Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
Done with:
./tools/moveconfig.py VIDEO_BMP_GZIP
The 3 suspicious migration because CMD_BMP and SPLASH_SCREEN
are not activated in these defconfigs:
- trats_defconfig
- s5pc210_universal_defconfig
- trats2_defconfig
For levels equal to the maximum value, the duty cycle must be equal to
the period.
Signed-off-by: Dario Binacchi <dariobin@libero.it>
The description of the 'max_level' field was incorrectly assigned to the
'min_level' field.
The Amlogic D-PHY in the Amlogic AXG SoC Family does support a frequency
higher than 10MHz for the TX Escape Clock, thus make the target rate
configurable.
This is based on the Linux commit [1] and adapted to the U-Boot driver.
[1] a328ca7e4af3 ("drm/bridge: dw-mipi-dsi: permit configuring the escape clock rate")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The timing values for dw-dsi are often dependent on the used display and
according to Philippe Cornu will most likely also depend on the used phy
technology in the soc-specific implementation.
To solve this and allow specific implementations to define them as needed
add a new get_timing callback to phy_ops and call this from the dphy_timing
function to retrieve the necessary values for the specific mode.
[1] 25ed8aeb9c39 ("drm/bridge/synopsys: dsi: driver-specific configuration of phy timings")
syslog_test.h is in test/log/, not include/
Fixes: 52d3df7fef ("log: Allow LOG_DEBUG to always enable log output")
Signed-off-by: Sean Anderson <seanga2@gmail.com>
- Fix Octeon SPI driver for Octeon TX2
- Fix and enhance Octeon watchdog driver
- Misc minor enhancements to Octeon TX/TX2
- Bring in the next round of dev_xxx cleanup patches.
Now that linux/compat.h does not define these macros, we do not need to
undefine them.
All users of these functions now include dm/device_compat.h directly.
Necessary for dev_xxx.
This driver doesn't use DM (in the correct places), so we use a device and
not a udevice. We also need to include device_compat.h
This was included, but was ifdef'd out. We also need dm.h for struct
udevice.
This header is necessary for the dev_xxx macros.
Enable WDT command for Octeon TX/TX2 boards.
Cc: Aaron Williams <awilliams@marvell.com>
Cc: Suneel Garapati <sgarapati@marvell.com>
Cc: Chandrakala Chavva <cchavva@marvell.com>
This patch enhances the Octeon TX/TX2 watchdog driver to fully enable
the WDT. With this changes, the "wdt" command is now also supported
on these platforms.
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
Clock support is needed for all Octeon TX/TX2 boards. This patch selects
CONFIG_CLK so that it is available.
Remove a left-over debug test message from the Octeon TX / TX2
MMC driver.
Octeon TX2 sets the TB100_EN bit in the config register. We need to use
a fixed 100MHz clock for this as well to work properly.
Cc: Jagan Teki <jagan@amarulasolutions.com>
This includes device_compat.h, and fixes several calls to dev_xxx.
We call log_debug, but do not have a category set.
https://gitlab.denx.de/u-boot/custodians/u-boot-mmc
- fsl_esdhc_imx cleanup
- not send cm13 if send_status is 0.
- Add reinit API
- Add mmc HS400 for fsl_esdhc
- Several cleanup for fsl_esdhc
- Add ADMA2 for sdhci
- Octeon TX: Add NAND driver (Suneel)
- Octeon TX: Add NIC driver driver (Suneel)
- Octeon TX2: Add NIC driver driver (Suneel)
- Armada 8040: Add iEi Puzzle-M80 board support (Luka)
- Armada A37xx SPI: Add support for CS-GPIO (George)
- Espressobin: Use Linux model/compatible strings (Andre)
- Espressobin: Add armada-3720-espressobin-emmc.dts from Linux (Andre)
- Armada A37xx: Small cleanup of config header (Pali)
- Add support for Linux "pstore" dumps.
- Button command fixup.
- gd cleanup and documentation.
- Assorted other cleanups.
Sphinx.override_domain() is deprecated since Sphinx 1.8 and removed in
Sphinx 3.
Use Sphinx.add_domain(, override=True) instead.
Set the defaults on probe for the packet buffer size registers
for the i210.
The TX/RX PBSIZE register of the i210 resets to its default value
only at power-on - see Intel Ethernet Controller I210 Datasheet rev 3.5
chapter 8.3 'Internal Packet Buffer Size Registers'.
If something (another driver, another OS, etc.) modifies this register
from its default value, the e1000 driver doesn't function correctly. It
detects a hang of the transmitter and continuously resets the adapter.
Here we set this value to its default when resetting the i210 to
resolve this issue.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
CONFIG_IS_ENABLED() takes the kconfig name without the CONFIG_ prefix,
e.g. CONFIG_IS_ENABLED(CLK) for CONFIG_CLK. Make including the prefix
an error in checkpatch.pl so calls in the wrong format aren't
accidentally reintroduced.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
e.g. CONFIG_IS_ENABLED(CLK) for CONFIG_CLK. Some of these were being
fixed every now and then, see:
commit 71ba2cb0d678 ("board: stm32mp1: correct CONFIG_IS_ENABLED usage for LED")
commit a5ada25e4213 ("rockchip: clk: fix wrong CONFIG_IS_ENABLED handling")
commit 5daf6e56d36c ("common: console: Fix duplicated CONFIG in silent env callback")
commit 48bfc31b6484 ("MIPS: bootm: Fix broken boot_env_legacy codepath")
Fix all files found by `git grep "CONFIG_IS_ENABLED(CONFIG"` by running
':%s/CONFIG_IS_ENABLED(CONFIG_\(\w+\))/CONFIG_IS_ENABLED(\1)/g' in vim.
Add the description of the global data pointer to the generated HTML
documentation.
Add the missing Sphinx documentation for struct global_data and
gd_board_type().
Sphinx documentation is only available for enums not for #defines.
Anyway it is better to keep related definitions in an enum.
Functions that are used in multiple C modules should be defined in an
include.
Reviewed-by: Michael Walle <michael@walle.cc>
get_ticks does not always succeed. Sometimes it can be called before the
timer has been initialized. If it does, it returns a negative errno.
This causes the timer to appear non-monotonic, because the value will
become much smaller after the timer is initialized.
No users of get_ticks which I checked handle errors of this kind. Further,
functions like tick_to_time mangle the result of get_ticks, making it very
unlikely that one could check for an error without suggesting a patch such
as this one.
This patch panics if we ever get an error. There are two cases in which
this can occur. The first is if we couldn't find/probe the timer for some
reason. One reason for this is if the timer is not available so early. This
likely indicates misconfiguration. Another reason is that the timer has an
invalid/missing device tree binding. In this case, panicing is also
correct. The second case covers errors calling get_count. This can only
occur if the timer is missing a get_count function (or on RISC-V, but that
should be fixed soon).
Fixes: c8a7ba9e6a5
The USB SDP protocol require the SPL serial support to allow the build
to succeed.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This parallels what I added for FAT in commit 6731bef6966, allowing the
environment to be found in a specific partition on the device that the
board's mmc_get_env_dev() returns. On the Banana Pi R2 that means the
device that U-Boot was loaded from; either the internal eMMC or an SD
card.
Since it's so trivial I could just about tolerate this when there were only
two copies of it. But now there are about to be three.
The EFI_RNG_PROTOCOL is needed for address randomization in Linux.
We should provide it by default on QEMU.
Reported-by: François Ozog <francois.ozog@linaro.org>
