Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Email address is not longer valid that's why remove it.
Since commit 326a682358c1 (malloc_f: enable SYS_MALLOC_F by default
if DM is on), Zynq MMC boot hangs up after printing the following:
U-Boot SPL 2015.04-rc5-00053-gadcc570 (Apr 08 2015 - 12:59:11)
mmc boot
reading system.dtb
Prior to commit 326a682358c1, Zynq boards enabled CONFIG_DM, but
not CONFIG_SYS_MALLOC_F. That commit forcibly turned on
CONFIG_SYS_MALLOC_F. I have not figured out the root cause, but
anyway it looks like CONFIG_SYS_MALLOC_F gave a bad impact on the
Zynq MMC boot.
We are planning to have the v2015.04 release in a few days.
I know this is a defensive fixup, but what I can do now is to add
# CONFIG_SYS_MALLOC_F is not set
to every Zynq defconfig file to get back the original behavior.
Tested on:
- Zedboard
- ZC706 board
Tested-by: Michal Simek <michal.simek@xilinx.com>
With e37f1eb we now use strict_strtoul() in do_mem_mtest() and this
gives us a warning:
../include/vsprintf.h:38:5: note: expected 'long unsigned int *' but
argument is of type 'int *'
Top-level Makefile has option to select dtc binary, but it is ignored
due to bug in Makefile.lib. Fix it.
Signed-off-by: Pavel Machek <pavel@denx.de>
Since the Kconfig conversion, boards.cfg scanned by MAKEALL is
generated by tools/genboardscfg.py. Every board is supposed to have
its own MAINTAINERS that contains maintainer and status information,
but, in fact, MAINTAINERS is missing from some boards.
For such boards, the first field, Status, is filled with '-'.
It causes a problem for "set" command, which ignores '-' in its
arguments. Consequently, get_target_arch() returns a wrong field
and MAKEALL fails to get a correct toolchain.
Since the Kconfig conversion, config.mk has been included only when
include/config/auto.conf is newer than the .config file.
It causes build error if both files have the same time-stamps.
It is actually possible because EXT* file systems have a 1s time-stamp
resolution.
The config.mk should be included when include/config/auto.conf is
*not older* than the .config file.
Reported-by: Tom Rini <trini@konsulko.com>
Reported-by: York Sun <yorksun@freescale.com>
Reported-by: Stephen Warren <swarren@nvidia.com>
Reported-by: Matthew Gerlach <mgerlach@opensource.altera.com>
Back in fc46bae a "clean up" was introduced that intended to reconcile
some of the AM335x codepaths based on how AM43xx operates.
Unfortunately this introduced a regression on the DDR2 platforms. This
was un-noticed on DDR3 (everything except for Beaglebone White) as we
had already populated sdram_config correctly in sequence. This change
brings us back to the older behavior and is fine on all platforms.
Tested on Beaglebone White, Beaglebone Black and AM335x GP EVM
Reported-by: Matt Ranostay <mranostay@gmail.com>
Currently, memtest will silently accept bad data. Perform error
checking on user intput.
In stead of user_buffer_size, transfer_size should be used to pass to
ahci_device_data_io(). transfer_size is the length that we want the
low level function to transfer each time.
If we use user_buffer_size which is the totally data length as parameter,
low level function will actually create many SGs to transfer as many data
as possible each time. That will produce many redundant data transfer.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
The u-boot environment is redundantly stored in a NOR flash on our boards.
Redundant means that there are two places to store the environment. But only
one of the two is active. I discovered that on one board the u-boot (env_sf)
uses the environment from the second place and the Kernel (fw_printenv) uses
the environment from the first place.
To decide which is the active environment there is a byte inside the
environment. 1 means active and 0 means obsolete. But on that board both
environments had have a 1. This can happen if a power loss or reset occurs
during writing the environment. In this situation the u-boot (env_sf)
implementation uses the second environment as default. But the Kernel
(fw_printenv) implementation uses the first environment as default.
