Sort include files in accordance to U-Boot coding style.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
default one
If board_fit_config_name_match() doesn't match any configuration node,
then use the default one (if provided).
If the dtb is the first data of the FIT, the its offset is 0x0. Change the
test to '<' instead of '<='
Those 2 functions don't modify their input, we can mark it const.
This prevents compilation warnings when they are provided const input.
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it
MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing
multiple DTBs. Also move the option to the Kconfig dedicated to the DTS
options and create a README for this feature.
These macros are useful to avoid link error on 32-bit systems.
Since commit ff98cb90514d ("part: extract MBR signature from partitions")
SPL boot on i.MX6 starts to fail:
U-Boot SPL 2017.09-00221-g0d6ab32 (Oct 02 2017 - 15:13:19)
Trying to boot from MMC1
(keep in loop)
Use the original allocation scheme for the SPL case, so that MX6 boards
can boot again.
This is a temporary solution to avoid the boot regression.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Rob Clark <robdclark@gmail.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
While this came in with a default value of 6 I am lowering this to 4.
The MTD/UBI code has a large number of error messages that we include
now. In addition, "normally" warning messages are not included so this
feels like a more natural level to have.
As we discussed before in ML, dm_dbg() causes undefined reference
error if #define DEBUG is added to users, but not drivers/core/util.c
We do not need this macro because we can use pr_debug() instead, and
it is pretty easy to enable it for the DM core by using ccflags-y.
Copied from Linux 4.13.
Commit log of 3e9b3112ec74 of Linux explains well why this header
is useful.
Many drivers had started to use dev_err, dev_info, etc. for log
functions. Currently, we are relying on <linux/compat.h>, but I
guess the best home is <dm/device.h>, taking into account that
Linux defines them in <linux/device.h>.
For now, I am leaving the ones in <linux/compat.h> because lots of
Linux-originated code uses dev_*(), but the first argument is not
struct udevice, so we need to ignore the bogus argument. More
efforts are needed to iron out the issues.
Collect runtime BUG/WARN into a self-contained header <linux/bug.h>
to make these macros easier to use.
As commit 84b8bf6d5d2a ("bug.h: move BUILD_BUG_* defines to
include/linux/bug.h") noted, include/linux/bug.h was locally
modified for U-Boot because the name conflict of error() caused
build errors at that time.
Now error() is gone, so we can fully sync BUILD_BUG* with Linux.
These macros are just compile-time utilities. Nothing depends on
platform code, so it should make sense to simply copy Linux's ones.
Please note Linux split BUILD_BUG stuff out into <linux/build_bug.h>
by commit bc6245e5efd7. Let's follow it.
This header uses ulong, size_t, loff_t.
Include <linux/types.h> to make this header self-contained.
This macro prevents us from using compiletime_error/assert defined
in <linux/compiler.h>.
Now we can remove it, then we will be able to import more BUILD_BUG
macros from Linux.
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in
include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it
difficult to fully sync BUILD_BUG macros with Linux. (Notice
Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl>
-error
+pr_err
// </smpl>
[trini: Re-run Coccinelle]
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
<common.h> pulls in a lot of headers. Including it from every .c
file is a bad idea. We need to remove contents until it contains
nothing.
Move printf() and friends to <stdio.h>.
If the USB Ethernet gadget is not yet enabled, the call of
usb_ether_init in board/sunxi/board.c will lead to undefined reference
error when building.
Fix this problem.
Fixes: 50ddbf1199a0 ("sunxi: Register usb_ether")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All the new SoCs from Allwinner since the A33 have had the phy_ctl offset
at 0x410 instead of 0x404 that was used on the previous SoCs.
Instead of adding more and more special cases as the number of SoCs grow,
let's invert the test to have 0x410 by default, and the (hopefully) fixed
number of old SoCs being the exception.
Suggested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Suggested-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Banana Pi M1 Plus is an open-source single-board computer
that adds more connectivity to the classic board using
Allwinner A20 SOC.
Bananapi M1-Plus features:
- A20 Dual-core 1.0GHz
- 1 GB DDR3 SDRAM
- MicroSD
- 10/100/1000 Ethernet RJ45
- WiFi b/g/n
- 5V DC Micro USB power-supply
For dts file,
Sync with Linux commit f92ca09("Merge branch 'akpm/master'").
