Commit 7f95104d91cc ("efi_loader: detach runtime in ExitBootServices()")
added a call to efi_runtime_detach() to ExitBootServices() but did not
remove the call in SetVirtualAddressMap().
Remove the superfluous function call.
Correct a comment referring to efi_runtime_detach().
Fixes: 7f95104d91cc ("efi_loader: detach runtime in ExitBootServices()")
Check the parameters DescriptorSize and DescriptiorVersion of
SetVirtualAddressMap() as prescribed by the UEFI specification.
U-Boot implements the EFI_PXE_BASE_CODE_PROTOCOL because GRUB uses the mode
information for booting via PXE. All function pointers in the protocol were
NULL up to now which will cause immediate crashes when the services of the
protocol are called.
Create function stubs for all services of the protocol returning
EFI_UNSUPPORTED.
- Various improvements to Keymile boards - mostly DT conversation
(Pascal & Holger)
- Removal of now unsupported Keymile boards (Pascal & Holger)
- Small MVEBU PCI fix (Marek)
- Turris Omnia defconfig update (Marek)
- Misc Allied Telesis defconfig updates (Chris)
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- amlogic: add support for the SEI Robotic SEI510
- More DaVinci updates and fixes
- PCIe support on am65x
- Watchdog converted to DM
- Assorted other bugfixes
- environment cleanup
- HiKey 960 support
- Some PCI fixes
We do not need to split binman, buildman, dtoc and patman test suite
runs into 3 jobs. Instead, run them as a single job.
The way that some of the tests here are designed, they expect USER to be
set in the environment. This is not the case in the docker images, so
set a reasonable value.
A previous commit...
commit 2a51e16bd57a ("configs: Make USE_TINY_PRINTF depend on SPL||TPL and be default")
...causes the System Firmware version string during SPL boot to no longer
getting printed to the console as expected. To fix this issue rework the
handling of that string to only use basic printf() syntax rather than
for example disabling CONFIG_USE_TINY_PRINTF on affected devices, this
way maintaining most of the memory size benefit the initial patch brings
when it comes to SPL.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Do not fail if any of the requested subtypes are not available, but set the
number of resources to 0 and continue parsing the resource ranges.
Based on Linux kernel patch by Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Historically there have been various boot options, SPI flash,
NAND or NOR. The NOR flash is mutually exclusive with MMC, but
it isn't mutually exclusive with NAND or SPI Flash, so this patch
enables both NAND flash and SPI Flash when booting from NOR.
The configuration with NOR is mutually exclusive with MMC, and as
such, the filesystem commands were disabled. With the USB host
enabled, this patch enables the file system command which can
be executed on storage devices attached to the USB.
The current size allocated to U-Boot is 384k, but U-Boot has grown
to 436K which means that saving the environmental variables wipes
out part of the U-Boot source and the board ceases to function.
Due to the sector and erase size for the NOR part and a desire to
not have to change partition sizes often, this patch moves the
U-Boot environmental variables to an offset of 1M so saveenv
does not brick the board. This patch also sets up MTDIDS and
MTDPARTS to clearly show where U-Boot and U-Boot's environmental
variables are located.
A previous patch for enabling the NAND config set a flag called
CONFIG_SKIP_LOWLEVEL_INIT when it should have been called
CONFIG_SKIP_LOWLEVEL_INIT_ONLY. The affect this had was creating
a delay on startup for the NOR version which is XIP and doesn't have
SPL, so the lowlevel initialization functions need to operate.
This delay was not really noticeable at first, but the delays have been
getting longer, finally reached the point of nearly seven seconds
before the board would appear to start.
This patch sets the CONFIG_SKIP_LOWLEVEL_INIT_ONLY instead which means
"The normal CP15 init (such as enabling the instruction cache) is still
performed" per the README. It doesn't appear to have any adverse
behavior on the SPI Flash or the NAND flash boards which use SPL.
Fixes: 93f3362762f0 ("ARM: configs: Add da850evm_nand to boot from NAND")
Enable support for Intel E1000 based PCIe ethernet cards that
can be used to test PCIe RC functionality on AM65x EVM.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Add needed device-tree nodes to support PCIe 0
and SERDES on AM65x SoC. The nodes are kept
disabled by default.
