2018-07-19arm: zynq: Try to enable the first watchdog via aliasesMichal Simek
The same change as was done for zynqmp with this description: Add support for enabling the first watchdog pointed via aliases. DT fragment: aliases { ... watchdog0= &watchdog0; watchdog1 = &watchdog_lpd; ... }; <zynqmp example removed> Till this patch the first watchdog found in DT was used and started which is not enabling all possible configuration based on user request. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Try to enable the first watchdog via aliasesMichal Simek
Add support for enabling the first watchdog pointed via aliases. DT fragment: aliases { ... watchdog0 = &watchdog0; watchdog1 = &watchdog_lpd; ... }; dm tree fragment for above configuration with patch applied: ZynqMP> dm tree Class index Probed Driver Name ----------------------------------------- ... watchdog 0 [ ] cdns_wdt | |-- watchdog@ff150000 watchdog 1 [ + ] cdns_wdt | `-- watchdog@fd4d0000 ... dm uclass fragment: ZynqMP> dm uclass ... uclass 75: watchdog 0 watchdog@ff150000 @ 7df02f40, seq -1, (req 1) 1 * watchdog@fd4d0000 @ 7df02ff0, seq 0, (req 0) ... It is visible that index 1 is IP with seq 0 which means that FPD watchdog (@fd4d0000) is in DT below LPD watchdog (@ff150000). Till this patch the first watchdog found in DT was used and started which is not enabling all possible configuration based on user request. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19gpio: zynq: Setup bank_name to dev->nameMichal Simek
There should be proper bank name setup to distinguish between different gpio drivers. Use dev->name for it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19microblaze: Do not call timer init that earlyMichal Simek
Timer needs to be converted to DM but as of now it can't be called so early because intc controller is not ready. Call it later in board_r.c. Before this patch timer_init is called twice which is wrong. The patch is blocking initialization before relocation. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19gpio: zynq: Read of mach data in platdata with dev_get_driver_dataMichal Simek
Remove bogus zynq_gpio_getplat_data() and read driver data directly. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19gpio: dm: Support manual relocation for gpioMichal Simek
Relocate gpio ops as was done by: "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19sysreset: dm: Support manual relocation for sysresetMichal Simek
Relocate sysreset ops as was done by: "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19gpio: zynq: Fix typo in one error messageMichal Simek
Just fix error message. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Remove unused XILINX_BOARD_NAME macroMichal Simek
This macro is not used anywhere that's why remove it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Sync defconfigs in connection to DEFINE_TCM_OCM_MMAPMichal Simek
CONFIG_MP was added to Kconfig with enabling CONFIG_DEFINE_TCM_OCM_MMAP=y for zynqmp boards. This option is enabled by default that's why it shouldn't be in defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19watchdog: dm: Support manual relocation for watchdogsMichal Simek
Relocate watchdog ops as was done by: "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19watchdog: dm: Change uclass name to watchdog and enable DM_UC_FLAG_SEQ_ALIASMichal Simek
uclass name is used by dev_read_alias_seq which return seq number when aliases are used. Code fragment: 168 int dev_read_alias_seq(struct udevice *dev, int *devnump) 169 { 170 ofnode node = dev_ofnode(dev); 171 const char *uc_name = dev->uclass->uc_drv->name; 172 int ret; 173 174 if (ofnode_is_np(node)) { 175 ret = of_alias_get_id(ofnode_to_np(node), uc_name); Also this patch enables DM_UC_FLAG_SEQ_ALIAS to be in sync with Linux which is also using watchdog name for watchdog aliases. drivers/watchdog/watchdog_core.c:215: ret = of_alias_get_id(wdd->parent->of_node, "watchdog"); Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19arm64: zcu100: Enable USB host ether and ASIX via defconfigMichal Simek
There is no reason to keep these configs in platform config file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Guard do_reset by CONFIG_SYSRESETMichal Simek
sysreset uclass have own do_reset function which should be used instead of board/platform specific. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19microblaze: Use default implementation from include/linux/io.hMichal Simek
