I have this board at work, so I can trun tests on it.
AM335x-based 'Gumstix Pepper' SBCs and variants use different types of
RAM (DDR2 vs DDR3 with DDR3 being the default). Detect the board type
by reading the factory-programmed EEPROM [1] and use this to select any
runtime boot options such as RAM type.
[1] http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs
Signed-off-by: Adam YH Lee <adam.yh.lee@gmail.com>
Signed-off-by: Ash Charles <ashcharles@gmail.com>
This patch adds the feature to only stop the autobooting, and therefor
boot into the U-Boot prompt, when the input string / password matches
a values that is encypted via a SHA256 hash and saved in the environment.
This feature is enabled by defined these config options:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_STOP_STR_SHA256
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
These defines for a 2nd autoboot stop and delay string are nearly unused. Only
sc3 defines CONFIG_AUTOBOOT_DELAY_STR2. And a patch to remove this most likely
unmaintained board is also posted to the list.
By removing these defines the code will become cleaner and moving the remaining
compile options to Kconfig will get easier.
I might have missed something, but I failed to use the escape char '\'
in strings. To pass a printf format string like "foo %d bar\n" via
Kconfig to the code.
Right now its not possible to use the escape character '\' in Kconfig
string values correctly to e.g. set this string value "test output\n".
The '\n' will be converted to 'n'.
The current implementation removes some of the '\' chars from the input
string in conf_set_sym_val(). Examples:
And then doubles the backslash chars in the output string in
sym_escape_string_value(). Example:
As you see in these examples, its impossible to generate a single '\'
charater in the output string as its needed for something like '\n'.
This patch now changes this behavior to not drop some backslashes in
conf_set_sym_val() and to not add new backslashes in the resulting
output string. Removing the function sym_escape_string_value()
completely as its not needed anymore.
max_freq in print_cpuinfo is used only with
imx6.
On this bus there is a EEPROM containing EDID and ddr3
calibration information.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Make it possible to use the i2c bus in SPL.
Add IOMUX for the pad used as USB pen. This needs to be driven low for
the Iris and Viola boards where it is pulled up high by default. This is
required for the USB host functionality to work on these boards. Use the
board specific weak initialisation function, to drive the pin low which
would be called on "usb start".
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add a weak function board_ehci_hcd_init which can be used by the board
file for board specific initialisation.
Most of the drivers available for Vybrid are not yet converted
to OF model to use device tree model, only few drivers
like SPI and GPIO drivers use device trees.
Add separate defconfig for who needs to use device tree model.
Later this can be integrated to single defconfig.
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add device tree files for Freescale Vybrid platform and
Toradex Colibri VF50, VF61 modules.
Device tree files are taken from upstream Kernel.
Removed the stuff which are not used/supported yet in U-Boot.
Add iomux definitions for DSPI second instance.
Inorder to use the pins as GPIO, apart from setting the alt-function,
pinmuxing need to be done, this patch adds pinmux entries of
few GPIOs.
Add GPIO driver support to Freescale VF610
Like SPI and I2C few GPIO controllers also have
multiple chip instances. This patch adds the
flag 'DM_UC_FLAG_SEQ_ALIAS' in gpio_uclass driver
to control device sequence numbering. By defalut
the dev->r_seq for gpio_uclass will alwalys
returns -1, which leads the gpio driver probe
failure when using the driver with device trees.
Commit 8183058188cd2d942 ("imx6: centralise common boot options in
mx6_common.h") broke boot on mx6sl and mx6sx by assuming that all mx6
SoCs use the same LOADADDR/SYS_TEXT_BASE range, which is not correct.
DDR on mx6sx/mx6sl starts at 0x80000000.
Adjust LOADADDR/SYS_TEXT_BASE to the proper values for mx6sx/mx6sl,
so that these SoCs can boot again.
Also, TQMA6 requires a custom CONFIG_SYS_TEXT_BASE value, so move
its setting prior to the inclusion of mx6_common.h.
Signed-off-by: Fabio Estevam <fabio.estevam at freescale.com>
There are two revisions of wandboard: version B1 and C1.
Add the revision detection support, so that the correct dtb file can
be automatically loaded.
