This choice is not about SPL for which we have a separate choice.
Fixes: 95f4bbd581 ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot")
Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Allow 64-bit DMA on AHCI. If not supported by the host controller, at
least print a message and fail.
Signed-off-by: Roman Kapl <rka@sysgo.com>
The signature 0x55 0xAA in bytes 510 and 511 of the first sector can either
indicate a DOS partition table of the first sector of a FAT file system.
The current code tries to check if the partition table is valid by looking
at the boot indicator of the partition entries. But first of all it does
not count from 0 to 3 but only from 0 to 2. And second it misses to
increment the pointer for the partition entry.
If it is a FAT file system can be discovered by looking for the text 'FAT'
at offset 0x36 or 'FAT32' at offset 0x52. In a DOS PBR there are no
partition entries, so those bytes are undefined. Don't require the byte at
offset 0x1BE to differ from 0x00 and 0x80.
With the patch the logic is changed as follows:
If the partition table has either an invalid boot flag for any partition or
has no partition at all, check if the first sector is a DOS PBR by looking
at the FAT* signature.
Provide a unit test for errno_str(). Test that known and unknown error
numbers are handled correctly.
If errno_str() is called with an unsupported error number, do not return a
random pointer but a reasonable text.
Add get_timer_us(), which is useful e.g. when we need higher
precision timestamps.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
[trini: Fixup arch/arm/mach-bcm283x/include/mach/timer.h]
Make sure that the PCI busses are enumerated before trying to
find a NVMe device.
Signed-off-by: Patrick Wildt <patrick@blueri.se>
Change the stack-allocated buffer for the identification command
to explicitly allocate page-aligned buffers. Even though the spec
seems to allow having admin queue commands on non page-aligned
buffers, it seems to not be possible on my i.MX8MQ board with a
a Silicon Power P34A80. Since all of the NVMe drivers I have seen
always do admin commands on a page-aligned buffer, which does work
on my system, it makes sense for us to do that as well.
It's possible that the data cache for the buffer still holds data
to be flushed to memory, since the buffer was probably used as stack
before. Thus we need to make sure to flush it also on reads, since
it's possible that the cache is automatically flused to memory after
the NVMe DMA transfer happened, thus overwriting the NVMe transfer's
data. Also add a missing dcache flush for the prp list.
For printing as %u we should use an unsigned int.
Update from upstream.
Just minor changes like checking that the author has also done a sign-off.
As initially this feature was implemented as a negative CONFIG and
later it was redesigned to be positive the help text should be
updated to reflect this change.
This commit updates the help text to match the current implementation.
Signed-off-by: Walter Lozano <wlozano@collabora.com>
When we have an excess size growth, fix the "limit" printf call to pass
in just the limit variable rather than the string bytes to the format
character.
_gpio_direction_output function currently calls gpio_set_value
with the wrong gpio number. gpio_set_value in the uclass driver
expects a different gpio number and the _gpio_direction_output
is currently providing the number specific to the bank.
Hence fix it by calling the _gpio_set_value function instead.
Reported-by: Faiz Abbas <faiz_abbas@ti.com>
Fixes: 8e51c0f254 ("dm: gpio: Add DM compatibility to GPIO driver for Davinci")
Signed-off-by: Keerthy <j-keerthy@ti.com>
We have two further uses of raw string usage in the test/py codebase
that are used under CI. The first of which is under the bind test and
is a direct update. The second of which is to strip VT100 codes from
the match buffer. While switching this to a raw string is also a direct
update, the comment it notes that problems were encountered on Ubuntu
14.04 (and whatever Python 2 version that was) that required slight
tweaks to the regex. Replace that now that we're saying Python 3.5 is
the minimum.
Tested-by: Simon Glass <sjg@chromium.org> [on sandbox]
As things stand today, we have tools that CI requires where "python"
must be "python2". We need to use a virtualenv and pip in order to
ensure that our pytest tests can be run. Rework things slightly so
that:
- On Travis-CI, we install python-pyelftools for the platforms that
require pyelftools to be installed.
- On GitLab-CI, we move to a newer base image that includes python3-pip
and continue to use a virtualenv per job that needs it, for the
correct set of packages.
To be more closely aligned with Python community best practices, we need
to better document our usage of pip and make use of a requirements.txt
file that shows the versions of the tools that we are using. This will
aide in ensuring reproducibility of our tests as well.
