commit 20f14714169 ("imx: spl: Update NAND bootmode detection bit")
broke the NAND bootmode detection by checking if
BOOT_CFG1[7:4] == 0x8 for NAND boot mode.
This commit essentially reverts it, while using the IMX6_BMODE_*
macros that were introduced since.
Tables 8-7 & 8-10 from IMX6DQRM say the NAND boot mode selection
is done when BOOT_CFG1[7] is 1, but BOOT_CFG1[6:4] is not
necessarily 0x0 in this case.
Actually, NAND boot mode is when 0x8 <= BOOT_CFG1[7:4] <= 0xf,
like it was in the code before.
Signed-off-by: Eran Matityahu <eran.m@variscite.com>
Cc: Jagan Teki <jagan@openedev.com>
Cc: Tim Harvey <tharvey@gateworks.com>
This is a virtual "board" that uses configuration files and
Kconfig to define the memory layout used by a real board during
the board bring-up process.
It generates an SPL image that can be loaded using imx_usb or
SB_LOADER.exe.
When run, it will generate a set of calibration constants for
use in either or both a DCD configuration file for boards that
use u-boot.imx or struct mx6_mmdc_calibration for boards that
boot via SPL.
In essence, it is a configurable, open-source variant of the
Freescale ddr-stress tool.
https://community.nxp.com/docs/DOC-105652
File mx6memcal_defconfig configures the board for use with
mx6sabresd or mx6qsabreauto.
Signed-off-by: Eric Nelson <eric@nelint.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Khadas VIM is an Open Source DIY Box manufactured by Shenzhen Wesion NOT 'Tomato'
The fix was provided by Khadas Team member 'numbqq'.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The patch replaces the former error() by the new pr_err().
This makes the TPS65910 driver conform to Masahiro's patch
'treewide:replace with error() with pr_err()' introduced
October 2017.
Signed-off-by: Felix Brack <fb@ltec.ch>
Commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate
BOOTCOMMAND") removed CONFIG_BOOTCOMMAND option from
include/configs/am335x_evm.h file. But that option wasn't added to
defconfig files for BeagleBone Black board.
Because of this we can't boot Linux from SD card using just
"run bootcmd", getting next error:
** File not found /boot/undefined **
That's because "fdtfile" variable has "undefined" value by default, and
"bootcmd" doesn't call "run findfdt" command, which assigns "fdtfile" to
correct device tree file for current board name (obtained from EEPROM).
So we are forced to either call "run findfdt" command manually, or
assign manually "fdtfile=am335x-boneblack.dtb" (e.g. in uEnv.txt file).
Bring back CONFIG_BOOTCOMMAND to BBB defconfigs so that we can boot
Linux rootfs from SD card automatically without any addition actions.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
struct driver_info has no field 'flags'.
This commit clears 'ethaddr' before calling 'smc911x_initialize' to
allow the SROM MAC address to be assigned properly.
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
This commit updates the configuration files needed to support OF_CONTROL
on the OMAP3 EVM baseboard.
Additionally:
- CONFIG_SYS_THUMB_BUILD is enabled
- CONFIG_SPL_ENV_SUPPORT is enabled
Tested using GCC 7.2.0 [--with-float=hard --with-mode=thumb].
This commit adds OMAP3 EVM devicetree files from Linux v4.15-rc3. Note
that this is the first addition of OMAP34XX devicetree files.
This commit keeps the 'fdtaddr' as provided by DEFAULT_LINUX_BOOT_ENV.
Enable sdmmc node in SPL and add it to boot order.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[Fixed commit tags:]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This commit changes the size of the enviroment (for the RK3399-Q7) to
8kiB for all possible locations of the environment (i.e. even when the
environment is saved to SD card).
With the default of 32kiB, the environment overwrites the SPL
stage which lives at 16kiB.
Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[Reworked commit-message:]
Since commit 999a78d5cf00 ("scripts/dtc: Update to upstream version v1.4.5-3-gb1a60033c110")
dtc warns about:
arch/arm/dts/imx53-cx9020.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/aips@50000000/serial@53fc0000
arch/arm/dts/imx53-cx9020.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/aips@50000000/ccm@53fd4000
arch/arm/dts/imx53-cx9020.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/aips@50000000/gpio@53fe4000
arch/arm/dts/imx53-cx9020.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/aips@60000000/sdma@63fb0000
arch/arm/dts/imx53-cx9020.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/aips@60000000/ethernet@63fec000
Fix this by adding a node for the tzic interrupt controller.
Copied from "<Linux>/arch/arm/boot/dts/imx53.dts"
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The DDR DRAM calibration doesn't work on T-topology sometimes, so disable it.
In commit 6e6cf015e7cdd7ca83a933320a81201972bd5e5e ("Merge
git://www.denx.de/git/u-boot-imx") the line defining spl_sd
configuration for wandboard was removed, which resulted in no SPL
target being built.
