Enables driver model flag CONFIG_DM_USB for LS1021A
platform defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Update USB 3.0 controller dts node in ls1021a.dtsi.
Adds code to use driver model for USB XHCI FSL driver
Adds code to use driver model for USB EHCI FSL driver
Moves code from ehci_hcd_init to new function ehci_fsl_init
which can be re-used in CONFIG_DM_USB.
The meaning of CONFIG_USB in U-Boot is different from that in Linux.
As you see in drivers/usb/Kconfig of Linux, CONFIG_USB enables the
USB host controller support, while CONFIG_USB_SUPPORT is used to
enable the whole of the USB sub-system.
When I added CONFIG_USB into Kconfig by commit 6e7e9294d321 ("usb:
add basic USB configs in Kconfig"), I planned to follow the Linux's
convention, i.e. CONFIG_USB to enable/disable the USB host support.
Then, commit 68f7c5db2d1e ("usb: Generic USB Kconfig option, that
fits both host and gadget and comments") changed the logic of the
CONFIG_USB to point to the whole of the USB sub-system. As a result,
currently we do not have an option for USB host.
This commit adds CONFIG_USB_HOST, which will be useful to compile
in the USB host support code.
CONFIG_USB_HOST is not referenced at all, but strangely some boards
define it in board headers. I removed them because USB_HOST will be
selected in Kconfig going forward.
There is no UHCI driver entry in Kconfig for now, but we have some
UHCI drivers, for example, LEON. This is a placeholder in case we
want to move them to Kconfig in the future.
The help message was copied from Linux.
Add this option as a common config for all OHCI controllers. Its
help message was copied from Linux. Also, I moved it below EHCI
to respect the order in Linux's Kconfig.
Add CONFIG_USB_OHCI_HCD=y to axs103_defconfig, which is the only
user of OHCI_GENERIC.
Add support for driver model, so that CONFIG_DM_ETH can be defined and
used with this driver.
This patch also adds the read_rom_hwaddr() callback so that the ROM MAC
address will be used to the DM part of this driver.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Ted Chen <tedchen@realtek.com>
Support driver model for ehci mx6 driver.
Consolidate code to be shared between DM and non-DM, such as
introducing ehci_mx6_common_init.
For simplicity, some old fasion code are keeped for DM usage,
such as board_ehci_power and board_usb_phy_mode. And 'dr-mode',
usbphy and vbus handling code for DM is not added now.
These will be added in future patches.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Stefan Agner <stefan@agner.ch>
We no longer need to set 'caps' as it's not passed to sdhci_setup_cfg
anymore.
Fixes: 14bed52d276a ("mmc: sdhci: remove the unnecessary arguments for
sdhci_setup_cfg")
This follows 9fd383724cf4 ("mmc: don't allow extra cmdline arguments"),
and affects omapl138_lcdk and omap3_evm_quick_mmc.
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
Inform getopt that '-c' requires a parameter.
Fixes: a02221f29deb ("mkimage: Convert to use getopt()")
Return one string for each command that was executed. This seems cleaner.
Suggested-by: Teddy Reed <teddy.reed@gmail.com>
Add a proper function for this rather than using internal functions. Use it
in the single call site.
Also, do a restart at the end of the vboot test to reset to the normal
device tree.
Suggested-by: Stephen Warren <swarren@nvidia.com>
Use 'cons.log.section' feature to split up the test output. This makes it
easier to read.
Rename this argument and pass it to each function that needs it, instead of
making it global.
Instead of this, use the existing run_and_log() function, enhanced to
support a command string as well as a list of arguments.
Fix some typos in various files introduced with the vboot test conversion.
Reported-by: Teddy Reed <teddy.reed@gmail.com>
This check was missed. Add it and make the message more verbose.
Reported-by: Tom Rini <trini@konsulko.com>
Fixes: 9e17b034 (test/py: Provide a way to check that a command fails)
Fix review comments that were missed at the time. Also explain why we need
to regenerate the device tree for each test.
Fixes: f6349c3c (test: Add a README)
Add this shortcut for running tests. Unfortunately 'make test' cannot be
used as it is an existing directory.
We create 2 sets of page tables: One for normal operation, one for
emergency (used while modifying the former).
Because the page tables grow dynamically, we have code that checks
for overflow. Unfortunately we didn't adjust the available space
variable while creating the emergency tables, so potentially someone
might run into an overflow there (not seen in real world yet though!).
Fix it by properly adjusting the size as well as the base offset in
emergency page table creation.
Reported-by: York Sun <york.sun@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The calculation of "dev_desc->lba - 34 - 1 - offset" is not correct for
size '-', because both fist_usable_lba and last_usable_lba will remain
34 sectors.
We can simply use 0 for size '-' because the part_efi module will decode
the size and auto extend the size to maximum available size.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
These config targets were added well before the Kconfig migration began
as a way to demonstrate how to make these platforms work with cut down
features. At this point in time they no longer serve a good purpose so
remove them.
The already available ilog2 function does exactly the same in the common
case than the log2 function the current clock-driver reimplement.
So, simply move to that one.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Enable the rockchip dwmmc driver for rk3399 and its evb.
rk3399 sdcard is using dwmmc controller, enable it for sdcard.
SCLK_SDMMC is the clock for controller operation clock, move it
to the first place.
MMC core will use 400KHz for card initialize first and then switch to
higher frequency like 50MHz, we need to support both 400KHz and about
50MHz for dwmmc controller.
To compatible with distro boot, we need to add gpt and fs support,
including gpt table and vfat, ext2, ext4 support.
Enable ums feature for rk3288 boards, so that we can mount the mmc
device to PC.
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
For compatibility with distro boot, fastboot, and mount the mmc deivce
to PC via usb mass storage feature, GPT partitions are essential.
You should write the partitions to mmc device prior to use above
feature.
=> gpt write mmc 1 $partitions
GPT successfully written to block device!
success!
Miniarm is a rockchip rk3288 based development board, which has lots of
interface such as HDMI, USB, micro-SD card, Audio etc.
With the number of Rockchip clock drivers increasing, don't clutter up
the core drivers/clk directory with them and instead move them out of
the way into a separate subdirectory.
Suggested-by: Simon Glass <sjg@chromium.org>
Updated for rk3399:
This patch add driver for:
- clock driver including set_rate for cpu, mmc, vop, I2C.
- sysreset driver
- grf syscon driver
Add an extra byte so that this data is not byteswapped.
Signed-off-by: Sandy Patterson <apatterson@sightlogix.com>
Enable fastboot feature on rk3036, please refer to doc/README.rockchip
for more detailed usage.
When disabled CONFIG_MMC_SDMA, variable caps didn't use.
This patch fixes the compiler error for -Wunused-but-set-variable
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
In the case of omap3 we have a number of platforms that are close to
exceeding SRAM limits, depending on compiler. Move to USE_TINY_PRINTF
to give them more room. OMAP4 will soon enough be in a similar place,
so enable that now.
In reality all omap3 platforms support SPL so move the select for this
up a level.
print_std_bdinfo outputs typical set of board information entries:
boot params location, memory and flash addresses and sizes, network
interfaces information and configured serial baud rate.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
print_baudrate outputs serial baud rate.
print_eth_ip_addr outputs eth configurations for up to 6 interfaces and
configured IP address.
print_bi_flash outputs flashstart, flashsize and flashoffset lines.
print_bi_dram outputs start address and size for each DRAM bank.
print_bi_mem outputs memstart and memsize lines.
print_bi_boot_params outputs boot parameters structure location.
