Select GPIO1 as the USB OTG ID pin for Nitrogen6x
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
desc is set at ep_enable, so for symmetry,
clear it at ep_disable.
Since we flush the TD, we may as well set it to a known value.
Make sure the transfer descriptor is flushed
before the queue is updated so that the controller
will not see old information.
This controller support full and high speed.
Change 'nfo=' to 'info='
This prevents a crash if tftpboot is given a bad filename.
rx_req will be released by eth_reset_config
which is called by eth_disconnect,
which is called using the .disconnect member of usb_gadget_driver by mv_pullup in mv_udc
which is called using the .pullup member of usb_gadget_ops by usb_gadget_disconnect
which is called by usb_eth_halt
which is called using the .halt member of eth_device by eth_halt
which is called by TftpHandler when TFTP_ERR_FILE_NOT_FOUND or TFTP_ERR_ACCESS_DENIED occurs
I trigger this with the following commands
setenv ipaddr 10.0.0.2 && setenv netmask 255.255.255.0 && setenv serverip 10.0.0.1
setenv usbnet_devaddr 00:11:22:33:44:55 && setenv usbnet_hostaddr 00:aa:bb:cc:dd:ee
setenv ethprime usb_ether && setenv ethact usb_ether && setenv ncip 10.0.0.1
tftpboot 10800000 10.0.0.1:missing_file
set wMaxPacketSize for full speed descriptors
fs_source_desc, fs_sink_desc to 64.
Full-speed bulk endpoint can have a maximum packet size of
8, 16, 32, or 64 bytes, so choice 64.
The hs_source_desc, hs_sink_desc, already have their wMaxPacketSize
set to 512. That is the only legal value for high speed bulk endpoints.
Strictly speaking, this patch is not needed because
usb_ep_autoconfig will call ep_matches which will
override wMaxPacketSize for BULK endpoints only with
the size associated with the endpoint setup by the udc driver.
But if you want to rely on this, you may as well combine the
full speed descriptor with the high speed descriptor to
minimize confusion.
Add the call back into the board file for to enable
the SMPS10 VBUS regulator.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Add the OMAP file for the xHCI Host controller
This code will initilialize the proper components within the
OMAP5 to enable the xHCI host controller.
Add the prcm registers and the bit definitions to enable the
USB SS port of the OMAP5 device.
Add new functionality to turn on SMPS10 regulator.
This supplies the VBUS to devices connected to the
USB host ports
This patch adds a new samsung,vbus-gpio parameter to the device tree, in
preparation of replacing the currently hardcoded VBUS GPIO mechanism in
exynos5-dt.c with a device tree controlled solution, just as it already
exists in the Linux kernel.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Some Exynos boards, such as the SMDK5250, control USB port power through
a GPIO pin. For now this had been hardcoded in the exynos5-dt board
file, but not all boards use the same pin, requiring local changes to
support different boards.
This patch moves the GPIO initialization into the USB host controller
drivers which they belong to, and uses the samsung,vbus-gpio parameter
in the device tree to configure it.
This enables support for xHCI host controller on Exynos5
and further disables EHCI support, to make sure only one
host controller is enabled at a time, since right now
using two controllers at a time is not possible with
current usb core infrastructure.
Anyone who wants to enable EHCI support again needs to
enable CONFIG_USB_EHCI, CONFIG_USB_EHCI_EXYNOS once again
in exynos5-dt config.
Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com>
Cc: Julius Werner <jwerner@chromium.org>
Cc: Dan Murphy <dmurphy@ti.com>
XHCI stack driver needs this to align buffers to
CacheLine boundary. So define the same to be '64'
Adding device node for xhci host controller to enable
usb 3.0 on exynos5250.
Adding required compatible string for xHCI host controller
as well as USB 3.0 PHY to enable dt support for usb 3.0 on
exynos5.
Adding methods to turn on/off power to USB3.0 type PHY
as and when required by the controller.
This adds driver layer for xHCI controller in Samsung's
exynos5 soc. This interacts with xHCI host controller stack.
This adds stack layer for eXtensible Host Controller Interface
which facilitates use of USB 3.0 in host mode.
Adapting xHCI host controller driver in linux-kernel
by Sarah Sharp to needs in u-boot.
