The definitions inside emif_defs.h concern davinci nand driver and
should be in it's header. So create header file for davinci nand
driver and move definitions from emif_defs.h and nand_defs.h to it.
Acked-by: Vitaly Andrianov <vitalya@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
[trini: Fixup more davinci breakage]
Signed-off-by: Ash Charles <ashcharles@gmail.com>
If CONFIG_(NAND|NOR|ONENAND) is not defined, no configuration is set
for GPMC on chip select #0---size is 0. In this case, the GPMC
configuration should be reset but not enabled. Enabling causes the
Gumstix DuoVero board to hang when entering Linux.
[trini: Switch to testing base as GPMC_SIZE_256M is 0x0]
The symbol "_start" is defined twice in arch/arm/lib/vectors.S:
around line 48 and line 54.
If CONFIG_SYS_DV_NOR_BOOT_CFG is defined (as on calimain board),
build fails:
arch/arm/lib/vectors.S: Assembler messages:
arch/arm/lib/vectors.S:54: Error: symbol `_start' is already defined
make[1]: *** [arch/arm/lib/vectors.o] Error 1
make: *** [arch/arm/lib] Error 2
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Currently cntvoff_el2 is initialised with an arbitrary bag of bits
derived from the initial value of cnthctl_el2 on the current CPU. This is
somewhat odd and problematic as some of these bits are UNKNOWN at reset
and may differ across CPUs (which may cause an OS at EL1 to observe time
going backwards across CPUs).
This patch instead initialises cntvoff_el2 with xzr, giving the register
a consistent value of zero on all CPUs.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Tom Rini <trini@ti.com>
Acked-by: David.Feng <fenghua@phytium.com.cn>
Add QSPI support for VF610TWR, such as clock and iomux.
Signed-off-by: Alison Wang <Huan.Wang@freescale.com>
Signed-off-by: Chao Fu <b44548@freescale.com>
Add PAD_CTL_DSE_150ohm and PAD_CTL_PUS_22K_UP for VF610 in
IOMUX_PAD structure.
Add Freescale QSPI driver support for VF610.
This family is supported by the TPS65218 PMIC. Implement a scale_vcores
to set the MPU and CORE voltage correctly to the max frequency that is
supported (and what we will be scaling them to in setup_dplls()).
Add a driver for the TPS65218 PMIC which is used by TI AM43xx SoCs and
may be used by TI AM335x SoCs.
Similar to OMAP4/5 we need to scale the voltage up prior to changing the
clock frequencies up higher. Add a similar hook to start with.
Cc: trini@ti.com
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
in almost all cases we need the i2c commands within the u-boot shell.
So we enable them within the common section.
Cc: trini@ti.com
if we have no NAND-Chip, we don't need the gpmc-controller and therefore
is no need to init it.
Cc: trini@ti.com
Cc: trini@ti.com
For usage of timer6 within B&R we need this defines to enable clock
modules and clk-source.
Also the 'Timer register bits' are expanded.
By the way we add defines for all timers within AM335x SoC.
Cc: trini@ti.com
After enabling a module, SW has to wait on IDLEST bit
until it is Fully functional. This wait is missing for UART module
and there is a immediate access of UART registers after this. So there
is a chance of hang on this module( This can happen when we are running
from MPU SRAM). So waiting for IDLEST bit.
loadbootenv expects devtype variable to be set. This is missing in
mmcboot command. With this the following error comes:
U-Boot# run mmcboot
mmc0 is current device
SD/MMC found on device 0
** Bad device usb 0 **
Fixing this by setting devtype as mmc.
Reported-by: Tony Lindgren <tony@atomide.com>
commit a0a37183bd7 "ARM: omap: merge GPMC initialization code for
all platform" needs CONFIG_NOR, CONFIG_NAND or CONFIG_CMD_ONENAND
to be set to access flash. Add CONFIG_NAND for tam3517 derived
boards to prevent the following error: "nand: error: Unable to
find NAND settings in GPMC Configuration - quitting"
cc: Stefano Babic <sbabic@denx.de>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Enable support of nand ecclayout command.
Acked-By: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: WingMan Kwok <w-kwok2@ti.com>
Currently PWREMU_MGMT is not configured in the Linux generic UART
driver as this register seems to be specific TI UART IP. So this
needs to be enabled in u-boot to use UART1 from kernel space.