Enable support for PCIe and related configurations
on AM654 EVM platform.
Add a new SERDES driver for TI's AM654x SoC which configures
the SERDES only for PCIe. Support fo USB3 can be added later.
SERDES in am654x has three input clocks (left input, external
reference clock and right input) and two output clocks (left
output and right output) in addition to a PLL mux clock which
the SERDES uses for Clock Multiplier Unit (CMU refclock).
The PLL mux clock can select from one of the three input
clocks. The right output can select between left input and
external reference clock while the left output can select
between the right input and external reference clock.
The driver has support to select PLL mux and left/right output
mux as specified in device tree.
Add driver supporting PCIe root-complex available
on TI's AM65x SoC.
Current dev_read_*() API lacks support to get address and size
of a "reg" property by name or index. Add support for the same.
Livetree support has been added but not tested on real hardware.
The existing unit tests testing reading address from device-tree
have been updated to test address as well as size.
Add support for clk_is_match() which is required to
know if two clock pointers point to the same exact
physical clock.
Also add a unit test for the new API.
Failure log for ti_sci_power_domain_on/off is as below:
"ti_sci_power_domain_on: get/set_device failed (-19)"
The above information is useless for debug without information
on what specific device access failed. So add that information as well.
Signed-off-by: Nishanth Menon <nm@ti.com>
This commit adds support for the B&R brsmarc1 SoM.
The SoM is based on TI's AM335x SoC.
Mainly vxWorks 6.9.4.x is running on the board,
doing some PLC stuff on various carrier boards.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
This patch disables DM watchdog support for SPL builds and uses
the legacy omap watchdog driver on TI AM335x chipsets.
The following build error is reported if DM watchdog support was
enabled in SPL:
CC spl/drivers/usb/gadget/rndis.o
LD spl/drivers/usb/gadget/built-in.o
LD spl/drivers/usb/musb-new/built-in.o
LD spl/drivers/built-in.o
LD spl/u-boot-spl
arm-linux-ld.bfd: u-boot-spl section .u_boot_list will not fit in region .sram
arm-linux-ld.bfd: region .sram overflowed by 440 bytes
make[1]: *** [spl/u-boot-spl] Error 1
make: *** [spl/u-boot-spl] Error 2
Adjusted WATCHDOG_RESET macro accordingly. Earlier it was pointing
to hw_watchdog_reset. Since CONFIG_WATCHDOG replaces CONFIG_HW_WATCHDOG,
now WATCHDOG_RESET macro points to watchdog_reset. This watchdog_reset
is not defined anywhere for am33xx/omap2 and needs to be defined. Fixed
this by simply calling hw_watchdog_reset in watchdog_reset.
Built and tested on AM335x device (BeagleboneBlack), compile tested for
all other AM33xx/omap2 based boards.
Signed-off-by: Suniel Mahesh <sunil.m@techveda.org>
[trini: Fix watchdog.h logic]
The non-DM version of this driver used to set BAR0 register after the
calls to pci_set_region.
I found out that for some strange reason the ath10k driver in kernel
fails to work if this is done the other way around.
I know that Linux's driver should not depend on how U-Boot does things,
but for some strange reason it does and this seems to be the simplest
solution. Fix it since it caused regressions on Omnia.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Cc: Stefan Roese <sr@denx.de>
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Phil Sutter <phil@nwl.cc>
Cc: VlaoMao <vlaomao@gmail.com>
Tested-by: Chris Packham <judge.packham@gmail.com>
This patch adds device tree and driver model watchdog support,
converts the legacy omap watchdog driver to driver model for
TI AM335x chipsets. The following compile warning is removed:
===================== WARNING ======================
This board does not use CONFIG_WDT (DM watchdog support).
Please update the board to use CONFIG_WDT before the
v2019.10 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
CONFIG_HW_WATCHDOG is no more a default option for AM33XX devices
after DT/DM conversion, adjusted kconfig accordingly.
