2018-01-28ARM: dts: stm32: Add STM32F429 Evaluation board supportPatrice Chotard
This DT file comes from kernel v4.15, this board offers : _ STM32F429NIH6 microcontroller _ 4.3” color TFT LCD with resistive touchscreen (480 x 272 pixels) _ Six 5 V power supply options: Power jack ST-LINK/V2 USB connector User USB HS connector User USB FS1 connector User USB FS2 connector Daughterboard _ SAI Audio DAC, stereo audio jack which supports headset with microphone _ Stereo digital microphone, audio terminal connector used to connect external speakers _ 2 GBytes (or more) SDIO interface MicroSD card _ RF EEPROM on I2 C compatible serial interface _ RS-232 communication _ IrDA transceiver _ JTAG/SWD and ETM trace debug support, ST-LINK/V2 embedded _ IEEE-802.3-2002 compliant Ethernet connector _ Camera module _ 8M x 32-bit SDRAM, 1M x 16-bit SRAM and 8M x 16-bit NOR Flash _ Joystick with 4-directional control and selector _ Reset, Wakeup and Tamper buttons _ 4 color user LEDs _ Extension connectors & memory connectors for daughterboard or wrapping board _ USB OTG HS and FS with Micro-AB connectors _ RTC with backup battery _ CAN2.0A/B compliant connection _ Potentiometer _ Motor control connector Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28board: stm32: Add stm32f429-evaluation board supportPatrice Chotard
Add stm32f429-evaluation board support. For more information, please visit: http://www.st.com/en/evaluation-tools/stm32429i-eval.html Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28configs: stm32f: Remove STM32_HSE_HZ for all STM32F seriesPatrice Chotard
As clk_stm32f driver is able to retrieve HSE frequency from DT, CONFIG_STM32_HSE_HZ becomes useless. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28clk: stm32: retrieve external oscillator frequency from DTPatrice Chotard
All current STM32F4 supported boards uses a 8MHz external oscillator. All current STM32F7 supported boards uses a 25MHz external oscillator. In order to introduce the new stm32f429-evaluation board which uses a 25MHz external oscillator without creating a dedicated struct stm32_clk_info for this board, retrieve the external oscillator frequency from DT and set pll_m accordingly to obtain 1MHz for the VCO. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28ARM: dts: stm32: add "u-boot, dm-pre-reloc" for clk_hse in stm32f7-u-bootPatrice Chotard
In order to retrieve the clk_hse fixed clock phandle in clk_stm32f driver, add "u-boot,dm-pre-reloc" property in Uboot specific DT file. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28arm: bootm-fdt.c: fix compiler warningHeiko Schocher
compiling U-Boot with bosch_mpcxxxxd_sd_defconfig drops warning: arch/arm/lib/bootm-fdt.c: In function ‘arch_fixup_fdt’: arch/arm/lib/bootm-fdt.c:37:6: warning: unused variable ‘ret’ [-Wunused-variable] int ret = 0; ^~~ Fix it. Signed-off-by: Heiko Schocher <hs@denx.de>
2018-01-28arm: mach-omap2: Pass args to secure ROM in SRAM in SPLAndrew F. Davis
When in early SPL we make some secure ROM calls that can effect DRAM, due to this it is more stable to store the args for these calls in SRAM, but uninitialized and zero'd globals are placed in BSS, located in DRAM. Force our args into the data section which is in SRAM during SPL. Signed-off-by: Andrew F. Davis <afd@ti.com>
2018-01-28common: board_r: Fix style violationsMario Six
Fix some style violations in the board_r file. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28common: board_f: Fix style violationsMario Six
Fix some style violations in the board_f file. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28serial: ns16550: Fix style violationMario Six
Clarify the computation precedence in two ternary operator constructions. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28include: dm: Fix 'devioe'/'devuce' typosMario Six
There are some typos in the documentation of some functions in read.h; fix those. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-28gpio: mpc8xxx: Make live-tree compatibleMario Six
Make the MPC8xxx GPIO driver compatible with a live device tree. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: mpc8xxx: Make compatible with more SoCsMario Six
Finally, make the mpc8xxx driver capable of handling more GPIO devices; this entails adding a special case for the MPC5121 SoC, and adding a set of new compatible strings. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: mpc8xxx: Rename Kconfig option, structures, and functionsMario Six
Rename the Kconfig option, structures (and their members), as well as functions of the mpc85xx driver to include mpc8xxx to reflect the more generic usage. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: mpc85xx: Rename driver file to mpc8xxxMario Six
In preparation to making the MPC85xx GPIO driver useable for a broader range of SoCs, rename the driver file. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: mpc85xx_gpio: Fix style violationsMario Six
Fix some style violations in the MPC85XX GPIO driver. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: pca953x_gpio: Make live-tree compatibleMario Six
Make the pca953x_gpio driver compatible with a live device tree. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28gpio: pca953x_gpio: Fix style violationsMario Six
Fix some style violations in the pca953x_gpio driver. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-28Initialize SHA buffer size var in passwd_abortMartin Etnestad
The call to hash_block in passwd_abort fails with error ENOSPC on some systems. The reason is that the variable which specifies the size of the buffer to contain the computed hash does not get initialized. This patch initializes the variable with the size of the buffer. Signed-off-by: Martin Etnestad <martin.etnestad@appeartv.com>
2018-01-28Merge git://git.denx.de/u-boot-usbTom Rini
2018-01-28usb: host: Drop unused hcd_name from r8a66597-hcd.cTom Rini
The variable hcd_name is unsued, drop. Cc: Marek Vasut <marex@denx.de> Cc: Chris Brandt <chris.brandt@renesas.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-28usb: Remove isp116x-hcd supportTom Rini
The isp116x-hcd driver is extremely long unused, so just remove it. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-27Merge git://git.denx.de/u-boot-uniphierTom Rini