Acked-By: Vitaly Andrianov <vitalya@ti.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
With the changes to the i2c framework (and adopting the omap24xx_i2c
driver to them) we can no longer call i2c functions prior to gd having
been set and cleared. When SPL booting, this is handled by setting gd
to point to SRAM in s_init. However in the cases where we are loaded
directly by ROM (memory mapped NOR or QSPI) we need to make use of the
normal hooks to slightly delay these calls.
We have two contexts for booting these platforms. One is SPL which is
roughly: reset, cpu_init_crit, lowlevel_init, s_init, sdram_init, _main,
board_init_f from SPL, ... then U-Boot loads. The other is a
memory-mapped XIP case (NOR or QSPI) where we do not run an SPL. In
this case we go, roughly: reset, cpu_init_crit, lowlevel_init, s_init,
_main, regular board_init_f.
In the first case s_init will set a valid gd and then be able to call
sdram_init which in many cases will need i2c (which needs a valid gd for
gd->cur_i2c_bus). In this second case we must (and are able to and
should) defer sdram_init() into dram_init() called by board_init_f as gd
will have been set in _main and cleared in board_init_f.
The patch populates the slave data which will be used by flash driver to
set the flash quad enable bit.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
The ePOS EVM and EVM SK have QSPI as an option to boot. Add a qspiboot
target that utilizes QSPI for env and so forth as an example of best
practices. As QSPI is booted from directly we need to chang
CONFIG_SYS_TEXT_BASE.
Note that on ePOS EVM the QSPI and NAND are mutually exclusive choices
we need to handle that elsewhere, once NAND support is also added.
updates documentation with explanation on how to select ECC schemes.
Signed-off-by: Pekon Gupta <pekon@ti.com>
This patch add support for BCH16_ECC to omap_gpmc driver.
*need to BCH16 ECC scheme*
With newer SLC Flash technologies and MLC NAND, and large densities, pagesizes
Flash devices have become more suspectible to bit-flips. Thus stronger
ECC schemes are required for protecting the data.
But stronger ECC schemes have come with larger-sized ECC syndromes which require
more space in OOB/Spare. This puts constrains like;
(a) BCH16_ECC can correct 16 bit-flips per 512Bytes of data.
(b) BCH16_ECC generates 26-bytes of ECC syndrome / 512B.
Due to (b) this scheme can only be used with NAND devices which have enough
OOB to satisfy following equation:
OOBsize per page >= 26 * (page-size / 512)
GPMC can support simultaneous processing of 8 512Byte data chunks, in parallel
GPMC_NAND_ECC_LP_x16_LAYOUT
OMAP3 used GPMC_NAND_ECC_LP_x8_LAYOUT and GPMC_NAND_ECC_LP_x16_LAYOUT macros
to configure GPMC controller for x7 or x8 bit device connected to its interface.
Now this information is encoded in CONFIG_SYS_NAND_DEVICE_WIDTH macro, so above
macros can be completely removed.
bus-width
GPMC controller needs to be configured based on bus-width of the NAND device
connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI
parameters is not possible in following situations:
SPL: SPL NAND drivers does not support ONFI parameter reading.
U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init()
which is called before probing for devices, hence any ONFI parameter
information is not available during GPMC initialization.
Thus, OMAP NAND driver expected board developers to explicitely write GPMC
configurations specific to NAND device attached on board in board files itself.
But this was troublesome for board manufacturers as they need to dive into
lengthy platform & SoC documents to find details of GPMC registers and
appropriate configurations to get NAND device working.
This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config
hich indicates that connected NAND device has x16 bus-width. And then based on
this config GPMC driver itself initializes itself based on NAND bus-width. This
keeps board developers free from knowing GPMC controller specific internals.
As per following Sections in ONFI Spec, GET_FEATURES and SET_FEATURES also need
byte-addressing on 16-bit devices.
*Section: Target Initialization"
"The Read ID and Read Parameter Page commands only use the lower 8-bits of the
data bus. The host shall not issue commands that use a word data width on x16
devices until the host determines the device supports a 16-bit data bus width
in the parameter page."
*Section: Bus Width Requirements*
"When the host supports a 16-bit bus width, only data is transferred at the
16-bit width. All address and command line transfers shall use only the lower
8-bits of the data bus. During command transfers, the host may place any value
on the upper 8-bits of the data bus. During address transfers, the host shall
set the upper 8-bits of the data bus to 00h."
