Add a new option '-E' for treating all compiler warnings as errors.
Eventually this will pass 'KCFLAGS=-Werror' to Kbuild.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Probably not all users are aware of this possibility, thus add a
pointer to the README. Also add a useful example.
Free Electrons is no more and is now known as Bootlin, change my email
address accordingly.
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
This patch adds a sec_init call into arch_misc_init(). Doing so in
conjunction with the patch "drivers/crypto/fsl: assign job-rings to
non-TrustZone" enables use of the CAAM in Linux when OPTEE/TrustZone is
active.
u-boot will initialise the RNG and assign ownership of the job-ring
registers to a non-TrustZone context. With recent changes by Lukas Auer to
fully initialize the RNG in sec_init() this means that u-boot will hand-off
the CAAM in a state that Linux then can use the CAAM without touching the
reserved DECO registers.
This change is safe both for the OPTEE/TrustZone boot path and the regular
non-OPTEE/TrustZone boot path.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Marco Franchi <marco.franchi@nxp.com>
Cc: Vanessa Maegima <vanessa.maegima@nxp.com>
Cc: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Tested-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
After enabling TrustZone various parts of the CAAM silicon become
inaccessible to non TrustZone contexts. The job-ring registers are designed
to allow non TrustZone contexts like Linux to still submit jobs to CAAM
even after TrustZone has been enabled.
The default job-ring permissions after the BootROM look like this for
job-ring zero.
ms=0x00008001 ls=0x00008001
The MS field is JRaMIDR_MS (job ring MID most significant).
Referring to "Security Reference Manual for i.MX 7Dual and 7Solo
Applications Processors, Rev. 0, 03/2017" section 8.10.4 we see that
JROWN_NS controls whether or not a job-ring is accessible from non
TrustZone.
Bit 15 (TrustZone) is the logical inverse of bit 3 hence the above value of
0x8001 shows that JROWN_NS=0 and TrustZone=1.
Clearly then as soon as TrustZone becomes active the job-ring registers are
no longer accessible from Linux, which is not what we want.
This patch explicitly sets all job-ring registers to JROWN_NS=1 (non
TrustZone) by default and to the Non-Secure MID 001. Both settings are
required to successfully assign a job-ring to non-secure mode. If a piece
of TrustZone firmware requires ownership of job-ring registers it can unset
the JROWN_NS bit itself.
This patch in conjunction with a modification of the Linux kernel to skip
HWRNG initialisation makes CAAM usable to Linux with TrustZone enabled.
Cc: Alex Porosanu <alexandru.porosanu@nxp.com>
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@nxp.com>
Link: https://github.com/OP-TEE/optee_os/issues/1408
Link: https://tinyurl.com/yam5gv9a
We should take the MX6DP and MX6QP options in consideration
in the I2C_PADS_INFO macro.
Based on a patch by Pierluigi Passaro <pierluigi.p@variscite.com>
Signed-off-by: Eran Matityahu <eran.m@variscite.com>
when defining imx_iomux_v3_setup_pad().
The original text is from the time that the config options were not
converted to Kconfig.
After the conversion to Kconfig only CONFIG_SECURE_BOOT and
CONFIG_CMD_DEKBLOB need to be selected by the user.
The other config options are automatically selected by the Kconfig
logic.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Breno Lima <breno.lima@nxp.com>
The input keycode KEY_POWER is used in the imx6ull.dtsi file,
hence include the input header where used.
fastboot tool is a convenient way to flash the eMMC, so
add support for it.
Examples of usages:
On the mx6sabresd:
=> fastboot 0
On the Linux PC connected via USB:
$ sudo fastboot getvar bootloader-version -i 0x0525
bootloader-version: U-Boot 2018.01-00550-g7517cfe
finished. total time: 0.000s
$ sudo fastboot reboot -i 0x0525
(this causes the mx6sabresd to reboot)
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Select CONFIG_CMD_USB_MASS_STORAGE so that the 'ums' can be used.
Selecting CONFIG_USB_FUNCTION_MASS_STORAGE=y in the defconfig leads to
the following error:
cmd/built-in.o: In function `do_usb_mass_storage':
cmd/usb_mass_storage.c:217: undefined reference to `fsg_main_thread'
cmd/usb_mass_storage.c:170: undefined reference to `fsg_init'
CONFIG_USB_FUNCTION_MASS_STORAGE option is built only for
the non-SPL case as per the logic in drivers/usb/gadget/Makefile,
so remove the incorrect CONFIG_SPL ifdefery to fix the build
failure.