2018-01-27Merge branch 'rmobile-mx' of git://git.denx.de/u-boot-shTom Rini
2018-01-28ARM: uniphier: enable HS200 support for uniphier_v8_defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27Merge git://git.denx.de/u-boot-usbTom Rini
2018-01-27Merge git://git.denx.de/u-boot-socfpgaTom Rini
2018-01-27ARM: rmobile: Convert R8A7791 Porter board to DM and DTMarek Vasut
Convert the R8A7791 Porter board to DM and DT. This implies mostly enabling the necessary configuration options and plucking out the ad-hoc configuration from the board file. Moreover, the pre-reloc malloc size was increased to allow the clock driver to start up early without running out of malloc space and the early stack was moved further up in the DRAM to avoid rewriting U-Boot itself. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: rmobile: Enable OF_CONTROL on RCar Gen2Marek Vasut
Since the DTs are now in place, enable OF control so that they get bundled into the U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Add SoC and board U-Boot DT extrasMarek Vasut
Add U-Boot DT extras for each SoC and board. This marks the required nodes with u-boot,dm-pre-reloc to start clock and PRR early on while avoiding modification of the DTs imported from Linux. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Add rudimentary R8A7790 Stout DTMarek Vasut
The Stout board is not supported in Linux, so add a rudimentary DTS for H2 Stout as a placeholder for when a proper DTS is available. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- NOTE: The Stout is already being shipped over, so proper DTS for both U-Boot and Linux will happen once it's delivered :-)
2018-01-27ARM: dts: rmobile: Import R8A7794 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7794 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Import R8A7793 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7793 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Import R8A7792 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7792 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Import R8A7791 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7791 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: dts: rmobile: Import R8A7790 DTS from Linux 4.15-rc8Marek Vasut
Import the Renesas R8A7790 DTS and headers from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27net: sh_eth: Add DM and DT supportMarek Vasut
Add DM capable code into the SH ethernet driver and support probing both from DT and pdata. The legacy non-DM, non-DT support is retained as there are still systems in the tree which are not DM or DT capable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Clump legacy functions togetherMarek Vasut
Move the legacy functions around, so that they can be wrapped in a massive ifdef CONFIG_DM_ETH once DM support is added. No functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Split sh_eth_initMarek Vasut
Split sh_eth_init() function into smaller chunks, which can be called from both DM and non-DM code while handling the specifics of both configurations. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Separate out MAC address programmingMarek Vasut
Pull out the code for writing MAC address into the NIC into a separate function, so it can be reused by both DM and non-DM code. This is done in preparation for DM support, which handles MAC address programming separately. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Split sh_eth_recvMarek Vasut
Split sh_eth_recv into two functions, one which checks whether a packet was received and one which handles the received packet. This is done in preparation for DM support, which handles these two parts separately. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Pass sh_eth_dev aroundMarek Vasut
Pass sh_eth_dev structure around instead of eth_device, since the later is specific to the legacy networking support. This change is done in preparation for the DM addition. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: sh_eth: Unify CONFIG_R8A779[01234] as CONFIG_RCAR_GEN2Marek Vasut
Use the common RCAR_GEN2 config option instead of enumerating each SoC and having a lengthy ifdef clause. No functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27net: ravb: staticize ravb_startMarek Vasut
Cosmetic fix, make ravb_start() static. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@ni.com>
2018-01-27pci: rmobile: Add RCar Gen2 PCIe controller driverMarek Vasut
Add driver for the Renesas RCar PCIe controller present on Gen2 SoCs. The PCIe on Gen2 is used both to connect external PCIe peripherals as well as access the on-SoC USB EHCI controller. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-01-27gpio: rmobile: Add RCar Gen2 compatible stringMarek Vasut
Add DT compatible string for RCar Gen2. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27env: sunxi: Enable FAT-based environment support by defaultMaxime Ripard
Now that we have everything in place to implement the transition scheme, let's enable it by default. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27sunxi: Transition from the MMC to a FAT-based environmentMaxime Ripard
The current environment has been hardcoded to an offset that starts to be an issue given the current size of our main U-Boot binary. By implementing a custom environment location routine, we can always favor the FAT-based environment, and fallback to the MMC if we don't find something in the FAT partition. We also implement the same order when saving the environment, so that hopefully we can slowly migrate the users over to FAT-based environment and away from the raw MMC one. Eventually, and hopefully before we reach that limit again, we will have most of our users using that setup, and we'll be able to retire the raw environment, and gain more room for the U-Boot binary. Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Mark env_get_location as weakMaxime Ripard
Allow boards and architectures to override the default environment lookup code by overriding env_get_location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Allow to build multiple environments in KconfigMaxime Ripard
Now that we have everything in place in the code, let's allow to build multiple environments backend through Kconfig. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
