This got dropped by a global 'make savedefconfig' resync as required patches
are still in flight.
Use CONFIG_DM_VIDEO=y by default for Colibri iMX6ULL.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Provide proper display timings for lcdif node, used by mxsfb DM_VIDEO
enabled framebuffer driver.
1. This fixes linking issues when building with DM_VIDEO enabled mxsfb
driver.
2. Provide proper defines for both VIDEO=y and DM_VIDEO=y.
Enable DM_VIDEO support for Colibri iMX7 NAND version.
Fix lcdif DT node and make it conform to the structure defined in the
Linux devicetree bindings [1]. Currently there is support only for
old style lcdif node definitions.
[1] https://www.kernel.org/doc/Documentation/devicetree/bindings/display/mxsfb.txt
Add support for display and bits-per-pixel properties.
We never really added a sensible DFU configuration for platforms
based on eMMC. Most of the things one might want to do can also be done
with UMS or fastboot, so drop the DFU configuration.
Enable DM_VIDEO for Colibri VF.
Add dumb node for NXP Display Control Unit0(DCU), which permits DM_ENABLED
converted driver to be probed. Currently no display timings are provided
in this node.
Extend the driver to build with DM_VIDEO enabled. DTS files
must additionally include 'u-boot,dm-pre-reloc' property in
soc and child nodes to enable driver binding to fsl_dcu_fb device.
Currently display timings aren't obtained from DT.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
cpu_imx_get_temp() definition is wrapped with a ifdef macro, which leads
to warnings if CONFIG_IMX_SCU_THERMAL isn't defined and there are still
references to this function, as, for example, in cpu_imx_get_desc().
Drop ifdef as linker will automatically remove the function
in case CONFIG_IMX_SCU_THERMAL is not enabled.
Fix warning:
arch/arm/mach-imx/imx8/cpu.c: In function ‘cpu_imx_get_desc’:
arch/arm/mach-imx/imx8/cpu.c:612:40: warning: implicit declaration of
function ‘cpu_imx_get_temp’; did you mean ‘cpu_imx_get_desc’?
[-Wimplicit-function-declaration]
ret = snprintf(buf, size, " at %dC", cpu_imx_get_temp());
cpu_imx_get_desc
cpu_imx_get_desc
Fixes: 82467cb217 ("imx8: cpu: get temperature when print cpu desc")
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM MEK board.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
(cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
Adding the HDP firmware loading to the build.
(cherry picked from downstream commit d4702582552aa1921fce58329ae40c24481fba3a)
This adds a command to load the HDP firmware and supporting libraries.
(cherry picked from downstream commit 94c9c7022c5b6cffb74bb2e34336cffc2790d0d8)
(cherry picked from downstream commit 21edff320e763585ebc6ab2d997c994561b69292)
Use streamids specified in dtb because they need to match anyway. This
removes the need to rebuild uboot for stream id assignments.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from downstream commit 3caa05e6dc973b8710642f27f834bf022fbb65b4)
Before starting the kernel, need to check if the enabled nodes (resources) in FDT
are owned by current partition. If it is not owned, need to disable it because A core
can't access it.
We use the node's power-domain property to get the PD node which has the SCFW resource
id in its reg property. Then we can check it with SCFW.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from downstream commit 358372674b29685788a4007b0944ab03b7fafc13)
We setup SMMU in arch_preboot_os to avoid breaking u-boot driver.
Add a kconfig entry CONFIG_IMX_SMMU to enable it.
So far, the USDHC0-USDHC1 and FEC0-FEC1 are added into sid.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from downstream commit 7da6345919ee59a26cf65b4bc29072eea2fc0909)
(cherry picked from downstream commit 45308e7da90f342c2de7fbec1f8c5b8bd3f1b8e5)
Add sc_rm_set_master_sid to support setting stream IDs.
Add thermal dts node
Enable thermal in defconfig
Add i.MX8 thermal driver to support get temperature from SCU.
Add sc_misc_get_temp to support get temperature
https://gitlab.denx.de/u-boot/custodians/u-boot-mips
- mtmips: network stability fixes for gardena-smart-gateway
The watchdog of mediatek chips is enabled by bootrom before u-boot is
running. Previously we choose to enable the wdt driver only to disable the
watchdog hardware.
Now wdt service is enabled by default. The function arch_misc_init which is
only used to disable wdt is no longer needed.
Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
The initr_watchdog is currently placed before initr_serial. The
initr_watchdog calls printf and printf finally calls ops->putc of a serial
driver.
However, gd->cur_serial_dev points to a udevice allocated in board_f. The
gd->cur_serial_dev->driver->ops->putc points the the code region before
relocation.