This commit corrects the default in the u-boot env_sf implementation when a
problem was detected. Now the recovery default is the same like in all other
environment implementations. E.g. fw_printenv and env_flash. This ensures that
u-boot and Kernel use the same environment.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
After this change it is possible to boot trats2 device with Image.itb,
which facilitates automated testing, since only one file is necessary.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
After this change it is possible to boot trats device with Image.itb,
This change allows using Image.itb image format with Exynos4 devices
(especially trats and trats2).
Such change facilitates automated testing since only one binary needs
to be prepared.
Remove GPIOs from smdk5420 board file and because the same
is already specified via DT.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add backlight enable GPIO, and delay needed for panel powerup
via FIMD DT node.
Now that parade driver supports reading SLP and RST GPIO
from DT, specify the same in parade DT node.
Now that the exynos_fb driver supports handling backlight GPIO
via DT, specify pwm output property via FIMD DT node.
Add support to configure EDP_RST GPIO and EDP_SLP GPIO,
if provided in parade DT node.
Add support to configure PWM_OUT(PWM output) GPIO and
BL_EN(backlight enable) GPIO, if provided in FIMD DT node.
The existing setting for rpll_sdiv generates 70.5Mhz RPLL
video clock to drive 1366x768 panel on peach_pit.
This clock rate is not sufficient to drive 1920x1080 panel on peach-pi.
So, we adjust rpll_sdiv to 3 so that it generates 141Mhz pixel clock
which can drive peach-pi LCD.
This change doesn't break peach-pit LCD since 141/2=70.5Mhz, i.e FIMD
divider at IP level will get set to 1(the required divider setting
will be calculated and set by exynos_fimd_set_clock()) and hence
peach-pit LCD still works fine.
Add get_lcd_clk and set_lcd_clk callbacks for Exynos5800 needed by
exynos video driver.
The peach boards have their SDRAM start address at 0x20000000 instead of
0x40000000 which seems common for all other exynos5 based boards. This
means the layout set in exynos5-common.h causes the kernel be loaded
more then 128MB (at 0x42000000) away from memory start which breaks
booting kernels with CONFIG_AUTO_ZRELADDR
Define a custom MEM_LAYOUT_ENV_SETTINGS for both peach boards which uses
the same offsets from start of memory as the common exynos5 settings.
This fixes booting via bootz and PXE
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
We can enable / disable trace feature from the FTRACE config options.
To enable, compile U-Boot with FTRACE=1.
This patch add #ifdef FTRACE in exynos5-common.h for enable/disable
to use FTRACE configs instead of having to change board config files.
Signed-off-by: Inha Song <ideal.song@samsung.com>
Acked-by: Simon Glass <sjg@chroimum.org>
Commit 2e82e9252695a612ab0cbf40fa0c7368515f6506 'Exynos: Clock: Cleanup
soc_get_periph_rate' introduced a bug in I2C config. This patch makes cros_ec
keyboard working again on Samsung Chromebook (snow).
Changes in V2: reorder lines as requested by Joonyoung Shim.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Simon Glass <sjg@chroimum.org>
Tested-by: Simon Glass <sjg@chroimum.org>
The Orangepi_mini is different enough from the regular Orangepi that it needs
its own dtb, but when it got added a copy and paste error was made and it
got the same dtb filename, fix this.
While at it also add a short description of both Orangepi boards to the
defconfig files for them.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
board/armltd/vexpress64/vexpress64.c
With the most recent board firmware correct SDIO clock is 50MHz as
opposed to 25 MHz before.
Also set max frequency of MMC data exchange equal to SDIO clock -
because there's no way to transfer data faster than interface clock.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
ARCv2 cores may have built-in SLC (System Level Cache, AKA L2-cache).
This change adds functions required for controlling SLC:
* slc_enable/disable
* slc_flush/invalidate
For now we just disable SLC to escape DMA coherency issues until either:
* SLC flush/invalidate is supported in DMA APIin U-Boot
* hardware DMA coherency is implemented (that might be board specific
so probably we'll need to have a separate Kconfig option for
controlling SLC explicitly)
Now when all infrastructure in ARC is ready for it let's switch ARC UART
to driver model.
