Drop include of netdev.h as it's a SATA driver not a network driver.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Decrease malloc size to 1MB from 256MB. Huge malloc
space is adding huge delay in mem_malloc_init() because
we are enabling CONFIG_SYS_MALLOC_CLEAR_ON_INIT
which clear the whole malloc space.
In older vivado version some psu_init* files didn't contain
mask*() which were missing.
The boot_device argument to spl_boot_mode was massively added without
actually modifying the existing functions.
This commit actually makes use of the handed value, which is the same.
Signed-off-by: Jean-Francois Dagenais <jeff.dagenais@gmail.com>
When enabling both SDHCI controllers, spl_mmc.c would actually choose
device sdhci0 even if booted from sdhci1 (boot_device). This is because
spl_mmc_get_device_index(boot_device) expects BOOT_DEVICE_MMC2[_2] in
order to return index 1 instead of 0.
The #if defined(...) statement is copied from board/xilinx/zynqmp/zynqmp.c
So the key to properly enabling both controllers as boot sources is
defining both CONFIG_ZYNQ_SDHCI0 and CONFIG_ZYNQ_SDHCI1 in your board's
include/configs/*.h.
Add missing SD boot mode to SPL. zcu102-rev1.0 is supporting
this boot mode.
Adding more targets to repository requires some additional
changes not simply just adding config file, defconfig and dts.
This patch makes this process easier by building only
particular DTB which is selected via defconfig
that Makefile doesn't need to contain all dts files in the repository.
Reported-by: Nathan Rossi <nathan@nathanrossi.com>
CPU_RELEASE_ADDR is used only when CONFIG_ARMV8_MULTIENTRY
is enabled. ZynqMP is running ATF which takes care about this
that's why no need to have this macro.
we removed 5xx support. So delete some forgotten remains.
we removed 82xx support. Missed some 82xx remains,
remove them now.
There was for long time no activity in the mpx5xxx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
Secure boot targets that can be loaded from an SD card FAT partition
need to be called "MLO" on the filesystem, make a copy with this name
to clarify the correct image for SD card booting.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
The for loop in cmd_keywords_opt_check() seems to use wrong array to
set boundary, reported by Coverity analysis.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Tom Rini <trini@konsulko.com>
CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reported-by: Coverity (CID: 163251)
To prevent possible double inclusions in future.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
For better readability and setup-handling we refactor the default
environment.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
This define isn't used anymore in the u-boot source tree, so we drop it
from the config header.
We drop it also from the 'config_whitelist.txt'
the BMP logo loading has become obsolete and is not used any more. So we
drop the support for it.
since commit
'd5abcf94c7123167725fc22ace342f0d455093c1' -
ti: boot: Register the MMC controllers in SPL in the same way as in u-boot
MMC boot on brxre1 board is broken, with this commit we make our board
working again.
Reviewed-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Adds CONFIG_SPL_USB_GADGET_SUPPORT and CONFIG_SPL_USBETH_SUPPORT.
Removes CONFIG_SPL_NAND_SUPPORT, CONFIG_SPL_MTD_SUPPORT, and CONFIG_SPL_YMODEM_SUPPORT
to free up space to fit in RAM.
Signed-off-by: Michael Welling <mwelling@ieee.org>
The terminator endif of ifdef _NAND_H_ should be at the
end of file as a fail safe.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
It turns out this change was not intended to be merged and as such,
revert it.
This reverts commit cdde7de0364ffa505d631b342f1a2fa729e8e67d.
Reported-by: Manfred Schlaegl <manfred.schlaegl@ginzinger.com>
Whistler is an ancient Tegra 2 reference board. I may have been the only
person who ever used it with upstream software, and I've just recycled
the board hardware. Hence, it makes sense to remove support from software.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Update maintainers for B4860QDS, P1010RDB, P1_TWR, T104xRDB.
Enable DHCP command by default. Update maintainer info.
Enable DHCP command by default. Move environmental variable location
to before U-Boot image. Enlarge reserved mem for malloc. Update
maintainer.
Commit a058052c changed the generic phy_reset() to clear all bits in
BMCR. This inevitably clears the ANEG bit. m88e1145 requires any
change to ANEG bit to be followed by a software reset. This seems to
be different from other PHYs. Implement read-modify-write procedure
for this PHY init.
Enable DHCP command to make TFTP easier.
Enable DDR interactive debug by default.
Fix compiling error of "no member named 'taamin_ps'" for DDR2.
Enable DHCP command to make TFTP easier. Users don't have to use
static IP address.
Drop support for these two legacy boards.
commit 0650798824 ("board: am335x: Introduce scale_vcores")
updated voltages of each board based on efuse. It updated
beagle bone specific voltages under the condition board_is_bone().
But this is true only for BeagleBoneWhite. Due to which voltages
are not configured for BBB, BBW as wrong device is being probed.
So create a common function board_is_beaglebonex() which includes
am335x based beagle family. Use this for updating voltages.
Also remove extra if condition for selecting voltages which is
done later using a switch case and match usb current limit as
before the commit 0650798824.
Fixes: 0650798824 ("board: am335x: Introduce scale_vcores")
Reported-by: Emmanuel Vadot <manu@bidouilliste.com>
Use eMMC (instead of SD card) to store U-Boot environment. Use
"reserved" partition for U-Boot environment.
Reviewed-by: Lokesh Vutla <lokeshvuta@ti.com>
Increase the size of u-boot.img, so that it conforms with new DFU
configuration (see commit [1]).
[1] 7a53a1a8115b ARM: ti: Update layout for MMC and eMMC (env and dfu)
Add myself as mpc83xx custodian.
refer in the README to tbots webpage, and delete
the README in tools/tbot, as the latest documentation
for tbot is on this webpage.
With Davinci I2C switching to device model, K2HK requires U-boot specific
device tree entries. This is only required for I2C 1 which is needed
extremely early during the boot process.
Fixes: 1743d040b1df ("ARM: keystone: Enable DM_I2C by default")
Reported-by: Yan Liu <yan-liu@ti.com>
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
The list of symbols listed in the error message for missing Kconfig
symbols is out of sync with the symbols actually tested.
Add the missing symbols and reorder their appearance to be in sync
with the #if statement for easier checking.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
