omap-common cache enabling sequence relies on cpu_init_cp15()
(inside start.S) for enabling I-caches. But cpu_init_cp15()
can be skipped if CONFIG_SKIP_LOWLEVEL_INIT is defined. So
enable I-caches if not enabled already.
Debugged-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Tested-by: Steve Kipisz <s-kipisz2@ti.com>
Tested-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Building with verified boot support requires hash, add that
dependency here. Otherwise the following build error will come out
without crc command.
LD u-boot
lib/built-in.o: In function `hash_calculate':
lib/rsa/rsa-checksum.c:29: undefined reference to
`hash_progressive_lookup_algo'
make[1]: *** [u-boot] Error 1
Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
A common voltage of 1.35V was being programmed for all am43 board
versions. EPOS-EVM Needs 1.20V for LPDDR2.
Fixes: fc69d472621b5 (“board: ti: AM43XX: Add ddr voltage rail configuration”)
Reported-by: James Doublesin <doublesin@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
With tighter build flags the fact that <stdio_dev.h> doesn't have a
reference back to MAX_NAMES causes an error. Include <stdio.h> here and
then in common/console.c use MAX_NAMES rather than 3 when working with
stdio_names.
Reported-by: Peter Robinson <pbrobinson@gmail.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
With tighter build flags the fact that this header referenced
uchar/ushort without including what typedefs it causes an error. Rather
than add another include here, drop the section in question as it is
unused.
The DEBUG macro is never defined unless explicitly enabled.
Drop useless #undef DEBUG in the board configs so it won't
spread any further.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Pull the symbol from the boards and zap struct rmobile_sysinfo as they
are rather useless. The entire purpose of that whole machinery was to
print board name in the CONFIG_ARCH_RMOBILE_BOARD_STRING. Do that in a
far simpler and more contained manner.
Convert the symbol to Kconfig, no functional change.
Rename CONFIG_RMOBILE_BOARD_STRING to CONFIG_ARCH_RMOBILE_BOARD_STRING
to make things consistent, no functional change.
Synchronize the README with the current state of U-Boot, unify
the build instructions to avoid duplication.
The R8A7792 does not have the USB extal, so drop it.
freescale.com domain is no longer reachable, so switch the
maintainers' emails to nxp.com domain instead.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
As ret is not set when calling max77693_get_vcell() there is no
need to check ret again.
The 'SDHCI_QUIRK_NO_HISPD_BIT' is used wrong here. The purpose of this
quirk is to tell the sdhci-driver that the IP-core doesn't have a "high-
speed-enable" bit in its registers.
With this commit we change this to the correct quirk:
SDHCI_QUIRK_BROKEN_HISPD_MODE
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Some IP-core implementations of the SDHCI have different troubles on the
silicon where they are placed.
On ZYNQ platform for example Xilinx doesn't accept the hold timing of an
eMMC chip which operates in High-Speed mode and must be forced to
operate in non high-speed mode. To get rid of this
"SDHCI_QUIRK_BROKEN_HISPD_MODE" is introduced.
For more details about this refer to the Xilinx answer-recor #59999
https://www.xilinx.com/support/answers/59999.html
This commit:
- doesn't set HISPD bit on the host-conroller
- reflects this fact within the host-controller capabilities
Upon this the layer above (mmc-driver) can setup the card correctly.
Otherwise the MMC card will be switched into high-speed mode and causes
possible timing violation on the host-controller side.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
sd_read_ssr returns 0, means no error.
Fixes: 5b2e72f32721484("mmc: read ssr only if MMC write support is enabled")
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
Exynos5422 board has s2mps11 pmic.
If CONFIG_PMIC_S2MPS11 is enabled, it can initialize PMIC and Regulators
during booting time.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Anand Moon <linux.amoon@gmail.com>
An unsigned int is always >= 0.
We should not make the same assignement twice.
If generating a script image and no datafile has been passed in, mkimage
dies with SIGSEGV:
#0 __strchr_sse2 () at ../sysdeps/x86_64/multiarch/../strchr.S:32
#1 0x0000000000403818 in main
at tools/mkimage.c:503
Add explicit test for datafile to fix this.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
The size of 'filebuf' was not increased as more and more bytes are read
from stdin, but 'filebuf' was always reallocated to the same fix size.
This works as long as only less bytes than the initial buffer size come
in, for more input this will segfault. (It actually does, I tested
that.) So for each loop cycle the buffer size has to be increased by the
number of bytes we want to read.
Signed-off-by: Alexander Dahl <ada@thorsis.com>
On success read() returns the number of bytes read or zero for EOF. On
error -1 is returned and errno is set, so the right way to test if read
had failed is to test the return value instead of errno.
