2020-05-10misc: scu: Increase the timeout for MU communicationYe Li
When power on some sources in Video system, current timeout 10ms is too short and returns before SCU response. So increase the timeout to 1s. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10misc: fuse: Update imx8 fuse driver for 8QMYe Li
Add the second ECC fuse area for 8QM which is different with 8QXP Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx: cpu: support tmuPeng Fan
Support tmu when print cpu info Signed-off-by: peng Fan <peng.fan@nxp.com>
2020-05-10imx: regs: add more fuse bank structurePeng Fan
Add more fuse bank structure for use. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx8mp: Set default SNSR25C for TMU probe1Ye Li
So far u-boot only load SNSR25C for TMU main probe (probe 0). However, kernel enables two probes. So it also needs to set default SNSR25C of TCALIV1 for blank samples. Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx: load calibration parameters from fuse for i.MX8MPYe Li
i.MX8MP thermal which has two probes and supports temperature range from -40 to 125. The driver still uses default 1p HW calibration at 25C and loads calibration parameters from fuse. Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx: i.MX8MN: Enable loading TASR and TCALIV from fuseYe Li
Like iMX8MM, iMX8MN also needs SW to load TMU TASR and TCALIV registers value from fuse before enabling TMU calibration. Otherwise the calibration is not exact. Reviewed-by: Anson Huang <Anson.Huang@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx8mm: Load fuse for TMU TCALIV and TASRYe Li
On iMX8MM, the default value of TMU registers TCALIV and TASR need be loaded from fuse. HW won't do this, it expect SW loads them before using TMU. Reviewed-by: Bai Ping <ping.bai@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_tmu: support i.MX8MPPeng Fan
Support i.MX8MP thermal which has two probes and supports temperature range from -40 to 125. Still uses default 1p HW calibration at 25C and loads calibration parameters from fuse. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_tmu: Check the TEMP range for iMX8MMPeng Fan
On iMX8MM, the V flag in TRISTR register only reflect the state of SNSR value, not the calibrated TEMP value. So checking this flag is not reliable. Per IC suggestion, change to read the TEMP/AVG_TEMP directly and check whether it in valid range 10-125C. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_tmu: Fix for temperature out of rangePeng Fan
When the temperature is out of sensor's range, the Valid bit won't be set in TRITSR register. So the polling loop won't go out. Change the codes to retry 10 times with 100ms interval for the Valid bit. If the timeout, we give a warning for the invalid data. Modifed from Ye's NXP patch Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_tmu: support TMU arch level initializationPeng Fan
i.MX8MM TMU needs to load some registers from fuse, this is arch dependent operation and may vary on different platforms. So add a interface for arch level initialization. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_tmu: Add support for thermal sensor on iMX8MMPeng Fan
The analog sensors on iMX8MM are new, used for 14LPP process. So the Temperature Sensor Monitoring Unit (TMU) has some change accordingly. We use version 2 in TMU driver to represent the new TMU, so the one driver can service for both i.MX8MQ/M. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: Add thermal driver for i.MX8MPeng Fan
The driver is ported form Linux Kernel and support driver model. Users need to provide the tmu node and sensors nodes in DTB. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10thermal: imx_scu_thermal: Update driver for i.MX8QM thermal sensorYe Li
Add iMX8QM thermal compatible string and its driver data. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10eQos: Implement the read_rom_hwaddr callbackYe Li
Implement the read_rom_hwaddr callback to load MAC address from fuse for imx8m platforms. Reviewed-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10fec: Move imx_get_mac_from_fuse declare to imx fileYe Li
imx_get_mac_from_fuse is used to load MAC address from fuse. On imx8mp, we have two different ENET controllers and both need to call this function. So decouple its declare from fec driver. Reviewed-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: eqos: implement callbaks to get interface and set txclk rateFugang Duan
Implement the callbacks to get phy mode interface and txclk rate configuration. Reviewed-by: Ye Li <ye.li@nxp.com> Signed-off-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: dwc_eth_qos: add dwc eqos for imx supportFugang Duan
Add dwc eqos for imx support. Reviewed-by: Ye Li <ye.li@nxp.com> Signed-off-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: phy: realtek: add rx delay support for RTL8211FFugang Duan
