2017-01-21common: Kconfig: Add BOARD_LATE_INIT entryJagan Teki
This patch add Kconfig entry for CONFIG_BOARD_LATE_INIT Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-01-20mx6saberesd_spl: Correct falcon mode additionTom Rini
When falcon mode support was added, it was right around when SPL_OS_BOOT was migrated to Kconfig. So first we must move the enablement to the defconfig file. Next, it turned off EXT support rather than add the information to allow for falcon mode from EXT. Add this information so that the board compiles after 5d28b930f237. Fixes: d96796ca23b2 ("mx6sabresd: Add Falcon mode support") Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-20bootm: qnx: Disable data cache before booting QNX imageEmmanuel Vadot
Instead of disabling the data cache in the bootelf command, disabling it in the do_bootm_qnxelf function. Some ELF binary might want the cache enabled. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20tools: mkimage: fix sizeof_mismatch found by coveritySven Ebenfeld
Reported-by: Coverity (CID: 155214) Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com>
2017-01-20ARM: OMAP5+: Remove unsed dpll structuresLokesh Vutla
Latest gcc compile strted complaining about defined structure definition that are not used. Remove the unused sturctures. Reported-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-01-20ARM: OMAP4: Fix compiler warningLokesh Vutla
Latest gcc 6.2 compiler is throwing the below warning for omap4_panda_defconfig arch/arm/mach-omap2/omap4/hw_data.c:136:3: warning: 'abe_dpll_params_sysclk_196608khz' defined but not used [-Wunused-const-variable=] abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { Fix this by guarding it with CONFIG_SYS_OMAP_ABE_SYSCK Reported-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-01-20binman: add tools directory to the python pathEmmanuel Vadot
The built _libfdt.so is placed in the /tools dir and need to say here as it contains relative paths. Add the directory to the python path so binman can use this module. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20build: Always build the libfdt python moduleEmmanuel Vadot
Do not rely on CONFIG_SPL_OF_PLATDATA to build the libfdt python module. If swig is present, this will be build Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20MAINTAINERS: DFU: Change e-mail address of DFU maintanierLukasz Majewski
Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-01-20odroid-c2: Enable distro bootAndreas Färber
Use the generic "distro" boot framework to enable automatic DHCP boot. MMC and USB are not yet implemented, so this is the only boot option. The fdt and kernel addresses are adopted from downstream; ramdisk and scriptaddr addresses were chosen arbitrarily. Signed-off-by: Andreas Färber <afaerber@suse.de> Reviewed-by: Alexander Graf <agraf@suse.de>
2017-01-20meson: misc_init_r is board-specificAndreas Färber
Move it from meson-gxbb-common.h to odroid-c2.h to allow new boards not to implement it. Signed-off-by: Andreas Färber <afaerber@suse.de>
2017-01-20board_init.c: Always use memset()Tom Rini
We can make the code read more easily here by simply using memset() always as when we don't have an optimized version of the function we will still have a version of this function around anyhow. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20mach-omap2: Fix secure boot media generationAndrew F. Davis
While moving OMAP related files to mach-omap2 the functionality relating to generating secure boot files was modified. This change prevents secure platforms other than AM33xx and OMAP54XX from correctly building files for all needed media types. Fixes: 983e37007da5 ("arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platforms") Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-01-20spl: Add some missing newlinesAndrew F. Davis
Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2017-01-20spl: Remove inline ifdef check for EXT and FAT supportAndrew F. Davis
These files are only included for build by the make system when CONFIG_SPL_{EXT,FAT}_SUPPORT is enabled, remove the unneed checks for these in the source files. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20common/image.c: Use correct suffixes for binary sizesxypron.glpk@gmx.de
IEC 80000-13:2008 Quantities and units Part 13: Information science and technology defines the prefixes to use for binary multiples. So instead of writing Data Size: 6726132 Bytes = 6568.49 kB = 6.41 MB in dumpimage we should write Data Size: 6726132 Bytes = 6568.49 KiB = 6.41 MiB. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-01-20api: storage: Test all block device in dev_stor_getEmmanuel Vadot
In a config with one MMC at device id '1' and no MMC at device id '0' (a BeagleBone Black with no sd inserted for example), the current code will first test to access the MMC 0 (sd port), seeing that no device is present it will simply return that no more device are present for this class. This patch fixes this by testing all devices for each class. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20api: Use hashtable function for API_env_enumEmmanuel Vadot
