In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of
the default searched LDSCRIPT paths. Remove these customizations.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
This tool has just been added but it seems I forgot to add it to
the ignore list. So to prevent the built binary being marked as
unversioned, add it to the ignore list.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Change my email address, too many mails
gets to my private mail, created specific email
account just for developmement.
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
- pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groups
- pinctrl: meson-gxbb: add hdmi related pins to fix HDMI on GXBB
- pinctrl: meson: add support for getting pinmux status
- pinctrl: meson-g12a: add support for drive-strength-microamp property
Pull request for UEFI sub-system for v2019.07-rc5
This pull request provides fixes for event services.
The GXBB pinctrl is missing pins related to HDMI, namely hot plug
detection (hpd) and I2C (sda + scl).
This fixes HDMI support for GXBB in u-boot.
Reported-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Tested-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
add drive-strength bank regiter and bit value for G12A SoC
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Tested-by: Neil Armstrong <narmstrong@baylibre.com>
drive-strength-microamp is a new feature needed for G12A SoC.
the default DS setting after boot is usually 500uA and it is not enough for
many functions. We need to be able to set the drive strength to reliably
enable things like MMC, I2C, etc ...
Add drive-strength-microamp property support to allow drive strength in uA
In order to support the "pinmux status" command, use the common functions
to get the pins count and names, and add the AXG specific function to get
the current function from registers.
to get the pins count and names, and add the GX specific function to get
Tested-by: Maxime Jourdan <mjourdan@baylibre.com>
In order to support the "pinmux status" command, add common function
to get pins count and pin name.
The GPIO_TEST_N was in the wrong pmx group table, move it back with the AO
groups, GPIODV_18 was missing, add it back, and finally the GPIOCLK_*
group names were missing.
- Add Ethernet support for STM32MP1
- Add saveenv support for STM32MP1
- Add STM32MP1 Avenger96 board support
- Add SPI driver suport for STM32MP1
- Add watchdog support for STM32MP1
- Update power supply check via USB TYPE-C for STM32MP1 discovery board
u-boot-imx-20190612
- Board fixes:
- imx6logic
- wandboard
- mx6sabre boots again
- imx8qm_mek
- pico-* boards
- Toradex apalis / colibri
- engicam imx6 (environment)
- KP MX53
- opos6ul
- Switch to DM:
- vining2000
- dh MX6
- Toradex colibri i.MX7
- Novena
- Security : fix CSF size for HAB
- Other:
- imx: fix building for i.mx8 without spl
- pcie and switch to DM
mx6sabreauto: Enable SPL SDP support
The SPL for the Tinker Board has to fit into 32 KiB. Currently this limit
is exceeded.
CONFIG_SPL_I2C_SUPPORT is not needed to move to main U-Boot. So let's
disable it.
Suggested-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
As explained in include/configs/imx6_spl.h. the i.MX6 SPL
size limit is 68KB (4KB header + 64KB max size).
Provide such limit for all i.MX6 boards that use SPL
to detect SPL size overflow in build time.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
To allow loading u-boot over USB enable SDP support in the SPL.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
The i.mx6 SPL binary cannot be bigger then 68K, while with the current
defconfig for sabreauto it's only about 56K as soon as USB support gets
added the size will overflows.
All i.mx6 boards seems to have moved to DM_USB, however gadget support
for mx6 is still pre-DM as CI_UDC isn't converted yet. To make this work
the usb otg controller used for gadgets needs to be usb number 0.
Add an alias for this directly in the main u-boot mx6qdl dtsi so it
doesn't need to be done for each board separately.
This fixes regressions wrt. usb gadget functionality in several boards
that have gadget functions enabled in their config, but no usb0 alias in
their device-tree.
Sabre Auto boards currently hang with:
U-Boot 2019.07-rc3-00057-gc41940c406 (Jun 03 2019 - 14:42:41 +0200)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C)Reset cause: WDOG
Model: Freescale i.MX6 Quad Plus SABRE Automotive Board
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Error binding driver 'ipuv3_video': -28
Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Some drivers failed to bind
Error binding driver 'generic_simple_bus': -28
initcall sequence 8ffe00b8 failed at call 1780e93b (err=-28)
Set SYS_MALLOC_F_LEN to reserve_video to work.
This is similar to the change Peng Fan did for mx6sabresd (9002e735e717)
Reviewed-by: Peng Fan <peng.fan@nxp.com>
With the conversion to DM we should select the pinctrl driver.
Staticize 'spl_dram_init' and 'i2c_pad_info1' to fix the
following sparse warnings:
board/freescale/imx8mq_evk/spl.c:30:6: warning: symbol 'spl_dram_init' was not declared. Should it be static?
board/freescale/imx8mq_evk/spl.c:41:22: warning: symbol 'i2c_pad_info1' was not declared. Should it be static?
Without this definition, fsl_esdhc will access reserved registers
on i.MX chips, so define ARCH_MXC to fix it.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
imx-regs.h under arch-imx has no user, drop it.
Read the temperature when print cpu inforation.
This commit is necessary to be able to re-use the pinctrl code in early
SPL to properly configure pins.
The problem is that those "static" structures (without explicit
initialization) are placed in the SDRAM area, which corresponds to
u-boot proper (not even SPL).
Hence, when one wants to configure pins before relocation via DTS/DM,
the board hangs (imx6q SoC powered one) as only OCRAM area is available
(0x009xxxxx).
This commit prevents from this issue by moving the imx6_pinctrl_soc_info
structure to data section (from BSS).
Signed-off-by: Lukasz Majewski <lukma@denx.de>
We should not access reserved register on i.MX8, otherwise met SERROR
Enable DM Serial support on iMX6SX VINING|2000.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Silvio Fricke <silvio.fricke@softing.com>
Enable DM PCI support on iMX6SX VINING|2000.
Enable DM GPIO support on iMX6SX VINING|2000 and fix up
board code where applicable.
Enable DM USB support on iMX6SX VINING|2000.
Enable DM block and DM MMC support on iMX6SX VINING|2000 .
Convert board code to match the DM support. This disables
USB mass storage support due to missing DM USB, however
that will be re-enabled in subsequent patch.
Enable DM pin control support on iMX6SX VINING|2000.
Import iMX6SX VINING|2000 device tree from Linux 5.1.1 b724e9356404 .
Enable DT control in full U-Boot .
The company Samtec was merged into Softing, migrate the board over to
the new name and update copyright headers.
This patch configures pinmux for pin usdhc4 reset.
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Add imx dts files to the MAINTAINERS file list, so that i.MX
devicetree related patches can be properly sent to the i.MX folks.
Reported-by: Adam Ford <aford173@gmail.com>
Add compatible string for iMX6SX.
Enable DM PCI support on iMX6Q Novena.
Cc: Vagrant Cascadian <vagrant@debian.org>
Add DM support and support for probing the iMX PCI driver from DT.
The legacy non-DM support is retained, however shall be removed once
DM PCI is the only option remaining.
Cc: Bin Meng <bmeng.cn@gmail.com>
Pass the driver private data around the driver as much as possible, instead
of having it as a static global variable. This is done in preparation for
the DM conversion, no functional change.
The driver limits the config space base to 32bit, however it can be
64bit on 64bit iMX hardware too. Remove that limitation. This patch
has no impact on the iMX6, which is the only SoC currently supported
by this driver.
Pull out hard-coded register base addresses into driver private
structure in preparation for DM conversion. No functional change.
The DM iMX PCI driver has DM_FLAG_OS_PREPARE set and will call
imx_pcie_remove() from the .remove callback. Do not call it from
the architecture code again.