Uart status register is named USART_ISR on STM32F7, STM32H7
and STM32MP1 SoCs family, but USART_SR only on STM32F4 SoCs.
Use USART_ISR_ prefix instead of USART_SR_ .
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Enable uart overrun feature which allows to benefits of uart
FIFO usage.
Previously overrun management was disabled, this has to effect
to bypassed the uart FIFO usage even if FIFO was enabled.
In particular configuration, for example when video console is
enabled, copy/pasting a long command line in console results in
corruption. This is due to the fact that a lot of time is consumed
in flushing the cache during frame buffer update, so uart chars are
not read fast enough.
By using uart FIFO and managing overrun, long command line can by
copy/paste in console without being corrupted.
If SPL serial support is disabled nothing brings in sprintf, snprintf
or simple_strtoul:
env/built-in.o: In function `regex_callback':
env/attr.c:128: undefined reference to `sprintf'
disk/built-in.o: In function `blk_get_device_by_str':
disk/part.c:386: undefined reference to `simple_strtoul'
disk/part.c:395: undefined reference to `simple_strtoul'
disk/built-in.o: In function `blk_get_device_part_str':
disk/part.c:522: undefined reference to `simple_strtoul'
disk/built-in.o: In function `part_set_generic_name':
disk/part.c:704: undefined reference to `sprintf'
drivers/built-in.o: In function `init_peripheral_ep':
drivers/usb/musb-new/musb_gadget.c:1826: undefined reference to `sprintf'
drivers/built-in.o: In function `musb_core_init':
drivers/usb/musb-new/musb_core.c:1451: undefined reference to `snprintf'
Add those dependencies here.
We had two implementations of __assert_failed which were almost identical,
combine them into one.
Now we have a guard for printf, disable it in the build if it's not
selected.
When SPL serial is disabled, callers who need sprintf or strtoul fail
because their inclusion is guarded by CONFIG_SPL_SERIAL_SUPPORT/
CONFIG_TPL_SERIAL_SUPPORT.
Split printf, sprintf and strto into their own entries and then select
all of them if SERIAL_SUPPORT is enabled to match the current behaviour.
Include panic.o unconditionally as it can be called from anywhere which
uses BUG_ON().
If CONFIG_SPL_SERIAL_SUPPORT is not set, then the build will fail:
board/ti/am335x/built-in.o: In function `spl_start_uboot':
board/ti/am335x/board.c:247: undefined reference to `serial_tstc'
board/ti/am335x/board.c:247: undefined reference to `serial_getc'
Avoid the calls to the serial functions in that case.
Building with Ymodem support requires serial in SPL/TPL, add that
dependency here.
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but
existed in some include files; fix those up here.
If CONFIG_SPL_SERIAL_SUPPORT is disabled then the build fails because
serial_init is undefined. Guard preloader_console_init() appropriately
to fix this.
SYS_ARCH_TIMER guards the usage of the ARM Generic Timer (aka arch
timer) in U-Boot.
At the moment it is mandatory for ARMv8 and used by a few ARMv7 boards.
Add a proper Kconfig symbol to express this dependency properly,
allowing certain board configuration to later disable arch timer in case
there are any problems with it.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[tuomas: rebase + fix conflicts and resync with moveconfig & use select]
After commit 46fc679ede5f69 ("arm: timer: get frequency for arch timer
armv7 in cp15 cntfrq") the ARM architected timer driver knows how to
determine the timer frequency at runtime by reading the CNTFRQ register,
so we don't need to hardcode the timer frequency anymore.
'env exists' is used for scripting in include/config_distro_bootcmd.h
This command is available only when CONFIG_CMD_ENV_EXISTS is enabled.
Reviewed-by: Alexander Graf <agraf@suse.de>
The default of DISTRO_DEFAULTS is messy. Using the 'imply' keyword
is equivalent and cleaner.
%s/alingment/alignment/
RSA_SOFTWARE_EXP and RSA_FREESCALE_EXP are wrapped inside:
if RSA
endif
So, remove the redundant "depends on RSA" from their depends expression.
In addition, move SPL_RSA into the same "if RSA ... endif" block, since
its only direct dependeny is CONFIG_RSA. This tidies up and simplifies
reading of lib/rsa/Kconfig.
No functional change intended.
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
This converts IMAGE_FORMAT_LEGACY to Kconfig
CONFIG_CMD_LOG without CONFIG_LOG leads to a build error:
‘gd_t {aka volatile struct global_data}’ has no member named
‘default_log_level’
So CMD_LOG should select LOG.
Compling with CONFIG_LOG and without CONFIG_DM results in
common/log.c:47: undefined reference to `uclass_get_name'
