Move env_set_hex() over to the new header file along with env_set_addr()
which uses it.
Move envmatch() over to the new header file. Also rename it to env_match()
to better line up with other functions.
Move env_relocate() over to the new header file.
Move env_init() over to the new header file.
Move this function over to the new header file.
Move this function over to the new header file. Also rename it to have an
env_ prefix like the other functions.
At present we have environment.h but this file includes all the
environment-related header files as well as internals such as
default_environment.
It seems desirable to have a new header to hold the commonly used
environment functions, so that most files can avoid including all of this
unnecessary stuff.
Create a new env.h header and move one function over to it.
This function is no-longer defined in U-Boot. Drop the declaration from
common.h
This function relates to lcd.h and is about to become obsolete with the
driver-model conversion. Move it out of common.h
These declarations are not used anymore, so drop them.
As part of the effort to remove things from common.h, create a new header
for the gzip functions. Move the function declarations to it and add
missing documentation.
1. Add myself as Android A/B and AVB maintainer
2. Add Sam Protsenko as Designated reviewer for A/B
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
Add MAINTAINERS entry for HI3660 SoC by adding the arch includes.
While doing so, adding myself as the co-maintainer for HISILICON
SoCs since I'm planning to maintain HI3660 SoC separately and considering
doing improvements to the existing HiSilicon SoC architecture.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
This commit adds MMC driver support for HI3660 SoC reusing hi6220_dw_mmc
driver. Since HI3660 operates at different clock rate and uses fifo
mode now, let's introduce the platform data and utilize it for different
SoCs supported by this driver.
This commit adds board support for Hikey960 board from Hisilicon. This
board is one of the Consumer Edition boards of the 96Boards family
powered by Kirin960 SoC.
More information about this board can be found in 96Boards website:
https://www.96boards.org/product/hikey960/
The initial supported/tested devices include:
- Debug serial
- SD
With these support, it's good enough for loading Linux Kernel from SD.
This commit adds devicetree for Hikey960 board. Most of the contents are
copied from Linux kernel with some modifications for u-boot. To be
more precise, SD card's speed related properties are removed due to a
bug in u-boot clock implementation. Hence forcing the SD controller to
work in standard speed.
This commit imports HI3660 SoC devicetree from Linux
This implements a stack usage check in SPL.
Many boards start up SPL to run code + data from one common, rather small
SRAM. To implement a sophisticated SPL binary size limit on such boards,
the stack size (as well as malloc size and global data size) must be
subtracted from this SRAM size.
However, to do that properly, the stack size first needs to be known.
This patch adds a new Kconfig option:
- SPL_SYS_REPORT_STACK_F_USAGE: memset(0xaa) the whole area of the stack
very early and check stack usage based on this constant later before the
stack is switched to DRAM
Initializing the stack and checking it is implemented in weak functions,
in case a board does not use the stack as saved in gd->start_addr_sp.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Should use CONFIG_IS_ENABLED not IS_ENABLED for CLK driver, so it will
check the CONFIG_SPL_CLK when building SPL
Signed-off-by: Ye Li <ye.li@nxp.com>
This fix issue when access config from PCIe switch.
The PCIe controller need to send Type 0 config TLP if the targeting bus
matches with the secondary bus number, which is when the TLP is targeting
the immediate device on the link.
The PCIe controller send Type 1 config TLP if the targeting bus is
larger than the secondary bus, which is when the TLP is targeting the
device not immediate on the link.
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
Hardware return completion status non-zero when read from non exist
function in multi-function PCIe device. Return error will cause PCIe
enumeration fail.
Change it to return 0 and return value 0xffffffff when error.
Some PCIe devices require longer time to response.
Increase polling counter to 20000 (~100ms).
- R8A77980 V3H support
- DaVinci USB updates
- Various OHCI fixes
- Gadget fixes
- Enable SD slot on Intel Edison
- Populate CSRT ACPI table for shared DMA controller on Intel Tangier
- Convert Intel ICH-SPI driver to use new spi-mem ops
- Enable config_distro_bootcmd for QEMU x86
- Support U-Boot as a payload for Intel Slim Bootloader
- Avoid writing temporary asl files into the source tree which fixes the
parallel build issue occasionally seen
Add board code for the R8A77980 V3H Condor board.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add a few bits of platform code to support R8A77980 V3H SoC.
Import R8A77980 V3H DTs and headers from Linux 5.2.7 , commit 5697a9d3d55f.
Import R8A77980 V3H clock tables from Linux 5.2.7 , commit 5697a9d3d55f.
Import R8A77980 V3H PFC tables from Linux 5.2.7 , commit 5697a9d3d55f.
Fix various type warnings when building this driver for 64bit machine.
The R8A77980 V3H gether needs a few minor adjustments to the sh_eth
driver, add them to support ethernet on R8A77980.
Remove obsolete legacy usbboot wrapper, as distroboot can handle
booting from USB drivers.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
When mainline kernels reboot TK1 they use SW_RESET,
that reset mode does not reset PMIC. Some rails
need to be off for RAM Re-repair to work correctly.
Remove video=tegrafb0:640x480-16@60 aka VESA VGA mode from vidargs in
order for the panel specification in the device tree to be used. This
causes the default to be the 10.1" LVDS display which will be available
in the Toradex webshop shortly.
Display proper reset reason after the SoC info.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Disabling ASPM fixes incompatibilities with some PCIe cards
Let the kernel print some debug messages when a user program
crashes due to an exception.
Use unified values for USB Product/Vendor numbers
when the config block is missing
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
We never really added a sensible DFU configuration for platforms
based on eMMC. Most of the things one might want to do can also be done
with UMS or fastboot, so drop the DFU configuration.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
This is a configuration option specific to the tegra controller.
Doing it this way makes it show up directly under the tegra controller
option, indented one level, as "Disable external clock loopback".
The way it is now, it shows up at the end of the controller list, not
indented, as if it's some kind of generic MMC configuration option.
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Tom Warren <twarren@nvidia.com>
Signed-off-by: Trent Piepho <tpiepho@impinj.com>
For U-Boot we allow a GPIO to be specified to enable the codec. Add this
to the relevant binding files.
This file was missed when adding the sound driver to U-Boot. Bring it in
from Linux 5.0.
Acked-by: Jon Hunter <jonathanh@nvidia.com>
from Linux 5.0.
The setting up MTRRs have already been done in previous
Slim Bootloader stages.
Signed-off-by: Aiden Park <aiden.park@intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