The current code can loop undefinitly as it doesn't parse correctly the env data. Since the env is an hashtable, use the hashtable function for the API_ENV_ENUM api call. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20cmd/host: add missing \n in help textSébastien Szymanski
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2017-01-20ARM: omap3_logic: Refactor Boot Environmental variablesAdam Ford
Some scripts are calling the same functions, so these changes consolidate common scripts together to reduce redundancy and shrink size a bit. This also keeps the 'bootargs' variable from growing if manually called more than one time. This also adds NAND booting scripts based on newly consolidated scripts. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-01-20bootm: relocate ramdisk if CONFIG_SYS_BOOT_RAMDISK_HIGH setRick Altherr
In 35fc84f, bootm was refactored so plain 'bootm' and 'bootm <subcommand>' shared a common implementation. The 'bootm ramdisk' command implementation is now part of the common implementation but not invoke by plain 'bootm' since the original implementation never did ramdisk relocation. Instead, ramdisk relocation happened in image_setup_linux() which is typically called during the OS portion of 'bootm'. On ARM, parameters to the Linux kernel can either be passed by FDT or ATAGS. When using FDT, image_setup_linux() is called which also triggers ramdisk relocation. When using ATAGS, image_setup_linux() is _not_ called because it mostly does FDT setup. Instead of calling image_setup_linux() in both FDT and ATAGS cases, include BOOTM_STATE_RAMDISK in the requested states during a plain 'bootm' if CONFIG_SYS_BOOT_RAMDISK_HIGH is set and remove the ramdisk relocation from image_setup_linux(). This causes ramdisk relocation to happen on any system where CONFIG_SYS_BOOT_RAMDISK_HIGH regardless of the OS being booted. Also remove IMAGE_ENABLE_RAMDISK_HIGH as it was only used by the now-removed code from image_setup_linux(). Signed-off-by: Rick Altherr <raltherr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joel Stanley <joel@jms.id.au>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-19Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-01-18armv8: ls1012a: define esdhc_status_fixup for RDB boardYangbo Lu
On LS1012ARDB board, three dual 1:4 mux/demux devices drive the SDHC2 signals to eMMC, SDIO wifi, SPI and Ardiuno shield. Only when we select eMMC and SDIO wifi, the SDHC2 could be used. Otherwise, the command inhibit bits of eSDHC2_PRSSTAT register will never release. This would cause below continious error messages in linux since it uses polling mode to detect card. "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." This patch is to define esdhc_status_fixup function for RDB to disable SDHC2 status if no SDIO wifi or eMMC is selected. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1012a: define esdhc_status_fixup for QDS boardYangbo Lu
The LS1012AQDS board has a hardware issue. When there is no eMMC adapter card inserted in SDHC2 adapter slot, the command inhibit bits of eSDHC2_PRSSTAT register will never release. This would cause below continious error messages in linux since it uses polling mode to detect card. "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." This patch is to define esdhc_status_fixup function for QDS to disable SDHC2 status if no eMMC adapter card is detected. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18mmc: fsl_esdhc: move 'status' property fixup into a weak functionYangbo Lu
Move fdt fixup of 'status' property into a weak function. This allows board to define 'status' fdt fixup by themselves. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18fsl PPA: enable PPA for ls1043ardb and ls1046ardbHou Zhiqiang
Enable PPA for ls1043ardb NOR boot and ls1046ardb QSPI boot. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18kconfig: fsl PPA: move CONFIG_* to KconfigHou Zhiqiang
2017-01-18ARMv8/sec_firmware: relocated and renamed the config FSL_PPA_ARMV8_PSCIHou Zhiqiang
Moved the config FSL_PPA_ARMV8_PSCI from fsl-layerscape's Kconfig to Kconfig under armv8 and renamed it to SEC_FIRMWARE_ARMV8_PSCI. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18kconfig: armv8: move armv8 sec_firmware CONFIG_* to KconfigHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [York S: clean up scripts/config_whitelist.txt] Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: aarch64: Fix the warning about x1-x3 nonzero issueAlison Wang
For 64-bit kernel, there is a warning about x1-x3 nonzero in violation of boot protocol. To fix this issue, input argument 4 is added for armv8_switch_to_el2 and armv8_switch_to_el1. The input argument 4 will be set to the right value, such as zero. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Alexander Graf <agraf@suse.de> Tested-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/fsl-layerscape: fdt: fixup LS1043A rev1 MSI nodeWenbin Song
