2012-01-16include/configs/omap3_overo.h: several cleanupsAndreas Müller
* remove unused macros * remove unused macro values * align tabs * remove Free Software Foundation address Signed-off-by: Andreas Müller <schnitzeltony@gmx.de>
2012-01-16board/overo/overo.c: replace printf with one argument by putsAndreas Müller
2012-01-16drivers/i2c/omap24xx_i2c.c: replace printf with one argument by putsAndreas Müller
Signed-off-by: Andreas Müller <schnitzeltony@gmx.de> Acked-by: Heiko Schocher <hs@denx.de>
2012-01-16ARM:AM33XX: Add SPL support for AM335X EVMChandan Nath
This patch is added to support SPL feature on AM335X platform. In this patch, MMC1 is configured as boot device for SPL and support for other devices will be added in the next patch series. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16ARM:AM33XX: Add mmc/sd supportChandan Nath
This patch add supports for mmc/sd driver on AM335X platform. PLL and pinmux configurations for mmc/sd are configured in this patch. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16ARM:AM33XX: Fixing AM335X config parametersChandan Nath
This patch is added to correct some of the AM335X config parameters which were incorrect along with some cleanup like removing unused code. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16ARM:AM33XX: Fix ddr and timer register offsetChandan Nath
This patch is added to update incorrect ddr and timer register offset. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16ARM:AM33XX: Replace CONFIG_AM335X with CONFIG_AM33XXChandan Nath
This patch is added to replace CONFIG_AM335X symbol with CONFIG_AM333XX for AM33XX platforms. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Thomas Weber <weber@corscience.de>
2012-01-16cm-t35: use the new EEPROM module to read the MAC addressNikita Kiryanov
Switch to the new EEPROM module and fix the problem of MAC address being read from the wrong offset due to lack of distinction between EEPROM layouts. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: pass correct revision information to LinuxNikita Kiryanov
Read revision from EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16omap3: make get_board_rev() function weakNikita Kiryanov
Current get_board_rev() function returns a hard coded value which is obviously incorrect for the majority of boards. Allow boards to provide a correct implementation by making this function weak. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: add EEPROM module and pass Linux a serial numberNikita Kiryanov
Add board specific EEPROM handling module, read the serial number from the EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: various cleanupsNikita Kiryanov
Move #ifdef CONFIG_SMC911X out of board_eth_init() function, simplify the board_mmc_init() function, and enclose handle_mac_address() in the CONFIG_SMC911X. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: cleanup the config fileNikita Kiryanov
Remove values from boolean defines, fix indentation, etc.. No functional changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16omap4: fix boot issue on ES2.0 PandaAneesh V
Fix boot issue on ES2.0 Panda by tuning some IO settings. The CONTROL_EFUSE_2 register has to be over-ridden in software for 4430 boards. Commit 23e9f0723e48615332119de4f4ec7a833a282628 wrongly did this for CONTROL_EFUSE_1. Reverting this and doing it for CONTROL_EFUSE_2. Signed-off-by: Aneesh V <aneesh@ti.com> Tested-by: Raúl Porcel <armin76@gentoo.org>
2012-01-16beagle: add eeprom expansion board info for bct brettl3Peter Meerwald
this is for a prototyping board vendor/product ids have been added to http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs
2012-01-16ARMV7: Add support For Logic OMAP35x/DM37x modulesPeter Barada
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo reference boards. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16arm, davinci: Change byte order of RTC kick register valuesChristian Riesch
Now the values in the defines agree with those in the manuals. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2012-01-16da850evm: Remove CONFIG_SYS_xxCACHE_OFF definesChristian Riesch
This patch removes the defines CONFIG_SYS_ICACHE_OFF, CONFIG_SYS_DCACHE_OFF, and CONFIG_SYS_L2CACHE_OFF from the board configuration. These defines are useless since cache is anyway disabled for the entire architecture since commit cba4b1809f043bf85c806e5a4e342f62bd5ded45. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com>
2012-01-16arm, davinci: Use a common configuration file for da850evm and da850_am18xxevmChristian Riesch
In commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783 a separate header file was introduced for the AM1808 EVM, include/configs/da850_am18xxevm.h. Before this commit, the da850evm.h configuration file was used for both the AM1808 and the OMAP-L138 EVMs. The only substantial difference between the da850evm and the da850_am18xxevm configuration is a single bit in the hardware revision that is passed to the Linux kernel. This patch removes include/configs/da850_am18xxevm.h. Instead the include/configs/da850evm.h configuration is used for AM18xx EVMs and CONFIG_DA850_AM18X_EVM is defined in boards.cfg. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com>
