Current relocation code is limited to 21bit PC-relative addressing
which might not be enough for bigger code sizes. The following patch
increases the addressing to 32bit PC-relative. This feature is
specially interesting if U-Boot is build without optimiation (-O0) as
the text section is increased significativelly.
Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com>
At least MIPS Boston currently uses srec_cat tool to fiddle with
srecords. There will be other platforms coming, so install the
tool to prevent build problems.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
The initial environment is linked to the u-boot binary. Modifying the
environment from User Space with the env tools requires that the tools
are always built together with the bootloader to be sure that they
contain the initial environment in case no environment is stored into
persistent storage or when a board boots with just the default
environment. This makes difficult for distros to provide a general
package to access the environment. A simpler way is if the tools are
generic for all boards and a configuration file is given to provide the
initial environment.
The patch just generates the initial environment by extracting it from
the compiled object. This file can then be used for tools in user space
to initialize the environment.
Add support for loading fully featured fitImages over YModem in SPL.
This is useful when various advanced features of full fitImages are
needed in SPL.
Currently only the first fdt is loaded from the extra configuration of
FIT image.
If the configuration have multiple fdt, load them all as well.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
In previously label which will be expanded to the node's full path was
used, and now replacing label with most commonly used DT phandle. The
codes were changed accordingly to the use of DT phandle and supporting
multiple instances.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
HVC call makes use of 6 mandatory arguments rather than 7 in the same way
as SMC calls. The 7th argument is optional (Client ID) for both HVC and
SMC but is implemented as 16-bit parameter and register R7 or W7. The aim
of this patch is just fix compilation error due to an invalid asm code in
the HVC call so that's why the 7th argument is removed.
The issue does not report any error in a normal build as hvc_call is not
used at all and is optimized by the compiler. Using -O0 triggers the
error so the patch is intended to fix issues on a ongoing effor to build
U-Boot with -O0.
It works perfectly fine to boot an Android boot.img with bootm command
followed by an explicit address argument that holds the image. But if
we have boot.img downloaded into default 'loadaddr', and then boot it
using bootm command without the address argument, we will run into
problem, because U-Boot fails to find ramdisk and fdt (second area) in
boot.img.
The current Android image support assumes there is always an address
argument on bootm command. However just like booting any other images,
'loadaddr' should be used when address argument is missing from bootm
command. It patches boot_get_ramdisk() and boot_get_fdt() a bit to
support this quite common usage of bootm command for Android image.
This function supports getting both data address and length for
existing FIT subimage and FIT external data.
When PSCI is enabled, we are expecting U-Boot which now act
as EL3 software will handle all the PSCI calls. We won't need
fwcall as no further HVC or SMC are needed.
Signed-off-by: Ang, Chee Hong <chee.hong.ang@intel.com>
Allow PSCI layer to handle any SiP service functions added by
platform vendors. PSCI layer will look for SiP service function
in the SiP function table located in '._secure_svc_tbl_entries'
section if the SMC function identifier is not found in the PSCI
standard functions table. Use DECLARE_SECURE_SVC macro to declare
and add platform specific SiP service function.
This new section '._secure_svc_tbl_entries' is located next to
'._secure.text' section. Refer to arch/arm/cpu/armv8/u-boot.lds.
Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com>
The unit tests in test/lib/hexdump.c are not related to the device tree.
So they should be executed via `ut lib` and not via `ut dm`.
Firmware loader would encounter problem if the block device is accessed
before initializing it. This patch would adding the support of probing
block device and initializing block before the block device is accessed by
firmware loader.
The 'exception' command allows to test exception handling.
This implementation supports ARM, x86, RISC-V and the following exceptions:
* 'breakpoint' - prefetch abort exception (ARM 32bit only)
* 'unaligned' - data abort exception (ARM only)
* 'undefined' - undefined instruction exception
Enable the nand support (driver and command)
in the configuration of the board bcm963158.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Enable the nand controller in the device tree
Add the nand controller in the bcm63158 device tree.
in the configuration of the board bcm968580xref.
Add the nand controller in the bcm6858 device tree.
in the configuration of the board bcm96838gerg.
Add the nand controller in the bcm6838 device tree.
tree
The option write-protect may only change on the kernel command line,
we add a property in the device tree to be more flexible.
The parameter page isn't always in big endian, so we add
an option to choose the endiannes of the parameter page.
The driver brcmnand come from linux kernel 4.18.
Only SoC bcm6838 and bcm6858 are supported.
This patch port the file include/linux/completion.h
from linux 4.18 to u-boot. It define the structure
but all the function are stubbed.
The macro devm_ioremap is only defined for configuration
that doesn't have ioremap. But this macro may also be
defined on configuration with ioremap.
This patch remove the condition for the macro devm_ioremap,
so it's always defined.
This patch port the function readX_relaxed and
writeX_relaxed from kernel 4.18.
Linux commit 97d90da8a88 ("mtd: nand: provide several helpers
to do common NAND operations")
This is part of the process of removing direct calls to ->cmdfunc()
outside of the core in order to introduce a better interface to execute
NAND operations.
