Clocks are an important feature of platforms and have become increasing
complex with time. Most modern SoCs have multiple PLLs and dozens of clock
dividers which distribute clocks to on-chip peripherals.
Some SoC implementations have a clock API which is private to that SoC family,
e.g. Tegra and Exynos. This is useful but it would be better to have a
common API that can be understood and used throughout U-Boot.
Add a simple clock API as a starting point. It supports querying and setting
the rate of a clock. Each clock is a device. To reduce memory and processing
overhead the concept of peripheral clocks is provided. These do not need to
be explicit devices - it is possible to write a driver that can adjust the
I2C clock (for example) without an explicit I2C clock device. This can
dramatically reduce the number of devices (and associated overhead) in a
complex SoC.
Clocks are referenced by a number, and it is expected that SoCs will define
that numbering themselves via an enum.
Since we want clk_ops to be used in U-Boot as a whole, rename the Zynq
version until it can be converted to driver model.
It is common for system reset to be available at multiple levels in modern
hardware. For example, an SoC may provide a reset option, and a board may
provide its own reset for reasons of security or thoroughness. It is useful
to be able to model this hardware without hard-coding the behaviour in the
SoC or board. Also there is a distinction sometimes between resetting just
the CPU (leaving GPIO state alone) and resetting all the PMICs, just cutting
power.
To achieve this, add a simple system reset uclass. It allows multiple devices
to provide reset functionality and provides a way to walk through them,
requesting a particular reset type until is it provided.
Some functions called by mkimage would like to know the output file size.
Initially this is the same as the input file size, but it may be affected by
adding headers, etc.
Add this information to the image parameters.
As a debug option, add positive confirmation that SPL has completed
execution. This can help with diagnosing the location of unexpected hangs.
Add an spl_init() function that does basic init such that board_init_f() can
use simple malloc(), device tree and driver model. Each one is set up only
if enabled for SPL.
Note: We really should refactor SPL such that there is a single
board_init_f() and rename the existing weak board_init_f() functions
provided by boards, calling them from the single board_init_f().
It can be quite confusing with a new platform to figure out why the device
tree cannot be located. Add some debug information for this case.
Split out the code in fdtdec which finds a number at the end of a string. It
can be useful in other situations.
Add an implementation of RC4. This will be used by Rockchip booting but may
Since Rockchip requires 32-bit serial access, add this to the driver.
Refactor a little to make this easier.
Several functions in this file should be marked as static. Update them.
Add support for a driver which sets up DRAM and can return information about
the amount of RAM available. This is a first step towards moving RAM init
to driver model.
This bloats the code size quite a bit and is less useful in SPL where there
is no command line.
Avoid including this code in SPL.
This functionality may be useful for setting up regulators early during
boot.
It is a common requirement to update some PMIC registers. Provide some
simple convenience functions to do this.
Tested-by: Przemyslaw Marczak <p.marczak@samsung.com>
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
To reduce unnecessary code size in an uncommon code path, use debug()
where possible(). The driver returns an error which indicates failure.
The device tree provides information about which regulators should be
on at boot, or always on. Use this to set them up automatically.
The regulator_autoset() function mixes printf() output and PMIC adjustment
code. It provides a boolean to control the output. It is better to avoid
missing logic and output, and this permits a smaller SPL code size. So
split the output into a separate function.
Also rename the function to have a by_name() suffix, since we would like
to be able to pass a device when we know it, and thus avoid the name
search.
Decide when the regulator is set up whether we want to auto-set the voltage
or current. This avoids the complex logic spilling into the processing code.
This is not user input (i.e. from the command line). It should be possible
to get the case correct and avoid the case-insensitive match. This will
help avoid sloppy device tree setups.
It took a little while to figure this out, so this patch adds documentation
to help the next person who needs to do this.
Enable MMC using driver model in SPL for consistency with U-Boot proper.
Allow read errors to be diagnosed more easily.
Add basic support for MMC, providing a uclass which can set up an MMC
device. This allows MMC drivers to move to using driver model.
Add a few messages to indicate progress and failure.
Add a simple driver which allows use of LEDs attached to GPIOs. The linux
device tree binding is used.
Add a simple uclass for LEDs, so that these can be controlled by the device
tree and activated when needed. LEDs are referred to by their label.
This implementation requires a driver for each type of LED (e.g GPIO, I2C).