Based on the patch from Richard Hu <hakahu@gmail.com>.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
This fixes the following compiler warning:
In file included from tools/common/image-fit.c:1:0:
./tools/../common/image-fit.c: In function ‘fit_conf_print’:
./tools/../common/image-fit.c:1470:27: warning: logical not is only applied
to the left hand side of comparison [-Wlogical-not-parentheses]
(const char **)&uname) > 0;
Select CONFIG_CMD_NET and CONFIG_CMD_SETEXPR by default rather then
needing to have this in every sunxi defconfig file.
This also fixes the Merrii_A80_Optimus defconfig no longer building.
Cc: Maxin B. John <maxin.john@enea.com>
Reported-by: Maxin B. John <maxin.john@enea.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add and use a proper dts for the ga10h a33 based tablet, as
submitted upstream.
This instroduces comments that explain the purpose, parameters and return codes
of a few fdt support functions, that are used to fill the fdt.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Before device-tree, the device serial number used to be passed to the kernel
using ATAGs (on ARM). This is now deprecated and all the handover to the kernel
should now be done using device-tree. Thus, this passes the serial-number
property to the kernel using the serial-number property of the root node, as
expected by the kernel.
The serial number is a string that somewhat represents the device's serial
number. It might come from some form of storage (e.g. an eeprom) and be
programmed at factory-time by the manufacturer or come from identification
bits available in e.g. the SoC.
Reviewed-by: Simon Glass <sgj@chromium.org>
Rename the Astar_MID756 to Et_q8_v1_6 to match the kernel dts name.
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 ,
this gives us a proper dtsi file for the A33 rather then abusing
sun8i-a23.dtsi for this.
And this replaces our minimal (dummy) sun7i-a20-mk808c and
sun8i-a33-astar-mid756 dts files with proper ones.
Add "allwinner,sun8i-a33-pinctrl", this is used by the latest upstream
linux sunxi dts files.
The Mele A1000G-quad and the Mele M9 have the same PCB, sofar we've been
using the same defconfig (and dts on the kernel side) for both models.
Unfortunately this does not work for the otg controller, on the M9 this
is routed to a micro-usb connector on the outside, while as on the
A1000G-quad it is connected to an usb to sata bridge.
This commit adds a new defconfig for the Mele-A1000G-quad to allow using
different otg controller settings on the 2 boards.
Before this commit the code for determining the disconnect threshold was
checking for sun4i or sun6i assuming that those where the exception and
that newer SoCs use a disconnect threshold of 2 like sun7i does.
But it turns out that newer SoCs actually use a disconnect threshold of 3
and sun5i and sun7i are the exceptions, so check for those instead.
Here are the settings from the various Allwinner SDK sources:
sun4i-a10: USBC_Phy_Write(usbc_no, 0x2a, 3, 2);
sun5i-a13: USBC_Phy_Write(usbc_no, 0x2a, 2, 2);
sun6i-a31: USBC_Phy_Write(usbc_no, 0x2a, 3, 2);
sun7i-a20: USBC_Phy_Write(usbc_no, 0x2a, 2, 2);
sun8i-a23: USBC_Phy_Write(usbc_no, 0x2a, 3, 2);
sun8i-h3: USBC_Phy_Write(usbc_no, 0x2a, 3, 2);
sun9i-a80: USBC_Phy_Write(usbc_no, 0x2a, 3, 2);
Note this commit makes no functional changes for sun4i - sun7i, and
changes the disconnect threshold for sun8i to match what Allwinner uses.
On some boards we need to enable the internal pull-up te reliable detect
that no card is inserted.
A conflict between the PMIC and unit test work means that the sandbox test
device tree file is no-longer built. Fix this.
Series-to: u-boot
Series-cc: joe, prz
Change-Id: I6616428e05713e5306f848e7dd0a645dedf0934e
These were lost when the PMIC series was applied. Add them back so that the
tests pass again.
Reported-by: Joe Hershberger <joe.hershberger@gmail.com>
Sort this by node name for easier browsing.
There are some core test nodes near the beginning of the file which should
be grouped together. But for other nodes, let's sort them.
Tidy up the sort order again.
