2014-11-14Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2014-11-14powerpc/85xx: enable some P1/P2 boards mtdparts for nor flashYangbo Lu
Enable these boards mtdparts for nor flash: p1020rdb-pd, p1021rdb-pc, p1022ds, p1025twr, and p2020rdb-pc. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Scott Wood <scottwood@freescale.com>
2014-11-14keymile/powerpc: move to the architecture-generic board systemValentin Longchamp
This converts all the Keymile powerpc boards to the generic board initialization. This includes the 3 Keymile powerpc subsystems: km82xx, km83xx, and kmp204x. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/mpc83xx: Zero boot_flags arg for calling board_init_f()Valentin Longchamp
The argument boot_flags of board_init_f() is not used at all in the powerpc specific board.c init sequence. Now with the generic init sequence, this boot_flags arg is used by board_init_f(). This patch sets the r3 register that is used to pass the boot_flags argument from the start.S board_init_f() call to 0 prior to the function call to avoid unknown content to end up in gd->flags. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/BSC9131RDB: Enable creation of dynamic partitions for NANDAshish Kumar
* fdt_fixup_mtdparts is called from ft_board_setup * Run "mtdparts default" to create NAND partition on uboot * Use mtdparts to create partitions dynamically rather than using static partitions in device tree Signed-off-by: Ashish Kumar <Ashish.Kumar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/BSC9132QDS: Enable creation of dynamic partition for NAND and NORAshish Kumar
* fdt_fixup_mtdparts is called from ft_board_setup * run "mtdparts default" to create NAND, NOR partition on uboot * Use mtdparts to create partitions dynamically rather than using static partitions in device tree Signed-off-by: Ashish Kumar <Ashish.Kumar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/mpc85xx: Use IFC accessor functionPrabhakar Kushwaha
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP. So use IFC acessor functions instead of in_be32(). Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14t104xrdb: Add Errata A_007662, A_008007 workaround in pbi.cfgPriyanka Jain
-A_007662 states that for x1 link width, PCIe2 controller trains in Gen1 speed while configured for Gen2 speed. Workaround:Set the width to x1 and speed to Gen2 by writing to CCSR registers in PBI phase -A_008007 states that PVR register may show random value. Workaround: Reset PVR register using DCSR space in PBI phase Add PBI based software workaround for A_007662 and A_008007 in t104x_pbi.cfg. This is required for SPL-based bootloaders like NAND-boot, SD-boot, SPI-boot Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14powerpc/t4rdb: Add support of CPLDChunhe Lan
This support of CPLD includes - Files and register definitions - Command to switch alternate bank - Command to switch default bank Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-1485xx/b4:Correct USB DR controller liodn entryramneek mehresh
LIODN entry for B4860/B4420 mentions USB controller as "mph" insread of "dr". This results in PAMU not permitting bus transactions for USB DR controller on B4860 resulting in USB function failure. Replacing "fsl-usb2-mph" with "fsl-usb2-dr" allows USB DR controller bus transactions Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Reviewed-by: Sethi Varun-B16395 <Varun.Sethi@freescale.com> Reviewed-by: Sun Yusong-R58495 <yorksun@freescale.com>
2014-11-14sbc8548: enable and test CONFIG_SYS_GENERIC_BOARDPaul Gortmaker
Tested on the following baseline (note "dirty" since I enabled ALT_BOOT in the config in order to use the alternate boot bank.) Everything seems to work fine with no additional changes. The banner warning message is now gone. --- U-Boot 2014.10-rc1-00075-ge49f14af1349-dirty (Aug 14 2014 - 10:26:15) CPU: 8548E, Version: 2.1, (0x80390021) Core: e500, Version: 2.2, (0x80210022) Clock Configuration: CPU0:990 MHz, CCB:396 MHz, DDR:198 MHz (396 MT/s data rate), LBC:99 MHz L1: D-cache 32 KiB enabled I-cache 32 KiB enabled I2C: ready DRAM: Detected UDIMM SDRAM: 128 MiB 256 MiB (DDR2, 64-bit, CL=3, ECC off) Flash: 72 MiB L2: 512 KiB enabled *** Warning - bad CRC, using default environment PCI: Host, 64 bit, 66 MHz, sync, arbiter 00:01.0 - 8086:1026 - Network controller PCI1: Bus 00 - 00 PCIe1: Root Complex, x1 gen1, regs @ 0xe000a000 02:00.0 - 1148:9e00 - Network controller PCIe1: Bus 01 - 02 In: serial Out: serial Err: serial Net: eTSEC0 [PRIME], eTSEC1 Hit any key to stop autoboot: 0 => ver U-Boot 2014.10-rc1-00075-ge49f14af1349-dirty (Aug 14 2014 - 10:26:15) powerpc-linux-gcc (GCC) 4.5.2 GNU ld (GNU Binutils) 2.21 => --- Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14driver/net/fm/memac_phy: set NEG bit for external MDIOsShaohui Xie
