When we enable CONFIG_OF_BOARD on Raspberry Pis, we may end up without
serial console support in early boot. Hence we need to make the serial
port optional, otherwise we will never get to the point where serial
would be probed.
This header needs to know 'fdt_region' is a struct for the
fit_region_make_list() prototype.
fdt_region.c does not depend on anything in libfdt_internal.h
This macro is locally referenced in common/image-fdt.c
Commit 286ede6 ("drivers: core: Add translation in live tree case") made
dev_get_addr always use proper bus translations for addresses read from
the device tree. But this leads to problems with certain busses, e.g.
I2C busses, which run into an error during translation, and hence stop
working.
It turns out that of_translate_address() and fdt_translate_address()
stop the address translation with an error when they're asked to
translate addresses for busses where #size-cells == 0 (comment from
drivers/core/of_addr.c):
* Note: We consider that crossing any level with #size-cells == 0 to mean
* that translation is impossible (that is we are not dealing with a value
* that can be mapped to a cpu physical address). This is not really specified
* that way, but this is traditionally the way IBM at least do things
To fix this case, we check in both the live-tree and non-live tree-case,
whether the bus of the device whose address is about to be translated
has size-cell size zero. If this is the case, we just read the address
as a plain integer and return it, and only apply bus translations if the
size-cell size if greater than zero.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com>
Reported-by: Martin Fuzzey <mfuzzey@parkeon.com>
Fixes: 286ede6 ("drivers: core: Add translation in live tree case")
dm_scan_fdt_node can't work when live dt is active,
we should use dm_scan_fdt_live instead.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
The value at the end of the rom is not a pointer, it is an offset
relative to the end of rom.
Signed-off-by: Andre Heider <a.heider@gmail.com>
The cast breaks the pointer on 64bit archs, so lets get rid of it.
Reviewed-by: Alexander Graf <agraf@suse.de>
Use live dt interface for pinctrl_select_state_full()
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add api for who can not get phandle from a device property.
Cc: Stefan Roese <sr@denx.de>
Signed-off-by: Ken Ma <make@marvell.com>
This patch enabled PCIe port on both devel-board
and espressobin board.
Signed-off-by: Wilson Ding <dingwei@marvell.com>
This patch introduced the Aardvark PCIe driver based
driver model.
The PCIe driver is supposed to work in Root Complex
mode. It only supports X1 lane width.
Reviewed-on: http://vgitil04.il.marvell.com:8080/38725
Reviewed-by: Victor Gu <xigu@marvell.com>
Reviewed-by: Hua Jing <jinghua@marvell.com>
Tested-by: Hua Jing <jinghua@marvell.com>
This patch added a new region of 32MiB AT 0xe800.0000
to Armada37x0's memory map. This region is supposed to
be mapped in MMU in order to enable the access to the
PCI I/O or MEM resources.
Reviewed-on: http://vgitil04.il.marvell.com:8080/38724
Tested-by: iSoC Platform CI <ykjenk@marvell.com>
Since the new pinctrl/gpio driver is used, so this patch removes
the old board specific pin control settings.
The commit "arm64: mvebu: Add pinctrl nodes for Armada 3700" has
added new pinctrl nodes.
This reverts commit f7cab0f95b05ec6a66fe4796b9ad44406d0cc864.
Reviewed-on: http://vgitil04.il.marvell.com:8080/43289
Reviewed-by: Kostya Porotchkin <kostap@marvell.com>
Reviewed-by: Igal Liberman <igall@marvell.com>
This patch corrects below mpp definitions for armada 3720 DB board
and ESPRESSOBin board:
- "smi" pins group is added and "smi" function is set for eth0;
- Now pcie pins are used as gpio to implement PCIe function in
hardware, so "pcie" group function is changed to "gpio".
Reviewed-on: http://vgitil04.il.marvell.com:8080/43287
This patch corrects below mpp definitions:
- The sdio_sb group is composed of 6 pins and not 5;
- The rgmii group contains pins mpp2[17:6] and not mpp2[19:6];
- Pin of group "pmic0" is mpp1[6] but not mpp1[16];
- Pin of group "pmic1" is mpp1[7] but not mpp1[17];
- A new group "smi" is added in A0 with 2 pins - mpp2[19:18], its
bitmask is bit4;
- Group "pcie1" has 3 pins in A0 - mpp2[5:3], its bit mask is
bit5 | bit9 | bit10 but not bit4;
- Group "ptp" has 3 pins in A0 as Z1, but its bitmask is changed to
bit11 | bit12 | bit13.
Reviewed-on: http://vgitil04.il.marvell.com:8080/43288
For armada_37xx_update_reg(), the parameter offset should be pointer so
that it can be updated, otherwise offset will keep old value, and then
when offset is larger than or equal to 32 the mask calculated by
"BIT(offset)" will be 0 in gpio chip hook functions, it's an error,
this patch set offset parameter of armada_37xx_update_reg() as pointer.
Pin 23 on South bridge does not belong to the rgmii group. It belongs to
a separate group which can have 3 functions.
Due to this the fix also have to update the way the functions are
managed. Until now each groups used NB_FUNCS(which was 2) functions. For
the mpp23, 3 functions are available but it is the only group which needs
it, so on the loop involving NB_FUNCS an extra test was added to handle
only the functions added.