Add board specific imx config file with recommended IPU Qos settings
and adapted DDR configuration.
Signed-off-by: Soeren Moch <smoch@web.de>
SION bit should be used in the situation that we need
to read back the value of a pin and should not be set by
default macro.
We get some malfunction as raised by following thread
https://www.spinics.net/lists/linux-usb/msg162574.html
As reported by this application note:
https://www.nxp.com/docs/en/application-note/AN5078.pdf
The software input on (SION) bit is an option to force an input
path to be active regardless of the value driven by the
corresponding module. It is used when the nature direction
of a pin depending on selected alternative function is an output,
but it is needed to read the real logic value on a pin.
The SION bit can be used in:
• Loopback: the module of a selected alternative function drives
the pad and also receives the pad value as an input
• GPIO capture: the module of a selected alternative function
drives the pin and the value is captured by the GPIO
SION bit is not necessary when the pin is configured as a peripheral
apart specific silicon bug. If an application needs to have this
set, this should be done in board file or in dts file
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
Enable UHS and HS200 for mx7dsabresd.
Read Speed improvement:
Kingston SD10VG2/16GB SDHC 3.0 card
22.2MB/s -> 73.7MB/s
eMMC5.0 MTFC8GACAEAM:
68MB/s -> 87MB/s
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Introduce SDR104 and HS200 support
The implementation takes linux kernel sdhci.c and sdhci-esdhc-imx.c
as reference.
- Implement esdhc_change_pinstate to dynamically change pad settings
- Implement esdhc_set_timing
- Implement esdhc_set_voltage to switch voltage
- Implement fsl_esdhc_execute_tuning to execute time process
- Enlarge the cfg->f_max to 200MHz.
- Parse fsl,tuning-step, fsl,tuning-start-tap and
fsl,strobe-dll-delay-target from device tree.
- Parse no-1-8-v property
- Introduce esdhc_soc_data to indicate the flags and caps
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
The pinmux and tuning settings are from
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/
arm/boot/dts/imx7s.dtsi?h=imx_4.9.11_1.0.0_ga
arm/boot/dts/imx7d-sdb.dts?h=imx_4.9.11_1.0.0_ga
To support HS200 and SDR104, we need change pinmux settings dynamically.
And configure tuning step and start tuning tap, otherwise you may
see tuning failure.
Add entries that will be used for tuning control.
The whole layout not changed, just expand reserved3[84] and
rename other reservedx in sequence.
The board header file included a reference to the starting point
from nitrogen6x.h, but since so much changed, the file bears
little resemblance to that file.
Signed-off-by: Eric Nelson <eric@nelint.com>
The initial implementation of mx6memcal reset the CPU after
running the memory calibration procedure because the generic
board has no information about which boot devices are available.
Now that we have SDP support in SPL, use it to allow a full
U-Boot to be uploaded (i.e. to use "mtest").
This patch just changes the order of configuration items in
mx6memcal_defconfig to match the Kconfig layout, making it easier
to track changes made using menuconfig.
Static variables are not available during board_init_f().
'static uint32_t mx53_dram_size[2];' was used in board specific
dram_init(), dram_init_banksize() and get_effective_memsize() to avoid
multiple calls to get_ram_size().
Reused dram initialization functions from arch/arm/mach-imx/mx5/mx53_dram.c
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Move dram_init(), dram_init_banksize() and get_effective_memsize() to
arch/arm/mach-imx/mx5/mx53_dram.c, where it can be reused by m53evk and
mx53loco.
However multiple calls are better than undefined behavior...
This fixes:
https://lists.denx.de/pipermail/u-boot/2017-November/313214.html
https://lists.denx.de/pipermail/u-boot/2017-December/314480.html
Validate the time at startup:
- in case rtc error add to kernel command line RTC_ERROR
- clamp date to 1-Jan-2036
Signed-off-by: Nandor Han <nandor.han@ge.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
message
The exact definition of a successful boot is defined by user-space.
Determine the boot partition automatically. A partition is selected if
file `/boot/bootcause/firstboot' exists (meaning that the partition has
freshly installed software) OR if file `/boot/fitImage' exists.
When userspace determines that new software was successfully installed,
it must (1) delete `/boot/fitImage' on the _inactive_ partition and (2)
remove `/boot/bootcause/firstboot'.
Enable video, but do not display logos or other version information.
Silence kernel console logging by default.
Print a message to VGA screen in case of boot failure and reset bootcount
to allow the user to attempt boot again.