NEG bit default is '1' for external MDIOs as per FMAN-v3 RM, but on some platforms, e.g. T2080QDS, this bit is '0', which leads to MDIO failure on XAUI PHY, so set this bit definitely to align with the RM. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14Fman/mEMAC: mEMAC fix for 10G MAC and PHYShaohui Xie
1. use Payload length check disable when enable MAC; 2. add XGMII support for setting MAC interface mode; 3. only enable auto negotiation for Non-XGMII mode; 4. return 0xffff if clause 22 is used to read 10G phy_id; Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-By: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14mpc85xx/kmp204x: raise u-boot size to 768KBValentin Longchamp
Until now this defined to be 512KB and the total binary size actually was on the edge of this limit. Most of the powerpc boards have thus moved to 768KB. Since on the current kmp204x boards there is 1MB reserved for u-boot on the SPI boot flash, there is no problem to set the limit to 768KB as well to be on line with the other powerpc boards and to eventually configure in some additional features (and binary size) to u-boot. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-13arm: mx6: add support for TBS2910 Matrix ARM miniPCSoeren Moch
Add initial support for TBS2910 Matrix ARM miniPC. Support includes MMC, Ethernet, UARTs, HDMI, USB, SATA, PCI, I2C, RTC. Signed-off-by: Soeren Moch <smoch@web.de>
2014-11-13mx6sabresd: Staticize when possibleFabio Estevam
Annotate 'static' when appropriate for the variables used locally. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13mx6sabresd: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13mx6: video_skip: Fix crash on NULL pointerNikolay Dimitrov
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de>
2014-11-13Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2014-11-13imx6: SPL support for iMX6 SabreSDJohn Tobias
This patch will enable the support for SPL on iMX6 SabreSD. It tested on SD2 and SD3 mmc port (Switch 1 or 2 of SW6) Signed-off-by: John Tobias <john.tobias.ph@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-13imx6: add spl in the header fileJohn Tobias
add the spl info in the header file. Also, added a macro statement in m6sabre_common.h to avoid compiler warning. Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
2014-11-13kconfig: imx6: add SUPPORT_SPLJohn Tobias
add SUPPORT_SPL feature for iMX6 SabreSD. It need to use mx6sabresd_spl_defconfig to compile it. Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
2014-11-13imx6: add data configuration file for SPLJohn Tobias
It's a trim version of mx6q_4x_mt41j128.cfg. It just removed the related settings for DDR Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
2014-11-13imx6: add spl config for mx6sabresdJohn Tobias
add a build configuration file for mx6sabresd with spl support Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
2014-11-13imx: mx6q/dlsabreauto: And NAND flash supportYe.Li
The i.MX6Q/DL sabreauto board has one NAND socket, set the CONFIG_NAND_MXS and relevant NAND configurations to enable the MXS NAND flash driver. Add board level codes to set IOMUX and clock for GPMI-NAND and BCH module. Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13imx: mx6q/dl sabre_common: Move MMC ENV offset to 512KB positionYe.Li
Set the CONFIG_ENV_OFFSET from 384KB to 512KB offset, so we will have larger space for u-boot image. When enabling NAND flash support feature, the u-boot image size has exceeded the 384KB, which causes overlay to the environment variables storage. Signed-off-by: Ye.Li <B37916@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13ot1200: fix card detect for usdhc4Christian Gmeiner
Today I got the final board and found out that a different connector is used as the one on my development board. The new connector has swaped pins for cd and wp. This change is tested on a production ready board. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-11-13mx53loco: Change 'fdt_file' dynamicallyFabio Estevam
Since kernel 3.15 there are two dtb's for the imx53-qsb board: imx53-qsb.dtb - For the boards with DA9053 PMIC imx53-qsrb.dtb - For the boards with MC34708 PMIC Change the 'fdt_file' dynamically, so that the correct dtb can be used depending on the board variant. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2014-11-13ot1200: add support for EHCIChristian Gmeiner