Here we provide several helpers and make use of them to remove all
direct calls to ->cmdfunc(). This way, we can easily modify those
helpers to make use of the new ->exec_op() interface when available.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[miquel.raynal@free-electrons.com: rebased and fixed some conflicts]
Signed-off-by: Miquel Raynal <miquel.raynal@free-electrons.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
[Philippe Reynes: adapt code to u-boot and only keep new function]
Linux commit d45bc58dd3b ("mtd: nand: import nand_hw_control_init()")
The code to initialize a struct nand_hw_control is duplicated across
several drivers. Factorize it using an inline function.
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Linux commit 28b8b26b308 ("mtd: add get/set of_node/flash_node helpers")
We are going to begin using the mtd->dev.of_node field for MTD device
nodes, so let's add helpers for it. Also, we'll be making some
conversions on spi_nor (and nand_chip eventually) too, so get that ready
with their own helpers.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[Philippe Reynes: only add function nand_set_flash_node and
nand_get_flash_node because others were already backported]
Second set of u-boot-atmel features and fixes for 2019.07 cycle
fix CONFIG_OF_EMBED and add CONFIG_DM_USB
build warnings.
- Various fastboot, dwc2/stm32 updates
- Various stratix10, gen5 updates
This fixes a disconnect issue detected with fastboot command, when using
dwc2 driver.
- On u-boot side:
uboot>$ fastboot 0
- On USB host PC side, few seconds after
PC>$ fastboot reboot # Get stuck, uboot target never reboots
By enabling DEBUG_ISR logs, the bus suspend interrupt is seen before the
PC command has been issued. When the USB bus suspend occurs, there's a HACK
that disables the fastboot (composite driver). Here is the call stack
upon USB bus suspend:
- dwc2_handle_usb_suspend_intr()
- dev->driver->disconnect()
- composite_disconnect()
- reset_config()
- f->disable()
- fastboot_disable()
- usb_ep_disable(f_fb->out_ep);
- usb_ep_disable(f_fb->in_ep);
.. other disable calls.
When the resume interrupt happens, everything has been disabled, then
nothing happens. fastboot command gets stuck on HOST side.
Remove original HACK, that disconnects the composite driver upon
USB bus suspend. Implement disconnect detection instead:
- check GINTSTS OTG interrupt
- read GOTGINT register
- check GOTGINT, SesEndDet bit (e.g. session end)
This is inspired by what is implemented currently in Linux dwc2 driver.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Reload the watchdog in the mass storage command ums
to avoid reboot during the usb waiting loop
when the host doesn't send any request.
Our R-Car3 Android userspace relies on the output of 'fastboot
getvar platform' and U-Boot currently is not able to handle it:
host $> fastboot getvar platform
getvar:platform FAILED (remote: Variable not implemented)
finished. total time: 0.001s
We either have the option of adding 'fastboot.platform' variable
to the default/saved environment as a workaround or add proper
'fastboot getvar platform' support in U-Boot via this patch.
In the latter case, other platforms can benefit from it too.
Note that R-Car3 already exports 'platform' environment variable via
v2019.01 commit 00e4b57e9e71c3 ("ARM: rmobile: Set environment variable
containing CPU type").
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Where we have to compute partition names, rather than using a hardcoded
32 for the partition name length, replace with PART_NAME_LEN.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Eugeniu Rosca <rosca.eugeniu@gmail.com>
The DK1 and DK2 boards use the USB Type-C controller STUSB1600.
This patch updates:
- the device tree to add the I2C node in the DT
- the board stm32mp1 to probe this I2C device and use this controller
to check cable detection.
- the DWC2 driver to support a new dt property
"u-boot,force-b-session-valid" which forces B session and
device mode; it is a workaround because the VBUS sensing and
ID detection isn't available with stusb1600.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Use the DWC2 device driver with DM_USB_GADGET support and
cleanup the USB support in STM32MP1 board.
Remove the HOST support for STM32MP1 USBO device = OTG DWC2.
The current DWC2 driver have no dynamic detection of device,
So it is dangerous to have start 3V3 when PC is
connected to the micro USB connector.
=> it is preferable to have only DEVICE support
CONFIG_USB_GADGET_DWC2_OTG for OTG port
See DWC3 driver for clean dual role support...
Add compatible "st,stm32mp1-hsotg" and associated driver data to manage
the usb33d-supply and the ST specific register for VBus sensing.
# Conflicts:
# drivers/usb/gadget/dwc2_udc_otg.c
All TX fifo size can be different, add tx_fifo_sz_array[]
into dwc2_plat_otg_data to be able to set them.
tx_fifo_sz_array[] is 17 Bytes long and can contains max 16
tx fifo size (synopsys IP supports max 16 IN endpoints).
First entry of tx_fifo_sz_array[] is the number of valid
fifo size the array contains.
In case of tx_fifo_sz_array[] doesn't contains the same
number of element than max hardware endpoint, display
a warning message.
Compatibility with board which doesn't use tx_fifo_sz_array[]
(Rockchip rk322x/rk3128/rv1108/rk3288/rk3036) is kept.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Some DWC2 ip variant doesn't use 16 hardware endpoint as hardcoded
in the driver. Bits INEps [29:26] of HWCFG4 register allows to get
this information.
Add a new function to check the session B validity, to be use to check
cable connection.
Handle "force-b-session-valid" property from DT.
Reset the hardware to be sure of the device state.
Minimal conversion to driver model by using the uclass
UCLASS_USB_GADGET_GENERIC based on:
- reset uclass
- clock uclass
- generic uclass.