Many SoCs have a number of system controllers which are dealt with as a
group by a single driver. It is a pain to have to add lots of compatible
strings and/or separate drivers for each. Instead we can identify the
controllers by a number and request the address of the one we want.
Add a simple implementation of this which can be used by SoC driver code.
Add a simple implementaton of register maps, supporting only direct I/O
for now. This can be enhanced later to support buses which have registers,
such as I2C, SPI and PCI.
It allows drivers which can operate with multiple buses to avoid dealing
with the particulars of register access on that bus.
This function can be used for testing to manually request a GPIO for use,
without resorting to the legacy GPIO API.
Provide a driver-model function to look up a GPIO name. Make the standard
function use it.
Now that we support driver model in SPL, allow GPIO drivers to be used there
also.
This parameter is named 'seq' but should be named 'of_offset'.
In some rare cases it is useful to be able to locate a device given a device
tree node offset. An example is when you have an alias that points to a node
and you want to find the associated device. The device may be SPI, MMC or
something else, but you don't need to know the uclass to find it.
Add a function to do a global search for a device, given its device tree
offset.
To avoid bloating SPL code, use debug() where possible in the driver model
core code. The error code is already returned, and can be investigated as
needed.
In SPL it is sometimes useful to be able to obtain a dump of the current
driver model state. Since commands are not available, provide a way to
directly call the functions to output this information.
Adjust the existing commands to use these functions.
At present printf() skips output if it can see there is no console. This
is really just an optimisation, and is not necessary. Also it is currently
incorrect in some cases. Rather than update the logic, just remove it so
that we don't need to keep it in sync.
When there is no console ready, allow the debug UART to be used for output.
This makes debugging of early code considerably easier.
This does not actually help any current arch. For x86 it makes it harder
to call (requires stack) and for ARM it has no effect. Drop it.
U-Boot uses structures for hardware access so it is important that these
structures are correct. Add a way of asserting that a structure member is
at a particular offset. This can be created using the datasheet for the
hardware.
This implementation uses Static_assert() since BUILD_BUG_ON() only works
within functions.
Driver-model I2C drivers can be picked up by the linker script rule for
legacy drivers. Change the order to avoid this.
We could make the legacy code depend on !CONFIG_DM_I2C but that is not
necessary and it is good to keep conditions to a minimum.
The SPL device tree size must be minimised to save memory. Only include
properties that are needed by SPL - this is determined by the presence
of the "u-boot,dm-pre-reloc" property. Also remove a predefined list of
unused properties from the nodes that remain.
This tool allows us to extract subsets of a device tree file. It is used by
the SPL vuild, which needs to cut down the device tree size for use in
limited memory.
This tool was originally written for libfdt but it has not been accepted
upstream, so for now, include it in U-Boot. Several utilfdt library
functions been included inline here.
If fdtgrep is eventually accepted in libfdt then we can bring that version
of libfdt in here, and drop fdtgrep (requiring that fdtgrep is provided by
the user).
If it is not accepted then another approach would be to write a special
tool for chopping down device tree files for SPL. While it would use the
same libfdt support, it would be less code than fdtgrep.c because it would
not have general-purpose functions.
Another approach (which was used with v1 of this series) is to sprinkler all
the device tree files with #ifdef. I don't like that idea.
These have been sent upstream but not accepted to libfdt. For now, bring
these into U-Boot to enable fdtgrep to operate. We will use fdtgrep to
cut device tree files down for SPL.
Property names are stored in a string table. When a node property is
removed, the string table is not updated since other nodes may have a
property with the same name.
Thus it is possible for the string table to build up a number of unused
strings. Add a function to remove these. This works by building a new device
tree from the old one, adding strings one by one as needed.
Offer to display the available image types in help. Also, rather than
hacking the genimg_get_type_id() function to display a list of types,
do this in the tool. Also, sort the list.
The list of image types is quite long, and hard to discover. Print it out
when we show help information.
Provide access to the dhrystone benchmark command.
Drystone provides a convenient sanity check that the CPU is running at full
speed. Add this as a command which can be enabled as needed.
Note: I investigated using Coremark for this but there was a license
agreement and I could not work out if it was GPL-compatible.
When final MMU table is setup in DDR, TCR attributes must match
those of the memroy for cacheability and shareability.
Signed-off-by: Zhichun Hua <zhichun.hua@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