There is no reason not to use default ioremap/iounmap io functions. The patch remove Microblaze macros. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19xilinx: zynq: Add support to secure imagesSiva Durga Prasad Paladugu
This patch basically adds two new commands for loadig secure images. 1. zynq rsa adds support to load secure image which can be both authenticated or encrypted or both authenticated and encrypted image in xilinx bootimage(BOOT.bin) format. 2. zynq aes command adds support to decrypt and load encrypted image back to DDR as per destination address. The image has to be encrypted using xilinx bootgen tool and to get only the encrypted image from tool use -split option while invoking bootgen. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19serial: zynq: Use platdata for storing static data instead of privMichal Simek
Explanation from Simon Glass "Private data is created when the device is probed and freed when the device is removed. Platform data is created when the device is bound, and survives probe/remove cycles. Strictly speaking, platform data should be used to hold the decoded device tree properties. Private data should be used for run-time things the device needs to keep track of." Based on description the driver needs to be switch to use platdata instead of priv. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19usb_kdb: Get stdio_dev directly from sdev pointerMichal Simek
Driver supports only one instance of usb keyboard. Remove the first dependency on generic usbkbd DEVNAME. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19usb_kbd: Add support for watchdogMichal Simek
There is need to service watchdog in while loop or system will be restarted when idlying. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19clk: zynqmp: Fixed the same if/else part error reported by coverityVipul Kumar
This patch fixed the same if/else part error by adding the required source select on the basis of is_pre_src check. Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm/arm64: zynq/zynqmp: pass the PS init file as a kconfig variableLuca Ceresoli
U-Boot needs to link ps7_init_gpl.c on Zynq or psu_init_gpl.c on ZynqMP (PS init for short). The current logic to locate this file for both platforms is: 1. if a board-specific file exists in board/xilinx/zynq[mp]/$(CONFIG_DEFAULT_DEVICE_TREE)/ps?_init_gpl.c then use it 2. otherwise use board/xilinx/zynq/ps?_init_gpl.c In the latter case the file does not exist in the U-Boot sources and must be copied in the source tree from the outside before starting the build. This is typical when it is generated from Xilinx tools while developing a custom hardware. However making sure that a board-specific file is _not_ found (and used) requires some trickery such as removing or overwriting all PS init files (e.g.: the current meta-xilinx yocto layer). This generates a few problems: * if the source tree is shared among different out-of-tree builds, they will pollute (and potentially corrupt) each other * the source tree cannot be read-only * any buildsystem must add a command to copy the PS init file binary * overwriting or deleting files in the source tree is ugly as hell Simplify usage by allowing to pass the path to the desired PS init file in kconfig variable XILINX_PS_INIT_FILE. It can be an absolute path or relative to $(srctree). If the variable is set, the user-specified file will always be used without being copied around. If the the variable is left empty, for backward compatibility fall back to the old behaviour. Since the issue is the same for Zynq and ZynqMP, add one kconfig variable in a common place and use it for both. Also use the new kconfig help text to document all the ways to give U-Boot the PS init file. Build-tested with all combinations of: - platform: zynq or zynqmp - PS init file: from XILINX_PS_INIT_FILE (absolute, relative path, non-existing), in-tree board-specific, in board/xilinx/zynq[mp]/ - building in-tree, in subdir, in other directory Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Nathan Rossi <nathan@nathanrossi.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19hush: Remove default CONFIG_SYS_PROMPT_HUSH_PS2 setting from board filesMichal Simek
There is no reason to define default option for this macro which is already done in common/cli_hush.c. 86 #ifndef CONFIG_SYS_PROMPT_HUSH_PS2 87 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " 88 #endif Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-19common: command: Handle USAGE failure separatelyMichal Simek
