CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
the x530 board needs conversion of SPL_SPI_LOAD to Kconfig first
Reviewed-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Exact two boards are referencing CONFIG_SYS_SPI_U_BOOT_OFFS to another
define, we replace this manually with the value for having a clean run
of moveconfig.py afterwards.
some boards have common headers for several individual build-targets
where CONFIG_SYS_SPI_U_BOOT_OFFS is defined even it is not needed (only
needed if CONFIG_SPL_SPI_LOAD is defined also). Take this define here
under '#ifdef CONFIG_SPL_SPI_LOAD' for having a clean run of
moveconfig.py
Some boards have coded this offset with formula or bitshifts in their
board-config. Manually convert these things into hex-values to be able
using moveconfig.py afterwards.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- remove rk3288 fennec board
- remove SPL raw image support for Rockchip SoCs
- add common misc_init_r() for ethaddr from cpuid
- enable USB HOST support for rk3328
- unify code for finding a valid gpt in part driver
- Migrate CONFIG_MX_CYCLIC, CONFIG_FSL_USDHC and CONFIG_MXS_GPIO to
Kconfig
- Fix some SPL/TPL and ARM64 dependencies
CONFIG_MX_CYCLIC
Acked-by: David Lechner <david@lechnology.com>
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Several options are presenting themselves on a various boards
where the options are clearly not used. (ie, arm64 options on
arm9, or SPL/TPL options when SPL or TPL are not defined)
This patch is not attempting to be a complete list of items, but
more like low hanging fruit.
This patch attempts to reduce some of the menuconfig noise
by defining dependencies so they don't appear when not used.
CONFIG_MXS_GPIO
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/571260789
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Peng Fan <peng.fan@nxp.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
This was changed to 1 in commit 0717dde057e, but a few months later,
commit 5f9411af37b swapped the order of eMMC and SD card by assigning
indexed aliases to `&sdhci` and `&sdmmc`.
Signed-off-by: Max Kellermann <max.kellermann@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
(Add signature)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Some ChromeOS devices (atleast veyron speedy) have the first 8MiB of
the eMMC write protected and equipped with a dummy 'IGNOREME' GPT
header - instead of spewing error messages about it, just silently
try the backup GPT.
Note: this does not touch the gpt cmd writing/verifying functions,
those will still complain.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
There were 3 copies of the same sequence, make it into a function.
We should use the shared helpers to setup the necessary parts
Signed-off-by: Rohan Garg <rohan.garg@collabora.com>
This enables us to set a static MAC address
Generate a MAC address based on the cpuid available in the efuse
block: Use the first 6 byte of the cpuid's SHA256 hash and set the
locally administered bits. Also ensure that the multicast bit is
cleared.
The MAC address is only generated and set if there is no ethaddr
present in the saved environment.
This is based off of Klaus Goger's work in 8adc9d
Since there is no one using this board, remove it.
RK3399 SPL only support FIT image for ATF bl31.
RK3368 SPL only support FIT image for ATF bl31.
RK3328 SPL only support FIT image for ATF bl31.
Use Kconfig for option SYS_MALLOC_LEN and default to 0x2000000.
According to rock64 schemetic, both VCC_HOST1_5V and VCC_HOST_5V are
controlled by USB20_HOST_DRV(GPIO0A2), fix it so that we can get correct
power supply for USB HOST ports.
Move all the nodes only shown in u-boot to -u-boot.dtsi to make
rk3328.dtsi clean.
Rock64 has a USB3.0 port, enable the controller so that we can use it.
Required to successfully probe the ehci generic driver
We need to store all the ram related cap/map info back to register
for each channel after all the init has been done in case some of register
was reset during the process.
Signed-off-by: YouMin Chen <cym@rock-chips.com>
- i2c dm model support of lx2160a, ls1088a, lx2088a, ls1028a
- icid setup for ls1028a, ls1088a
- other small fixes
Add ICID setup for the platform devices contained on this chip: usb,
sata, sdhc, edma, qdma, gpu, display and sec.
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Reviewed-by: Horia Geantă <horia.geanta@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
sata, sdhc, sec. The ICID macros for SEC needed to be adapted because
the format of the registers is different.
The current implementation assumes that the registers holding the ICIDs
are universally big endian. That's no longer the case on newer
platforms so update the code to take into account the endianness of
each register.
Add CCSR base addresses for ESDHC2, EDMA QDMA, DISPLAY and GPU devices.
Add defines for all the SEC job rings base addresses.
By default, i2c input clock is platform clk / 2, but some of the
platform of i2c clock divider does not meet this kind of circumstance,
so alone to set default values for these platforms.
Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com>
BRDCFG4[USBOSC] and BRDCFG5[SPR] register field of Qixis device is used
to control SPI and other IP signal routing.
USBOSC:
0= SPI_CLK used as external USB REFCLK input driven with 24.000 MHz.
SPI devices are unusable in this mode.
1= SPI_CLK used as SPI clock.
SPI devices are usable in this mode. USB block is clocked from
internal sources
SPR[3:2]:
SPI_CS / SDHC_DAT4:7 Routing (schematic net CFG_SPI_ROUTE[3:2]):
00= SDHC/eMMC 8-bit
01= SD Card Rev 2.0/3.0
10= SPI on-board memory
11= TDM Riser / SPI off-board connector.
The default value is 00 if an SDCard/eMMC card is selected as the boot
device.
SPR[1:0]:
SPI_SIN/SOUT/SCK Routing (schematic net CFG_SPI_ROUTE[1:0]):
00= SDHC Sync loop
01= TDM Riser / SPI off-board connector.
10= SPI on-board memory.
11= SPI off-board connector.
By default, the SPI feature is not available, so we need to configure
the above register fields to select the route to the SPI feature.
Define ARCH_MISC_INIT for LS1028AQDS platform to handle board
related mux.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
Defines CONFIG_ENV_ADDR for QSPI Boot which specifies the start
address of the flash sector containing the environment. It fixes
the issue that bootcmd is always set as default at bootup.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Flexcan in LX2160ARDB is controlled by FPGA register boardcfg4
bit 5. enable this bit so that flexcan is enabled in LX2160ARDB.
Enable related configs on all ls1088aqds boards to support pcf2127
rtc DM function.
Add the pcf2127-rtc node under the i2c0->i2c-mux@77->i2c@3 for ls1088aqds boards.
Udate ls1088aqds board init code to support DM_I2C.
This patch adds some slave nodes to support the i2c dm on the device
side under the i2c0 controller.
One ls1088a, there are four I2C controllers. So add all I2C node
for ls1088a in device tree.
As no gpio.h is defined for this architecture, to avoid
compilation failure, do not include <asm/arch/gpio.h> for
arch ls1088a.
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM
I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for
compilation, a compilation error will be generated. This patch
solves the problem that the i2c-related api of the ls1088a platform
does not support dm.
Enable related configs on all ls2088aqds boards to support ds3231
rtc DM function.