Add RX delay enable support for RTL8211F PHY. Reviewed-by: Ye Li <ye.li@nxp.com> Signed-off-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: Update eQos driver and FEC driver to use eth phy interfacesYe Li
Update eQoS and fec ethernet drivers to support shared MDIO framework Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: Add eth phy generic driver for shared MDIOYe Li
For dual ethernet controllers, the HW design may connect ETH phys to one MDIO ports. So two different ethernet drivers have to share MDIO bus. Since two ethernet drivers are independent, we can't ensure their probe order. To resolve this problem, introduce an eth phy generic driver and uclass. After eth-uclass binds, we search the mdio node and binds the phy node with the eth-phy-generic driver. When one eth driver get its phy device, the parent of phy device will probe prior than phy device. So this ensure the eth driver ownes the MDIO bus will be probed before using its MDIO. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10net: eth-uclass: add return value checkPeng Fan
Add return value check Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10pinctrl: nxp: scu: Check the pad partition before set pinmuxYe Li
If a pad is not owned by current partition we should not set its pinmux. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx8mq_phanbell: Run SPL with caches enabledFabio Estevam
It is safe to run SPL with caches enabled on i.MX8M, so remove such restriction. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-05-10net: fec: add fuse checkPeng Fan
Add fuse check for fec. If the fuse indicates the module will not work in the SoC, let's fail the initialization. Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-05-10usb: mx6: add fuse checkPeng Fan
Add fuse check for USB. If the fuse indicates the module will not work in the SoC, let's fail the initialization. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10i2c: mxc: add fuse checkPeng Fan
Add fuse check for I2C. If the fuse indicates the module will not work in the SoC, let's fail the initialization. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10imx: add module fuse supportPeng Fan
There are different parts from one SoC. Take i.MX6ULL for example, some part might not have ENET, some might have; some might not have USB, some might have. The information could be got from OCOTP, to make one image support the different parts, we need runtime disable linux kernel dts node and uboot driver probe if the corresponding module not exists in the part. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-10ARM: imx: pico-imx8mq: Add support for Technexion Pico-iMX8MQMarek Vasut
Add initial support for Technexion Pico-iMX8MQ SoM on PicoPI carrier board. Currently working is ethernet, serial, eMMC. DT is imported from Linux 5.4.28 ("462afcd6e7ea") . Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2020-05-10Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2020-05-08Merge branch '2020-05-08-assorted-fixes'Tom Rini
2020-05-08test: fix naming of test functions in the log test suiteHeinrich Schuchardt
Both the nolog as well as the syslog tests were not found by Python function generate_ut_subtest() due to not following the nameing requirements imposed by the regular expression used to find linker generated list entries in file u-boot.sym. Adjust the naming of test functions. With the patch the following tests are executed successfully for sandbox_defconfig: test/py/tests/test_ut.py::test_ut[ut_log_syslog_debug] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_err] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_info] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_nodebug] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_notice] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_warning] PASSED The nolog tests are only executed if CONFIG_LOG=n and CONFIG_CONSOLE_RECORD=y. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-08test: describe naming conventions for macro UNIT_TESTHeinrich Schuchardt
Strict naming conventions have to be followed for Python function generate_ut_subtest() to collect C unit tests to be executed via command 'ut'. Describe the requirements both on the C as well on the Python side. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-08env/sf.c: honour CONFIG_SPL_SAVEENVRasmus Villemoes