2012-01-16i.mx: i.mx6q: add the initial support for i.mx6q Sabre Lite boardJason Liu
Add the initial support for Freescale i.MX6Q Sabre Lite board Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Jason Liu <jason.hui@linaro.org> CC: Eric Nelson <eric.nelson@boundarydevices.com>
2012-01-16imx: mx6q: add aipstz init for off platform periphJason Liu
Init peripheral access control register of AIPSTZ OPACRx: Buffer Writes(BW): 0 -> not bufferable, Supervisor Protect(SP): 0 -> not require supervisor privilege level for accesses. Write Protect(WP): 0 -> allows write accesses. Trusted Protect(TP): 0 -> allows unstrusted master Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de>
2012-01-16mx28: fix clearing of IRQs in power initZach Sadecki
There are 2 locations in the power init code for the mx28 where IRQs are not being cleared because incorrect methods to clear those bits were being used. This was causing my board to get stuck waiting for POWER_CTRL_VDD5V_DROOP_IRQ to clear. Using the correct method to clear the IRQs fixes it. Signed-off-by: Zach Sadecki <zach@itwatchdogs.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16M28EVK: Fix build if CONFIG_CMD_NAND not selectedMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-01-16m28evk: Remove 'all' target from MakefileFabio Estevam
Remove 'all' target from Makefile, as this is unused code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16m28evk: Use GENERATED_GBL_DATA_SIZEFabio Estevam
Use GENERATED_GBL_DATA_SIZE for calculating CONFIG_SYS_INIT_SP_OFFSET. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-01-16mx28evk: Remove 'all' target from MakefileFabio Estevam
2012-01-16MX28: Fix MXSBOOT segfault if no params specifiedMarek Vasut
2012-01-16i.mx6:imx6q: allign MAC address with burned-in orderingJason Liu
For the i.mx6q, the burned-in MAC address will be the following odering, fuse: 0x620[7:0] MAC_ADDR[7:0] ---> mac[5] fuse: 0x620[15:8] MAC_ADDR[15:8] ---> mac[4] fuse: 0x620[23:16] MAC_ADDR[23:16] ---> mac[3] fuse: 0x620[31:24] MAC_ADDR[31:24] ---> mac[2] fuse: 0x630[7:0] MAC_ADDR[39:32] ---> mac[1] fuse: 0x630[15:8] MAC_ADDR[47:40] ---> mac[0] This patch also fix the error caculation for the fuse bank[0] address Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de>
2012-01-16mx28evk: Add initial support for MX28EVK boardFabio Estevam
Add initial support for Freescale MX28EVK board. Tested boot via SD card and by loading a kernel via TFTP through the FEC interface. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16mx28: Let dram_init be common for mx28Fabio Estevam
Let dram_init function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28: Let imx_get_mac_from_fuse be common for mx28Fabio Estevam
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16net: imx: Add multi-FEC support for imx_get_mac_from_fuseFabio Estevam
Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter. This feature is important on mx28 SoC for example that has two FEC ports. Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16i.mx6q: mx6qarm2: Enable the usboh3 clockEric Nelson
Bits 0 and 1 of CCM_CCGR7 are the usboh3 clock enable bits. Enabling this clock is necessary for the USB download. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> CC: Jason Hui <jason.hui@linaro.org> Acked-by: Jason Hui <jason.hui@linaro.org>
2012-01-16mx28: remove omap specific config optionsVeli-Pekka Peltola
Config options for OMAP are not used with i.MX28 so remove dead code. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16i.mx6q: arm2: Add the enet function supportJason Liu
This enable the network function on the i.mx6q armadillo2 board(arm2), thus we can use tftp to load image from network. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jason Liu <jason.hui@linaro.org> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-01-16fec: add the i.mx6q enet driver supportJason Liu
Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jason Liu <jason.hui@linaro.org> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16i.mx: i.mx6q: Add the enet clock functionJason Liu
2012-01-13openrisc: Add MAINTAINERS entryStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2012-01-13openrisc: Add architecture to MAKEALLStefan Kristiansson
2012-01-13openrisc: Add openrisc-generic example boardStefan Kristiansson
2012-01-13openrisc: Add support for standalone programsStefan Kristiansson
2012-01-13openrisc: Add board info printout to cmd_bdinfoStefan Kristiansson
2012-01-13openrisc: Add library functionsStefan Kristiansson
2012-01-13openrisc: Add cpu filesStefan Kristiansson
2012-01-13openrisc: Add architecture image supportStefan Kristiansson
2012-01-13openrisc: Add architecture header filesStefan Kristiansson
2012-01-13Strip mkenvimageDavid Wagner
Signed-off-by: David Wagner <david.wagner@free-electrons.com>
2012-01-13post/Makefile: Only build FP post tests if enabled via CONFIG_SYS_POST_FPUKumar Gala