The bug was visible when the gpio regulator used the gpio 23, the whole
rgmii group was setup to gpio which broke the Ethernet support on the
Armada 3720 DB board. Thanks to this patch, the UHS SD cards (which need
the vqmmc) _and_ the Ethernet work again.
Reviewed-on: http://vgitil04.il.marvell.com:8080/43284
The number of pins in South Bridge is 30 and not 29. There is a fix for
the driver for the pinctrl, but a fix is also need at device tree level
for the GPIO.
Reviewed-on: http://vgitil04.il.marvell.com:8080/43286
On the south bridge we have pin from 0 to 29, so it gives 30 pins (and
not 29).
Reviewed-on: http://vgitil04.il.marvell.com:8080/43285
Add mmc pins, pcie pins and sdio pins definition and do these pins'
configuration for DB board and espressobin board;
Add uart2 pins configuration for DB board.
Reviewed-on: http://vgitil04.il.marvell.com:8080/40914
Reviewed-by: Wilson Ding <dingwei@marvell.com>
Tested-by: Wilson Ding <dingwei@marvell.com>
Reviewed-on: http://vgitil04.il.marvell.com:8080/40913
This patch enable the PINCTRL and GPIO support, including the GPIO
command on the Armada 3720 espressobin board.
Reviewed-on: http://vgitil04.il.marvell.com:8080/40746
The various load address values are taken from the a37xx configuration
and match the dowstream 'u-boot-2017.03-armada-17.10' release where
appropriate.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
The kwbimage format is reading beyond its header structure if it
misdetects a Xilinx Zynq image and tries to read it. Fix it by
sanity checking that the header we want to read fits inside our
file size.
Tested-by: Michal Simek <michal.simek@xilinx.com>
This makes the network devices usable when booting a blank board over
UART, with no pre-configured MAC address stored in the environment area.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Currently, ATU (address translation unit) implementation doesn't
support translate addresses > 32 bits.
This patch allows to configure ATU correctly for different
memory accesses (memory, configuration and IO).
The same approach is used in Linux Kernel.
Signed-off-by: Igal Liberman <igall@marvell.com>
On x86 platforms, U-Boot does not pass Device Tree data to the kernel.
This prevents the kernel from using FDT loaded by U-Boot.
Read the working FDT address from the "fdtaddr" environment variable
and add a copy of the FDT data to the kernel setup_data list.
Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com>
[bmeng: add #include <linux/libfdt.h> to zimage.c to fix build error]
Use dm_pci_map_bar function for BAR mapping. This has the advantage
of clearing BAR flags and and only accepting mapped memory.
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
It makes no sense to set a PCI region that has 0 size.
PCI enumeration may happen very early on an x86 board. The board
information pointer should have been checked in decode_regions()
as its space may not be allocated yet.
With this commit, Intel Galileo board boots again.
Fixes: 664758c ("pci: Fix decode regions for memory banks")
The get_codeseg32() wants to know if a passed in descriptor has
flag GDT_NOTSYS set (desc & GDT_NOTSYS), not whether desc and
GDT_NOTSYS are not != 0 (desk && GDT_NOTSYS).
This is an obvious typo. Fix it up.
Enable CONFIG_OF_BOAD to support delivery dtb to u-boot
at run time instead of embedded.
There are two methods to delivery dtb.
1 Pass from loader:
When u-boot boot from RAM, gdb or loader can pass dtb
via a2 to u-boot dynamically. Of course gdb or loader
shall be in charge of dtb delivery.
2 Configure CONFIG_SYS_FDT_BASE:
It can be configured as RAM or ROM base statically,
no mater u-boot boot from RAM or ROM.
If it was configured as ROM base, dtb can be burned
into ROM(spi flash) by spi driver.
Meanwhile remove CONFIG_SKIP_LOWLEVEL_INIT which is
useless in nx25-ae250 configuration.
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Cc: Greentime Hu <green.hu@gmail.com>
Remove CONFIG_MMC_NDS32 from the three config
(adp-ae3xx_defconfig, adp-ag101p_defconfig, nx25-ae250_defconfig).
nsd32_mmc was created to support ftsdc010 dm.
It is not necessary to separate both, so merge it
to ftsdc010.
Convert CONFIG_FTSDC010_SDIO to Kconfig.
So CONFIG_FTSDC010_SDIO can also be
removed from config_whitelist.txt.
CONFIG_FTSDC010_NUMBER was not used anymore,
can be removed now.
So CONFIG_FTSDC010_NUMBER
can also be removed from config_whitelist.txt.
After drop non-dm code of ftsdc010, the sd register
base definition can be droppped now.
So CONFIG_FTSDC010_BASE and CONFIG_FTSDC010_BASE_LIST both
can be removed from config_whitelist.txt
Remove board_mmc_init() in adp-ag101p, adp-ae3xx
and nx25-ae250 boards.
Only three defconfig(adp-ag101p_defconfig,
adp-ae3xx_defconfig, nx25-ae250_defconfig)
set CONFIG_FTSDC010=y. And they all also
enable CONFIG_DM_MMC. So the non-dm code
of ftsdc010 can be dropped now.