U-Boot 2014.10-17457-g0b23780-dirty (Nov 10 2014 - 11:41:04) CPU: Freescale i.MX6D rev1.2 at 792 MHz Reset cause: WDOG Board: ot1200 I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected M25P16 with page size 256 Bytes, erase size 64 KiB, total 2 MiB In: serial Out: serial Err: serial Net: using phy at 0 FEC [PRIME] Hit any key to stop autoboot: 0 => usb start (Re)start USB... USB0: Port not available. USB1: USB EHCI 1.00 scanning bus 1 for devices... 4 USB Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 2mA) | +-3 Mass Storage (480 Mb/s, 80mA) | USBest Technology USB Mass Storage Device 0000000000028B | +-4 Vendor specific (480 Mb/s, 2mA) => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-11-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-11-13arm: mx6: Fix missing Kconfig option for NovenaMarek Vasut
Add two missing Kconfig options for Novena and drop the SPL from the Novena config. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13sunxi: gmac: Update bananapi fixup to the new CONFIG_TARGET_<BOARD> structureZoltan HERPAI
The magic bit toucher needs to be updated to reflect the new board Kconfig structure Signed-off-by: Zoltan HERPAI <wigyori@uid0.hu> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-13sun6i: ehci: Add sun6i ehci supportHans de Goede
Add support for the 2 ehci controllers found on the sun6i (A31) soc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Marek Vasut <marex@denx.de>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add Mele M9 boardHans de Goede
2014-11-13sun6i: Enable SPLHans de Goede
Enable the SPL now that we've all the necessary bits in place. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Poke magic sram controller register to avoid cache issuesHans de Goede
Without this the cache will only work in write-through mode, and as soon as it is put in write-back mode things break. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add dram initialization codeHans de Goede
Add full support for dram initialization, using a fixed clock and autodetection of the memory organization (numbers of channels, bus-width, etc.). This is based on dram_sun6i.c and dram.h from u-boot in the Allwinner A31 SDK, extended with extra initialization sequences and the autodetect algorithm from boot0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun4i: Rename dram files to dram_sun4i.xHans de Goede
In preparation for adding sun6i dram support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add cpucfg register definitionsHans de Goede
Not used atm, for future use (e.g. PSCI). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add clock functions needed for SPL / DRAM initHans de Goede
Add clock_init_safe and clockset_pll5 functions, as these are needed for SPL support resp. DRAM init (which is needed for SPL too). Also add some extra clock register constant defines. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add basic axp221 driverOliver Schinagl
The A31 uses the AXP221 pmic for various voltages. Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> -- Changes in v2: -Rebase Changes in v3: -Add support for all dldo and aldo-s -Add Kconfig option to select building AXP221 and to select voltage of dldo and aldo-s Changes in v4: -Add axp221_setbits helper function -Use symbolic names for enabled bits in CTRL1 - CTRL3 registers
2014-11-13sun6i: Add new p2wi controller driverOliver Schinagl
The A31 uses a new push-pull two wire interface, which features higher transfer speeds (upto 6 MHz) in theory. While the hardware can burst 8 bytes each time, this driver will only see very little use and thus is limited to single byte transmission only. Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13zynq: zybo: Move CONFIG_DEFAULT_DEVICE_TREE to defconfigMichal Simek
This is a MIME GnuPG-signed message. If you see this text, it means that your E-mail or Usenet software does not support MIME signed messages. The Internet standard for MIME PGP messages, RFC 2015, was published in 1996. To open this message correctly you will need to install E-mail or Usenet software that supports modern Internet standards. Move CONFIG_DEFAULT_DEVICE_TREE from board config directly to defconfig. This patch removes compilation warning: include/configs/zynq_zybo.h:24:0: warning: "CONFIG_DEFAULT_DEVICE_TREE" redefined [enabled by default] #define CONFIG_DEFAULT_DEVICE_TREE zynq-zybo Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-11-13Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-11-13kconfig: arm: move "armv8" define to arch/arm/KconfigMasahiro Yamada
Commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs) collected the default values of CONFIG_SYS_CPU into arch/arm/Kconfig. This commit moves "armv8" to there for consistency. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-11-13ARM: remove unused CPU directoryMasahiro Yamada
There is no board with CPU "arm_intcm". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2014-11-13sh: define CONFIG_CPU_SH4A for some boardsMasahiro Yamada
Precisely, these boards are SH4A rather than SH4. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