Add it back.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Currently CONFIG_SECURE_BOOT is selecting FSL_CAAM for all i.MX devices,
this causes the following error when building mx6sl boards since
this SoC doesn't have the CAAM block:
In file included from drivers/crypto/fsl/jobdesc.c:12:0:
drivers/crypto/fsl/jobdesc.c: In function 'inline_cnstr_jobdesc_blob_dek':
include/fsl_sec.h:268:25: error: 'CAAM_ARB_BASE_ADDR' undeclared (first use
in this function)
#define SEC_MEM_PAGE1 (CAAM_ARB_BASE_ADDR + 0x1000)
drivers/crypto/fsl/jobdesc.c:140:21: note: in expansion of macro 'SEC_MEM_PAGE1'
memcpy((uint32_t *)SEC_MEM_PAGE1, (uint32_t *)plain_txt, in_sz);
include/fsl_sec.h:268:25: note: each undeclared identifier is reported only
once for each function it appears in
scripts/Makefile.build:280: recipe for target 'drivers/crypto/fsl/jobdesc.o'
failed
make[3]: *** [drivers/crypto/fsl/jobdesc.o] Error 1
scripts/Makefile.build:425: recipe for target 'drivers/crypto/fsl' failed
make[2]: *** [drivers/crypto/fsl] Error 2
scripts/Makefile.build:425: recipe for target 'drivers/crypto' failed
make[1]: *** [drivers/crypto] Error 2
Add HAS_CAAM configuration to avoid this error.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
MX6UL contains features that MX6ULL doesn't support.
Deselect CONFIG_MX6UL and select SYS_L2CACHE_OFF and ROM_UNIFIED_SECTIONS.
The motivation for doing this change is that MX6UL supports CAAM and
MX6ULL does not.
Currently the MX6SL option is selected via CONFIG_SYS_EXTRA_OPTIONS,
but it is better to select it directly via Kconfig.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Secure boot is not enabled in warp imximage.cfg, add support for it.
Secure boot is not enabled in mx6slevk imximage.cfg, add support for it.
Acked-by: Peng Fan <peng.fan@nxp.com>
Currently only imx6sx-sdb.dtb is loaded, but if revA board is used the
correct dtb is imx6sx-sdb-reva.dtb, so make this possible.
While at it, remove an extra 'mmc dev'.
NXP development boards based on i.MX6/i.MX7 contain the board
revision information stored in the fuses.
Introduce a common function that can be shared by different boards and
convert mx6sabreauto to use this new mechanism.
USE_BOOTCOMMAND
This commit switch display5_factory_defconfig to use new, generic
USE_BOOTCOMMAND Kconfig option.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Include dm/ofnode.h.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Commit 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support")
enabled driver model support for MMC. Remove the old mmc init code, which
is no longer used, from the board file.
Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de>
enabled driver model support for AHCI. Remove the old, now unused, sata
init code from the board file.
enabled driver model support for USB. But it missed to enable driver
model support for keyboards. As a result, USB keyboards do no longer
work.
Fix this by enabling driver model support for keyboards.
Fixes: 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support")
enabled driver model support for USB, thereby effectively removing USB
support because the cm_fx6 devicetree in the U-Boot does *not* enable the
USB nodes.
Reinstate the USB support by syncing the devicetree with Linux whose
devicetree enables the USB nodes properly.
More precisely, use the devicetree found in Linux v4.15-rc1 with the
following two changes:
1) Remove the audio mux; the required dt-bindings header is not
present in the U-Boot.
2) Keep the usdhc3 MMC controller node currently present in the
U-Boot's devicetree to retain the ability to boot from MMC.
We are going to be using check_time() on more than the mx53ppd, move this
function to a common location.
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
There is an #ifdef and #endif with nothing in between. This patch simply
removes this dead/useless code.
In order to provide a consistent user experience for imx board users,
remove the custom CONFIG_BOOTDELAY values from defconfig files, so that
all boards can use the default two second delay.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
Linux device tree contains "ethernet" node for all possible
interface supported by SoC i.e. LS1046A.
It is not necessary for a SerDes protocol to support all possible
interface. So disable unavailable "ethernet" node in device tree.
Also, enable FDT_SEQ_MACADDR_FROM_ENV to fetch MAC address
sequentially from environment variables
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
"ethernet" node fix-up for device tree happens before Linux boot.
There can be requirement of updating "ethernet" node even before
fix-up. So, add support of updating "ethernet" node.
The MAC addresses get fixed in the device tree for "ethernet" nodes
is by using trailing number behind "ethernet" found in "/aliases".
It may not be necessary for the "ethernet" nodes to be sequential.
There can be gaps in between or any node disabled
So provide a support to fetch MAC addr sequentially from env
and apply them to "ethernet" nodes in the order they appear in
device tree only if "ethernet" is not "disabled"
FLIS IP since now gets its own ACPI ID.
Drop PRP0001 workaround in favour of official ACPI HID.
Corresponding kernel commit dabd4bc6de2b
pinctrl: intel: merrifield: Introduce ACPI device table
in the pin control subsystem tree [1] targeting v4.16.
[1]: https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl.git/commit/?h=for-next&id=dabd4bc6de2b
When adding a partition, set the logical_partition member in the media
structure as mandated by the UEFI spec.
Signed-off-by: Emmanuel Vadot <manu@freebsd.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This spi-nor is 4Mbit/512KB
Fixes: b4fbcbc5a5 ("mtd/spi: add support for is25lq040b")
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Order sun50i-h5-orangepi-prime.dts nodes in alphabetic
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Now FASTBOOT_FLASH is auto select for sunxi platform,
so drop explicit addition.
The default value of CONFIG_SYS_BOOTM_LEN, 0x800000, causes error
when uncompressing Image.gz out of FIT image.
Uncompressing Kernel Image ... Error: inflate() returned -5
Image too large: increase CONFIG_SYS_BOOTM_LEN
and loading Image out of FIT image.
Loading Kernel Image ... Image too large: increase CONFIG_SYS_BOOTM_LEN
Must RESET board to recover