So porting following commit from linux kernel
commit e34fcb07a6d57411de6e15a47724fbe92c5caa42
Author: David Mosberger <davidm@egauge.net> (preserving authorship)
mtd: nand: fix GET/SET_FEATURES address on 16-bit devices
As per following Sections in ONFI Spec, NAND_CMD_READID should use only
lower 8-bit for transfering command, address and data even on x16 NAND device.
Thus porting following commit from linux-kernel to ensure that column address
is not altered to align to x16 bus when issuing NAND_CMD_READID command.
commit 3dad2344e92c6e1aeae42df1c4824f307c51bcc7
mtd: nand: force NAND_CMD_READID onto 8-bit bus
Author: Brian Norris <computersforpeace@gmail.com> (preserving authorship)
The NAND command helpers tend to automatically shift the column address
for x16 bus devices, since most commands expect a word address, not a
byte address. The Read ID command, however, expects an 8-bit address
(i.e., 0x00, 0x20, or 0x40 should not be translated to 0x00, 0x10, or
0x20).
This fixes the column address for a few drivers which imitate the
nand_base defaults.
Porting below commit from linux-tree, preserving original authorship & commit log
commit bd9c6e99b58255b9de1982711ac9487c9a2f18be
mtd: nand: don't use read_buf for 8-bit ONFI transfers
Use a repeated read_byte() instead of read_buf(), since for x16 buswidth
devices, we need to avoid the upper I/O[16:9] bits. See the following
commit for reference:
commit 05f7835975dad6b3b517f9e23415985e648fb875 (from linux-tree)
Author: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Date: Thu Dec 5 22:22:04 2013 +0100
mtd: nand: don't use {read,write}_buf for 8-bit transfers
Now, I think that all barriers to probing ONFI on x16 devices are
removed, so remove the check from nand_flash_detect_onfi().
This patch
omap-elm.c: replaces -ve integer value returned during errorneous condition,
with proper error-codes.
omap-gpmc.c: updates omap-gpmc driver to pass error-codes returned from
omap-elm driver to upper layers
This patch tries to avoid some local pointer dereferences, by using common
local variables in omap_correct_data_bch()
This patch renames 'struct nand_bch_priv' which currently holds private data only
for BCH ECC schemes, into 'struct omap_nand_info' so that same can be used for
all ECC schemes
This patch prepares to refactor 'struct nand_bch_priv' -> 'struct omap_nand_info'
And thus performs following clean-ups:
- remove nand_bch_priv.type: use nand_bch_priv.ecc_scheme instead
- remove nand_bch_priv.mode: <unused>
This patch adds macros for following parameters of ELM Hardware engine
- ELM_MAX_CHANNELS: ELM can process 8 data streams simultaneously
- ELM_MAX_ERRORS: ELM can detect upto 16 ECC error when using BCH16 scheme
between BCH4/BCH8/BCH16
ELM hardware engine support ECC error detection for multiple ECC strengths like
|Type | ECC syndrome length |
|BCH4 | 6.5 bytes = 13 nibbles |
|BCH8 | 13 byte = 26 nibbles |
|BCH16 | 26 bytes = 52 nibbles |
Current implementation of omap_elm driver uses ECC syndrom length (in 'nibbles')
to differentiate between BCH4/BCH8/BCH16. This patch replaces it with 'bch_type'
There is no dependency of omap_elm.c on omap_gpmc.h
For each of Jetson TK1, Venice2, and Beaver:
- Enable the first USB controller in DT, and describe its configuration.
- Enable USB device/gadget support. This allows the user to type e.g.
"ums 0 mmc 0" at the command-line to cause U-Boot to act a USB device
implementing the USB Mass Storage protocol, and expose MMC device 0
that way.
This allows a host PC to mount the Tegra device's MMC, partition it, and
install a filesystem on it.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Setting ps_hold ought to be one of the first things we do when we
first boot up. If we wait until the main u-boot runs we won't set it
in time and the PMIC may power us back off.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
Add CONFIG_SYS_GENERIC_BOARD for all Exynos4 boards.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Add the ability to display the code offset of an initcall even after it
is relocated. This makes it much easier to relate initcalls back to the
U-Boot System.map file.
The backlight uses FETs on the TPS65090. Enable this so that the display
is visible.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Enable LCD for snow. This is a 1366 x 768 panel.
