2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-08-14POST: Add option for external ethernet loopback testStefan Roese
When CFG_POST_ETHER_EXT_LOOPBACK is defined, the ethernet POST is not done using an internal loopback connection, but by assuming that an external loopback connector is plugged into the board. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14POST: Add ppc405 support to cache and UART POSTStefan Roese
2007-08-14Replace lost end of at45.c.Peter Pearse
2007-08-14Update Makefiles for merged and split at45.c.Peter Pearse
2007-08-14Delete the merged files.Peter Pearse
2007-08-14Add the files.Peter Pearse
2007-08-14Add MACH_TYPE records for several AT91 boards.Peter Pearse
Merge to two at45.c files into a common file, split to at45.c and spi.c Fix spelling error in DM9161 PHY Support. Initialize at91rm9200 board (and set LED). Add PIO control for at91rm9200dk LEDs and Mux. Change dataflash partition boundaries to be compatible with Linux 2.6. Signed-off-by: Peter Pearse <peter.pearse@arm.com> Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2007-08-14Coding style cleanup, update CHANGELOGWolfgang Denk
2007-08-14Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-08-14Coding style cleanup; rebuild CHANGELOGWolfgang Denk
2007-08-1485xxCDS: Add make targets for legacy systems.Randy Vinson
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x. Signed-off-by Randy Vinson <rvinson@mvista.com>
2007-08-1485xxCDS: Enable the VIA PCI-to-ISA bridge.Andy Fleming
Author: Randy Vinson <rvinson@linuxbox.(none)> Enable the PCI-to-ISA bridge in the VIA Southbridge located on the Arcadia main board. Signed-off-by: Randy Vinson <rvinson@mvista.com> Signed-off-by: York Sun <yorksun@freescale.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add PCI support for MPC8568MDS boardHaiying Wang
This patch is against u-boot-mpc85xx.git of www.denx.com Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
2007-08-14Empirically set cpo and clk_adjust for mpc85xx DDR2 supportHaiying Wang
This patch is against u-boot-mpc85xx.git of www.denx.com Setting cpo to 0x9 for frequencies higher than 333MHz is verified on both MPC8548CDS board and MPC8568MDS board, especially for supporting 533MHz DDR2. Setting clk_adjust to 0x6(3/4 late cycle) for MPC8568MDS board is for DDR2 on all current board versions especially ver 1.92 or later to bring up. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-08-14Use an absolute address when jumping out of 4k boot pageKumar Gala
On e500 when we leave the 4k boot page we should use an absolute address since we don't know where the board code may want us to be really running at. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-14MPC85xx BA bits not set for 3-bit bank address DIMMAndy Fleming
The current implementation does not set the number of bank address bits (BA) in the processor. The default assumes 2 logical bank bits. This works fine for a DIMM that uses devices with 4 internal banks (SPD byte17 = 0x4) but needs to be set appropriately for a DIMM that uses devices with 8 internal banks (SPD byte17 = 0x8). Signed-off-by: Greg Davis <DavisG@embeddedplanet.com>
2007-08-14Fix minor 85xx warningsAndy Fleming
Some patches had inserted warnings into the build: * mpc8560ads declared data without using it * cpu_init declared ecm and immap without using it in all CONFIGs * MPC8548CDS.h had its default filenames changed so that they contained "\m" in the paths. Made the defaults not Windows-specific (or anything-specific) Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-148548cds PCIE support.Ed Swarthout
Make the early L1 cache stack region guarded to prevent speculative fetches outside the locked range. Use _PHYS defines, not _MEM for cpu-side PCI memory mapped regions. init.S whitespace cleanup. Allow TEXT_BASE value to be specified on command line. This allows it to be set to 0xfffc0000 which cuts the uboot binary in half. Clear and enable lbc and ecm errors. Update last_busno in device-tree for pci and pcie. Remove load of obsolete cpu/mpc85xx/pci.0 Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-148544ds PCIE supportEd Swarthout
PCI1 LAW mapping should use CFG_PCI1_MEM_PHY and not _BASE address. Enable LBC and ECM errors and clear error registers. Add tftpflash env var to get uboot from tftp server and flash it. Add pci/pcie convenience env vars to display register space: "run pcie3regs" to see all pcie3 ccsr registers "run pcie3cfg" to see all cfg registers Whitespace cleanup and MPC8544DS.h Enable CONFIG_INTERRUPTS. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-1485xx start.S cleanup and exception supportAndy Fleming