The default MSI node in kernel tree is for LS1043A rev1.0 silicon, if rev1.1 silicon used, need to fixup the MSI node to match it. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/ls1043a: fixup GIC offset for ls1043a rev1Wenbin Song
The LS1043A rev1.1 silicon supports two types of GIC offset: 4K alignment and 64K alignment. The bit SCFG_GIC400_ALIGN[GIC_ADDR_BIT] is used to choose which offset will be used. The LS1043A rev1.0 silicon only supports the CIG offset with 4K alignment. If GIC_ADDR_BIT bit is set, 4K alignment is used, or else 64K alignment is used. 64K alignment is the default setting. Overriding the weak smp_kick_all_cpus, the new impletment is able to detect GIC offset. The default GIC offset in kernel device tree is using 4K alignment, it need to be fixed if 64K alignment is detected. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: fsl-lsch3: enable snoopable sata read and writeTang Yuantian
By default the SATA IP on the ls208Xa SoCs does not generating coherent/snoopable transactions. This patch enable it in the sata axicc register. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18ls1046ardb: Add support power initializationHou Zhiqiang
Add the chip power supply voltage initialization on LS1046ARDB. Add function power_init_board(), and it will initialize the PMIC and call the chip power initialization function. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/fsl_lsch2: Add chip power supply voltage setupHou Zhiqiang
Set up chip power supply voltage according to voltage ID. The fuse status register provides the values from on-chip voltage ID fuses programmed at the factory. These values define the voltage requirements for the chip. Main operations: 1. Set up the core voltage 2. Set up the SERDES voltage and reset SERDES lanes 3. Enable/disable DDR controller support 0.9V if needed Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18ls1046ardb: cpld: add API for selecting core voltHou Zhiqiang
2017-01-18pmic: pmic_mc34vr500: Add APIs to set/get SWx voltHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18pmic: pmic_mc34vr500: Add a driver for the mc34vr500 pmicHou Zhiqiang
This patch adds a simple pmic driver for the mc34vr500 pmic which is used in conjunction with the fsl T1 and LS1 series SoC. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: fsl-layerscape: Fix SECURE_BOOT configYork Sun
Without a prompt in Kconfig, SECURE_BOOT cannot be selected by defconfig. The option was dropped unintentionally when defconfig files were cleaned up. Three targets were impacted ls1043ardb_SECURE_BOOT, ls2080ardb_SECURE_BOOT, ls2080aqds_SECURE_BOOT. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-18LS2080A: Add validation of MC & DPC images.Udit Agarwal
Add secure boot validation of MC, DPC images using esbc_validate command. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18SECURE_BOOT: Update bootscript and its hdr addressesUdit Agarwal
Update bootscript and its hdr addresses for Layerscape Chasis 3 based platforms instead of individual SoCs. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18configs: ls1012a: enable driver model for eSDHCYangbo Lu
Enable driver model for eSDHC on ls1012a rdb and qds boards. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1012a: add eSDHC nodesYangbo Lu
This patch is to add eSDHC nodes for ls1012a. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18mmc: fsl_esdhc: add 'fsl, esdhc' into of_match tableYangbo Lu
This patch is to add 'fsl,esdhc' into of_match table to support driver model for QorIQ eSDHC. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18mmc: fsl_esdhc: make GPIO support optionalYangbo Lu
There would be compiling error as below when enable driver model for esdhc. undefined reference to `dm_gpio_get_value' undefined reference to `gpio_request_by_name_nodev' This patch is to make GPIO support optional with CONFIG_DM_GPIO. Because all boards of QorIQ platform don't need it and they just check register for CD/WP status, only some boards of i.MX platform require this. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/fsl-lsch3: consolidate the clock system initializationHou Zhiqiang
This patch binds the sys_info->freq_systembus to Platform PLL, and implements the IPs' clock function individually. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/fsl-lsch2: refactor the clock system initializationHou Zhiqiang
Up to now, there are 3 kind of SoCs under Layerscape Chassis 2, like LS1043A, LS1046A and LS1012A. But the clocks tree has a lot of differences, for instance, the IP modules have different dividers to derive its clock from Platform PLL. And the core cluster PLL and platform PLL maybe have different reference clocks, such as LS1012A. Another problem is which clock/PLL should be described by sys_info->freq_systembus, it is confused in Layerscape Chissis 2. This patch is to bind the sys_info->freq_systembus to the Platform PLL, and handle the different divider of IP modules separately between different SoCs, and separate reference clocks of core cluster PLL and platform PLL. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
