable. Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-06-06ARM64: zynqmp: Remove CONFIG_BOOTP_SERVERIPAlexander Graf
When the CONFIG_BOOTP_SERVERIP option is set, we ignore all dhcp values for the tftp server and use our own serverip and file name instead. This is usually not what we want and I doubt it's set for a good reason on ZynqMP. It definitely hurts if we want to support uEFI PXE boot on it. So just remove the option for now. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable AHCI when CONFIG_SATA_CEVA is definedMichal Simek
Simplify zcu102 board file by moving CONFIG_AHCI enabling to common file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable support for SPL FIT imagesMichal Simek
Enable support for RAM based FIT images read by SPL. Empty function for now to keep compiler happy. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06env: Setup GD_FLG_ENV_DEFAULT flag when default environment are usedMichal Simek
Setup flag when default environment are used to be able to rewrite default distro boot variables based on SoC boot mode. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-06-06ARM64: zynq: Fix boot.bin generation for Zynq and ZynqMPMichal Simek
Fix boot.bin generation for Zynq and ZynqMP. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2016-06-06ARM64: zynqmp: Extend page_table_sizeMichal Simek
0xc000 is not sufficient page table size if dc4 with 4 gems is enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Add support for zc1751-dc4Michal Simek
zc1751-dc4 contains four GEMs. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Add debug uart for zc1751-dc2Michal Simek
Add debug uart for zc1751-dc2. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable Vitesse and RealTek ethernet physMichal Simek
Phys are available on zc1751-dc4 that's why enable them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Move MSR instruction selection to KconfigMichal Simek
Select MSR instructions via Kconfig instead of xparameters.h. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Add option to pass cpu version numberMichal Simek
Toolchain can use some flags by default based on cpu version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Select compilation flags via KconfigMichal Simek
Remove autogenerated config.mk and select CPU options via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable CMD_NAND via KconfigMichal Simek
Simplify board file by enabling CMD_NAND via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06mtd: nand: arasan_nfc: Correct nand ecc initializationSiva Durga Prasad Paladugu
Correct the nand ecc initialization code This fixes the issue of incorrect nand ecc init if no device is found in ecc_matrix then it endsup ecc init with junk initialization instead of the most suited one. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-04arm: lib: Fix fix push/pop-section directivesMarek Vasut
Repair typos in the previous "arm: lib: fix push/pop-section directives" patch, which prevented VCMA9 board from building. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: b2f1858455e9 ("arm: lib: fix push/pop-section directives") Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stephen Warren <swarren@nvidia.com>
2016-06-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2016-06-04spl: fit: Fix non-matching DT names console outputAndreas Dannenberg
When no DTB can be matched successfully to the board that's being used a list of available FIT-embedded DTBs will be output to the console for diagnostic purposes. But rather than the contents of the "description" FDT property a non-existent property was accessed and as a result "NULL" was output instead of the actual name(s) of the DTB(s). Fix this issue by using the correct property which is also the exact same property that's used earlier during the actual board matching process. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2016-06-04Merge git://git.denx.de/u-boot-nand-flashTom Rini
2016-06-04Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-06-03freescale: Tweak various Makefiles to remove redundancy, fix aestheticsRobert P. J. Day
No intended functional change, just remove redundancies in some Makefiles, and make whitespace aesthetics uniform. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03dm: test: Add GPIO open drain testsmario.six@gdsys.cc
Add some tests for the new open drain setting feature of the GPIO uclass, and extend the capabilities of the sandbox GPIO driver accordingly. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03dm: gpio: Implement open drain for MPC85XX GPIOmario.six@gdsys.cc
This patch implements the open-drain setting feature for the MPC85XX GPIO controller. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03dm: gpio: Add methods for open drain settingmario.six@gdsys.cc
Certain GPIO devices have the capability to switch their GPIOs into open-drain mode, that is, instead of actively driving the output (Push-pull output), the pin is connected to the collector (for a NPN transistor) or the drain (for a MOSFET) of a transistor, respectively. The pin then either forms an open circuit or a connection to ground, depending on the state of the transistor. This patch adds functions to the GPIO uclass to switch GPIOs to open-drain mode on devices that support it. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03dm: gpio: Add driver for MPC85XX GPIO controllermario.six@gdsys.cc
This patch adds a driver for the built-in GPIO controller of the MPC85XX SoC (probably supporting other PowerQUICC III SoCs as well). Each GPIO bank is identified by its own entry in the device tree, i.e. gpio-controller@fc00 { #gpio-cells = <2>; compatible = "fsl,pq3-gpio"; reg = <0xfc00 0x100> } By default, each bank is assumed to have 32 GPIOs, but the ngpios setting is honored, so the number of GPIOs for each bank in configurable to match the actual GPIO count of the SoC (e.g. the 32/32/23 banks of the P1022 SoC). The usual functions of GPIO drivers (setting input/output mode and output value setting) are supported. The driver has been tested on MPC85XX, but it is likely that other PowerQUICC III devices will work as well. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03arch/powerpc: Simplify some calculations using ARRAY_SIZE() macro.Robert P. J. Day
Replace a number of array length calculations with the ARRAY_SIZE() macro, for clarity. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03board/freescale: Use unified setup_ddr_tlbs for spl boot and non-spl bootShengzhou Liu
We should use unified setup_ddr_tlbs() for spl boot and non-spl boot to make sure 'M' bit is set for DDR TLB to maintain cache coherence. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03powerpc/board: SPL: Enable malloc flag in global data.Sumit Garg
For malloc to work in SPL framework enable GD_FLG_FULL_MALLOC_INIT flag in global data after allocating memory using mem_malloc_init. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03nand: fix nand torture to use changed mtd apiMax Krummenacher
The mtd subsystem deprecated and renamed the direct use of the mtd_info struct's functionpointers. Instead the corresponding mtd_xxx function should be used. See also: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=3c3c10bba1e4ccb75b41442e45c1a072f6cded19 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-03mtd: nand: Sync with Linux v4.6Scott Wood
Updates the NAND code to match Linux v4.6. The previous sync was from Linux v4.1 in commit d3963721d93fafa. Note that none of the individual NAND drivers tracked Linux closely enough to be synced themselves, other than manually applying a few cross-tree changes. Signed-off-by: Scott Wood <oss@buserror.net> Tested-by: Heiko Schocher <hs@denx.de>
