This explicitly sets VUSB voltage to 3.3V when enabling USB.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This correctly enables the USB PHY clocks, by enabling CM_ALWON_USBPHY_CLKCTRL
and correctly setting CM_L3INIT_USBPHY_CLKCTRL's value.
On (at least) OMAP4, the USB DPLL is required to be setup for the internal PHY
to work properly. The internal PHY is used by default with the MUSB USB OTG
controller.
The Amazon Kindle Fire (first generation) codename kc1 is a tablet that was
released by Amazon back in 2011.
It is using an OMAP4430 SoC GP version, which allows running U-Boot and the
U-Boot SPL from the ground up.
I2C is often enabled withing the U-Boot SPL, thus those clocks are required to
be enabled early (especially when the bootrom doesn't enable them for us).
This removes a duplicate reference to CM_L3INIT_USBPHY_CLKCTRLin
enable_basic_uboot_clocks. Also, a doubled whitespace is removed.
save_omap_boot_params is called from spl_board_init in the SPL context. Thus,
there is no reason to duplicate that call on arch_cpu_init.
There is no distinction between essential and non-essential mux configuration,
so it doesn't make sense to have an "essential" prefix.
Individual boards might provide their own emif_get_device_timings function and
use the jedec timings in their own way, hence those have to be exported.
use the elpidia timings in their own way, hence those have to be exported.
Individual boards might provide their own emif_get_device_details function and
use elpidia device details in their own way, hence those have to be exported.
This also wraps existing definitions with the proper ifdef logic.
Boards using the TWL6030 regulator may not all use the LDOs the same way.
Some might also not use MMC1 at all, so VMMC would't have to be enabled.
This delegates TWL6030 MMC power initializations to board-specific functions,
that may still call twl6030_power_mmc_init for the default behavior.
Not every device has multiple MMC slots available, so it makes sense to enable
only the required LDOs for the available slots. Generic code in omap_hsmmc will
enable both VMMC and VAUX1, in doubt.
This enables the VAUX1 supply, used for eMMC power in standard configurations.
Its voltage is determined by the value of the BOOT2 pin of the TWL6030.
Note that the TWL6030 might already have enabled this regulator at startup
(depending on the value of the BOOT3 pin of the TWL6030), according to the
TWL6030 datasheet.
This makes the twl6030 mmc and usb-related power registers and values
definitions more explicit and clear and adds prefixes to them.
Reboot mode garbage is found on cold reset and might be seen as valid on the
next warm reset, thus it has to be cleared on cold reset.
There is no need to set the reboot mode to a particular value prior to reboot,
since valid values will have been caught and cleared earlier.
In addition, this breaks the reboot-bootloader fastboot call, by overriding the
required value for fastboot.
This introduces a define for the offset to the reboot reason, rather than
hardcoding it.
This switches reboot mode handling to a string-based interface, that allows more
flexibility to set a common interface with the next generations of OMAP devices.
Global definition of priv seems no-sense to use it
for non-dm case and pass the pointer to functions
which are common to both dm and non-dm.
So, fix this by removing omap3_spi_slave from non-dm
and make visible to omap3_spi_priv for both dm and non-dm.
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Reported-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
To make SPL_OF_CONTROL work on ARM64 SoCs, _image_binary_end must be
defined in the linker script.
LD spl/u-boot-spl
lib/built-in.o: In function `fdtdec_setup':
lib/fdtdec.c:1186: undefined reference to `_image_binary_end'
make[1]: *** [spl/u-boot-spl] Error 1
make: *** [spl/u-boot-spl] Error 2
Note:
CONFIG_SPL_SEPARATE_BSS must be defined as well on ARM64 SoCs.
All the mux configurations needs to be done as part of the IODelay
sequence to avoid glitch. Adding all the mux configuration, MANUAL/VIRTUAL
mode configuration as needed for DRA72-evm.
Also update the mux for SD card detect on DRA74-evm.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Vignesh R <vigneshr@ti.com>
Updating the memory banks properly so that DT is populated accordingly.
And updating this only after DDR is properly detected by eeprom, so that
git bisect is still maintained.
Acked-by: Nishanth Menon <nm@ti.com>
The REVH and later versions of DRA7-evm uses MICRON MT41K512M16HA-125 memory
chips which is of size 4GB(2GB on EMIF1 and 2GB on EMIF2). Add support for the
same.
Enable configs that are required for detecting memory > 2GB.
The newer versions of DRA7 boards has EEPROM populated with DDR
size specified in it. Moving DRA7 specific emif related settings
to board files so that emif settings can be identified based on EEPROM.