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
As we have already DRAM initialization code for V3s SoC, we can
defaultly enable SPL now on Lichee Pi Zero.
Add CONFIG_SPL in Lichee Pi Zero defconfig.
Set CONFIG_MMC_SUNXI_SLOT_EXTRA=2 to enable the eMMC controller to
access eMMC on the board.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The upstream (Linux) device tree file for the Bananapi M3 follows the
convention of using the well known brand name, instead of the vendor
name, for naming. The file was recently added to upstream in commit
359b5a1e1c2d ("ARM: sun8i: a83t: Add device tree for Sinovoip Bananapi
BPI-M3")
Rename the device tree file in U-boot to match.
USB_GADGET will fail to compile if USB_MUSB_GADGET is not defined. Make
sure we have that condition right.
Fixes: e0ea88042d51 ("sunxi: Imply USB_ETHER")
The current code, if there's both an eMMC and an MMC slot available on the
board, will swap the MMC indices based on whether we booted from the eMMC
or the MMC. This way, the MMC we're supposed to boot on will always have
the index 0.
However, this causes various issues, for example when using other
components that base their behaviour on the MMC index, such as fastboot.
Let's remove that hack, and take the opposite approach. The MMC will always
have the same index, but the bootcmd will pick the same device than the one
we booted from. This is done through the introduction of the mmc_bootdev
environment variable that will be filled by the board code based on the
boot device informations we can get from the SoC.
In order to not introduce regressions, we also need to adjust the fastboot
MMC device and the environment device in order to set it to the eMMC, over
the MMC, like it used to be the case.
Tested-by: Chen-Yu Tsai <wens@csie.org>
Our current board code duplicates a bit the sunxi_get_boot_device logic.
Now that we can use that function in the full-flavoured U-Boot, remove that
duplication and call the function instead.
U-Boot itself might need to identify the boot device, for example to be
able to tell where to load the kernel from when several options are
possible.
Move the logic of spl_boot_device to a function that is compiled both for
the SPL and the main binary.
From rev.J A20-OLinuXino-MICRO has eMMC option. For now this is
only 4GB, but in the future size may increase.
The dts file is the same from mainline kernel.
Signed-off-by: Stefan Mavrodiev <stefan@olimex.com>
GPT is pretty common these days and can be useful for things like fastboot.
Add a platform imply, so that users can still opt out if they wish so.
CONFIG_RANDOM_UUID is used by the GPT command to generate random UUID when
none are provided.
Move that option to Kconfig.
The kernel DT of the SinA33 has evolved quite a bit. Make sure we sync it
and its upstream DTSI to be able to use the OTG. The DTs were taken from
the 4.13 kernel release.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Now that we can enable the usb_ether gadget, do it. This will be especially
useful for boards that don't have any ethernet controller, such as the ones
based on the A13 or A33.
Call the function to register the usb_ether gadget in the board.
The device model was implemented so far using a hook that needed to be
called from the board support, without DT support and only for the host.
Switch to probing both in peripheral and host mode through the DT.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
A good number of our boards have USB_GADGET enabled. Imply it so that all
the boards can benefit from it, and remove some boilerplate from our
defconfigs.
All the Allwinner boards use the same manufacturer, VID and PID for the
gadgets. Make them the defaults to remove some boilerplate from our
defconfigs.
The usb_ether gadget duplicates the USB settings for the manufacturer,
product ID and vendor ID.
Make sure we use the common option so that we can expect a single VID/PID
couple for a single device.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
We need to select an interface for the usb_ether gadget, and they haven't
been converted to Kconfig yet. Add a choice to make sure we have an option
selected, and convert all the users.
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
While the USB Ethernet device address is already defined in Kconfig, the
host address isn't. Convert it.
Add an help about the USBNET_DEVADDR Kconfig option to make it clearer what
it's about.
Acked-by: Łukasz Majewski <lukma@denx.de>
The USBNET_DEVADDR has nothing to do with the USB download gadget, but
rather with the USB Ethernet gadget. Move it out of the if statement.
The setbits/clrbits/clrsetbits macros are used widely across the tree,
let's provide implementation for them in the sandbox.
