2016-09-09Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-09-09cmd: Rework disk.c usageTom Rini
We only need the function found in cmd/disk.c when we have IDE, SCSI or USB_STORAGE enabled. While the first two are easy to get right, in the 3rd case we assume that the set of cases where we do have USB and do not enable USB_STORAGE are small enough that we can take the small bloat of un-discarded strings on gcc prior to 6.x Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-09net: asix: Fix AX88772B when used with DriverModelJoshua Scott
A previous patch (net: asix: fix operation without eeprom) added a two-byte shift to the packet buffer when receiving a packet on the AX88772B. This shift was not included when the driver was updated to work with DriverModel. Testing on a Marvell DB-88F6820-ACM showed that the adapter was not functioning correctly (EHCI timeouts). This patch brings the two-byte shift to the DriverModel implementation of ops->recv (asix_eth_recv). Testing on the same board, we were able to TFTP a file over and confirm that the crc32 was correct. Signed-off-by: Joshua Scott <joshua.scott@alliedtelesis.co.nz> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-09-09Revert "net: nfs: Correct the reply data buffer size"Joe Hershberger
This reverts commit 6279b49e6c2fdaf8665355d1777bc90cd41fcf90. This caused a bad data crc. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-09-09Revert "net: nfs: Use the tx buffer to construct rpc msgs"Joe Hershberger
This reverts commit 998372b4798fd7ebb666f571950df925b8d80f69. This caused a data abort on some platform. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-09-07board: ks2: README: Update to add K2G supportLokesh Vutla
Update the README to add support for K2G EVM. Also - Add steps on how to use MMC boot - Fix load address when using CCS - Update build target to u-boot.bin from u-boot-dtb.bin as all ks2 platforms uses DT. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-09-07efi_loader: provide efi_mem_desc versionMian Yousaf Kaukab
Provide version of struct efi_mem_desc in efi_get_memory_map(). EFI_BOOT_SERVICES.GetMemoryMap() in UEFI specification v2.6 defines memory descriptor version to 1. Linux kernel also expects descriptor version to be 1 and prints following warning during boot if its not: Unexpected EFI_MEMORY_DESCRIPTOR version 0 Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@gmail.com>
2016-09-07image-fit: switch ENOLINK to ENOENTJonathan Gray
ENOLINK is not required by POSIX and does not exist on OpenBSD and likely other systems. Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
2016-09-07compiler.h: use system endian macros on OpenBSDJonathan Gray
The u-boot endian macros map directly to system endian macros on OpenBSD. Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
2016-09-07board: am57xx: Fix missing check for beagle_x15Nishanth Menon
When beagleboard-X15 is booted, we see the following log: Unidentified board claims BBRDX15_ in eeprom header This is because of the missing check for x15 (the default) and reports an error for a valid board configuration. Fix the same. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-09-07board: am57xx: MAINTAINERS: Update for current maintainerNishanth Menon
Felipe Balbi has move on from TI and the current email ID is no longer valid. So, replacing with Lokesh. While at it, update missing config file which was untracked. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-07global_data.h: Standardize tabs and alignment for commentsRobert P. J. Day
Line up comments for readibility. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-09-07pxe: Modify README to add the description about FIT imageWenbin Song
Use environment variable "kernel_addr_r" to indicate the location in RAM where FIT image will be stored. Use label command "kernel" to indicate which <path> the FIT image at. Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
2016-09-07pxe: Fix pxe boot with FIT imageYork Sun
When FIT image is used, a single image provides kernel, device tree and optionally ramdisk. Argc and argv need to be adjusted to support this. Test cases: 1. Booting with legacy images 2. Booting with legacy images without initrd 3. Booting with FIT image Test commands: 1. pxe get && pxe boot 2. sysboot Signed-off-by: York Sun <york.sun@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
2016-09-07common/Kconfig: Fix various innocuous typos.Robert P. J. Day
Correct a small number of spelling mistakes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-09-07omap3_pandora: Only set bootargs if distro_bootcmd failed to load.Vagrant Cascadian
As bootargs is hard-coded for the default behavior on the omap3_pandora, only set the bootargs if distro_bootcmd fails to load. This leaves distro_bootcmd free to use alternate boot arguments. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2016-09-07omap3_pandora: Switch to use config_distro_bootcmd.Vagrant Cascadian
Add support for using distro_bootcmd to the omap3_pandora target, falling back to prior behavior. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2016-09-07ARM: am335x: select DM_GPIOMasahiro Yamada
We are supposed to not add config entries with only "default y" in board/SoC Kconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: guard memory reserve for PSCI with #ifdef CONFIG_ARMV7_PSCIMasahiro Yamada
If CONFIG_ARMV7_NONSEC is enabled, the linker script requires CONFIG_ARMV7_PSCI_NR_CPUS regardless of CONFIG_ARMV7_PSCI. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: tegra: remove wrong dependency on SPL_BUILDMasahiro Yamada
SPL_BUILD is not a CONFIG in Kconfig, so !SPL_BUILD is always true. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-06omap3_pandora: Switch to using "load" command to load the autoboot script.Vagrant Cascadian
CONFIG_CMD_FS_GENERIC is enabled; use it to load the autoboot script, rather than first attempting with fatload and falling back to ext2load. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Grazvydas Ignotas <notasas@gmail.com>
2016-09-06omap3_pandora: Fix mmc loading of autoboot script to use correct syntax.Vagrant Cascadian
fatload/ext2load both require that the device and partition be specified after specifying the device type. Specify the first partition on mmc device 0, which is the only mmc device currently configured on the pandora. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Grazvydas Ignotas <notasas@gmail.com>
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-09-06omap3logic: Fix PBIAS BugAdam Ford
The PBIAS fixing is done in the MMC driver, and doing it in the the board file conflicts with the driver causing intermittent hangs on reboot. Remove this from the board file and let the driver do it. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06README: add cmd directory descriptionXu Ziyuan