Enable EEPROM support for DRA74-evm.
DRA7 EVM revH and later EVMs have EEPROM populated that can contain board
description information such as name, revision, DDR definition, etc. Adding
support for this EEPROM format.
There are certain EMIF timing failures seen on the some x15 boards. Updating
the EMIF settings to get rid of these timing failures.
A few boards still use ns16550_platdata structures, but assume the structure
is going to be in a specific order. By explicitly naming each entry,
this should also help 'future-proof' in the event the structure changes.
Tested on the Logic PD Torpedo + Wireless.
I only changed a handful of devices that used the same syntax as the Logic
board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods
and Alexander Graf.
V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c
V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c
V4: Fix subject heading
V3: Remove reg_offset out in all the structs. It was reverted out, and and if
it did exist, it would get initialized to 0 by default.
V2: I hastily copy-pasted the boards without looking at the UART number.
This addresses 3 boards that use UART3 and not UART1.
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Early system initialization is being done before initf_dm is being called
in U-Boot. Then system will fail to boot if any of the DM enabled driver
is being called in this system initialization code. So, rearrange the
code a bit so that DM enabled drivers can be called during early system
initialization.
Given that DRA7/OMAP5 SoCs can support more than 2GB of memory,
enable interleaving for this higher memory to increase performance.
Read and write leveling can be enabled independently. Check for these
enable bits before updating the read and write leveling output values.
This will allow to use the combination of software and hardware leveling.
Commit (20fae0a - ARM: DRA7: DDR: Enable SR in Power Management Control)
enables Self refresh mode by default and during warm reset the EMIF
contents are preserved. After warm reset EMIF sees that it is idle and
puts DDR in self-refresh. When in SR, leveling operations cannot be done
as DDR can only accept SR exit command, so its hanging during warm reset.
In order to fix this reset the power management control register before
EMIF initialization if it is a warm reset.
On DRA7, refresh ctrl shadow should be updated with
the final value.
OMAP timer driver directly typecasts fdt_addr_t to a pointer. This is
not strictly correct, as it gives a build warning when fdt_addr_t is u64.
So, use map_physmem for a proper typecasts.
This is inspired by commit 167efe01bc5a9 ("dm: ns16550: Use an address
instead of a pointer for the uart base")
Because KS2 u-boot works in 32 bit address space the existing ram_size
global data field cannot be used. The maximum, which the get_ram_size()
can detect is 2GB only. The ft_board_setup() needs the actual ddr3 size
to fix up dtb.
This commit introduces the ddr3_get_size() which uses SPD data to
calculate the ddr3 size. This function replaces the "ddr3_size"
environment variable, which was used to get the SODIMM size.
For platforms, which don't have SODIMM with SPD and ddr3 is populated to
a board a simple ddr3_get_size function that returns ddr3 size has to be
implemented. See hardware-k2l.h
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
This commit replaces hard-coded EMIF and PHY DDR3 configurations for
predefined SODIMMs to a calculated configuration. The SODIMM parameters
are read from SODIMM's SPD and used to calculated the configuration.
The current commit supports calculation for DDR3 with 1600MHz and 1333MHz
only.
The maximum device and arm speeds can be determined by reading
EFUSE_BOOTROM register. As there is already a framework for reading this
register, adding support for all possible speeds on k2g devices.
Its not compulsory that speed definition should be same on EFUSE_BOOTROM
register for all keystone 2 devices. So, allow for board specific
speed definitions.
The DSPs are powered on by default upon a Power ON reset, and
they are powered off on current Keystone 2 SoCs - K2HK, K2L, K2E
during the boot in u-boot. This is not functional on K2G though.
Extend the existing DSP power-off support to the only DSP present
on K2G. Do note that the PSC clock domain module id for DSP on K2G
differs from that of previous Keystone2 SoCs.
Signed-off-by: Suman Anna <s-anna@ti.com>
Define a macro for the DSP GEM power domain id number and
use it instead of a hard-coded number in the code that
disables all the DSPs on various Keystone2 SoCs.
These cyg_ prototypes are not referenced anywhere in current mainline
U-Boot. So lets remove them.
The original name of this function is unclear. This patch renames this
CRC16 function to crc16_ccitt() matching its name with its
implementation.
To make the usage of this function more flexible, lets add the CRC start
value as parameter to this function. This way it can be used by other
functions requiring different start values than 0 as well.
lib/crc16.c is changed to match the common U-Boot coding-style.
FIT image supports more than 32 bits in addresses by using #address-cell
field. Fixing 64-bit support by using this field.
Signed-off-by: York Sun <york.sun@nxp.com>