From: Ed Swarthout <Ed.Swarthout@freescale.com> Support external interrupts from platform to eliminate system hangs. Define CONFIG_INTERRUPTS board configure option to enable. Enable ecm, ddr, lbc, and pci/pcie error interrupts in PIC. Remove extra cpu initialization redundant with hardware initialization. Whitespace cleanup. Define and use _START_OFFSET consistent with other processors using ppc_asm.tmpl Move additional code from .text to boot page to make room for exception vectors at start of image. Handle Machine Check, External and Critical exceptions. Fix e500 machine check error determination in traps.c TEXT_BASE can now be 0xfffc_0000 - which cuts binary image in half. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add MPC8544DS READMEAndy Fleming
2007-08-1485xx allow debugger to configure ddr.Ed Swarthout
Only check for mpc8548 rev 1 when compiled for 8548. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-14mpc85xx L2 cache reporting and SRAM relocation option.Ed Swarthout
Allow debugger to override flash cs0/cs1 settings to enable alternate boot regions Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-14e500 needs ppc_asm.tmp MCK_EXCEPTIONEd Swarthout
Always define MCK_EXCEPTION macro - so e500 can use it too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13New CONFIG_BOOTP_SERVERIP optionWilson Callan
Added CONFIG_BOOTP_SERVERIP to allow the tftp server to be different from the bootp server Signed-off-by: Wilson Callan <wcallan@savantav.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Add ability to take MAC address from the environment to DM9000 driverMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Sync'd u-boot-net with mainlineBen Warren
Merge git://www.denx.de/git/u-boot Conflicts: drivers/bcm570x.c drivers/tigon3.c
2007-08-13Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-13Merge commit 'remotes/wd/master'Jon Loeliger
Conflicts: MAKEALL With any luck, this is the last MAKEALL merge conflict!
2007-08-13Modify SBC8641D to use new Freescale PCI routinesJoe Hamman
PCI-Express sockets 1 and 2 verified working with Intel Pro/1000 PT adapter. Signed-off-by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signde-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-13atmel_mci: Fix data timeout valueHaavard Skinnemoen
Calculate the data timeout based on values from the CSD instead of just using a hardcoded DTOR value. This is a backport of a similar fix in BSP 2.0, with one additional fix: the DTOCYC value is rounded up instead of down. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-13AVR32: Include <div64.h> instead of <asm/div64.h>Haavard Skinnemoen
include/asm-avr32/div64.h was recently moved to include/div64.h, but cpu/at32ap/interrupts.c wasn't properly updated (an earlier version of the patch was merged perhaps?) This patch updates cpu/at32ap/interrupts.c so that the avr32 port compiles again. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-13Merge commit 'upstream/master'Haavard Skinnemoen
2007-08-13atmel_mci: Use 512 byte blocksize if possibleHaavard Skinnemoen
Instead of always using the largest blocksize the card supports, check if it can support smaller block sizes and use 512 bytes if possible. Most cards do support this, and other parts of u-boot seem to have trouble with block sizes different from 512 bytes. Also enable underrun/overrun protection. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com>
2007-08-13ppc4xx: Fix problem in PLL clock calculationStefan Roese
This patch was originall provided by David Mitchell <dmitchell@amcc.com> and fixes a bug in the PLL clock calculation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-12Update CHANGELOGWolfgang Denk
2007-08-12Minor alignment of output, 2nd try.Wolfgang Denk
Also update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-12Minor alignment of outputWolfgang Denk
2007-08-12Cleanup output on ADS5121 boardWolfgang Denk
2007-08-12Merge with git+ssh://gemini_vpn/home/wd/git/u-boot/masterWolfgang Denk
2007-08-12Adapt board configuration and fix kernel crash on MCC200 board.Wolfgang Denk
The update procedure was modified to turn off the USB subsystem before exit for MCC200 and TRAB. This is necessary as otherwise the USB controller continues to write periodically to system memory! MCC200-specific notes: - the patch disables the magic key check for MCC200 - the patch contains the configuration changes made for the new revision of the board. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-12Adjust default configuration of ADS5121 board.Wolfgang Denk
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-11Merge with /home/wd/git/u-boot/custodian/u-boot-fdtWolfgang Denk
2007-08-10Improve error print messages.Gerald Van Baren
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10fdt: allow for builds that don't want env and bd_t nodesKim Phillips
protect fdt_env and fdt_bd_t invocations, fix codingstyle while in the area. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