Now that we have moved to being based on pytest for python3 we need to
make our test.py wrapper more robust in terms of only calling python3
rather than possibly finding and using python2. To do this, change from
execvp()'ing pytest to invoking the package itself via python. In the
event that pytest is unavailable we still get a user-friendly error:
pkg_resources.DistributionNotFound: The 'pytest' distribution was not found and is required by the application
The check_output function from the subprocess Python module by default
returns data as encoded bytes and leaves decoding to the application.
Given our uses of the call, it makes the most sense to immediately
decode the results.
- In python 3 you must use raw strings for regex as other forms are
deprecated and would require further changes to the pattern here.
In one case this lets us have a simpler match pattern.
- As strings are now Unicode our complex tests (Euro symbol,
SHIFT+ALT+FN 5) we need to declare that as a bytes string and then
decode it for use.
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
In the case of some unit tests we are working with providing a fake
flash device that we have written some text strings in to. In this case
we want to tell Python to encode things to bytes for us.
- Modern pytest is more visible in telling us about parameters that we
had not described, so describe a few more.
- ConfigParser.readfp(...) is now configparser.read_file(...)
- As part of the "strings vs bytes" conversions in Python 3, we use the
default encoding/decoding of utf-8 but in some places tell Python to
replace problematic conversions rather than throw a fatal error.
- Fix a typo noticed while doing the above ("tot he" -> "to the").
- As suggested by Stephen, re-alphabetize the import list
- Per Heinrich, replace how we write contents in test_fit.py
Use the 2to3 tool to perform numerous automatic conversions from Python
2 syntax to Python 3. Also fix whitespace problems that Python 3
catches that Python 2 did not.
Fix the following spit from pytest:
u-boot/test/py/conftest.py:438: RemovedInPytest4Warning: MarkInfo objects are deprecated as they contain merged marks which are hard to deal with correctly.
Please use node.get_closest_marker(name) or node.iter_markers(name).
Docs: https://docs.pytest.org/en/latest/mark.html#updating-code
for board in mark.args:
In both cases, the later suggestion is applicable.
Cc: Igor Opaniuk <igor.opaniuk@gmail.com>
[trini: Update for current file with a few more cases, un-pin pytest in CI]
We inconsistently note multiple dependencies today in our tests,
sometimes with a single line that declares multiple and sometimes
multiple single lines. Current pytest seems to fail on the single line
format so change to multiple declarations.
Currently we set the entire PATH rather than prepend the new paths that
we need to have searched. This however breaks parts of the "virtualenv"
that was have set up and need to use as that also will be modifying
PATH. To fix this, prepend our new locations instead.
In a number of our stanzas we had multi-line commands that were one
space short of alignment, correct this.
https://gitlab.denx.de/u-boot/custodians/u-boot-clk
- Add I2C clocks for i.MX6Q CCF driver
- Fix check in clk_set_default_parents()
- Managed API to get clock from device tree
- Fixes for core clock code (including sandbox regression tests)
https://gitlab.denx.de/u-boot/custodians/u-boot-mmc
- fsl_esdhc driver cleanup
- spl_mmc bug fix to avoid access wrong emmc partition
- Clean up Travis-CI slightly and then add support for Microsoft Azure
pipelines, all from Bin Meng.
- H6 dts(i) sync (Clément)
- H6 PIO (Icenowy)
- Fix pll1 clock calculation (Stefan)
- H6 dram, half DQ (Jernej)
- A64 OLinuXino eMMC (Sunil)
This expands current Azure Pipelines Windows host tools build
testing to cover all the CI testing in gitlab and travis CI.
Note for some unknown reason, the 'container' cannot be used for
any jobs that have buildman, for buildman does not exit properly
and hangs the job forever. As a workaround, we manually call
docker to run the image to perform the CI tasks.
A complete run on Azure Pipelines takes about 2 hours and 10
minutes.
At present some boards generate kwbimage.cfg in the source tree
during the build. This breaks buildman testing on some systems
where the source tree is read-only. Update makefile rules to
generate it in the build tree instead.
Note some other boards have the kwbimage.cfg file written in
advance, hence we need check if the file exists in the build
tree first, otherwise we fall back to one in the source tree.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
In the 'Make' function, the codes tries to create a directory
if current stage is 'build'. But the directory isn't used at
all anywhere.
buildman always generates boards.cfg in the U-Boot source tree.
When '-o' is given, we should generate boards.cfg to the given
output directory.
On i.MX8, when booting from eMMC boot partition, the whole flash.bin
is stored in boot partition, however SPL switches to user partition
during the init of mmc driver:
spl_mmc_load() -> mmc_init()
Then it tries to load the container image in
spl_mmc_get_uboot_raw_sector(), but here it reads the data from user
partition and the header is not recognized as a valid header.