All of the command files have moved to cmd directory, add description to Directory Hierarchy. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06board/BuR/common: increase NET_RETRY_COUNT to 10Hannes Schmelzer
Sometimes boards may need more time to become stable network connection due to several reasons: - phy speed - link-partner (switch) Therefore we increase the retry-count to 10 for making sure that network connection works always. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06configs: am4xhs: Modify SPL load address to fix UART boot issueMadan Srinivas
An issue in the TI secure image generation tool causes the ROM to load the SPL at a different load address than what is specified by CONFIG_ISW_ENTRY_ADDR while doing a peripheral boot on HS devices. This causes the SPL to fail on secure devices during peripheral boot. The TI secure image generation tool has been fixed so that the SPL will always be loaded at 0x403018E0 by the ROM code for both peripheral and memory boot modes. Signed-off-by: Madan Srinivas <madans@ti.com> Reviewed-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06ARM: AM57xx: Enable post-processing of FIT artifacts loaded by U-BootAndreas Dannenberg
Enable the platform-specific post-processing of FIT-extracted blobs such as Kernel, DTB, and initramfs on TI AM57xx high-security (HS) devices which will ultimately invoke a ROM-based API call that performs secure processing such as blob authentication. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06ARM: DRA7xx: Enable post-processing of FIT artifacts loaded by U-BootAndreas Dannenberg
Enable the platform-specific post-processing of FIT-extracted blobs such as Kernel, DTB, and initramfs on TI DRA7xx high-security (HS) devices which will ultimately invoke a ROM-based API call that performs secure processing such as blob authentication. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06ARM: AM43xx: Enable post-processing of FIT artifacts loaded by U-BootAndreas Dannenberg
Enable the platform-specific post-processing of FIT-extracted blobs such as Kernel, DTB, and initramfs on TI AM43xx high-security (HS) devices which will ultimately invoke a ROM-based API call that performs secure processing such as blob authentication. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06spl: Rework image header parse to allow abort on raw image and os bootPaul Kocialkowski
This reworks spl_set_header_raw_uboot to allow having both os boot (which comes with a valid header) and aborting when no valid header is found (thus excluding raw u-boot.bin images). Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06regulator: fixed: obey startup delayJohn Keeping
When enabling a fixed regulator, it may take some time to rise to the correct voltage. If we do not delay here then subsequent operations will fail. Signed-off-by: John Keeping <john@metanate.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06tools: moveconfig: add --spl option to move options for SPL buildMasahiro Yamada
Prior to this commit, the tool could not move options guarded by CONFIG_SPL_BUILD ifdef conditionals because they do not show up in include/autoconf.mk. This new option, if given, makes the tool parse spl/include/autoconf.mk instead of include/autoconf.mk, which is probably preferred behavior when moving options for SPL. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06tools: moveconfig: warn loudly if moved option has no entry in KconfigMasahiro Yamada
Currently, the tool gives up moving an option quietly if its entry was not found in Kconfig. If the option is not defined in the config header in the first place, it is no problem (as the Kconfig entry may have been hidden by reasonable "depends on"). However, if the option is defined in the config header, the missing Kconfig entry is a sign of possible behavior change. It is highly recommended to manually check if the option has been moved as expected. In this case, let's add "suspicious" in the log and change the log color (if --color option is given) to make it stand out. This was suggested by Tom in [1]. [1] http://lists.denx.de/pipermail/u-boot/2016-July/261988.html Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Suggested-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06tools: moveconfig: use sets instead of lists for failed/suspicious boardsMasahiro Yamada
The sets feature is handier for adding unique elements. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-09-06tools: moveconfig: remove document about deprecated error messageMasahiro Yamada
Since commit cc008299f852 ("tools: moveconfig: do not rely on type and default value given by users"), we do not have this error case. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-09-06meson: odroid-c2: enable Ethernet support through the device treeBeniamino Galvani
Remove the device definition from board file, update the driver with the new compatible property and update config with necessary options. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06pinctrl: add driver for meson-gxbb pin controllerBeniamino Galvani
Add a pin controller driver for Meson GXBB adapted from Linux kernel. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06arm: dts: update DTS files for meson-gxbb and odroid-c2Beniamino Galvani
Import DTS files and dt-bindings includes from Linux 4.8-rc1. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06pinctrl: generic: scan for "pins" and "groups" properties in sub-nodesBeniamino Galvani
In cases where the pins and groups definitions are in a sub-node, as: uart_a { mux { groups = "uart_tx_a", "uart_rx_a"; function = "uart_a"; }; }; pinctrl_generic_set_state_subnode() returns an error for the top-level node and pinctrl_generic_set_state() fails. Instead, return success so that the child nodes are tried. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-06image-fit: fix fit_image_load() OS checkAndreas Bießmann
Commit 62afc601883e788f3f22291202d5b2a23c1a8b06 introduced fpga image load via bootm but broke the OS check in fit_image_load(). This commit removes following compiler warning: ---8<--- In file included from tools/common/image-fit.c:1: /Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: warning: use of logical '||' with constant operand [-Wconstant-logical-operand] os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA || ^ ~~~~~~~~~~~~ /Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: note: use '|' for a bitwise operation os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA || ^~ | 1 warning generated. --->8--- Signed-off-by: Andreas Bießmann <andreas@biessmann.org> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06bcm2835_gpio: Implement GPIOF_FUNCAlexander Graf
So far we could only tell the gpio framework that a GPIO was mapped as input or output, not as alternative function. This patch adds support for determining whether a function is mapped as alternative. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
