CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
It does not seem worth having an option to enable another sub-command in
this legacy driver. Drop this option so that the sub-command is always
available.
CONFIG_CMD_PCA953X
CONFIG_CMD_ONENAND
CONFIG_CMD_MTDPARTS_SPREAD
[trini: Make this a bool not a string]
CONFIG_CMD_MMC_SPI
These are currently not quite in alphabetical order. Before adding more,
sort them.
Suggested-by: Bin Meng <bmeng.cn@gmail.com>
This is not actually used in U-Boot. Most likely it means
CONFIG_CMD_MEMORY so change all occurences to that.
CONFIG_CMD_MAX6957
Traditional KS2 devices supported NAND via the AEMIF peripheral. However,
66AK2G doesn't use the AEMIF but rather the GPMC for NAND. Therefore,
clarify some statements to indicate only certain devices have AEMIF and
in other places just say NAND instead of AEMIF NAND
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Acked-by: Roger Quadros <rogerq@ti.com>
commit f1896c45cb2f: spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LEN
introduced independent SYS_MALLOC_F_LEN for SPL and U-Boot.
Use it on the smartweb board, as above commit broke
the smartweb board.
The 512 MB DDR version of SOM's use CS0 and CS1. CS1 is not correctly
setup in the pin muxing. This causes erratic behavior on suspend/resume
This fix has been tested on both 256 and 512 MB DDR versions.
The 'tests' target will run sandbox, sandbox_spl and sandbox_flattree in
test.py and in the case of sandbox_spl ensure that we just run the
specific tests for that build. Update our matrix to perform similar
test.py runs.
Allow sending restart conditions upon direction change as this is
required by some chips.
Cc: Stefan Roese <sr@denx.de>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Reviewed-by: Heiko Schocher <hs@denxx.de>
CONFIG_SYS_I2C_OMAP24XX
Set BM poll size once during priv probe and do not
overwrite it during port probe procedure. Pool is common for
all CP ports.
Signed-off-by: Stefan Chulski <stefanc@marvell.com>
Tested-by: iSoC Platform CI <ykjenk@marvell.com>
Reviewed-by: Nadav Haklai <nadavh@marvell.com>
Reviewed-by: Igal Liberman <igall@marvell.com>
TX drain in transmit procedure could cause issues due
to race between drain procedure and transmition of descriptor
between AGGR TXQ and physical TXQ.
TXQ will be cleared before moving to Linux by stop procedure.
MVPP22 driver support 64 Bit arch and require BM pool
high address configuration.
Remove IRQ configuration from U-Boot PP driver.
U-Boot don't use interrupts and configuration of IRQ in U-Boot
caused crashes in Linux shared interrupt mode.
Also interrupt use is redundant in RX routine since a single RX
queue is used.
MBUS driver were replaced by AXI in PPv22 and relevant
only for PPv21.
U-boot use single physical tx queue with size 16 descriptors.
So aggregated tx queue size should be equal to physical tx queue
and cpu descriptor chunk(number of descriptors delivered from
physical tx queue to aggregated tx queue by one chunk) shouldn't be
larger than physical tx queue.
Fix:
Set AGGR_TXQ and CPU_DESC_CHUNK to be 16 descriptors, same as
physical TXQ.
Issue:
BM counters were overrun by probe that called per Network interface and
caused release of wrong number of buffers during remove procedure.
Fix:
Use probe_done and num_ports to call init and remove procedure
once per communication controller.
This patch enables padding of packets shorter than 64B in TX(set by default).
Disabling of padding causes crashes on MACCIATO board.
A8K marvell SoC has two South Bridge communication controllers(CP0 and CP1).
Each communication controller has packet processor ports and MDIO.
On MACHIATOBin board ports from CP1 are connected to mdio on CP0.
Issue:
Wrong base address is assigned to MDIO interface during probe.
Fix:
Get MDIO address from PHY handler parent base address.
This should be refined in the future when MDIO driver is implemented.
This patch add GPIO configuration support in mvpp2x driver.
Driver will handle 10G SFP gpio reset and SFP TX disable. GPIO pins should
be set in device tree.
Reviewed-by: Kostya Porotchkin <kostap@marvell.com>
Increase env sector size from 64kb to 256kb for qspi boot.
Signed-off-by: Santan Kumar <santan.kumar@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The implementation of function set_pcie_ns_access() uses a wrong
argument. The structure array ns_dev has a member 'ind' which is
initialized by CSU_CSLX_*. It should use the 'ind' directly to
address the PCIe's CSL register (CSL_base + CSU_CSLX_PCIE*).
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[YS: Revise commit message]
In fsl_mc_ldpaa_exit(), in case of mc is booted and dpl is applied,
it should return earlier without executing dpbp_exit().
Acked-by: Priyanka Jain <priyanka.jain@nxp.com>
Acked-by: Yogesh Narayan Gaur <yogeshnarayan.gaur@nxp.com>
IFC and QSPI are muxed on board. Add fsl_fdt_fixup_flash() to disable
IFC node in dts if QSPI is enabled, or disable QSPI node in dts if
otherwise.
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: yinbo.zhu <yinbo.zhu@nxp.com>
[YS: Revise subject, remove commit message]
We shouldn't always change the status to okay. There could be
situations that the esdhc is intentionally disabled in the device
tree.
Signed-off-by: Li Yang <leoyang.li@nxp.com>
This bug is brought by the commit 3d8553f0a3 (pci: layerscape: add
LS2088A series SoC pcie support), which only updated cfg_res.start
and did not update the .end field. This causes fdt_resource_size()
getting wrong value when calculate the cfg1 space address.
[YS: Revise subject and commit message]
This patch enables driver model for USB in defconfigs for LS1021A
platforms.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Function enable_layerscape_ns_access() is alreayd called soc-wide.
Remove duplicated calling from individual boards.
[YS: Add commit message]
It is derived from Platform clock instead of Platform PLL frequency.
Function config_board_mux() reads env variable 'hwconfig' which is
only available after relocation for QSPI boot. Move calling
config_board_mux() to misc_init_r().
Smart voltage translator is removed from LS2080ARDB/LS2088ARDB
RevF boards. It is only used on LS2081ARDB. Programming GPIO
is only required for LS2081ARDB.
Update the default core frequency to 1800MHZ for best performance under
SD boot and eMMC boot.
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Commit 4483b7eb added variable vqmmc_dev but only uses it under
CONFIG_DM_REGULATOR. Add the same macro to variable declaration to
get rid of compiling warning.
Signed-off-by: York Sun <york.sun@nxp.com>
The driver is for all boards 24XX and up, so let's eliminate the
extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks
for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX.
Add missing probe function to the device driver to active a device.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This defconfig uses the PCIe x4 binary blobs from the congatec BIOS.
Cc: Bin Meng <bmeng.cn@gmail.com>
