Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
Removed initialization of the driver from net/eth.c
Affected boards:
mpc7448hpc2
Affected boards:
hidden_dragon
MPC8544DS
MPC8610HPCN
R2DPLUS
TB0229
Affected boards:
linkstation
r7780mp
Removed at91sam9_eth_initialize() from net/eth.c
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
The 8544DS and 8572DS platforms support an optional SGMII riser card to
expose ethernet over an SGMII interface. Once the card is in, it is also
necessary to configure the board such that it uses the card, rather than
the on-board ethernet ports. This can either be done by flipping dip switches
on the motherboard, or by modifying registers in the pixis. Either way
requires a reboot.
This adds a command to allow users to choose which ports are routed through
the SGMII card, and which through the onboard ports. It also allows users
to revert to the current switch settings.
This code does not work on the 8572, as the PIXIS is different.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The 8544 DS has an optional SGMII Riser card, which uses different PHY
addresses. Check if we are in SGMII mode, and invoke the SGMII Riser
setup code if so.
The 8544DS and 8572DS systems have an optional SGMII riser card which
exposes new ethernet ports which are connected to the eTSECs via an
SGMII interface. The SGMII PHYs for this board are offset from the standard
PHY addresses, so this code modifies the passed in tsec_info structure to
use the SGMII PHYs on the card, instead.
Adds support for configuring the TBI to talk properly with the SerDes.
The tsec driver contains a hard-coded array of configuration information
for the tsec ethernet controllers. We create a default function that works
for most tsecs, and allow that to be overridden by board code. It creates
an array of tsec_info structures, which are then parsed by the corresponding
driver instance to determine configuration. Also, add regs, miiregs, and
devname fields to the tsec_info structure, so that we don't need the kludgy
"index" parameter.
This is to prepare the way for board code passing in the tsec_info structure
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This boards used old type preprocessor.
This patch fix compile error.
AP325RXA is SH7723's reference board.
This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other.
In this patch, support SCIF, NOR Flash, and Ethernet.
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other.
This patch supports CPU register's header file and SCIF serial driver.
This adds initial support for the RTE RSK+ SH7203 board.
Add support SH2/SH2A basic function.
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash,
Graphic, Ethernet, USB, SD, RTC, and I2C controller.
This patch supports the following functions:
- 128MB DDR2-SDRAM (29-bit address mode only)
- NOR Flash
- USB host
- Ethernet
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Renesas SH7785 has DDR2-SDRAM controller, PCI, and other.
This patch supports CPU register's header file.
Double bootargs setting leads to a duplicated environmant entry.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl
driver for it too. The board can also boot from the NOR flash, but due to
hardware limitations it can only address 64KiB on it, which is not enough
for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
Based on the original S3C64XX NAND driver by Samsung for U-Boot 1.1.6.
As noted by Harald Welte, HWFLOW support in the S3C64XX serial driver is
broken and currently unused. Remove it.
Based on the original S3C64XX UART driver by Samsung for U-Boot 1.1.6.
Notice: USB on S3C6400 currently works _only_ with switched off MMU. One could
try to enable the MMU, but map addresses 1-to-1, and disable data cache, then
it should work too and we could still profit from instruction cache.
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6.
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
- memsetup.s is changed/merged to lowlevel_init.S
memsetup.S has a global label memsetup that just returns back to caller
- memsetup global label is changed/merged to lowlevel_init
This label is not called from anywhere.
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
ARM DaVinci: Standardize names of directories/files.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
ARM DaVinci: Move common functions to board/davinci/common.
This function is needed for the new NAND infrastructure. We only need
a dummy implementation though for the NDFC.
This is needed since now with HUSH enabled (amcc-common.h) the image
read from NAND exceeds the previous limit.
