Apply changes from commit 44b4dbed to board/trab/memory.c, too.
Actually we'd need a major cleanup here - as it turns out,
board/trab/memory.c is more or less a verbatim copy of
post/drivers/memory.c ... but then, trab is EOL anyway,r
so this is not worth the effort.
Include <linux/mtd/compat.h> header for min_t definition instead of
providing our own one. Removes warnings in case of OneNAND support
enabled.
Although I thinks it's a bit silly to include <linux/mtd/compat.h>
just for min_t...
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Casting a pointer to a phys_addr_t when it's an unsigned long long
on a 32-bit system without first casting to a non-pointer type
generates a compiler warning. Fix this.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Use our own local functions in lib_arm/ instead.
Parallel builds (using "make -jN") would occasionally fail with error
messages like
ppc_4xxFP-objdump: string.o: File format not recognized
or
post/libpost.a(cpu.o): In function `cpu_post_test':
/home/wd/git/u-boot/work/post/lib_ppc/cpu.c:130: undefined reference to `cpu_post_test_string'
or similar. We now make sure to run the 'postdeps" step before
attempting to build the specific POST libraries.
messages like
include/autoconf.mk:212: *** missing separator. Stop.
Line numbers and affected boards were changing. Obviously some
Makefiles included autoconf.mk while it was still being written to.
As a fix, we now write to a temporary file first and then rename it,
so that it is really ready to use as soon as it appears.
The stmicro_wait_ready() func tries to show the actual opcode that was sent
to the device, but instead it displays the array pointer. Fix it to pull
out the opcode from the start of the array.
If both CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE are defined, and the sect
size is larger than the env size, then it means the env is embedded in a
block. So we have to save/restore the part of the sector which is not the
environment. Previously, saving the environment in SPI flash in this
setup would probably brick the board as the rest of the sector tends to
contain actual U-Boot data/code.
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
All implementations of the functions i2c_reg_read() and
i2c_reg_write() are identical. We can save space and simplify the
code by converting these functions into inlines and putting them in
i2c.h.
Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
- It is possible to miss flush/invalidate the last
cache line, we fix it at here.
- add the volatile and memory clobber.
They are pointed by Scott Wood.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Add a library that helps in translating between virtual and physical
addresses. This library can be useful as a simple means to implement
map_physmem() and virt_to_phys() for platforms that need functionality
beyond the simple 1:1 mapping.
virt_to_phys() returns the physical address given a virtual. In most
cases this will be just the input value as the vast majority of
systems run in a 1:1 mode.
However in systems that are not running this way it should report the
physical address or ~0 if no mapping exists for the given virtual
address.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Reported-by: Martin Michlmayr <tbm@cyrius.com>
Also fix some minor typos.
This warning is issued by modern ARM-EABI GCC on non-thumb targets.
Signed-off-by: Vladimir Panfilov <pvr@emcraft.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
FDT support is used for both FIT style images and for architectures
that can pass a fdt blob to an OS (ppc, m68k, sparc).
For other architectures and boards which do not pass a fdt blob to an
OS but want to use the new uImage format, we just need FIT support.
Now we can have the 4 following configurations :
1) FIT only CONFIG_FIT
2) fdt blob only CONFIG_OF_LIBFDT
3) both CONFIG_OF_LIBFDT & CONFIG_FIT
4) none none
This patch disables EEPROM wrtie access by default on PMC440 board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch now adds a flush to the data cache upon relocation. The
current implementation is missing this. Only a comment states that it
should be done. So let's really do it now.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
This patch adds the CONFIG_SKIP_LOWLEVEL_INIT option to start.S. This
enables support for boards where the lowlevel initialization is
already done when U-Boot runs (e.g. via OnChip ROM).
This will be used in the upcoming VCTH board support.
This patch adds the board_early_init_f() call to the MIPS init
sequence. A weak dummy implementation is also added which can be
overridden by a board specific version.
This will be used by the upcoming VCTH board support.
This patch adds a call to onenand_init() for OneNAND support and moves
the nand_init() call to an earlier place, so that the environment can
be used from NAND and OneNAND.
Renesas SH2/SH2A timer broken.
This patch fix timer function.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
SH4 is different a value of CACHE_OC_NUM_ENTRIES and
CACHE_OC_WAY_SHIFT every CPU.
This patch corrects these values.
Change to write/readX function and fix timer problem.
A value of BSC CS4 was wrong, Fixed it.
The address of SCFSR register is wrong at SH7720/SH7721.
This patch fix this.
This patch fixes building U-Boot for CPCI405 boards.
With this patch we set the type back to NONE upon failing UBI partition
initialization. Otherwise further calls to the UBI subsystem would try
to really access the non-existing UBI partition.
Thanks to Michael Lawnick for pointing this out.
Return with correct error code (-ENOMEM) from ubi_attach_mtd_dev() upon
failing malloc().
Microblaze platforms use generic settings and to have
many platforms is confusing that's why I decided to remove this
platform from U-BOOT. ml401 tree is sufficient for covering
all Microblaze platforms.
This change will go through microblaze custodian tree.