Signed-off-by: Ian Ray <ian.ray@ge.com>
Change the kernel command line to mount the root filesystem read-only in
order to be able to run filesystem check on it on boot.
Signed-off-by: Hannu Lounento <hannu.lounento@ge.com>
Enable bootcount using an EXT file.
Read boot script from shared partition, if available.
Modify configuration to support FIT. Set variable `confidx' from VPD,
in order to load the correct device tree. Modify/simplify U-Boot
environment to support loading FIT image.
Enable the hardware watchdog on bx50v3 to cause it to reset in the event
the board hangs.
Configure GPIO_9 pin as WDOG1_B so that a watchdog timeout results in a
full system reset.
The watchdog is used and reconfigured by systemd approximately 1.7 seconds
into boot. Adding a few seconds for U-Boot and a few more seconds as a
safety margin.
Note that the PCIe controller is _not_ put back into a safe state prior
to board reset. This is a problem if board reset is implemented as CPU
reset.
There are two I210s on the b850v3 and one on the b450v3 and b650v3.
One is connected to Marvell 88e6240 which is already programmed.
Follow the flow documented in doc/README.enetaddr: set the
enet[0-9]*addr environment variable and let the driver program the
hardware.
The mapping from the driver's index to the environment variable's name
is documented in README: Note for Redundant Ethernet Interfaces. It is
assumed that eth_devices for the controllers on the board are always
indexed in the same order.
The environment variables are removed after programming the hardware
because the variables seem to influence MAC addresses also after U-Boot.
Specifically the MAC address of FEC (MC interface) would be incorrectly
set: 'ethaddr', which maps to the first I210 chip and is set to I210's
default address read from the driver by eth_write_hwaddr in eth_legacy.c
because the variable is undefined (not set even by bx50v3.c), would
result in the eth0 interface's MAC address to be set to I210's default
address.
Instead of programming the hardware directly in the board
implementation, follow the flow documented in doc/README.enetaddr: set
the enet[0-9]*addr environment variable and let the driver program the
hardware.
This avoids duplicating the implementation as it already exists in the
driver (drivers/net/fec_mxc.c: fec_set_hwaddr).
indexed in the same order, i.e. FEC always has the index 2.
The FEC driver does *not* set the flag Set MAC Address on Transmit (bit
set_eth0_mac_address used to do but this is unnecessary as the Linux
networking stack fills in the MAC address.
Modify b450v3, b650v3 and b850v3 defconfigs to enable the network devices
found in these products.
The change in i2c configuration added to support access to the VPD has
inadvertantly caused access to i2c buses 1 & 2 to be lost. This has
resulted in the configuration for the PMIC to be attempted on the wrong
bus and thus isn't taking effect.
Add the required configuration to return access to buses 1 & 2. In order
to ensure that any users of the bus numbering prior to addition in VPD
patches work, add buses before configuration related to mux on bus 0 and
tweak VPD bus usage to fit new numbering scheme.
Add a new driver for RX8010SJ rtc chip. The driver implements both
formats of U-Boot driver model.
Implement programming MAC address to the hardware, i.e. external flash
seen as EEPROM.
MAC address is only written if it differs from what is already stored in
flash or if reading the current MAC address fails.
CC: Joe Hershberger <joe.hershberger@ni.com>
Split the implementation of e1000_read_mac_addr into eeprom and register
versions called by e1000_read_mac_addr.
This allows for calling e1000_read_mac_addr when MAC address is needed
with no constraints where it is read from, and for calling the register
and, especially, the eeprom version directly in order to specify where
to read the address from.
Port functions for writing to EEPROM, updating the checksum and
committing data to flash from the Linux kernel igb driver.
Functions were ported from Linux 4.8-rc2 (694d0d0bb20).
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add ddrc memory map and enum types used in ddr initialization.
Allow the dm driver be omitted by SPL.
Add dtsi file for i.MX8MQ.
When building for 64bits system, we get some warnings about type
cast between pointer and integer. This patch eliminates the warnings
by using ulong/long type which is 32bits on 32bits system or 64bits on
64bits system.
Signed-off-by: Ye Li <ye.li@nxp.com>
The MIB RAM and FIFO receive start register does not exist on
i.MX8M. Accessing these register will cause system hang.
Add i.MX8M GPIO support.
There are 4 GPIO banks on i.MX8M.
Include i.MX8M in lcdif register layout map.
Also included i.MX7ULP in this patch, since share same with i.MX8M.
Support i.MX8M in fsl esdhc driver.