Deciding whether to compile the env_sf_save() function based solely on CONFIG_SPL_BUILD is wrong: For U-Boot proper, it leads to a build warning in case CONFIG_CMD_SAVEENV=n (because the initialization of the .save member is guarded by CONFIG_CMD_SAVEENV, while the env_sf_save() function is built if !CONFIG_SPL_BUILD - and even without the CONFIG_CMD_SAVEENV guard, the env_save_ptr() macro would just expand to NULL, with no reference to env_sf_save visible to the compiler). And for SPL, when one selects CONFIG_SPL_SAVEENV, one obviously expects to actually be able to save the environment. The compiler warning can be fixed by using a "<something> ? env_sf_save : NULL" construction instead of a macro that just eats its argument and expands to NULL. That way, if <something> is false, env_sf_save gets eliminated as dead code, but the compiler still sees the reference to it. For <something>, we can use CONFIG_IS_ENABLED(SAVEENV), which is true precisely: - For U-Boot proper, when CONFIG_CMD_SAVEENV is set (because CONFIG_SAVEENV is a hidden config symbol that gets set if and only if CONFIG_CMD_SAVEENV is set). - For SPL, when CONFIG_SPL_SAVEENV is set. As a bonus, this also removes quite a few preprocessor conditionals. This has been run-time tested on a mpc8309-derived board to verify that saving the environment does indeed work in SPL with these patches applied. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
2020-05-08sata: dwc_ahsata: Fix memory issue in reset_sataYe Li
The reset_sata should reset the sata device info and free the probe_ent memory. Otherwise, it will cause memory leak if we init the sata again. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-08sata: dwc_ahsata: Fix incorrect freeYe Li
Fix coverity issue CID 43665: Free of address-of expression (BAD_FREE) incorrect_free: free frees incorrect pointer pp. pp points the port array field of struct ahci_uc_priv, should not free it. Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-08sata: ahsata: Fix wrong operand for checking SERR DIAG_XYe Li
Fix coverity issue CID 3261683: Wrong operator used (CONSTANT_EXPRESSION_RESULT) operator_confusion: ({...; __v;}) | 67108864 is always 1/true regardless of the values of its operand. This occurs as the logical operand of ! When DIAG_X is set, the PHY COMINIT signal is detected, so should use '&' to check whether it is set. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-08sata: ahsata: Fix resource leakYe Li
Fix coverity issue CID 3606684: Resource leak (RESOURCE_LEAK) leaked_storage: Variable uc_priv going out of scope leaks the storage it points to Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-08Merge tag 'efi-2020-07-rc2-3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc2-3 This series contains bug fixes and code simplifications. Following clarification in the discussion of the EBBR specification device trees will be passed as EfiACPIReclaimMemory to UEFI applications.
2020-05-08Merge branch '2020-05-07-more-kconfig-migrations'Tom Rini
- Migrate CONFIG_SET_DFU_ALT_INFO, CONFIG_SYS_MTDPARTS_RUNTIME and finish the rest of the memtest related options.
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Enable MEMTEST via defconfigMichal Simek
There is no reason to enable MEMTEST from headers when was converted to Kconfig already. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-05-08treewide: mem: Remove alternate memtest setup from Mox and x530Michal Simek
The commit e89f8aae3d67 ("treewide: Migrate CONFIG_SYS_ALT_MEMTEST to Kconfig") setup correct dependency on MEMTEST that's why there is no reason to enable enable alternate memtest without mtest command. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-05-08cmd: mem: Remove CONFIG_SYS_MEMTEST_SCRATCH mappingMichal Simek
There is no real need to exactly define space for saving patterns for alternate memory test. It is much easier to allocate space on the stack and use it instead of trying to find out space where pattern should be saved. For example if you want to test the whole DDR memory you can't save patter to DDR and you need to find it out. On Xilinx devices DDR or OCM addresses were chosen but that means that OCM needs to be mapped and U-Boot has access permission there. It is easier to remove this limitation and simply save it on stack because it is very clear that memory test can't rewrite U-Boot and U-Boot has also full access to memory where runs from. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2020-05-08configs: migrate CONFIG_SYS_MTDPARTS_RUNTIME to defconfigsPatrick Delaunay
Move CONFIG_SYS_MTDPARTS_RUNTIME into Kconfig done by moveconfig.py. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2020-05-08configs: migrate CONFIG_SET_DFU_ALT_INFO to defconfigsPatrick Delaunay
Move CONFIG_SET_DFU_ALT_INFO into Kconfig done by moveconfig.py. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-07Merge branch '2020-05-07-atheros-phy-improvements'Tom Rini
2020-05-07efi_loader: crypto/pkcs7_parser.h is not a local includeHeinrich Schuchardt
User <> and not "" for referencing a global include. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