command_ret_t enum contains 3 return values but only two are handled now. Extend cmd_process_error() and handle CMD_RET_USAGE separately. These commands are affected by this change. cmd/demo.c cmd/efi.c cmd/gpio.c cmd/qfw.c cmd/x86/fsp.c test/dm/cmd_dm.c And scripts shouldn't be affected because return value is not 0. But every command implementation can choose what it is correct to pass. I would expect that RET_USAGE is called when parameters are not correctly passed (have incorrect value, missing parameters) and RET_FAILURE when correct parameters are passed but command fails. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromum.org>
2018-07-19common: command: Use command_ret_t enum values instead of valuesMichal Simek
Use enum command_ret_t types in cmd_process_error(). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromum.org>
2018-07-19arm64: zynqmp: Enable usb mass storage command and functionalityMichal Simek
Enable ums command for zcu100 to enable mass storage gadget. Tested with ums 0 mmc 0 (for SD) and ums 0 usb 0 (for USB flashdisk). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19gpio: zynq: Use live-tree functionMichal Simek
Use live-tree function. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-17Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2018-07-17sunxi: Enable eMMC on Libre Computer Board ALL-H3-CC boardsChen-Yu Tsai
The Libretech ALL-H3-CC has a high density connector for attaching an eMMC module. The module form factor and connection is specific to Libretech, and has provisions for split vmmc/vqmmc (core and I/O) voltage supplies, but this board does not wire the vqmmc side. The H2+/H3/H5 SoCs do not support alternate I/O voltages for eMMC either. Only 3.3V is supported. A specific module that ties vqmmc to vmmc, with both at 3.3V, must be used. Given that a) eMMC is not designed to be hotplugged, b) power is always provided on the pins, and c) MMC controllers can deal with missing cards, we can enable this by default. If a module is attached it will be picked up by the system. The device tree change was also submitted to the Linux Kernel and has already been queued up for 4.19. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2018-07-16sf: add paired dev info for winbond w25q16jvLudwig Zenz
This commit adds paired dev info for winbond w25q16jv (tested w25q16jvssiq with a i.mx6 board) Signed-off-by: Ludwig Zenz <lzenz@dh-electronics.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16sf: add Macronix mx25l1633e entryLudwig Zenz
Add support for the Macronix mx25l1633e nor flash. (Tested on a imx6 board) Signed-off-by: Ludwig Zenz <lzenz@dh-electronics.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16sf: add Gigadevice gd25q16c entryLudwig Zenz
Add support for the Gigadevice gd25q16c nor flash. (Tested on a imx6 board) Signed-off-by: Ludwig Zenz <lzenz@dh-electronics.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi_flash: add a bunch of winbond flashes to id-tableHannes Schmelzer
This commit adds the following flashes to the id-table - W25Q16JV - W25Q32JV - W25Q64JV - W25Q128JV - W25Q256JV Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16zynqmp: zcu102: Add qspi driver support for ZynqMP zcu102 boardsSiva Durga Prasad Paladugu
This patch adds qspi driver support for all ZynqMP ZCU102 boards. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi: zynqmp_gqspi: Add support for ZynqMP qspi driverSiva Durga Prasad Paladugu
This patch adds qspi driver support for ZynqMP SoC. This driver is responsible for communicating with qspi flash devices. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> [jagan: removed GQSPI_MIO_NUM_ macros] Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi: xilinx_spi: convert to livetreeVipul Kumar
Update the xilinx spi driver to support a live tree. Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi: xilinx_spi: Added support to read JEDEC-id twice at the boot timeVipul Kumar
This patch is for the startup block issue in the spi controller. SPI clock is passing through STARTUP block to FLASH. STARTUP block don't provide clock as soon as QSPI provides command. So, first command fails. This patch added support to read JEDEC id in xilinx_spi_xfer (). Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi: xilinx_spi: Modify transfer logic xilinx_spi_xfer() functionVipul Kumar
This patch modify xilinx_spi_xfer() function and add rxfifo() and txfifo() functions to add the modularity so that these functions can be used by other functions within the same file. This patch also added support to read fifo_size from dts. Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16spi: xilinx: Read reg base address from DTS fileMichal Simek