Some serial drivers call WATCHDOG_RESET() in ops->putc. When DM is enabled
for watchdog, watchdog_reset() is called. watchdog_reset() calls get_timer
to get current timer.
On some platforms the timer driver is also a DM driver. initr_watchdog is
placed right after initr_dm, which means the timer driver hasn't been
initialized. So dm_timer_init() is called. To create a new udevice, calloc
is called.
However start from ops->putc, u-boot execution flow is redirected into the
memory region before relocation (board_f). In board_f, dlmalloc hasn't
been initialized. The call to calloc will fail, and this will cause DM to
print out an error message, and it will call printf again, causing
recursive error outputs.
This patch places initr_watchdog after initr_serial to solve this issue.
Cc: Stefan Roese <sr@denx.de>
Tested-by: Frank Wunderlich <frank-w@public-files.de>
Tested-by: Suniel Mahesh <sunil.m@techveda.org>
Fix booting for wandboard
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix pwm backlight
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a
boot device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- DWC and i.MX6 fixes
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is
not implemented, leaving the backlight dark. Fix this by returning
no error if set_invert() is not implemented and no polarity change
is requested.
Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell")
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
- fix complation error for CONFIG_USB
- update RPi3 DTBs to v5.1-rc6 state
- add defconfig for RPi3 B+
- Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
With commit 06985289d452 ("watchdog: Implement generic watchdog_reset()
version") the init sequence has changed in arch_misc_init(), resulting
in a re-appearance of the d-cache issue on MT7688 boards (e.g. gardena).
When this happens, the first (or sometimes later ones as well) TFTP
command hangs and does not complete correctly. This leads to the
assumption that the d-cache is not in a clean state once the ethernet
driver is called (d-cache is used here for the buffers). The old work-
around with the cache flush somehow does not work any more now with
the new code change.
Unfortunately adding CONFIG_SYS_MALLOC_CLEAR_ON_INIT also did not fix
this issue. With v2019.07-rc3 it shows again. The time of accessing
the data seems to be very important here. It needs to be "very late"
in the boot process.
Testing has shown, that copying a 64KiB area in DDR at a very late
bootup time, directly before calling into the prompt, fixes this issue.
Flushing of the complete d-cache does not seem to necessary, as this
copy alone seems to fix this problem.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
dwc3-generic has been broken since MISC uclass has been modified to scan DT
sub-nodes after bind.
Fixing it by a using the no-op uclass.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This uclass is intended for devices that do not need any features from the
uclass, including binding children.
This will typically be used by devices that are used to bind child devices
but do not use dm_scan_fdt_dev() to do it. That is for example the case of
several USB wrappers that have 2 child devices (1 for device and 1 for
host) but bind only one at a any given time.
There is simply no reason to do that here.
The EHCI iMX6 driver is only partly converted to DT probing and
still uses a tremendous amount of hard-coded addresses. Worse,
the driver uses hard-coded SoC-model-specific base addresses, which
are derived from values protected by SoC-specific macros, hence the
driver is also compiled for a specific SoC model. Even worse, the
driver depends on specific sequential indexing of the controllers,
from which it derives offsets in the PHY and ANATOP register sets.
However, when the driver is probed from DT, the indexing is not
correct. In fact, each controller has index 0. This patch derives
the index for DT probing case from the controller base addresses,
which is not the way this should be done, however it is the least
intrusive approach, favorable this close to release.
The necessary steps to convert this driver fully to DT probing are
described inside the patch, however this should be done in the next
release and depends on iMX clock driver patches.
Cc: Abel Vesa <abel.vesa@nxp.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Ludwig Zenz <lzenz@dh-electronics.com>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Commit b238e4b00ced ("rockchip: Cleanup of make_fit_atf.py.") set
firmware = "atf_1";
loadables = "uboot","atf_1","atf_2";
Actually it should be:
firmware = "atf_1";
loadables = "uboot","atf_2","atf_3";
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add missing mailing-list to the amlogic boards MAINTAINERS file.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- Wandboard
After the conversion to DM the U-Boot proper binary name
is 'u-boot-dtb.img', so adjust it accordingly.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
After the transition to DM, only the mx6dl/solo wandboard
is supported.
Add FIT image support so that all the wandboard variants
can be supported, like it was prior to the DM conversion.
Successfully booted Linux on mx6q/solo/qp wandboards.
Add a mmc0 alias so that U-Boot proper can associate mmc0
with the boot SD card.
Import wandboard devicetree files so that the mx6q and mx6qp
variants can be properly supported.
