Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
The Nand flash was unable to read and write properly
due to Nand Chip Select (nCE) setup was in reverse
order. Also, increase the Nand time out value to 60.
Update PLATFORM_CPPFLAGS to accept 4.3.x version of
ColdFire compiler.
Default gzip bootm size is 8MB. Some platforms require
more than 8MB
The serial boot dram extended/standard mode register was not
setup and was using default DRAM setup causing the U-boot was
unstable to boot up in serial mode.
According to coldfire manual data timeout > address time out
also use correct macro to program XARB_CFG
Signed-off-by: Arun C <arunedarath@mistralsolutions.com>
Update CHANEGLOG, fix minor coding style issue.
The routine assumed 4 bank SDRAMs, enhance to configure for 4 or 8
bank SDRAMs.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Acked-by: Dave Liu <daveliu@freescale.com>
This patch makes sure the correct mask is applied when setting
the encryption and I2C bus 0 clock in SCCR.
Failing to do so may lead to ENCCM being 0 in which case I2C bus 0
won't function.
Signed-off-by: Norbert van Bolhuis <nvbolhuis@aimvalley.nl>
Read and store OMAP3 die ID in U-Boot environment.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Set a non-zero speed in the MII register so that MII commands will work.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
The rtl8139 driver use pci_mem_to_phys. So it need PCI system memory
registration.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Some register value was hardcoded for System memory size 128MB and
memory offset 0x08000000. This patch fixed the problem.
It is necessary for some pci device driver.
Commit af1c2b84 added a generic phy support, with an ID of zero
and a 32 bit mask; meaning that it will match on any PHY ID.
The problem is that there is a test that checked if a matching
PHY was found, and if not, it printed the non-matching ID.
But since there will always be a match (on the generic PHY,
worst case), this test will never trip.
In the case of a misconfigured PHY address, or of a PHY that
isn't explicitly supported outside of the generic support,
you will never see the ID of 0xffffffff, or the ID of the
real (but unsupported) chip. It will silently fall through
onto the generic support.
This change makes that test useful again, and ensures that
the selection of generic PHY support doesn't happen without
some sort of notice. It also makes it explicitly clear that
the generic PHY must be last in the PHY table.
Acked-by: Andy Fleming <afleming@freescale.com>
Fix typo in makefile which broke out of tree builds.
Also use expolicit "rm" instead of "ln -sf" which is known to be
unreliable.
This adds tsec12ioovcr to include/asm-ppc/immap_85xx.h (was reserved.)
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
These were left in accidentally, and are not really useful unless the
code is as broken as it was when it was being developed.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Commit e1be0d25, "32bit BUg fix for DDR2 on 8572" prevented other
sdram_cfg bits (such as ecc and self_refresh_in_sleep) from being set.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
unreliable.
lib_ppc/board.c
add CONFIG_BOOTCOUNT_LIMIT feature for 8360 CPU.
The bootcounter uses 8 bytes from the muram,
because no other memory was found on this
CPU for the bootcount feature. So we must
correct the muram size in DTS before booting
Linux.
This feature is actual only implemented for
MPC8360, because not all 83xx CPU have qe,
and therefore no muram, which this feature
uses.
old code implemented the QE_ENET10 errata only for Silicon
Revision 2.0. New code reads now the Silicon Revision
register and sets dependend on the Silicon Revision the
values as advised in the QE_ENET10 errata.
- HRCW update
HRCWH_BOOTSEQ_DISABLE not HRCWH_BOOTSEQ_NORMAL
HRCWH_LALE_EARLY added
- DDR-SDRAM settings modified. This solves sporadically
problems with this memory.
- CS1 now 128 MB window size
- CS3 now 512 MB window size
- PRAM activated
- MTDPARTS_DEFAULT defined
- CONFIG_HOSTNAME added
- MONITOR_LEN now 384 KB
it is possible that some board variants have different DDR II
RAM sizes. So we autodetect the size of the assembled RAM.
This patch adds I2C mux support for the fsl_i2c driver. This
allows you to add "new" i2c busses, which are reached over
i2c muxes. For more infos, please look in the README and
search for CONFIG_I2C_MUX.
This patch adds I2C support for the Keymile kmeter1 board.
It uses the First I2C Controller from the CPU, for
accessing 4 temperature sensors, an eeprom with IVM data
and the booteeprom over a pca9547 mux.
In case where a board not uses CONFIG_POST, it is not
necessary to init the DTTs when running from flash.
1. RD_TO_PRE missed to add the AL, and need min 2 clocks for
tRTP according to DDR2 JEDEC spec.
2. WRTORD - tWTR need min 2 clocks according to DDR2 JEDEC spec.
3. add the support of DDR2-533,667,800 DIMMs
4. cpo
5. make the AL to min to gain better performance.
The Micron MT9HTF6472CHY-667D1 DIMMs test passed on
MPC837xEMDS platform at 266MHz/333MHz/400MHz data rate.
items 1, 2 and 5:
Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Reported-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Signed-off-by: Dave Liu <daveliu@freescale.com>
The previous version rebooted forever with DDR bigger than 256MB.
Access the DS1339 RTC chip is on I2C1 bus.
Allow DHCP.
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
The SerDes initialization should be finished before negating the reset
signal according to the reference manual. This isn't an issue on real
hardware, but we'd better stick to the specifications anyway.
Suggested-by: Liu Dave <DaveLiu@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
it is not necessary to init the DTTs so early,
so move this init to board_init_r ().
Fix following warning while compilation for mcc200 board:
lcd.c: In function 'lcd_display_bitmap':
lcd.c:625: warning: unused variable 'cmap'
Fixes commit 407976185e0dda2c90e89027121a1071b9c77bfb
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
The smc911x driver has a lot of useful defines/functions which can be used
by pieces of code (such as example eeprom programmers). Rather than
forcing each place to duplicate these defines/functions, split them out
of the smdc911x driver into a local header.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Guennadi Liakhovetski <lg@denx.de>
CC: Magnus Lilja <lilja.magnus@gmail.com>
CC: Ben Warren <biggerbadderben@gmail.com>