DM watchdog support is enabled by default in SPL. The SPL image
doesn't fit into SRAM because of size constraints and build breaks
with an overflow. For this reason DM watchdog support should be
disabled in SPL, driver code should be adjusted accordingly to serve
this purpose.
for all other AM33xx based boards.
The SPL for the Overo board does not initialise the MMC. Hence, it
cannot load the main boot loader from the SD card susequently. This
patch moves the initialisation code for the MMC so it gets included in
the SPL.
[trini: Add missing header]
Disable the PSCI_RESET reboot handler to permit handling the reboot
flag and calling the PSCI handler with the flag in parameter.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Add support for fastboot_set_reboot_flag() by storing the reboot
flag in the common code to be used by the custom PSCI reboot handler.
The SEI510 board is based on the Amlogic S905X2 SoC
from the Amlogic G12A SoC family.
The board has the following specifications :
- Amlogic S905X2 ARM Cortex-A53 quad-core SoC
- XGB DDR4 SDRAM
- 10/100 Ethernet (Internal PHY)
- 1 x USB 3.0 Host
- eMMC
- SDcard
- Infrared receiver
- SDIO WiFi Module
The board default behaviour is for booting Android and triggers
fastboot on recovery or reboot mode.
USB vendor ID (used by fastboot) is 0x18d1 (Google) for
default udev rules for existing android users work out of the box.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
The Secure Monitor offers multiple services, like returning the
SoC unique serial number, and can provide the "reboot reason" as
set by the previous booted system.
This extends the Amlogic specific "sm" cmd with a "reboot_reason" subcommand
to print or set a specified environment variable with the reboot reason in
human readable format.
SoC unique serial number, already used to generate an unique MAC
address.
This adds a new, Amlogic specific, "sm" cmd with a "serial" subcommand
to write the SoC unique serial to memory.
This "cm" command will be extended in further patches.
Permit redefining ENV_SIZE for board specific configs.
Import Linux 5.2-rc1 sei510 DT from 5f9e832c1370 ("Linus 5.3-rc1") for the
meson-g12a-sei510 board.
Add Macronis SPI flash support - some Omnia routers are shipped with
this SPI flash chip.
Also add the memtest command to defconfig.
The mvgbe driver supports DM_ETH so switch these boards to using it.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This board is unmaintained and can be removed. This also allows us to
remove kmp204x-common.h and integrate it in kmp204x.h.
Signed-off-by: Valentin Longchamp <valentin.longchamp@ch.abb.com>
Signed-off-by: Holger Brunck <holger.brunck@ch.abb.com>
Remove the PORTL2 board and all its dependencies as it is no longer
supported by the company.
Signed-off-by: Pascal Linder <pascal.linder@edu.hefr.ch>
Activate the driver model for the Ethernet interface (RGMII) in the KM
Kirkwood Kconfig file. Additionally, raise the auto negotiation timeout
to eight seconds as more time is required for those boards.
Activate the driver model for the serial interface in the KM Kirkwood
Kconfig file. The associated preprocessor definitions could be removed
from the header file. However, the clock of 200 MHz needs to be declared
in the device tree.
A typo in the km_kirkwood.h header prevented to undefine the initialization
of the Kirkwood PCIe interface.
Remove unused preprocessor definitions and comments of already eliminated
code.
The Ethernet driver configuration is already declared in
arch/arm/mach-kirkwood/include/mach/config.h and, therefore, superfluous.
After moving the KM specific configurations to Kconfig, the associated
preprocessor definitions can now be removed in the headers. Moreover, the
whitelist has been adapted correspondingly.
To execute the conversion away from board specific header files, Kconfig
menus have been implemented for all KM boards and additionally for those
having an ARM architecture.
For the moment, the preprocessor definitions stay in the headers. The
boolean types, however, needed a modification (#define CONFIG_* 1).
The default configuration files of some boards required an update in order
to not change the currently defined values of the configurations.
This file has quite a lot of general definitions and include files. Add a
note about our intent to remove more of this.
The file should ultimately include the configuration and perhaps a very
other very common things used by most U-Boot files.
This is no-longer used in U-Boot and has not been converted to driver
model. Drop it.