Initial porting from Linux kernel version 3.4, with following
top commit history of drivers/usb/host/xhci* :
cf84055 xHCI: Cleanup isoc transfer ring when TD length mismatch found
This adds the basic xHCI host controller driver with bare minimum
features:
- Control/Bulk transfer support has been added with required
infrastructure for necessary xHC data structures.
- Stream protocol hasn't been supported yet.
- No support for quirky devices has been added.
Macros defining bmRequestType field of USB device request,
given in table 9.2 USB 2.0 spec, are rather generic macros
which can be further used by other Host controller stacks.
So moving them to usb_defs header.
The patch:
"blackfin: Move blackfin watchdog driver out of the blackfin arch folder."
(sha1: e9a389a18477c1c57a0b30e9ea8f4d38c6e26e63)
changed hw_watchdog_init() prototype which didn't match
with Microblaze one.
This patch fixes the driver and Microblaze initialization.
This bug was introduced by:
"Add GPL-2.0+ SPDX-License-Identifier to source files"
(sha1: 1a4596601fd395f3afb8f82f3f840c5e00bdd57a)
commit 39ac34473f3c96e77cbe03a49141771ed1639486 ("cmd_mtdparts: use 64
bits for flash size, partition size & offset") introduced warnings
in a couple places due to printf formats or pointer casting.
This patch fixes the warnings pointed out here:
http://lists.denx.de/pipermail/u-boot/2013-October/164981.html
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Tom Rini <trini@ti.com>
If dout buffer is not 32 bit-aligned or data to transmit is not multiple
of 32 bit the read data pointer is already incremented on single byte reads.
Signed-off-by: Timo Herbrecher <t.herbrecher@gateware.de>
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
As the spi flash transfer to multiple parts, it is forgot to add
Atmel AT25DF321 spi flash support, which broken several Atmel EK
boards which this chip. So, add it
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Added GPL-2.0+ SPDX-License-Identifier for missed spi
source files.
Added GPL-2.0+ SPDX-License-Identifier for missed sf
source files.
Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
- Add comments.
- Renamed few macros.
- Add tabs.
Unified the bank_sel calculation code for erase and
write ops.
python used in buildman doesn't need to be placed in
/usr/bin/python, So use env to ensure that the interpreter
will pick the python from environment.
Usefull with several versions of python's installed on system.
Pass a valid cmdtp into do_tftpb(), do_ext2load(), and do_get_fat(), to
avoid possible crashes due to null pointer dereferencing.
Commit d7884e047d08447dfd1374e9fa2fdf7ab36e56f5 does not go far enough.
There is still at least one call chain that can result in a crash.
The do_tftpb(), do_ext2load(), and do_get_fat() functions expect a valid
cmdtp. Passing in NULL is particularly bad in the do_tftpb() case,
because eventually boot_get_kernel() will be called with a NULL cmdtp:
do_tftpb() -> netboot_common() -> bootm_maybe_autostart() -> do_bootm()
-> do_bootm_states() -> bootm_find_os() -> boot_get_kernel()
Around line 991 in cmd_bootm.c, boot_get_kernel() will dereference the
null pointer, and the board will crash.
Signed-off-by: Steven A. Falco <stevenfalco@gmail.com>
[trini: Drop changes for PEP 4 following python tools]
Add a MAC address create based on the OMAP die ID registers.
Then poplulate the ethaddr enviroment variable so that the device
tree alias can be updated prior to boot.
0x1D is reserved. So BUCK3DVS1 is started from 0x1e.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
commit d196bd880347373237d73e0d115b4d51c68cf2ad adds
redundand environment to mmc. The usage of malloc in
env_relocate_spec triggers cache errors on armv7.
Tested on a not mainlined i.MX53 board:
Board: TQMa53
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57c2d8
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f57e2d8
ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57e2e0
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f5802e0
Using default environment
Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
As the SPI controller is not initialized before env_init(), it causes
reading env in dataflash failed. So, although saveenv() successfully,
it shows warning information when reboot the system as following:
*** Warning - bad CRC, using default environment
Let the env_relocate() to check env CRC and import it.
OMAP4 panda rev A6 is a 4430 es2.3 IC with an updated memory
part.
The panda rev A6 uses Elpida 2x4Gb memory and no longer uses Micron
so the timings needs to be updated
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
In [1] we discussed how we should deal with dual (or, more generally,
multiple) licensed files. Add this to Licenses/README so it's
properly documented.
[1] http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/166518
[trini: Add the word 'list' to the end of the line, per Stephen Warren's
feedback]