[1] Fix misspeling in ARC_CACHE_LINE_SHIFT dependency, now cache-line
lenth selection is correctly enabled if either I$ or D$ are enabled.
[2] Add dummy entry to target list to make sure target type is always
mentioned in defconfig. Otherwise defconfig for the first target in the
list will not have target name and later on with addition of the new
target on top of the list in Kconfig will lead to corrupted
configuration expanded from defconfig.
As discussed on mailing list we're drifting away from
CONFIG_SYS_GENERIC_GLOBAL_DATA in favour to use of board_init_f_mem()
for global data.
So do this for ARC architecture.
Before that moment our defconfigs were manually modified with addition
of new options. That means once anybody wants to add another option and
re-genarate defconfig with "make defconfig" there will be lots of
differences. So to make future modifications more clean we'll do bulk
re-generation right away.
Intention behind this work was elimination of as much assembly-written
code as it is possible.
In case of ARC we already have relocation fix-up implemented in C so why
don't we use C for U-Boot copying, .bss zeroing etc.
It turned out x86 uses pretty similar approach so we re-used parts of
code in "board_f.c" initially implemented for x86.
Now assembly usage during init is limited to stack- and frame-pointer
setup before and after relocation.
This separation makes maintenance of code easier because those low-level
interrupt- or exception handling routines are pretty static and usually
require not much care while start-up code is a subject of modifications
and enhancements.
Even though ARCompact and ARCv2 are not binary compatible most of
assembly instructions are used in both. With this change we'll get rid
of duplicate code.
Still IVTs are implemented differently so we're keeping them in separate
files.
always
Make both invalidate_icache_all() and invalidate_dcache_all() available
even if U-Boot is configured with CONFIG_SYS_DCACHE_OFF and/or
CONFIG_SYS_ICACHE_OFF.
This is useful because configuration of U-Boot may not match actual
hardware features. Real board may have cache(s) but for some reason we
may want to run U-Boot with cache(s) disabled (for example if some
peripherals work improperly with existing drivers if data cache is
enabled). So board may start with cache(s) enabled (that's the case for
ARC cores with built-in caches) but early in U-Boot we disable cache(s)
and make sure all contents of data cache gets flushed in RAM.
Being global variable with 0 value it falls into .bss area which we may
only use after relocation to RAM. And right afetr relocation we zero
.bss - effectively cleaing register address set for early console.
Now with pre-set value "regs" variable is no longer in .bss and this way
safely survives relocation.
Create a new configuration file: at91-sama5_common.h. Which includes the
configurations that reused by all SAMA5 chips.
at91-sama5_common.h includes:
- hw macros (clock, text_base and etc.)
- default commands.
- BOOTARGS
- U-Boot common configs.
NOTE: NOR flash definition should be put before including the common header.
For sama5d3-xplained:
- add CMD_SETEXPR
For sama5d3xek:
- add CMD_SETEXPR
- change CONFIG_SYS_MALLOC_LEN to (4*1024*1024)
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Enable SPL support for at91sam9n12ek boards, now it supports
boot up from NAND flash, serial flash.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Enable SPL support for at91sam9x5ek board. Now, it supports
boot up from NAND flash and SPI flash.
Supports boot up from NAND flash with software ECC eanbled.
And supports boot up from SD/MMC card with FAT file system.
As the boot from SD/MMC card with FAT file system, the BSS
segment is too big to fit into SRAM, so, use the lds to put
it into SDRAM.
Config MCKR according to the datasheet sequence, or else it
will cause the MCKR configuration failed.
Remove timeout checking for clock configuration, if configure
the clock failed, let the system hang while not run in wrong
clock configuration.
Tested-by: Heiko Schocher <hs@denx.de>
Insteading in mmc's raw sectors, this patch will save the environment
in a fat file (uboot.env) in mmc card's first FAT patition by default.
If you want to save in mmc's raw sectors, you only need to define
CONFIG_ENV_IS_IN_MMC.
Acked-by: Bo Shen <voice.shen@atmel.com>