So we move spl_mmc_get_uboot_raw_sector after eMMC partition switch
to address this issue.
Anyway put spl_mmc_get_uboot_raw_sector before eMMC partition switch
is not correct, so let's move it after eMMC partition switch.
Reported-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
A previous patch below adding DDR mode support was actually for i.MX
platforms. Now i.MX eSDHC driver is fsl_esdhc_imx.c. For QorIQ eSDHC,
it uses different process for DDR mode, and hasn't been supported.
Let's drop DDR support code for i.MX in fsl_esdhc driver.
0e1bf61 mmc: fsl_esdhc: Add support for DDR mode
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Remove redundant DM_MMC checking which is already in DM_MMC conditional
compile block.
U-boot prefers DM_MMC + BLK for MMC. Now eSDHC driver has already
support it, so let's force to use it.
- Drop non-BLK support for DM_MMC introduced by below patch.
66fa035 mmc: fsl_esdhc: fix probe issue without CONFIG_BLK enabled
- Support only DM_MMC + BLK (assuming BLK is always enabled for DM_MMC).
- Use DM_MMC instead of BLK for conditional compile.
Microsoft Azure Pipelines [1] provides unlimited CI/CD minutes and
10 parallel jobs to every open source project for free.
This adds a configuration file for Azure Pipelines to utilize the
free Windows VM hosted by Microsoft to ensure no build broken in
building U-Boot host tools for Windows.
[1] https://azure.microsoft.com/en-us/blog/announcing-azure-pipelines-with-unlimited-ci-cd-minutes-for-open-source/
When building U-Boot host tools for Windows from Microsoft Azure
Pipelines, the following errors were seen:
HOSTCC tools/mkenvimage.o
In file included from tools/mkenvimage.c:25:
./tools/version.h:1:1: error: expected identifier or ‘(’ before ‘.’ token
1 | ../include/version.h
tools/mkenvimage.c: In function ‘main’:
tools/mkenvimage.c:117:4: warning: implicit declaration of function ‘usage’ [-Wimplicit-function-declaration]
117 | usage(prg);
tools/mkenvimage.c:120:35: error: ‘PLAIN_VERSION’ undeclared (first use in this function)
120 | printf("%s version %s\n", prg, PLAIN_VERSION);
tools/mkenvimage.c:120:35: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [scripts/Makefile.host:114: tools/mkenvimage.o] Error 1
It turns out tools/version.h is a symbolic link and with Windows
default settings it is unsupported hence the actual content of
tools/version.h is not what file include/version.h has, but the
the linked file path, which breaks the build.
To fix this, remove the symbolic links for tools/version.h. Instead
we perform a copy from include/version.h during the build.
Pipelines, we see tons of weird warnings and errors emitted from
every Kconfig files:
Kconfig:6:warning: ignoring unsupported character ''
Kconfig:8:warning: ignoring unsupported character ''
Kconfig:9:warning: ignoring unsupported character ''
Kconfig:10:warning: ignoring unsupported character ''
Kconfig:13:warning: ignoring unsupported character ''
arch/Kconfig:1:warning: ignoring unsupported character ''
arch/Kconfig:2:warning: ignoring unsupported character ''
arch/Kconfig:4:warning: ignoring unsupported character ''
After several rounds of experiments, it turns out this is caused
by line endings. Historically, Linux and macOS used linefeed (LF)
characters while Windows used a carriage return plus a linefeed
(CRLF). When Azure Pipelines checks out the U-Boot repo, Git tries
to compensate for the difference by automatically making lines end
in CRLF in the working directory on Windows, which confuses the
Kconfig file parsing logic.
Fortunately Git provides a way for repos to tell Git not to do such
automatical line endings conversion via .gitattributes file below:
* text eol=lf
This adds a reST document for how to build U-Boot host tools,
including information for both Linux and Windows.
Some compilers may provide __packed define for us.
'struct ustat' uses linux-specific typedefs to declare its memebers:
__kernel_daddr_t and __kernel_ino_t. It is currently not used by any
U-Boot codes, but when we build U-Boot tools for other platform like
Windows, this becomes a problem.
Let's surround it with __linux__.
__swab32() is a Linux specific macro defined in linux/swab.h. Let's
use the compiler equivalent builtin function __builtin_bswap32() for
better portability.
__leXX has Linux kernel specific __attribute__((bitwise)) which is
not portable. Use corresponding uintXX_t instead.
__be32 has Linux kernel specific __attribute__((bitwise)) which is
not portable. Use uint32_t instead.