This patch added support to read register base address from DTS file. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-16configs: Bananapi_M2_Ultra: enable gigabit ethernetLothar Felten
Enable the gigabit ethernet for the Bananapi M2 Ultra board. Tested on BananaPi M2 Berry (R40), custom board (V40) Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com>
2018-07-16sunxi: R40: add gigabit ethernet devicetree nodeLothar Felten
Add a device tree node for the Allwinner R40/V40 GMAC gigabit ethernet interface. The R40 SoC does not use the syscon register for GMAC settings. The gigabit ethernet interface can only be routed to a fixed set of pins. Updated to match the Linux kernel's device tree. Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com>
2018-07-16net: sun8i-emac: support R40 GMACLothar Felten
Add support for the GMAC found in the Allwinner R40/V40 SoC. The R40 GMAC interface is not controlled by the syscon register but has a separate configuration register in the CCU. The clock gate and reset bits are in a different register compared to the other SoCs supported by this driver. The driver uses the -gmac suffix for the R40 because the R40 also has a different 100 MBit MAC (EMAC). Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com>
2018-07-16net: sun8i-emac: set mux and clock by driver dataLothar Felten
Use driver data->variant information to select device specific pin mux and phy clock settings. Suggested by Jagan Teki Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Lothar Felten <lothar.felten@gmail.com>
2018-07-16net: sun8i-emac: fix printing NULL characterLothar Felten
If the variant is not set and therefore NULL, do not attempt to print the variant. Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com>
2018-07-16sunxi: R40: add gigabit ethernet clocksLothar Felten
Add clock control entries for the gigabit interface of the Allwinner R40/V40 CPU Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Lothar Felten <lothar.felten@gmail.com>
2018-07-16dm: sunxi: Use DM for MMC and SATA on all A10 boardsAdam Sampson
Use the driver model for MMC and SATA, in preparation for CONFIG_BLK defaulting to y. Tested on A10 Cubieboard. Signed-off-by: Adam Sampson <ats@offog.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2018-07-16dm: mmc: sunxi: Add A10/A20 compatible stringsAdam Sampson
Commit dd27918c2252 ("dm: mmc: sunxi: Add support for driver model") only added the allwinner,sun5i-a13-mmc compatible string for this driver. The DM initialisation code here also works with (at least) A10 and A20, so add the appropriate compatible strings as per Linux 4.17's driver. Tested on A10 Cubieboard and A20 pcDuino3 Nano with CONFIG_DM_MMC. (A20 worked already, because sun7i-a20.dtsi specifies both the A13 and A20 strings.) Signed-off-by: Adam Sampson <ats@offog.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2018-07-16sunxi: DT: A64: add proper SoPine baseboard device treeAndre Przywara
When the defconfig for the SoPine baseboard was added, there wasn't any proper DT for the board yet, so we used the Pine64 DT as a placeholder. Copy the DT file(s) meanwhile added in Linux over to U-Boot, and use them in our defconfig. This is as of v4.18-rc3, exactly Linux commit: commit 7d556bfc49adddf2beb0d16c91945c3b8b783282 Author: Jagan Teki <jagannadh.teki@gmail.com> Date: Mon Dec 4 10:23:07 2017 +0530 arm64: allwinner: a64-sopine: Fix to use dcdc1 regulator instead of vcc3v3 Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16sunxi: DT: H3: update board .dts files from LinuxAndre Przywara
Update the .dts file for the various boards with an Allwinner H3 SoC. This is as of v4.18-rc3, exactly Linux commit: commit 721afaa2aeb860067decdddadc84ed16f42f2048 (HEAD) Merge: 7c00e8ae041b 87815dda5593 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Mon Jun 11 17:57:38 2018 -0700 Merge tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc This also includes the OrangePi Zero .dts, which technically has an Allwinner H2+ SoC. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16sunxi: DT: H5: update board .dts files from LinuxAndre Przywara
Update the .dts file for the various boards with an Allwinner H5 SoC. This is as of v4.18-rc3, exactly Linux commit: commit af5d05bdc99c211729cba0a3d5417bccfa308caf Author: Neil Armstrong <narmstrong@baylibre.com> Date: Tue Apr 24 13:47:14 2018 +0200 arm64: dts: allwinner: Add dts file for Libre Computer Board ALL-H3-CC H5 ver. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
